Greetings,
I have a 2008 MK5 Golf that I need to change the workshop code for as it is currently filled with "zeroes" I have the WSC configured in the VCDS application itself, but I don't have the option to do any coding in the power steering module itself (so that I can overwrite the WSC). I want to get the steering correctly coded, so that I can in-turn code the brakes as well.
Friday,18,November,2016,07:26:59:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.3.1 (x64)
Dealer/Shop Name: Matthew Taylor
VIN: WVWZZZ1KZ8W111078 License Plate:
Mileage: 155270km-96480mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56
VIN: WVWZZZ1KZ8W111078 Mileage: 155270km-96480miles
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 R HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0G83NA8OV
Coding: 040300101C070060
Shop #: WSC 66565 257 00032
VCID: 354FD8585CDD5EEA5F-8060
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage
Mileage: 155258 km
Time: 13:37:04
Temperature: 40.0∞C
Temperature: 40.0∞C
Absolute Pres.: 1000.0 mbar
Voltage: 12.319 V
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 - 004 - Malfunction / Open Circuit
Mileage: 155259 km
Time: 17:15:30
RPM: 803 /min
Load: 21.2 %
Speed: 10.0 km/h
Temperature: 71.0∞C
Temperature: 31.0∞C
Voltage: 13.843 V
Readiness: 0110 0101
Part No SW: 02E 300 044 J HW: 02E 927 770 AD
Component: GSG DSG 082 1407
Revision: 04808020 Serial number: 00000907050136
Shop #: WSC 09537 809 89632
VCID: 1C192DFCDF37EFA240-8048
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004744
VCID: 73CB2640122900DAB1-8026
003 - Mechanical Failure
013 - Check DTC Memory
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
VCID: 79D7146830457A8AFB-802C
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007456322
Coding: E70E8B2F000415004F14000414000000000900005C100100000000000000
VCID: 71C72C48683532CA43-8024
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 300807 021 0501
Coding: 00038805
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 130907 046 0204
Coding: 00208933
Shop #: WSC 12345
02499 - Right Low Beam Reflector Motor (V295)
Fault Status: 01111100
Reset counter: 69
Mileage: 155266 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.25 V
00924 - Relay for Headlamp Cleaning System (J39)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 69
Mileage: 155258 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 11.95 V
010 - Open or Short to Plus
Fault Status: 01111010
Reset counter: 69
Mileage: 155258 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.70 V
Reset counter: 69
Mileage: 155258 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.75 V
Fault Status: 01101100
Reset counter: 69
Mileage: 155258 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.75 V
Component: 3A AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1FKU0T
Coding: 0013121
Shop #: WSC 01269 785 00200
VCID: 3D5FC07864ED86AA97-8068
Subsystem 1 - Serial number: 6332MSME2C406B29H
Subsystem 2 - Serial number: 6342MSME2C42223ED
Subsystem 3 - Serial number: 6352QSME3D213635D
Subsystem 4 - Serial number: 6362QSME3C0B0C41L
7 Faults Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
007 - Short to Ground - Intermittent - MIL ON
00589 - Airbag Igniter 1; Passenger Side (N131)
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0012102
VCID: 01277C885895224AB3-8054
Component: E0221 002 0010
Part No SW: 1K6 920 974 HW: 1K6 920 974
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0G83NA8OV
Coding: 0004103
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 040907F1000254
Coding: ED811F060002020001
VCID: 3041E94CA3BF7BC20C-8064
Component: IMMO VDD 1216
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 120B
Coding: 0000564
Shop #: WSC 00000 785 00200
VCID: 3851D16C4BCFA38244-806C
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 69 2901
Revision: 00H15000
VCID: 2F43EA30BE81643A15-807A
01312 - Powertrain Data Bus
Fault Status: 00101110
Fault Frequency: 110
Reset counter: 107
Mileage: 155258 km
Time: 07:37:07
Voltage: 13.88 V
DU
Temperature: 42.0∞C
RPM: 1498 /min
Count: 3
008 - Implausible Signal - MIL ON
Fault Status: 11101000
Reset counter: 67
Mileage: 155258 km
Time: 13:37:09
Battery Volts: 12.4 V
DD
Temperature: 38.0∞C
Count: 5
Steering Angle: -8.71∞
SteerAng Init
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 9890020851030C7F42CC8F0F70085A2690BC00
VCID: 032B76804289305AA1-8056
Subsystem 1 - Component: Sounder No Answer
Reset counter: 67
Mileage: 155258 km
Time: 13:37:09
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000564
VCID: 3957D46870C5BA8ABB-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74C9255C172707E2A8-8020
01533 - Terminal 56 (High Beams)
Part No SW: 1K0 035 180 M HW: 1K0 035 180 M
Component: Radio PM6 018 0035
Revision: 00018000 Serial number: VWZ5Z7G2174742
Coding: 0040400
VCID: 2A75FB2485630112C2-807E
End-------------------------(Elapsed Time: 01:08)--------------------------
Control Module Part Number: 1K0 959 701 M HW: 1K0 959 701 M
Component and/or Version: Tuer-SG 006 120B
Software Coding: 0000564
Work Shop Code: WSC 00000 785 00200
Address 44,1K0 909 144 H,channel 3,adapted from,1,to,0,
Address 46,1K0 959 433 BT,recoded (Long Coding),from,9890020851030C7F42CC8F0F70085A2690BC00,to,9890020851030C3F42CC0F0FF0085A26D09C40,(12345/123/12345),
Control Module Part Number: 1K0 909 144 H
Component and/or Version: EPS_ZFLS Kl. 69 2901
Software Coding:
Advanced Identification
Identification: ZF0-103
Revision: 00H15000
Date: 29.05.09
Test stand number: 4080
Manufacturer number: 0070
Flash Status
Programming Attempts: 0
Successful Attempts: 0
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 00000 000 00000
Software
Z0000
Misc.
Car Info
Chassis Number: WVWZZZ1KZ8W111078
Engine code: ABE
VCDS Info:
