Hidden menu (Green menu) is NAV/MAP (or CAR) + RADIOGreen Menu on MIB2 is activated by enabled Developing Mode in Adaption Channel in 5F then holding the Engineering mode Keys down for at least 20 seconds. I think its NAV up and MEDIA down. hold them simultaneously for 20 seconds.
However, Green Menu doesnt offer much like the old green menu now in MIB2. Activating new options in the MIB2 is driven primarily from coding and adaption channel changes now.
HTH
Andy
MVB 002 in the logs are correctHey Dana
here is the Measuring Blocks log for 42 and 52, carried out the output test and window going down and up on 42 and 52 as well as folding door mirrors
Mileage: Repair Order: Log 42
Address 42: Door Elect, Driver (4G8 959 793 H)
10:13:59 Group 001
00000000 Bin. Bits
00000000 Bin. Bits
0101 Bin. Bits
12.00 V Voltage
10:13:59 Group 002
Not Oper.
Not Oper.
Not Oper.
Not Oper.
10:13:59 Group 003
0.0 % Load
11.0°C Temperature
1101 Bin. Bits
Still
Mileage: Repair Order: 52
Address 52: Door Elect, Pass. (4G8 959 792 J)
10:23:02 Group 001
00000000 Bin. Bits
00000000 Bin. Bits
0101 Bin. Bits
12.16 V Voltage
10:23:02 Group 002
Not Oper.
Not Installed
Not Installed
Not Installed
10:23:02 Group 003
0.0 % Load
10.0°C Temperature
1101 Bin. Bits
Still
Hey Folks
Great work, I can now confirm back and the bottom left of the silver keys gets you into the hidden green menu, it's changed dramatically, so can't see anywhere to do mods but we are progressing, thank you folks
You'll find to enable "new" menu options in the MIB2, that is driven from enabling adaption channels in 5F along with the correct Terminal (in most cases its Terminal 15)
If you scroll through them to see ones that are enabled from factory you can duplicate for ones that arent.
Cheers
Andy
Code:Mileage: Repair Order: Log 42 Address 42: Door Elect, Driver (4G8 959 793 H) 10:13:59 Group 001 00000000 Bin. Bits 00000000 Bin. Bits 0101 Bin. Bits 12.00 V Voltage 10:13:59 Group 002 Not Oper. Not Oper. Not Oper. Not Oper. 10:13:59 Group 003 0.0 % Load 11.0°C Temperature 1101 Bin. Bits Still
... but I was looking to see if all of the switch positions (Auto Open/Auto Close/Manual Open/Manual Close/Not Oper.) were shown when the switches are operated. The only switch position that really maters is Auto - but making sure all positions are recognized isn't a bad idea. At this point it does confirm the correct group number based on the Not Oper. data.Code:Mileage: Repair Order: 52 Address 52: Door Elect, Pass. (4G8 959 792 J) 10:23:02 Group 001 00000000 Bin. Bits 00000000 Bin. Bits 0101 Bin. Bits 12.16 V Voltage 10:23:02 Group 002 Not Oper. Not Installed Not Installed Not Installed 10:23:02 Group 003 0.0 % Load 10.0°C Temperature 1101 Bin. Bits Still
Also, did you try with the factory condition 46: Central Conv. coding in post # 16?
