VW T5 2010 mod Engine CAAC, DPF light on, no DTC
distrub
Norway
C?ID=192694
Hello.
This T5 came inn whit cloged DPF. Used VCDS and regenerated the DPF. Deleted DTC and all is fine. But the DPF light is on permanently and there is no DTC. Replaced the G450 an adapted it whit VCDS. No change. I have used the car for many km now, but noe help. MVB on soot is fine. Any ideas?
Monday,21,November,2016,19:54:56:44240
VCDS Version: 16.8.1.3 (x64)
Data version: 20160902 DS256
VIN: WV1ZZZ7HZAHxxxxx   License Plate:
Chassis Type: 7H (6N0)
Scan: 01 03 04 08 09 15 17 18 19 22 25 56 69 0B
VIN: WV1ZZZ7HZAHxxxxx   Mileage: 131520km-81722miles
Address 01: Engine (J623-CAAC)       Labels: 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 DK    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H32 9135
   Revision: 26H32---    Serial number: 00000000000000
   Coding: 0119401A231600080000
   Shop #: WSC 66565 257 00032
   ASAM Dataset: EV_ECM20TDI01103L906019DK 002007
   ROD: EV_ECM20TDI01103L906019DK.rod
   VCID: 77FD05D5CE6194FA9F-8022
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 E    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0103
   Revision: 00H43001
   Coding: 508724AD91A60A9C24A88976695E10
   Shop #: WSC 02736 790 49152
   VCID: 3467F2D99797BFE27A-8060
Address 08: Auto HVAC (J301)       Labels: 7E5-907-047.clb
   Part No SW: 7E5 907 047 Q    HW: 7E5 907 047 Q
   Component: Climatic-T5   H10 0101
   Revision: 00004001
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ClimaticT5 A01002
   ROD: EV_ClimaT5Basis.rod
   VCID: 3D71D7FDACDD7EAA85-8068
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 086 B    HW: 7H0 937 086 B
   Component: BCM T5GP M++4 H46 0207
   Revision: BM046001    Serial number: 0154 341090379
   Coding: A0A0293A0E212002002000003C2B8CD40000430F60060000300000000000
   Shop #: WSC 02736 790 00000
   VCID: 326BF4C16D83B1D268-8066
   Subsystem 1 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-801.CLB
   Component: J386__TSG_FT  002 3310
   Subsystem 2 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-802.CLB
   Component: J387__TSG_BT  002 3310
   Part No SW: 7E0 959 655 A    HW: 7E0 959 655 A
   Component: VW10Airbag00N H05 0011
   Revision: --------    Serial number: 003E5000RLSC
   Coding: 00000000000000000000000000000000304E
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3467F2D99F97BFE27A-8060
   Part No SW: 7E0 920 860 A    HW: 7E0 920 860 A
   Component: KOMBI         H16 0111
   Coding: 160000
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
   ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
   VCID: 26431891594BDD72F4-8072
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 A
   Component: J737__Standheizung  0404
   Revision: 00085000    Serial number: 09019275D00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: 23450185E279285A93-8076
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 086 B
   Component: GW-K-CAN TP20 0207
   Coding: 042200
   VCID: 70EF3EC9A30FC3C25E-8024
   Part No SW: 09N 907 554 A    HW: 09N 907 554 A
   Component: Haldex 4Motion      6007
   Coding: 0000001
   VCID: 3663C8D141EBADF244-8062
   Component: IMMO          H16 0111
   Part No SW: 7E0 035 156     HW: 7E0 035 156
   Component: Radio         H21 0058
   Revision: R0000000    Serial number: VWZAZ1I9808309
   Coding: 0000020001
   VCID: 60CF4E8973EF7342CE-8034
Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H08 0080
   Revision: 3A002002    Serial number: 00000123088244
   Coding: 4100000100000000
   VCID: 2F6DFDB57EB19C3A07-807A
End-------------------------(Elapsed Time: 02:17)--------------------------
distrub
Norway
C?ID=192694
Monday,21,November,2016,19:56:40:44240
VIN: WV1ZZZ7HZAH227650   License Plate: AY11122
Mileage: 131520km-81722mi   Repair Order:
                Address 01: Engine  (03L 906 019 DK)
19:56:21
  IDE00427   Particle filter: difference pressure 4 hPa
  IDE00428   Particle filter: offset for differential press. 0 hPa
  IDE00434   Particle filter: soot mass calculated 0.78 g
  IDE00435   Particle filter: soot mass measured 6.04 g
  IDE02229   Exhaust gas temperature sensor 1 165.5 °C
  IDE02233   Exhaust gas temperature sensor 2 -0.0 °C
  IDE02234   Exhaust gas temperature sensor 3 142.2 °C
  IDE02236   Exhaust gas temperature sensor 4 153.6 °C
I suppose I would try clearing faults in the 17-Instruments and 19-CAN Gateway despite the fact that there aren't any there.
Is the software in the various control modules up-to-date? Engine, Instrument Cluster, and BCM (which contains the CAN Gateway)...
distrub
Norway
C?ID=192694
I have done a full DTC reset. Im not sure if all off the systems have the latest SW, but i gues thats not the problem. The DPF was cloged when it came in, so it was a fault that is related to the problem. I will serch more and try some different things now. The customer will use the car for a while now. I will observe if the passive regeneration is in order ore if the dpf will fill up again.
distrub
Norway
C?ID=192694
That i dont know. Is this common? Never heard of it, but this is something i need to check out.
distrub
Norway
C?ID=192694
Update. The DPF light is now off. We did a long run whit the car on th highway, and after a while, the light turn it self off. Funny thing because i preformed a activ regeneration whit the VCDS, and this has always fixed the problem before.
Now im happy the car is alright again :-)
