We have a 2012 A8L in the shop that the owner "tried" lowering by himself with help from friend with a "scanner". Control unit is not coded along with other issues. Could someone help me with coding this module? I am hoping that he did not "reset all adaptations". Could not get a clear answer on this.
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4H0 907 553 E HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0099
Coding: 008000
Shop #: WSC 12345 123 12345
ROD: EV_AirSuspe_AU64.rod
VCID: 2E59177C71E7C13200-807A
367877 - Ride Height Not Learned
C1044 00 [009] - - Confirmed - Tested Since Memory Clear
266752 - Control module not coded
U1013 00 [009] - - Confirmed - Tested Since Memory Clear
267266 - Control Module Incorrectly Coded
U1014 00 [009] - - Confirmed - Tested Since Memory Clear
38144 - No End-of-Line Programming
B2013 00 [009] - - Confirmed - Tested Since Memory Clear
Long time user of VCDS, however this is my first post to forum. I am unsure how to attach entire quick test, instruction would be appreciated. Thanks.
Coding: 008000
