Lane Assist Error
dt-spd
C?ID=249294
Hi all, got a 2015 Seat Leon ( MQB platform same as VW Golf) with a lane assist and light assist fault. Car has been back to dealer who did a full ADAS calibration but the fault came back when driving the car back home after they had done their work. Can anyone help with root cuse of this fault and what the fix is ??
Complete scan below (done before dealer looked at it) and then the individual fault ( as set after collecting the car)
Tuesday,01,November,2016,15:36:52:10334
VCDS Version: 16.8.3.1 (x64)
VIN: VSSZZZ5FZFR077313   License Plate: BP15WNO
Mileage: 28125km-17476mi   Repair Order:
Chassis Type: 5F (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A5
VIN: VSSZZZ5FZFR077313   Mileage: 28125km-17476miles
Address 01: Engine (J623-CUPA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EL    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 7542
   Revision: 83H22---
   Coding: 11190012034501080000
   Shop #: WSC 00049 770 00126
   ASAM Dataset: EV_ECM20TDI01104L906021EL 002008
   ROD: EV_ECM20TDI01104L906021EL_SK37.rod
   VCID: 73E590F5DA9D76DAB1-8026
   Part No SW: 3Q0 907 379 C    HW: 3Q0 907 379 C
   Component: ESC           H32 0384
   Revision: 00000000    Serial number: 63004000001005
   Coding: 19EE8A9234270973007A060141C62998512C9000608294F414615070C003
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 034024
   ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
   VCID: 3A7B7DD1BD77C792B2-806E
   Part No SW: 5F0 907 044 J    HW: 5F0 907 044 J
   Component: Climatronic   H04 0910
   Revision: 00001K09
   Coding: 02100104200100011105000000101000
   Shop #: WSC 00049 770 00106
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   VCID: 2D51468D7C39602A27-8078
   Air quality sensor:
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011429700830
   Coding: 0B000B46C24102FB03A04000B11C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 000FCF399B2B5D42BC-8054
   Subsystem 1 - Part No SW: 5F2 955 119     HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 141020  041 0574
   Serial number:         141023153241
   Coding: 0BC5FD
   Component: RLHS  037 0059
   Serial number: S4Y14M10D24H16M16S04
   Coding: 00095D
   Serial number: 000000000ZY141903GP2
   Serial number: 00000000000060760609
535060 - Databus
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331428805794
   Coding: 0071051001
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 3D7176CDAC59F0AA97-8068
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 22101403271660
   Coding: 00200600FE0739
   VCID: 387F67D9837BD58244-806C
1104 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0200
   Revision: --------    Serial number: 003P4PN3KPFE
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F0D4CC5E6D522BAC5-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 510 14
   Serial number: 3576U0000002A10D611%
   Subsystem 2 - Part No SW: -----------    HW: 454 001 910 14
   Serial number: 3586U0000005A78C311D
   Subsystem 3 - Part No SW: -----------    HW: 454 802 410 14
   Serial number: 3516REFF92205000000I
   Subsystem 4 - Part No SW: -----------    HW: 454 802 310 14
   Serial number: 3526R0BF62205000000+
   Subsystem 5 - Part No SW: -----------    HW: 454 800 810 14
   Serial number: 3556V640BD904000000B
   Part No SW: 5Q0 953 507 DL    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 02111404221655
   Coding: 6C00
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 0305C0358A3D465AA1-8056
   Part No SW: 5F0 920 972 A    HW: 5F0 920 972 A
   Component: KOMBI         302 4270
   Coding: 27A511006D80260001886A031000000000000000
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 2959B29D48D17C0ACB-807C
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0002695615
   Coding: 030100F40F087300EF0002D8080F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 72EB95F1A5877FD2BA-8026
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Serial number: 000000000B0744021014
   Coding: 002000
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185703001411042309
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000122616785
   Coding: 00100220DE01040000001000
   VCID: 44870329CFB38162D8-8010
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000004232538
   Coding: 2D0000
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 9103
   VCID: 43850035CABD865AE1-8016
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000122305784
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000004212469
   Coding: 350000
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 039E000009000000
   ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
   VCID: 75E1AEEDD4E968EA9F-8020
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 5F0 035 858 A    HW: 5F0 035 858 A
   Component: MU-S-ND-ER    041 0425
   Serial number: E5F00511141966
   Coding: 04730301FF0A000021111101000800002F0101060100010046
   ASAM Dataset: EV_MUStd6C3PASE 002029
   ROD: EV_MUStd6C3PASE_VW37.rod
   Subsystem 1 - Part No SW: 5F0 919 603 A    HW: 5F0 919 603 A
   Component: ABTmin_Std_Nv  H60 0030
   Serial number: SEZ8Z9PT901FH9
   Subsystem 2 - Part No SW: 5F0 919 866 K    HW: -----------
   Component:  ECE 2015  --- 0045
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 10000153050
   Coding: 0100010001020304000500000100010100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B7578D5B24DFE9AA9-806E
0662 - Dynamic Calibration
          C1106 F0 [009] - Limit Exceeded
End---------------------(Elapsed Time: 04:03, udsna)-----------------------
Wednesday,09,November,2016,18:07:56:10334
Mileage: 17709   Repair Order:
                Address A5: Frt Sens. Drv. Assist       Labels: 5Q0-980-653.clb
Control Module Part Number: 5Q0 980 653 F    HW: 5Q0 980 653
  Component and/or Version: MQB_MFK       H06 0052
           Software Coding: 0100010001020304000500000100010100
            Work Shop Code: WSC 00049 770 00126
              ASAM Dataset: EV_MFKBoschAU370 001001 (SE37)
                    Reset counter: 124
                    Mileage: 28491 km
                    Date: 2016.11.09
                    Time: 17:49:37
                    Control Module temperature: 44 °C
                    Outside air temperature: 5.5 °C
                    Vehicle speed: 77.44 km/h
                    Voltage terminal 15: 14.3 V
                    System run time: 1247.2 s
dt-spd
C?ID=249294
Lots of views but sadly no replies. :(
Does anyone know the details of what causes a C1106 fault and the recommended repair ?
DrPeter
16.4905° S, 151.7375° W
The fault code means the 'calibration' values, that are monitored by the [A5-Frt Sens. Drv. Assist] controller, are not within the specified or acceptable range.
- There could be a mechanical issue or a calibration procedure issue.. either case I would take it back to the dealer that performed the procedure so they can see the concern.
Hope this helps,
drpeter
Jools
Czech Republic
C?ID=136940
Hi,
so any solution how to fix this issue??
South Molton, UK
Jools said:
So any solution how to fix this issue????
I think DrPeter has already answered how to fix this issue...
downtime
Finland
C?ID=280813
I was about to reply the same as DrPeter. I would take this back to the dealer for recalibration. The calibration routine clearly was not done correctly.
The calibration is a very tedious procedure and needs VERY careful placement of the calibration board. If not properly positioned and the mechanic does not make the measurements between the board, height to wheel archers etc. properly, the calibration values will be off.
Also what I would check is that the camera is seated properly on the windshield before even starting the calibration.
patrascul25
Romania
C?ID=374594
Seat Leon 2014 Lane Assist Error - No Basic Settings
I have a Seat Leon 2014 with Lane Assist error that could be related to the same bad recalibration issue. The car has a calibration certificate but Lane Assist was disabled due to Dynamic calibration - Limit Exceeded error. Managed to reset to Basic Settings and now is working until you turn off the engine. If i restart the engine will show "Lane Assist" error message on the cluster display. Do you think there's a need for dealership static calibration? I get also a temperature errror from time to time inside the camera module. This could be related as this camera needs constant temperature in order to work?
Thanks in advance!
here's the code:
Thursday,19,September,2019,13:43:12:15962
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
Dealer/Shop Name: patrascul25
VIN: VSSZZZ5FZFR051234   License Plate: CT13SYN
                Address A5: Frt Sens. Drv. Assist       Labels: 5Q0-980-653.CLB
           Software Coding: 0100010001020304000500000000000101
            Work Shop Code: WSC 00049 770 00123
                      VCID: BB36A63A325B7A970C-80EE
0660 - No Basic Setting
          B2010 00 [009] - -
          [ruCalibMissingFailure]
                    Reset counter: 249
                    Mileage: 191971 km
                    Date: 2019.09.19
                    Time: 13:42:25
                    Control Module temperature: 51 °C
                    Outside air temperature: 19.0 °C
                    Vehicle speed: 0.00 km/h
                    Voltage terminal 15: 12.7 V
                    Terminal 15 on: 1.4 s
South Molton, UK
Since you have a complete different vehicle it would make more sense for this to be in a separate thread - if Uwe agrees?
Posting a full unedited VCDS Auto-Scan would be more helpful than a small edited section :thumbs:
It seems they are quite similar, only one model year apart?
Absolutely!
myounus
Northwest UK
C?ID=321059
ADAS Calibration is required. If it is done correctly then the basic settings will be saved to the camera and the error will disappear.
patrascul25
Romania
C?ID=374594
Ok, thanks!
This was my first post so, please, bear with me as i'm still learning. I will take your advice and post full unedited VCDS scan next.
Have a nice day!
