hi all. need help with audi Q5 2012 dash warning light reading 90 miles left till non start have topped up level driving usually resets light. any help will be appreciated with any basic settings or adaptions needed to reset
Sunday,27,November,2016,13:06:04:11898
VCDS Version: 16.8.3.1 (x64)
Dealer/Shop Name: Sterling Garage Ltd
VIN: WAUZZZ8R0CA029787 License Plate: NJ61LVG
Mileage: 109420km-67990mi Repair Order:
Chassis Type: 8R (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 56 62 72 77
VIN: WAUZZZ8R0CA029787 Mileage: 109420km-67990miles
Address 01: Engine (J623-CGLB) Labels: 03L-906-018-CGL.clb
Part No SW: 03L 906 018 MQ HW: 03L 906 018 DN
Component: R4 2,0L EDC H25 2844
Revision: 45H25---
Coding: 2A254012040702080000
Shop #: WSC 00378 210 91429
ASAM Dataset: EV_ECM20TDI01103L906018MQ 003010
ROD: EV_ECM20TDI01103L906018MQ.rod
VCID: 050BA369840F5C6A8F-8050
2937 - Please Check Fault Codes in Transmission Control Module
U1026 00 [032] - -
5120 - Oxygen (Lambda) Sensor B1 S1
P2196 00 [096] - Signal too High (Rich)
9567 - NOx Sensor 2 Bank 1
P229F 00 [237] - Implausible Signal
Mileage: 106587 km
Date: 2016.09.23
Time: 20:42:09
Engine speed: 1483.50 /min
Vehicle speed: 59 km/h
Coolant temperature: 89 °C
Intake air temperature: 17 °C
Voltage terminal 30: 14.360 V
Air mass: actual value (mg/stroke): 595.4 mg/stroke
Mean injection quantity: 0.00 mg/stroke
EGR Vacuum Regulator Solenoid Valve: activation: 100.00 %
15733 - ROD - Unknown Error Code
- 00 [237]
Mileage: 108527 km
Date: 2016.10.31
Time: 20:01:59
Engine speed: 1715.50 /min
Normed load value: 17.3 %
Vehicle speed: 90 km/h
Coolant temperature: 91 °C
Intake air temperature: 15 °C
Voltage terminal 30: 14.340 V
Long-term adaptation of reduction agent dosage: 1.00
Measured NOx conversion: -0.500
Calculated efficiency of NOx conversion: 0.976
Efficiency threshold of NOx conversion: 0.392
Current temperature in NOx reducing catalytic converter: 305.6 °C
Readiness: 1 2 0 0 0
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8R0 927 156 T HW: 0B5 927 156 F
Component: 0B5 20 TDIRdW H10 0007
Revision: --H10--- Serial number: 0000000531
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 4C9D564DE7E56D2210-8018
9473 - Sensor for Gear Actuator 2
P17E1 00 [096] - Mechanical Malfunction
Address 03: ABS Brakes (J104) Labels: 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 G HW: 8R0 907 379 G
Component: ESP8 quattro H07 0070
Coding: 0D1540
Shop #: WSC 06334 000 00000
VCID: 448D7E6DC7B5A562D8-8010
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CP HW: 8K0 907 064 CP
Component: BCM2 2.0 H05 0435
Coding: 011500
VCID: 0005B27D932D7942BC-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0811000122327020
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 2311000163614005
Part No SW: 8T2 820 043 AD HW: 8T2 820 043 AD
Component: KLIMA 1 ZONE H08 0182
Revision: B0000000 Serial number: 01160820111088
Coding: 34050000
Shop #: WSC 50945 002 1048576
VCID: 74EDEEADD79555E2A8-8020
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 K HW: 8K0 907 063 K
Component: BCM1 1.0 H30 0392
Revision: 06030001 Serial number: 00000001013268
Coding: 690040B10034A7010001000000005F5F001D460802000101000000
VCID: 377719A18663FEFA4D-8062
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 110729 H11 0050
Serial number: 90243015110708201649
Coding: 01DD13
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11610194
Coding: 024D25
Component: E1 - LDS H03 0031
Serial number: 00000000000908110577
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 T HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0081
Revision: 11001001 Serial number: 36861123000170
Coding: 000105
VCID: 4A915055E591731222-801E
Address 15: Airbags (J234) Labels: 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Component: AirbagVW-AU10 H44 0610
Serial number: 003JPD0ACYD0
Coding: 30473331313030303030554A305238523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 48956A5DF39D810234-801C
Serial number: 6334MSME62545A7DP
Serial number: 6344MSME6252640A9
Serial number: 6352QSME1D5B355EY
Serial number: 6362QSME2F5B2F54.
Serial number: 63732SME175D06783
Serial number: 63832SME775A404A4
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KH90000N
Coding: 000013
VCID: 3D7B0B89A45FD4AA97-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 981 H HW: 8R0 920 981 H
Component: KOMBIINSTR. H31 0402
Revision: 00000000 Serial number: KIK44298C
Coding: 2F06220002002600010000
VCID: 3F877181AE53C6BA85-806A
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G118028627
Coding: 00C303
VCID: 0103B7799827704AB3-8054
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790110871
Reset counter: 55
Mileage: 109409 km
Date: 2016.11.26
Time: 05:09:00
Bin. Bits: 00000
Voltage: 12.20 V
Count: 17
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 N HW: 8K0 959 793 N
Component: TSG FA H12 0357
Revision: Serial number: 0000011684749
Coding: 011002204001440004
VCID: 4B9F5551EAEB6A1A19-801E
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0156043201
Coding: 013B062220B900008420053280000000
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8R0 035 223 G HW: 8R0 035 223 E
Component: DSP STD H11 0460
Revision: 00000000 Serial number: 00000000000001
Coding: 0203010102
VCID: 306522BD630D29C20C-8064
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 N HW: 8K0 959 792 N
Component: TSG BF H12 0357
Revision: Serial number: 0000011372551
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 20000000079407
VCID: 346D2EAD971515E268-8060
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 P HW: 8T2 035 186 P
Component: Concert3 H06 0350
Revision: 00000011 Serial number: AUZ5Z6K1631001
Coding: 0502008201058D00015B070000
VCID: 458B6369CC8F9C6ACF-8010
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
Component: TSG HL H11 0357
Revision: Serial number: 0000011607677
Coding: 010002204001240004
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0000011607678
Part No SW: 8T0 862 335 F HW: 8T0 862 335 E
Component: FSE_256x BT H45 0660
Revision: 00000000 Serial number: 00000005419356
Coding: 0010320
VCID: 3D7B0B89645FD4AA97-8068
End-------------------------(Elapsed Time: 03:12)--------------------------
