2012 A8 4H 34 level control coding
Autohaus Frankfurt
C?ID=30574
We have a 2012 A8L in the shop that the owner "tried" lowering by himself with help from friend with a "scanner". Control unit is not coded along with other issues. Could someone help me with coding this module? I am hoping that he did not "reset all adaptations". Could not get a clear answer on this.
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4H0 907 553 E HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0099
Coding: 008000
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_AU64.rod
VCID: 2E59177C71E7C13200-807A
367877 - Ride Height Not Learned
C1044 00 [009] - - Confirmed - Tested Since Memory Clear
266752 - Control module not coded
U1013 00 [009] - - Confirmed - Tested Since Memory Clear
267266 - Control Module Incorrectly Coded
U1014 00 [009] - - Confirmed - Tested Since Memory Clear
38144 - No End-of-Line Programming
B2013 00 [009] - - Confirmed - Tested Since Memory Clear
Long time user of VCDS, however this is my first post to forum. I am unsure how to attach entire quick test, instruction would be appreciated. Thanks.
Autohaus Frankfurt
C?ID=30574
2012 A8l- 34(level control) coding
We have a A8 4H in the shop that has issue with the level control. Customer attempted to lower the car with help from a friend with a "scanner". I have a feeling that "reset all adaptations" was selected. Codes for no coding and incorrect coding. I tried change all variables in long coding with no success. Long time user of VCDS, however this is my second post and Im not sure how to add the entire quick test. Any help with the coding would be appreciated
Coding: 008000
C1044 00 [009] - -
U1013 00 [009] - -
U1014 00 [009] - -
B2013 00 [009] - -
Thanks, Sean @ Autohaus Frankfurt
Autohaus Frankfurt
C?ID=30574
VCDS Version: 16.8.0.1 (x64)
Data version: 20160801 DS254
VIN: WAURVAFDXCN035626   License Plate:
Mileage: 62035km-38546mi   Repair Order:
Chassis Type: FD (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 34 36 3B 3C 42
          46 47 52 53 56 5F 62 6C 6D 6F 72 81 85 88 89 8B 8E 8F 90
VIN: WAURVAFDXCN035626   Mileage: 62035km-38546miles
85-On Board Cam. -- Status: Malfunction 0010
Address 01: Engine (------CDRA)       Labels: None
   Part No SW: 4H0 907 560 C    HW: 4H0 907 560
   Component: 4.2l V8/4V    H07 0004
   Revision: N5H07---
   Coding: 0106000A290F0268
   Shop #: WSC 02313 785 00200
   ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
   ROD: EV_ECM42FSI0114H0907560C.rod
   VCID: 2A511B6C4D0FAD12DC-807E
10333 - Thermostat for Transmission
          P19A2 00 [047] - Open Circuit
2863 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
          P0056 00 [237] - Malfunction / Open Circuit
2859 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
          P0036 00 [237] - Malfunction / Open Circuit
7676 - Oxygen (Lambda) Sensor B1 S1
          P2237 00 [232] - Pump Current Open Circuit
Readiness: 0000 0001
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 4H1 927 158 BR    HW: 0BK 927 156 AF
   Component: 0BK 42 FSIUSA H16 1003
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMALX51011 002018
   ROD: EV_TCMALX51011.rod
   VCID: 01039CC090F98E4AAD-8054
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
   Component: ESP PREMIUM   H10 0352
   Coding: 44E6F20022674F00E200
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005013
   ROD: EV_ESPPremi_AU64.rod
   VCID: 346D05149FCBEBE276-8060
0120 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
0675 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
0778 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 BD
   Component: BCM2 2.0      H31 0510
   Coding: 0D872006000000000000
   Shop #: WSC 57464 001 1048576
   VCID: 6ED9D77CB967813240-803A
   Serial number: 2312000031433006
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000027102536
   Coding: C018320085043201010001010101112131313333283333
   VCID: 356B38109CB1F2EA41-8060
Address 08: Auto HVAC (J255)       Labels: 4H0-820-043.clb
   Part No SW: 4H0 820 043 H    HW: 4H0 820 043 H
   Component: Klima 4 Zonen H20 0120
   Coding: 4801227ECC
   ASAM Dataset: EV_AirCondiFront 001050
   ROD: EV_AirCondiFront_AU64.rod
   VCID: 254BE8502411826AF1-8070
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 BP    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0111
   Revision: 11012002    Serial number: 00000001280160
   Coding: 09072091073C9FE38B000804A0003800009CD308820001218001085C3B00
   VCID: 77F7F218C63DC0FA93-8022
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 111212  H35 0080
   Serial number:         120121172407
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 20003849
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Serial number: 08 03 2012  00000908
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R1E1Y02
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000029031200010117
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000030031200010961
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA103085000001107549
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 5C78C026000000000001
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 E    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0190
   Revision: AA001001
   VCID: 2241F34C3D3F755294-8076
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 Q    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0061
   Revision: 11001001    Serial number: 55901207900451
   Coding: 280902
   ASAM Dataset: EV_EPHVA18AU57X0000 004005
   ROD: EV_EPHVA18AU57X0000.rod
   VCID: 408559C4DB734742E2-8014
Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4H0 907 561 B    HW: 4H0 907 561
   Component: ACC3          H17 0400
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContrAU64X 002021
   ROD: EV_AdaptCruisContrAU64X.rod
10240 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H44 0041
   Revision: --------    Serial number: 003JS0019BZK
   Coding: 303143303230303030314A55304C34483053
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: 377732188EBD00FA53-8062
   Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
   Component: BF-Gewichtss.  H03 0040
   Serial number: 5850000R123030405S
   Serial number: 3575HRB406317UE43OVU
   Serial number: 3585HRB405F17UE2BODU
   Serial number: 3515JRB405P184COO9AP
   Serial number: 3525JRB405P184COC162
   Serial number: 3554VRB400K4UHPK9OL2
   Serial number: 3564VRB400K4UHPKJOIA
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Revision: --------    Serial number: 90815LCM0002B
   Coding: 0000BC
   VCID: 3777321886BD00FA53-8062
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
   Component: E221 - MFL  H09 0009
   Serial number: 10 01 2012  33178761
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4H0 920 980 J    HW: 4H0 920 980 J
   Component: TBenUSAACC--- H71 0416
   Revision: 35081058    Serial number: 658280312592042
   Coding: 0B4608015700D705020000
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K.rod
   VCID: 3261030C65DFE5D264-8066
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0224
   Serial number: 1120228000499
   Part No SW: 4H0 907 468 AB    HW: 4H0 907 468 AA
   Component: J533--Gateway H10 0028
   Revision: --------    Serial number: 00000000463591
   Coding: 00C1034A00
   ASAM Dataset: EV_GatewPkoUDS 001013
   ROD: EV_GatewPKOUDS_AU57.rod
   VCID: 71E3CC00A0599ECA5D-8024
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 00000000004970292456
6221 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
6232 - Media player in position 1
          U105E 00 [008] - No Communication
0267 - Optical data bus
          U1049 00 [008] - Open circuit
Address 28: HVAC, Rear (E265)       Labels: None
   Part No SW: 4H0 919 158 C    HW: 4H0 919 158 C
   Component: Klima Fond    H16 0111
   Coding: 0000000000
   ASAM Dataset: EV_AirCondiHeck 001039
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: 306509046BD3D7C212-8064
   Coding: 008000
          C1044 00 [009] -  -
          U1013 00 [009] - -
          U1014 00 [009] - -
          B2013 00 [009] -  -
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000027103765
   Coding: C0183B0085053201010001010101112131313333203333
            000 -  -  - Intermittent
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637     HW: 4H0 907 637
   Component: SARA 6D       H02 0020
   Revision: --------    Serial number: EJ1BPA3101GYNT0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA.rod
   VCID: 6CDDDD74877B73226E-8038
   Part No SW: 4H0 907 566 A    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0040
   Revision: 00H02000    Serial number: 6PZ 010 287-07
   Coding: 0000002
   VCID: 2E59177CB9E7C13200-807A
   Subsystem 1 - Part No: 4H0 907 568 A
   Component: J770  SWA Slave H02 0040
   Subsystem 2 - Serial number: 6PZ 010 287-27
   Subsystem 3 - Serial number: 5F01.04.1200H020003CX25019ÿ
   Subsystem 4 - Serial number: X25019ÿ
   Part No SW: 4H0 959 793 G    HW: 4H0 959 793 G
   Component: TSG FA        H06 0261
   Revision: --------    Serial number: 0000126159543
   Coding: 011F1F005E0062C202003017
   Shop #: WSC 02312 785 00200
   VCID: 3D7B2030A4812AAA89-8068
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0174422415
   Coding: 0106023A00FA759FB0B0C780020301000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0080
   Serial number: 00000000000000074855
   Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J245  007C  H06 0005
   Serial number: 212200055134
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
   Component: Dachelektroni  H11 0080
   Serial number: A2012000000000549751
   Coding: 070000
   Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J394  0014  H06 0005
   Serial number: 212200055174
   Coding: 020200
   Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J392  006A  H06 0005
   Serial number: 212200055141
   Coding: 020200
   Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J867  00E0  H06 0005
   Serial number: 212200055172
   Coding: 020200
   Subsystem 8 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H12 0719
   Serial number: 84234125
   Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0130
   Revision: CJ007000    Serial number: 00000000042550
   Coding: 030000
   VCID: 1C3DCDB41F5B43A25E-8048
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H06 0261
   Revision: --------    Serial number: 0000126160777
   Coding: 011F1F005E0062C202003007
   VCID: 3C7D2D34BF9B23A2BE-8068
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000305004
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H0 035 082 C    HW: 4H0 035 082
   Component: Radio U SIRIU H53 0101
   Revision: AB001007    Serial number: 235CO0C7502243
   Coding: 020007010000000001
   VCID: 2143FC4038396E4A8D-8074
   Part No SW: 4H0 035 746 D    HW: 4H0 035 746
   Component: H-BNT-NA      H48 0423
   Revision: --------    Serial number: 035CV0C7510577
   Coding: 020200000001F9EF7D128B1E00000003140001000000000000
   VCID: 2953E4604009A60AD5-807C
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 4H0 919 604 F    HW: 4H0 919 604 F
   Component: DU8 D4 SV NB  H47 0021
   Serial number: AUZ8ZDC9300CSP5
   Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000075090
   Component: CD-Database  3371
02067 - Optical Databus; Unpermitted Wake-Up Request
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0262
   Revision: --------    Serial number: 0000126337890
   Coding: 010F1F00400062C202003007
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4H0 907 441 B    HW: 4H0 907 441 B
   Component: SG Rueckfahrkamera  0161
   Revision: --H05---    Serial number: 525 PA8J21D05X
   Coding: 1080003
   VCID: 2757E258961D907AC3-8072
Address 6D: Trunk Elect. (----)       Labels: None
   Part No SW: 4H0 959 107 R    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0039
   Revision: 10011001    Serial number: 085200324
   Coding: 0210044100
   ASAM Dataset: EV_DeckLidContrUnit 001025
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3D7B2030AC812AAA89-8068
Address 6F: Centr. Conv. II (J773)       Labels: None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000069063
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 63CFB6486AA53C5ADF-8036
   Component: TSG HR        H06 0262
   Revision: --------    Serial number: 0000126336682
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H08 0083
   Revision: 0L0D5013    Serial number: SN120207  0498
   ROD: EV_GSM2x3Mono.rod
   VCID: 2B5F1E6842F5B41A27-807E
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H25 0038
   Coding: E9060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2649EF5C59178972F8-8072
0793 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
Address 88: Multicont. Seat Driver (J873)       Labels: None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00005112160702
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F670A7876EDC83A0B-807A
Address 89: Multicont. Seat Pass. (J872)       Labels: None
   Serial number: 00005598130301
   Coding: 364FF2
Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4H0 907 541 B    HW: 4H0 907 541
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
   ROD: EV_AdaptCruisContr2AU57X.rod
   VCID: 2855E16453039F02CA-807C
Address 8E: Image Processing (J851)       Labels: 4H0-907-107-V2.clb
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000053003127
   Coding: 02A19A000111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 2757E2585E1D907AC3-8072
0091 - Function Limitation due to Missing Video Data
          C1108 00 [009] -  -
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 0066F609031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 31630C0060D9DECA1D-8064
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 07:41)---------------------
Thanks for the instruction!
Autohaus Frankfurt
C?ID=30574
I did try all three of those coding numbers, it says coding accepted but I still get the fault codes.
The coding itself seems OK. However, the module may not like the 12345/123/12345 WSC/Importer/Equipment combo.
The "No End-of-Line Programming" fault code is quite puzzling.
Although I thought I'd seen it somewhere, I can't find a procedure for recalibrating the ride height off-hand. Hopefully someone else will chime in on that.
See this page for How to Post an Auto-Scan.
Merged the two threads that Autohaus Frankfurt started...
United States
Yeah, 20103 is the SA code but that's so common now I can't find the thread either. I think that EOL DTC is bad news as well - but I'll ping Peter on the calibration. He should have a template handy for the 4G/4H models.
Autohaus Frankfurt
C?ID=30574
Yea, i noticed that too. I tried to change it in options with the same numbers I found in the other modules(02391 785 00200). When I input the coding it shows the numbers I entered at the bottom but after coding is accepted and It returns to main level control screen and it reads 123 12345???
Autohaus Frankfurt
C?ID=30574
So I was just informed that the owner had installed aftermarket links on the car, do you guys think this would cause and issue at this point?
DrPeter
16.4905° S, 151.7375° W
Hello, ping received :)
Yeah, 20103 is the SA code but that's so common not I can't find the thread either. I think that EOL DTC is bad news as well - but I'll ping Peter on the calibration. He should have a template handy for the 4G/4H models.
The coding value of [008002] is the correct, based on the VIN number.
After you have correctly coded the [34-Level Control] controller, please have a look and follow the 'Re-adapt Adaptive Suspension to default position' procedure below, if this works as expected, the fault codes should clear.
As long they are the same exact size/parts, it should be okay.. If not I would not proceed.
Important!
Please be advised that the procedure below has not been 100% confirmed and /or fully tested.
Use this procedure at your own risk, Ross-Tech assumes no responsibility for any damages or claims of any type.
We have not had any customers that had any negative affects, it appears the procedure will in many cases work or it will not work (codes do not clear).
** Feedback is requested **
Good or bad
- Re-adapt Adaptive Suspension to default position -
- Prerequisites
- Use a Battery maintainer
- Vehicle on level surface
- No persons or gear in Vehicle
- Nothing under vehicle
- Door are to remain shut
Using the MMI (under [Car]) the following needs to be set-
- Air Spring Wheel Change = [off]
- Automatic Drive Program = [auto] or Audi Drive Select (under Car menu)
Select - [34-Level Control]
Login or Security Access - [20103]
[Basic Settings - 04]
- Choose - [Delete calibration for level control] - Press [Go!]
- Wait for basic Settings to End (Finished Correctly), then press [Stop]
- Choose - [Start up to reference level] - Press [Go!]
- Wait for basic Settings to End (Should run for 30 seconds or so), then press [Stop]
Measure the ride height, in millimeters, from the center of the wheel to the edge of fender, do this for all four wheels and record the values.
[Adaptation - 10]
Choose from the drop down menu and enter the [New value] recorded value for each of the wheels below, then press [Do it!]
- [Body height left front wheel house edge]
- [Body height right front wheel house edge]
- [Body height left rear wheel house edge]
- [Body height right rear wheel house edge]
Reference only - Do not enter these values, see above.
D4 Audi A8 (4H):
1BK standard running gear:
Specification, front axle = 410mm
Specification, rear axle = 405 mm
- Choose - [Calibrate level control] - Wait for basic Settings to End
- Choose - [Activate level control] - Wait for basic Settings to End
Measure the ride height again and verify the values are within 3mm of the displayed values in Advanced Measuring Value Blocks.
Using the MMI verify the following setting -
Clear ALL fault codes and re-check for fault codes, road test vehicle.
Hope this helps,
drpeter
Autohaus Frankfurt
C?ID=30574
drpeter, thanks for the info and your time. The procedure unfortunately did not work. Everything is good up until i try to select calibrate level control.
ERROR:request sequence error
DrPeter
Hello again....
- It maybe possible the ride height values were not within specification limits allowed by the controller. Wrong parts??
What were the values you had entered?
Thanks,
drpeter
Autohaus Frankfurt
C?ID=30574
Hello again....
Thanks,
drpeter
I entered the standard running gear numbers 405/410. I tried looking for voltage numbers from the sensors because I am concerned that the length of the "links" is not correct although i feel that it should accept it.
DrPeter
Hi,
Ah.. okay, try the procedure again .. this time "Measure the ride height, in millimeters, from the center of the wheel to the edge of fender, do this for all four wheels and record the values." as described in the procedure... The given values are for reference only, so do not enter these values.
Last post of the evening, so I hope this works, have a good night and a great thanksgiving to all :)
drpeter
