2012 A8 4H 34 level control coding
   #21
Autohaus Frankfurt
C?ID=30574
Ah.. okay, try the procedure again .. this time "Measure the ride height, in millimeters, from the center of the wheel to the edge of fender, do this for all four wheels and record the values." as described in the procedure... The given values are for reference only, so do not enter these values.
Last post of the evening, so I hope this works, have a good night and a great thanksgiving to all :)
drpeter
I did try it that way as well as several other numbers with the same result. Even with the correct coding I still get the "no/incorrect coding error as well as the "no end of line programming' fault. I am going to put this one aside for now to get on to other work, I will report back with any new information. Thanks again for everybody's help.
   #22
Time for a module if you maybe can't brute force the sensors into a static position on lift disconnected from suspension & to force a parameter tolerance.
   #23
Dana
Western PA, USA
We had a similar inquiry today. The shop we worked with got a 2013 A8L from another shop with unknown original fault codes and all we know is a few level sensors were replaced. They are digging to see if a scan was saved in the original condition and if any additional parts were replaced.
I won't post the entire scan for privacy reasons. This was the 34 condition when we received the scan from shop #2:
> Address 34: Level Control (J197)       Labels: 4G0-907-553.clb
>    Part No SW: 4H0 907 553 E    HW: 4H0 907 553
>    Component: LUFE-DAEMPFER H17 0099
>    Coding: 008000
>    Shop #: WSC 12345 123 12345
>    ASAM Dataset: EV_AirSuspe 003024
>    ROD: EV_AirSuspe_AU64.rod
>    VCID: 2E593D0D710AF93202-807A
> 3 Faults Found:
> 367877 - Ride Height Not Learned
>           C1044 00 [009] -  -
>           Confirmed - Tested Since Memory Clear
>              Freeze Frame:
>                     Fault Status: 00000001
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 6
>                     Mileage: 88980 km
>                     Date: 2016.11.29
>                     Time: 15:24:53
> 266752 - Control module not coded
>           U1013 00 [009] - -
>              Freeze Frame:
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 6
>                     Mileage: 88980 km
>                     Date: 2016.11.29
>                     Time: 15:24:53
> 38144 - No End-of-Line Programming
>           B2013 00 [009] -  -
>              Freeze Frame:
>                     Fault Priority: 2
>                     Fault Frequency: 1
>                     Reset counter: 6
>                     Mileage: 88980 km
>                     Date: 2016.11.29
>                     Time: 15:24:53
The coding was all zeros so 008000 -and- Shop #: WSC 12345 123 12345 were performed with VCDS. Even though that coding was correct, the module still refuses to clear U1013 00 - Control module not coded - Confirmed. I even had him enable Trailer installed (incorrect) coding with a 444 Importer code which caused function restriction issues but that didn't help the U1013 cause.
He could only get through the first few steps:
Using the MMI (under [Car]) the following needs to be set-
- Automatic Drive Program = [auto] or Audi Drive Select (under Car menu)
Select - [34-Level Control]
Login or Security Access - [20103]
[Basic Settings - 04]
- Choose - [Delete calibration for level control] - Press [Go!]
- Wait for basic Settings to End (Finished Correctly), then press [Stop]
- Choose - [Start up to reference level] - Press [Go!]
.. Start up to reference level resulted in an error with C10C8 - Function Shut-Off Active.
I suspect a leak or faulty compressor - but No End-of-Line Programming might be the cause instead. Battery Jesus, inflating, deflating the suspension in addition everything else he attempted before calling wasn't successful.
Even though we did not succeed and the vehicle is probably headed to the dealer we did determine "Air Spring Wheel Change", including similar service/Jack mode, MMI options were not available. Searching Advanced Measuring Values for "Jack" resulted in on/activated feedback from various groups. He was able to put the shifter into Reverse, back into Park and the jack mode deactivated per Advanced Measuring Values.
If I have anything else to add I'll post here but I wanted to comment on Jack Mode at the least. I think these cars would automatically come out of that mode when VSS is present - however I didn't have him move the car after a simple slip to Reverse and Park made the values change.
Internal ref to: ST?ID=72167
   #24
Dana
Did you have the OP or the other customer above aforementioned, remove the sensors from the control arms, and than relax the sensors manually at full stop, then do calibrations by manually manipulating the sensors to desired positions?
If the sensors are not seeing the bottom out or full sweep point anticipated ........I have seen stuff like this happen.
   #25
Dana
Western PA, USA
I did not Jack. Since shop #1 in the above example replaced sensors - I certainly should. We're nearing closing time but I'll try to give him a ring in the AM or drop an e-mail. Thanks!
   #26
No problem ..........You will note I will keep saying this in regards to suspension electronics or air rides, because sometimes modules act weird unless things are not a specific criteria.
A recode after bottom out and terminal 15 wake + hot boot maybe in order.
HOT BOOT
Plugging a control unit in after being recoded and leaving key in ON position.
Then shutting key off and waiting 30 seconds for new baseline.
fordy51
C?ID=171923
End of line programming? Anyway to solve?
   #28
Oliver C
Canada
C?ID=205891
I know this is kind of old thread but I accidentally hit CLEAR ALL ADAPTATIONS,is there any way to undo this or do I have to go to the dealer?When I try recalibration of the height I gives me that error when calibrate level in basic settings is activated.Up to that point everything seems to work
   #29
Oliver C
Canada
C?ID=205891
Trying to reach drPeter for my problem with air suspension on 2011 A8.
   #30
Part No SW: 4H0 907 553 C HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0096
Coding: 008004
Shop #: WSC 02311 785 00200
VCID: 2C57044847E5A45EF2-8078
455691 - Sensor for Ride-Height
C1048 07 [008] - Mechanical Failure
Reset counter: 143
Mileage: 77369 km
Date: 2016.03.02
Time: 08:20:06
http://forums.ross-tech.com/showthread.php?5537-2011-Audi-A8-Air-suspension-code&p=53771#post53771
You can't complete an adaption while the same faults are still in error & over a year later!
Coding: 008004
ROD: EV_AirSuspe_VW51.rod
VCID: 2C57044847E5A42780-80784 Faults Found:
455692 - Sensor for Ride-Height
Reset counter: 40
Mileage: 94920 km
Date: 2017.05.19
Time: 22:03:51
C1044 00 [009] - -
Reset counter: 111
Mileage: 94918 km
Date: 2017.05.19
Time: 21:40:31
U1013 00 [009] - -
Reset counter: 111
Mileage: 94918 km
Date: 2017.05.19
Time: 21:40:31
B2013 00 [009] - -
Reset counter: 111
Mileage: 94918 km
Date: 2017.05.19
Time: 21:40:31
RTFB your last thread and stop trying to circumvent a JPPSG process.
   #31
Oliver C
Canada
C?ID=205891
I didn't want to offend anyone and not trying to start pissing contest.Yes I know year ago I asked for a help with height sensor which I couldn't figure out which one was causing my air ride to screw up,but for 4 months last summer it never set the code and I just didn't have time to deal with it.In winter time started doing again same thing,first once a week then once a day and that's the reason I changed RF height sensor (looked more loose then the rest).After that I wanted to calibrate height of the car but like I said I "Cleared all adaptations " and now it won't accept coding or calibration.I didn't even know that code for sensor was back because that code wasn't there when I was trying to do that calibration (must've set on the way back home ) and when I sent you auto scan I never looked into it to see if there was new codes so obviously the sensor I replaced wasn't the problem.
I'm not an expert in running VCDS on 4H series of A8 as this is the first one that I ever even scanned so I know I screwed up with clearing all adaptations but I was simply asking if you can help me code it and calibrate it without going to the dealer.And I would pay for that help as well.
I live in Saskatchewan,Canada and there is probably 4 vehicles like this in 10 000 square miles so not to many "experts" to ask for advice.
Once again sorry if I offended anyone.
   #32
Oliver Twist...........no one is offended. :rolleyes:
It's just simple.............. adaptations can't take place in this module when a fault is present..............
Fix/replace the sensor then recode and start over.
Don't clear values in modules, unless you know what it is you are doing or at the very least make a backup of all the data.
FYI: I saw no reason to take your offered money in an email, not for this....... but if people contact me there they are expected to follow the rules & to the letter.
I just had to search your posts and saw your old scan ........that is why we JPPSG!
Even I have violated my own rules and it bites me in the ass most times when I do.
Don't take short cuts and don't do things half ass........ even the process..........understood?
It's grille time in T-30 minutes.........
:p
NostraJackAss Has Spoken!
   #33
Oliver C
Canada
C?ID=205891
I tried to change wsc to original and to recode and do adaptation cause when i clear codes that one 455692 is not coming back but again same outcome with sequence request error when I try to calibrate level control.I know you said to fix that sensor first but just thought i should try it aagain as that code is not there.Here is fresh auto-scan after clearing all codes and trying to recode and recalibrate
Chassis Type: FD (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 15 16 17 19 1B 28 34 36 3B 42 46
          47 52 53 56 5F 62 6C 6D 6F 72 7F 81 84 88 89 8F 90
VIN: WAUCVAFD9BN017414   Mileage: 94924km-58983miles
7F-Inform. Electr. II -- Status: OK 0000
Address 01: Engine (------CDRA)       Labels: None
   Part No SW: 4H0 907 560 C    HW: 4H0 907 560
   Component: 4.2l V8/4V    H07 0005
   Revision: N5H07---
   Coding: 0106000A290F0168
   Shop #: WSC 15398 002 1048576
   ASAM Dataset: EV_ECM42FSI0114H0907560C 001006
   ROD: EV_ECM42FSI0114H0907560C.rod
   VCID: 2A5B02504D11BA1772-807E
Readiness: 1110 1101
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 4H1 927 158 AD    HW: 0BK 927 156 K
   Component: 0BK 42 FSIUSA H08 1006
   Revision: --H08---
   Coding: 000002
   Shop #: WSC 93204 999 100796
   ROD: EV_TCMALX51011.rod
   VCID: 72EBDA30A541B2D70A-8026
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 B    HW: 4H0 907 379 B
   Component: ESP PREMIUM   H10 0273
   Coding: 44F6B200226F4D00E200
   ASAM Dataset: EV_ESPPremi 005006
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 3169153C60C7C9CFB3-8064
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 AD
   Component: BCM2 2.0      H24 0510
   Coding: 0D872000000000000000
   Shop #: WSC 93204 999 15538
   VCID: 6ED3CE40B9799637EE-803A
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2310000094535002
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00001002298952
   Coding: C018320085043201010001010101112131313333283333
   Shop #: WSC 02313 785 00200
   VCID: 3561212C9CAFE5EFEF-8060
Address 08: Auto HVAC (J255)       Labels: 4H0-820-043.clb
   Part No SW: 4H0 820 043 E    HW: 4H0 820 043 E
   Component: Klima 4 Zonen H14 0061
   Coding: 488120B888
   ROD: EV_AirCondiFront.rod
   VCID: 224BEA70352162573A-8076
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 G    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0092
   Revision: 11012002    Serial number: 00000000921982
   Coding: 09072016073C9FF19B010004A0003800009CD308820001218001085C3B00
   VCID: 2C5704484FE5A42780-8078
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 110120  H32 0040
   Serial number:         110121232629
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10056533
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 C    HW: 4H0 941 531 C
   Component: E1 - LDS  H07 0044
   Serial number: 20 01 2011  00000289
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R09SV06
   Subsystem 5 - Part No SW: 4H0 907 472 A    HW: 4H0 907 472 A
   Component: A31 LED Mod1L  H01 0006
   Serial number: 00000024011100010088
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 472 A    HW: 4H0 907 472 A
   Component: A27 LED Mod1R  H01 0006
   Serial number: 00000025011100010438
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Serial number: WA102032000000169242
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 11280D85000000000001
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 D    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0180
   Revision: AA001001
   Coding: 020000
   VCID: 2149E57C3827794F23-8074
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0030
   Revision: 11001001    Serial number: 55901102003862
   Coding: 300102
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_AU57XParkiAssis2.rod
   VCID: 377D2B248EA317FFFD-8062
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H41 0041
   Revision: --------    Serial number: 003JS00124FT
   Coding: 303143303230303030344A55304C34483053
   Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
   Serial number: 5850000R1111101A0H
   Serial number: 3575HRB405L096J6AGON
   Serial number: 3585HRB405H0C15I60N
   Serial number: 3515JRB405F0974OD9SH
   Serial number: 3525JRB405F0974ONP8O
   Serial number: 3554VRB405R09GGSG1C5
   Serial number: 3564VRB405R09GGSH060
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Part No SW: 4H0 953 568 B    HW: 4H0 953 568 B
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815KAS00022
   Coding: 000434
   VCID: 326B1A306DC1F2D7CA-8066
   Subsystem 1 - Part No SW: 4H0 951 528 H    HW: 4H0 951 528 H
   Component: E221 - MFL  H04 0009
   Serial number: 19 07 2010  33014157
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4H0 920 800 C    HW: 4H0 920 800 E
   Component: TBenRDW---NV- H30 0297
   Revision: 26110011    Serial number: 658140111593027
   Coding: 03A7080133000008020000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K.rod
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 H    HW: 4H0 919 204 H
   Component: Analoguhr D4  H05 0224
   Serial number: 1110127000438
   Part No SW: 4H0 907 468 E    HW: 4H0 907 468 C
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000088434
   Coding: 00C1034A00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 33651F349ADBFBDFC1-8066
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005659358544
   Part No SW: 4H0 907 144 A    HW: 4H0 907 144 A
   Component: DYNAMIKLENK.  H06 0080
   Revision: 51001005    Serial number: --------------
   Coding: 8B0000
   VCID: 2643F66051099E7756-8072
Address 28: HVAC, Rear (E265)       Labels: None
   Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
   Component: Klima Fond    H14 0062
   Coding: 0000000000
   ROD: EV_AirCondiHeck.rod
   Coding: 008004
          C1044 00 [009] -  -
                    Reset counter: 111
                    Mileage: 94924 km
                    Date: 2017.05.29
                    Time: 13:05:03
          U1013 00 [009] - -
                    Reset counter: 111
                    Mileage: 94924 km
                    Date: 2017.05.29
                    Time: 13:05:03
          B2013 00 [009] -  -
                    Reset counter: 111
                    Mileage: 94924 km
                    Date: 2017.05.29
                    Time: 13:05:03
   Revision: AA000000    Serial number: 00001002299039
   Coding: C0183B0085053201010001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 A    HW: 4H0 907 637 A
   Component: SARA 6D red   H02 0015
   Revision: --------    Serial number: EJ1BPA3700BNVQ0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D51094C7CFFAD2F97-8078
   Part No SW: 4H0 959 793 F    HW: 4H0 959 793 F
   Component: TSG FA        H07 0162
   Revision: --------    Serial number: 0000112102428
   Coding: 011F13205E00628202000002
   Shop #: WSC 02312 785 00200
   VCID: 3C773408BF8534A710-8068
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0142720441
   Coding: 0106063A00FA7585B0B0C7C0020100000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0070
   Serial number: 00000000000000018508
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.028  H06 0006
   Serial number:     WOO1122344Y
   Coding: 001F00
   Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
   Component: Dachelektroni  H11 0080
   Serial number: A2011000000000321026
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS009  H05 0004
   Serial number:     WOO1000B4XN
02616 - Fuel Tank Cap; Unlock
                    Fault Status: 00101001
                    Fault Frequency: 28
                    Reset counter: 136
                    Mileage: 89976 km
                    Date: 2017.01.02
                    Time: 13:24:02
   Part No SW: 4H0 035 465 A    HW:
   Component: BO G3 D4      H06 0150
   Revision: 04S00000    Serial number: 0012153
   VCID: 2447EC6827356C6748-8070
   Subsystem 1 - Part No SW: 4H0 035 466     HW: 4H0 035 466
   Component: BO D4 SLAVE  H51 0180
   Serial number: 00710100002337
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000112328468
   VCID: 3B753714BA8B339F19-806E
   Revision: --------    Serial number: 00000000035736
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H0 035 082 A    HW: 4H0 035 082
   Component: Radio U SIRIU H51 0068
   Revision: AB001007    Serial number: 155BR0B7500753
   Coding: 020007010003000001
   VCID: 1F4DE3840E534FBF15-804A
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
   Part No SW: 4H0 035 664 B    HW: 4H0 035 664
   Component: H-BN-NA       H48 0294
   Revision: --------    Serial number: 098BT0B7501307
   Coding: 020200000001F1EF45168F0E00000003F400010000000000
   Subsystem 1 - Part No: 8R0 060 884 AC
   Component: NAR 2011  0503
   Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
   Component: DU8 D4 SV NB  H46 0021
   Serial number: AUZ8ZDB1100BS8J
   Subsystem 3 - Part No SW: 4H1 919 600 D    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0063
   Serial number: 00000000027714
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000110764700
   Coding: 010F13204000628202000002
   VCID: 3A7B3210B5B10A9702-806E
   Part No SW: 4H0 907 441     HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0030
   Revision: --H04---    Serial number: 525 PA8J0ZD0FZ
   Coding: 1021002
   VCID: 65C1B16CAC8F556F9F-8030
Address 6D: Trunk Elect. (----)       Labels: None
   Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0036
   Revision: 10011001    Serial number: 022100180
   Coding: 0210044100
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3B753714B28B339F19-806E
Address 6F: Centr. Conv. II (J773)       Labels: None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000021984
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 63C5AF746ABB2B5F71-8036
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000110764697
Address 7F: Inform. Electr. II (J829)       Labels: None
   Part No SW: 4H0 035 774 B    HW: 4H0 035 774
   Component: H-BN-NA       H48 0295
   Revision: --------    Serial number: 108AB0B7501001
   Coding: 020200000001004001000004000013000000000000000000
   VCID: 285FF8585B1D880764-807C
   Subsystem 1 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Component: DU10 RSE  H41 0021
   Serial number: AUZ8ZDB12006ZAO
   Subsystem 2 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Serial number: AUZ8ZDA12006CD3
   Subsystem 3 - Part No SW: 4H0 919 709 C    HW: 4H0 919 709 C
   Component: E499 BDT 2  H07 0019
   Serial number: 90238KB30000V
   Subsystem 5 - Part No: 8R0 060 884 AC
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H05 0081
   Revision: 0L0D5012    Serial number: SN101216  0165
   ASAM Dataset: EV_GSM2x3Mono 001014
   ROD: EV_GSM2x3Mono.rod
   VCID: 2B55075442EBA31F89-807E
Address 84: Night Vision (J853)       Labels: 4H0-907-547.clb
   Part No SW: 4H0 907 547 E    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H09 0026
   Serial number: 0K84AE40023799
   Coding: 1100
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H07 0006
   Serial number: 00000000001101500007
Address 88: Multicont. Seat Driver (J873)       Labels: None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00456940027002
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F6D134476F3DF3FA5-807A
Address 89: Multicont. Seat Pass. (J872)       Labels: None
   Serial number: 00456774018201
   Coding: 364FF2
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 00060000031F030000030801424CD8010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FEDD344B6739F3FE5-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70EFD038AB4D80C7FC-8024
No Oliver Twist you are speculating because we don't have a valid baseline with eeprom set with no errors.
   #35
Oliver C
Canada
C?ID=205891
Had to try anyway .Got appointment with the dealer next Wednesday,hopefully they'll be gentle with me 😄
   #36
Put the sensors in yourself and check wiring for corrosion at the plug........ it's cake...........:rolleyes:
You been dicking around with this for over a year......why not just actually do something, verse expect the tool to perform magic tricks?
   #37
AvernturaA8
C?ID=405840
Hi, on my Audi A8L 2012 I get "Request Sequence Error" when entering the measured value in " [Body height left front wheel house edge]". I am now unable to complete a calibration as a result of this. Any ideas of why I would get this error.
Thanks so much for your help.
   #38
Please post an Auto-Scan for context.
AvernturaA8
C?ID=405840
Follow up of "Request Sequence Error" when entering the measured value in "[Body height left front wheel house edge]" during the calibration routine. The Suspension error codes are: "403200 - Function Shut-Off Active" and "367877 - Ride Height Not Learned". Included is the full "Auto Scan".
Log-WAURVAFD3CN015301-82273km-51122mi.txt
Not shared
Type
Text
Size
27 KB (27,488 bytes)
Storage used
My Drive
Owner
me
Modified
7:40 PM by me
Opened
7:41 PM by me
Created
7:40 PM with Google Drive Web
Add a description
Viewers can download
Tuesday,01,September,2020,19:40:13:56142
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
VIN: WAURVAFD3CN015301   License Plate:
Mileage: 82273km-51122mi   Repair Order:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 15 16 17 19 34 36 3B 42 46 47 52
          53 56 5F 62 6C 6D 6F 72 81 88 89 8F 90
VIN: WAURVAFD3CN015301   Mileage: 82273km-51122miles
Address 01: Engine (------CDRA)       Labels:| 079-907-560-CFS.clb
   Component: 4.2l V8/4V    H07 0004
   Revision: N5H07---
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
   ROD: EV_ECM42FSI011_AU64.rod
   VCID: 2A0D07C92C729DBB2C7-807E
   Part No SW: 4H1 927 158 BR    HW: 0BK 927 156 K
   Component: 0BK 42 FSIUSA H08 1001
   Revision: --H08---
   Coding: 000002
   ROD: EV_TCMALX51011_002_AU64.rod
   VCID: 015F8065F184BEE35DD-8054
   Coding: 44E6F20022674F00E200
   VCID: 313F10A501A4EE63EDD-8064
0675 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Net_Fahrwerk_03_FA_Niveau_Druck_HL_Error]
                    Reset counter: 205
                    Mileage: 82266 km
                    Date: 2020.08.31
                    Time: 21:57:03
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 02
                    Bit Info 4: 12
                    F-Path: 39
                    F-Type: 24
                    Uz: 99
0677 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Net_Fahrwerk_03_FA_Niveau_Druck_VL_Error]
                    Reset counter: 205
                    Mileage: 82261 km
                    Date: 2020.08.31
                    Time: 17:08:08
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 39
                    F-Type: 1A
                    Uz: 94
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 BD
   Component: BCM2 2.0      H31 0510
   Shop #: WSC 58001 000 1048576
   VCID: 6E85CBD9D09AB19BB0F-803A
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000207513007
   Revision: AA000000    Serial number: 00000015316696
   VCID: 353724B5F54CC243B15-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 H    HW: 4H0 820 043 H
   Component: Klima 3 Zonen H20 0072
   Coding: 4801222EC8
   ROD: EV_AirCondiFront_001_AU64.rod
   VCID: 2517F4F5456CB2C3015-8070
0137 - Motor for  Right Side Window Defrost Flap
          B10D8 22 [009] - Signal Amplitude Too High
                    Fault Frequency: 50
                    Reset counter: 165
                    Mileage: 82011 km
                    Date: 2020.08.21
                    Time: 14:07:29
0279 - Coolant Shut-Off Valve
          B10C8 11 [009] - Short to Ground
                    Fault Frequency: 39
                    Reset counter: 165
                    Mileage: 82011 km
                    Date: 2020.08.21
                    Time: 14:05:40
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001238724
   Coding: 09072091073C9FE18B000804A0003800009CD308820001218001085C3B00
   Component: WWS641 110811  H35 0040
   Serial number:         110923104943
   Coding: 0045F7
   Serial number: 10142877
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Serial number: 23 09 2011  00000168
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R0P6V02
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000016091100010297
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000020091100010928
   Coding: 100000
   Serial number: WA102070000000459719
   Coding: 020300
   Serial number: 42188FC5000000000001
   Part No SW: 4H0 035 108 E    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0190
   Revision: AA001001
   VCID: 221DEFE954C245FB647-8076
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Revision: 11001001    Serial number: 55901127300702
   Coding: 280102
   ROD: EV_EPHVA18AU57X0000_002_AU64.rod
   VCID: 3B23328DD3E81433471-806E
   Revision: --------    Serial number: 003JS0016B6V
   VCID: 372B2EBDEFC03053A39-8062
   Serial number: 5850000R11908020U1
   Serial number: 3575HRB40670T3R6GH7P
   Serial number: 3585HRB40670T3R6A0RN
   Serial number: 3515JRB405H0Q8K4KHJ$
   Serial number: 3525JRB405L0Q8K4LPD4
   Serial number: 3554VRB405J0OPMMMGPC
   Serial number: 3564VRB405J0OPMM40SP
   Revision: --------    Serial number: 90815KIU0008H
   Coding: 000034
   VCID: 372B2EBDEF403053A39-8062
   Subsystem 1 - Part No SW: 4H0 951 528 J    HW: 4H0 951 528 J
   Component: E221 - MFL  H09 0009
   Serial number: 23 08 2011  33120288
   Part No SW: 4H0 920 920 E    HW: 4H0 920 920 E
   Component: TBenUSA------ H38 0373
   Revision: 32480030    Serial number: 658170911592006
   Coding: 0B6608011300D705020000
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K_AU64.rod
   VCID: 270BFEFD3F60A0D3339-8072
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Serial number: 1110919013871
   Part No SW: 4H0 907 468 F    HW: 4H0 907 468 C
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000262302
   Coding: 00C1034A00
   VCID: 343119B1FEB6DB4B86B-8060
   Serial number: 00000000005650615707
12290 - Quiescent Current
          U1406 00 [009] - Too High
                    Reset counter: 142
                    Mileage: 81986 km
                    Date: 2020.08.19
                    Time: 00:08:55
                    Voltage terminal 30: 12.6 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 49 °C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
   Coding: 008000
   VCID: 2C0101D12686838BDEB-8078
          C1044 00 [009] - -
                    Reset counter: 165
                    Mileage: 82273 km
                    Date: 2020.09.01
                    Time: 15:43:57
   Revision: AA000000    Serial number: 00000015311925
   Part No SW: 4H0 907 637     HW: 4H0 907 637
   Component: SARA 6D       H02 0015
   Revision: --------    Serial number: EJ1BPA3100YHBH0
   VCID: 6C81C1D1E606438B9EB-8038
   Part No SW: 4H0 959 793 M    HW: 4H0 959 793 E
   Component: TSG FA        H02 0166
   Revision: --------    Serial number: 0000120545812
   Coding: 011F1F205E0062C202000006
   VCID: 43D34A6DAB986CF30F1-8016
   Revision: 00002001    Serial number: 0160292508
   Coding: 0106023A00FA759FB0B0C780020100000000000000000000000000000000
   Serial number: 00000000000000046851
   Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J245  007C  H06 0005
   Serial number: 139100093900
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
   Serial number: A2011000000000484768
   Coding: 070000
   Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J394  0014  H06 0005
   Serial number: 138600092253
   Coding: 020200
   Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J392  006A  H06 0005
   Serial number: 139100093914
   Coding: 020200
   Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J867  00E0  H06 0005
   Serial number: 138700092260
   Coding: 020200
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
                    Reset counter: 181
                    Mileage: 81970 km
                    Date: 2020.08.18
                    Time: 14:14:46
02615 - Fuel Tank Cap; Lock
                    Fault Status: 01101001
                    Reset counter: 112
                    Mileage: 80906 km
                    Date: 2020.07.09
                    Time: 14:56:31
                    Reset counter: 88
                    Mileage: 80906 km
                    Date: 2020.07.09
                    Time: 15:05:48
   Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0130
   Revision: CJ007000    Serial number: 00000000027230
   Coding: 030000
   VCID: 1C61D11176A6730BAEB-8048
   Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
   Component: TSG BF        H02 0166
   Revision: --------    Serial number: 0000120541683
   VCID: 3A2D3789DC522D3B5C7-806E
   Revision: --------    Serial number: 00000000154875
330240 - Function Restricted due to Missing Message(s)
          U1111 00 [000] - -
          [FC_KESSY_02_MESSAGE_TIMEOUT]
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [000] - -
          [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
   Part No SW: 4H0 035 082 B    HW: 4H0 035 082
   Component: Radio U SIRIU H53 0076
   Revision: AB001007    Serial number: 155J$0B7512934
   Coding: 020007010000000001
   VCID: 2019E5E15ACE57EB723-8074
   Part No SW: 4H0 035 746 D    HW: 4H0 035 746
   Component: H-BNT-NA      H48 0423
   Revision: --------    Serial number: 035J-0B7504429
   Coding: 020200000001F1EF45128B0E00000003140001000000000000
   VCID: 290FF8C529F496A325D-807C
   Subsystem 1 - Part No: 8R0 060 884 AD
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 4H0 919 604 D    HW: 4H0 919 604 D
   Component: DU8 D4 SV NB  H47 0021
   Serial number: AUZ8ZDB6900CU7Y
   Subsystem 3 - Part No SW: 4H1 919 600 F    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0064
   Serial number: 00000000053820
   Subsystem 4 - Part No: 8R0 060 961 B
   Component: CD-Database  3371
                    Reset counter: 204
                    Mileage: 82261 km
                    Date: 2020.08.31
                    Time: 14:06:11
                    Bin. Bits: 00000100 00000000
                    Bin. Bits: 00000000 00000000
                    Fault Status: 01101011
                    Reset counter: 88
                    Mileage: 80902 km
                    Date: 2020.07.09
                    Time: 13:41:23
                    Voltage: 14.00 V
   Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
   Component: TSG HL        H04 0167
   Revision: --------    Serial number: 0000120480444
   Coding: 010F1F20400062C202000006
   VCID: 392F2885D954262355D-806C
   Part No SW: 4H0 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H04---    Serial number: 525 PA8J18D372
   Coding: 1080003
   Shop #: WSC 02391 785 00200
   VCID: 2615F3F934EAB9DB08F-8072
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 R    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0039
   Revision: 10011001    Serial number: 260100221
   Coding: 0210044100
   VCID: 3D273C95CDFC1A03795-8068
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Revision: --------    Serial number: 000000047402
   ROD: EV_Ambie.rod
   VCID: 6393AAED0BD80CF32F1-8036
   Component: TSG HR        H04 0167
   Revision: --------    Serial number: 0000120480445
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Component: GSM-LL        H07 0083
   Revision: 0L0D5012    Serial number: SN110803  0312
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 2B0302CD238884B3D71-807E
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Serial number: 00002663068801
   Coding: 764FF2
   VCID: 2F3B16DD1790F893FB9-807A
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00002663156401
   Coding: 364FF2
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 00060000031F030000030801424CDA010000
   ROD: EV_RGS_L_VW51.rod
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ROD: EV_RGS_R_VW51.rod
   VCID: 323D1FA904A2D57B947-8066
End----------(Elapsed Time: 02:48, VBatt start/end: 14.3V/14.1V)-----------
AvernturaA8
C?ID=405840
Hi, I wanted to post an update of my situation regarding my suspension level problem that persists on my 2012 Audi A8. The car sits about an inch lower on the left side (driver side). Since my last post, I have replaced the "OEM Air Ride Control Solenoid Valve Block" and the 4 level control sensors. The situation has not improved. I have attempted to perform the calibration and I am stuck at the "Startup to Reference Level" step which terminates with "Aborted Safety Reasons". I have attempted multiple times to no avail. What's unusual is that I was able to get past this step before replacing the sensors. At this point, I am out of ideas. Any suggestions welcome. Also, I'll be willing to pay someone with expertise in this forum to assist me remotely.
Your help is greatly appreciated.
