VW Polo 9N 1,9l TDI engine BMS G450 adaption - request out of range?
MartinsX
Riga, Latvia
C?ID=268515
It's clear, that DPF of this car is clogged, but why? I would like to find a reason before starting repair/replacement works. One thing I noticed is, that G450 shows approx -15 mbar @ ignition on/engine off. I tried to recalibrate G450 but login 30605 was not accepted, "Error 31, Request out of range" is displayed after login attempt. Is it because of permanent DPF fault stored or this ECU need different login for G450 adaption?
Tuesday,22,November,2016,10:45:47:32442
VCDS Version: 16.8.3.1
VIN: WVWZZZ9NZ7Y148259   License Plate:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ7Y148259   Mileage: 177880km-110529miles
Address 01: Engine        Labels: 045-906-013-BMS.clb
   Part No SW: 045 906 013 F    HW: 045 906 013
   Component: R3 1,4L EDC G000SG  9560
   Revision: --H01---    Serial number: VWZ5Z0FD221415
   Coding: 0003071
   Shop #: WSC 80093 222 69422
   VCID: 122BD0770E113BD21A-5122
001668 - Glow Plug Control Module (J179)
               P0684 - 000 - Implausible Signal - Intermittent
                    Fault Status: 00110000
                    Mileage: 177540 km
                    RPM: 1071 /min
                    Speed: 14.0 km/h
                    Load: 34.8 %
                    Voltage: 14.21 V
                    Bin. Bits: 00001100
                    Temperature: 3.6°C
                    Bin. Bits: 10110000
008194 - Particulate Trap Bank 1
               P2002 - 000 - Efficiency Below Threshold - Intermittent
                    Mileage: 177810 km
                    RPM: 1533 /min
                    Speed: 61.0 km/h
                    (no units): 0.0
                    Duty Cycle: 95.6 %
                    (no units): 17.85
                    Temperature: 27.9°C
                    Time: 4429.8 s
009263 - Diesel Particulate Filter (Bank 1)
               P242F - 000 - Restricted/Clogged - MIL ON
                    Fault Status: 11100000
                    Mileage: 177811 km
                    RPM: 2079 /min
                    Speed: 56.0 km/h
                    (no units): 0.0
                    Duty Cycle: 99.5 %
                    (no units): 30.60
                    Temperature: 26.1°C
                    Time: 4482.6 s
Readiness: 1 1 0 0 0
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.lbl
   Part No SW: 6Q0 907 379 AF    HW: 6Q0 907 379 AF
   Component: ABS 8.0 front   H05 0002
   Coding: 0002190
   Shop #: WSC 00788 785 00200
   VCID: 0109EF3B5B77B04AB3-5140
Address 08: Auto HVAC        Labels: 6Q0-907-044.lbl
   Part No: 6Q0 907 044 E
   Component: CLIMAtronic PQ24    3805
   VCID: 346776EF5445D5E268-5122
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 F
   Component: 0009 BN-SG.         2S36
   Coding: 09870
   Shop #: WSC 00788
   VCID: 3E7354C73A090FB28E-5140
   Part No: 1C0 909 605 K
   Component: 17 AIRBAG VW51 0N   0009
   Coding: 12599
   Shop #: WSC 00788
   VCID: 2C576E8FDC758D2230-5140
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6Q0 920 825 F
   Component: KOMBIINSTRUMENT AGD V03
   Coding: 01132
   VCID: 377D41E315333EFA4D-5140
   Part No: 6N0 909 901
   Component: 01K1 GATEWAY CAN    2S36
   Coding: 00014
   Shop #: WSC 00788
   VCID: 70EFBAFF30DDA9C24C-5140
Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
   Component: IMMOBILIZER     AGD V03
   Coding: 01132
   VCID: 377D41E315333EFA4D-5122
   WVWZZZ9NZ7Y148259     VWZ5Z0FD221415
   Part No: 6Q0 423 156 AB
   Component: LenkhilfeTRW        V270
   Coding: 10110
   VCID: 6FEDB9832DE3B63A55-515E
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 6Q0 959 433 E
   Component: 5F Komfortgerįt     0002
   Coding: 00017
   Shop #: WSC 00788
   VCID: 3D7153CB370F14AA97-4B00
End-------------------------(Elapsed Time: 03:42)--------------------------
How has the car been used/driven? Is the DPF on this car the original one? At almost 180,00 km, it's probably approaching the end of its expected life, no?
MartinsX
Riga, Latvia
C?ID=268515
It seems like this ECU does not support G450 adaption by way of login 30605 even without permanent faults stored. Should be some other way how to calibrate G450 to 0 value.
comments45059306
Wednesday,23,November,2016,13:22:39:32442
VCDS Version: Release 16.8.3 Running on Windows XP x86
Control Module Part Number: 045 906 013 F    HW: 045 906 013
  Component and/or Version: R3 1,4L EDC G000SG  9560
           Software Coding: 0003071
            Work Shop Code: WSC 12345 123 12345
                      VCID: 122BD0770E113BD21A-5106
http://fotki.lv/lv/Martins_X/comments45059306/
NEtech
Denmark
C?ID=56995
Maybe the -15 mbar is to far away from acceptable, have you installed a new one ?
Have you tested that login in [Secure access-16] ?
Or it is just done with ignition ON / OFF
Have you checked that CAN-Sleep is okay a while after ign. is OFF.
