Hey folks
Can anyone help with me accessing my hidden menu, tried all combinations but none of them are working, I presume there is a work around with the MIB1/MIB2 but not sure where to start
Here is my log and thank you for the support
> Regards
> Mr S Patel
> Sunday,16,October,2016,09:25:25:17058
> VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
> VCDS Version: 16.8.3.1 (x64)
> Data version: 20161010 DS267.0
> www.Ross-Tech.com
> VIN: WAUZZZ4G2HN036*** License Plate:
> Chassis Type: 4G (4G8)
> Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 30 34 36 3B 3C 42 44
> 46 52 53 55 5F 62 6C 6D 72 82 85 8B 8E 8F 90 AC
> VIN: WAUZZZ4G2HN036468 Mileage: 1240km-770miles
> 01-Engine -- Status: OK 0000
> 02-Auto Trans -- Status: OK 0000
> 03-ABS Brakes -- Status: OK 0000
> 04-Steering Angle -- Status: OK 0000
> 05-Acc/Start Auth. -- Status: OK 0000
> 08-Auto HVAC -- Status: OK 0000
> 09-Cent. Elect. -- Status: Malfunction 0010
> 10-Park/Steer Assist -- Status: OK 0000
> 13-Auto Dist. Reg -- Status: OK 0000
> 15-Airbags -- Status: OK 0000
> 16-Steering wheel -- Status: Malfunction 0010
> 17-Instruments -- Status: OK 0000
> 19-CAN Gateway -- Status: OK 0000
> 28-HVAC, Rear -- Status: OK 0000
> 30-Special Function II -- Status: OK 0000
> 34-Level Control -- Status: Malfunction 0010
> 36-Seat Mem. Drvr -- Status: OK 0000
> 3B-Sensor Elect. -- Status: OK 0000
> 3C-Lane Change -- Status: OK 0000
> 42-Door Elect, Driver -- Status: OK 0000
> 44-Steering Assist -- Status: OK 0000
> 46-Central Conv. -- Status: Malfunction 0010
> 52-Door Elect, Pass. -- Status: OK 0000
> 53-Parking Brake -- Status: OK 0000
> 55-Headlight Range -- Status: OK 0000
> 5F-Information Electr. -- Status: OK 0000
> 62-Door, Rear Left -- Status: OK 0000
> 6C-Back-up Cam. -- Status: OK 0000
> 6D-Trunk Elect. -- Status: OK 0000
> 72-Door, Rear Right -- Status: OK 0000
> 82-Heads Up Display -- Status: OK 0000
> 85-On Board Cam. -- Status: OK 0000
> 8B-Adaptive Cruise 2 -- Status: OK 0000
> 8E-Image Processing -- Status: OK 0000
> 8F-Pretens. Frt Left -- Status: OK 0000
> 90-Pretens. Frt Right -- Status: OK 0000
> AC-Reductant Control -- Status: OK 0000
> Address 01: Engine (J623-CZVA) Labels: None
> Part No SW: 4G2 907 311 B HW: 4G2 907 311 A
> Component: 3.0TDI MD1 H24 0003
> Revision: C4H24---
> Coding: 1A254012046601030800
> Shop #: WSC 02391 785 00200
> ASAM Dataset: EV_ECM30TDI0114G2907311B 001007
> ROD: EV_ECM30TDI0114G2907311B.rod
> VCID: 2447BADA2F995D62F8-8070
> No fault code found.
> Readiness: 0 0 0 0 0
> Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
> Part No SW: 4G0 927 166 K HW: 0B5 927 156 K
> Component: 0B5 30 TDIRdW H03 0006
> Revision: --H03---
> Coding: 100001
> ASAM Dataset: EV_TCMDL501021 001022
> ROD: EV_TCMDL501021_VW51.rod
> VCID: 3561779E9403D4EA5F-8060
> Address 03: ABS Brakes (J104) Labels: Redir Fail!
> Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
> Component: ESP9 Premium H01 0530
> Revision: -------- Serial number: --------------
> Coding: 17A6DE4BE8657BD29B00
> ASAM Dataset: EV_ESP9BOSCHAU57X 004018
> ROD: EV_ESP9BOSCHAU57X_VW51.rod
> VCID: 4189134ED0CB684AF3-8014
> Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
> Part No SW: 4H0 907 064 HN HW: 4H0 907 064 HN
> Component: BCM2 2.0 H61 0824
> Revision: 00002001
> Coding: 01BA704E000000000000
> VCID: 7CF7A2BAFFA9C5A2E0-8028
> Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
> Component: J764 ELV MLB H40 0046
> Serial number: 3216000137851013
> Address 08: Auto HVAC (J255) Labels: 4G0-820-043-4Z.clb
> Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
> Component: KLIMA 4 ZONEN H14 0113
> Serial number: 23081600040783
> Coding: 36231178350000
> ASAM Dataset: EV_AirCondiComfoUDS 003008
> ROD: EV_AirCondiComfoUDS_003.rod
> VCID: 63C5F9C66A171A5AC1-8036
> Address 09: Cent. Elect. (J519) Labels: Redir Fail!
> Part No SW: 4H0 907 063 GG HW: 4H0 907 063 AG
> Component: BCM1 2.0 H20 0368
> Revision: 14020001 Serial number: 00001421234801
> Coding:
> 0105C01441349FE2C9014083A0001800CF9DC30A2F0802010000089461001702004000090900
> 00
> VCID: 73E58986D2F78ADAB1-8026
> Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels:
> 1KX-955-119.CLB
> Component: WWS57X 160622 H38 0080
> Serial number: 160701112001
> Coding: 0045F7
> Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels:
> 8U0-955-559.CLB
> Component: G397_RLFS H06 0004
> Serial number: 62161523
> Coding: 02006E
> Subsystem 3 - Part No SW: 4G0 941 531 BG HW: 4G0 941 531 BG
> Component: E1 - LDS H07 0044
> Serial number: 12 07 2016 00001786
> Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
> Component: AQ_Hum_Sensor H01 0005
> Serial number: F1B9424800PAG0MUFU03
> 2 Faults Found:
> 01800 - Light Switch (E1)
> 004 - No Signal/Communication - Intermittent
> Freeze Frame:
> Fault Status: 00100100
> Fault Priority: 3
> Fault Frequency: 1
> Reset counter: 58
> Mileage: 713 km
> Time Indication: 0
> Date: 2016.10.06
> Time: 10:16:40
> 03280 - Switch Position of Light-Switch Knob
> 008 - Implausible Signal - Intermittent
> Freeze Frame:
> Fault Status: 00101000
> Fault Priority: 3
> Fault Frequency: 1
> Reset counter: 58
> Mileage: 713 km
> Time Indication: 0
> Date: 2016.10.06
> Time: 10:45:36
> Address 10: Park/Steer Assist (J791) Labels: None
> Part No SW: 4G0 919 475 H HW: 4H0 919 475 E
> Component: PARKHILFE PLA H06 0080
> Revision: -------- Serial number: 56231620100794
> Coding: B83B10
> ASAM Dataset: EV_EPHVA2CAU64X0000 001014
> ROD: EV_EPHVA2CAU64X0000.rod
> VCID: 366370928905DFF256-8062
> Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
> Part No SW: 4G0 907 561 B HW: 4G0 907 561
> Component: ACC3 H21 0055
> Serial number: 00000000000000
> Coding: 7E04010201
> ASAM Dataset: EV_AdaptCruisContrAU57X 002015
> ROD: EV_AdaptCruisContrAU57X_002.rod
> VCID: 2959ABEE48BB800ACB-807C
> Address 15: Airbags (J234) Labels: 4H0-959-655.clb
> Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
> Component: Airbag10.43 H82 0086
> Revision: -------- Serial number: 003P100AX60Z
> Coding: 30333046313130313137554A305234473853
> ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
> ROD: EV_AirbaAU10BPAAU64X_AU57.rod
> VCID: 3B7561A6B227029AA9-806E
> Crash sensor for side airbag: driver side:
> Serial number: 3575HRB400O5703KF0P6
> Crash sensor for side airbag: front passenger side:
> Serial number: 3585HRB400M5703K712I
> Crash sensor for side airbag: rear: driver side:
> Serial number: 3515JRB4014571NEKH61
> Crash sensor for side airbag: rear: passenger side:
> Serial number: 3525JRB40065744AE1IG
> Crash sensor for front airbag: driver side:
> Serial number: 3554VRB4006574IOOGI/
> Crash sensor for front airbag: front passenger side:
> Serial number: 3564VRB4006574IOMP9$
> Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
> Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
> Component: Lenks.Modul H04 0005
> Revision: -------- Serial number: 90372PG30003B
> Coding: 0000FC
> VCID: 377D7D96860F26FA4D-8062
> Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
> Component: E221 - MFL H08 0010
> Serial number: 20 07 2016 A0040505
> 1 Fault Found:
> 00457 - Control Module for Network (J519)
> 013 - Check DTC Memory - Intermittent
> Freeze Frame:
> Fault Status: 00101101
> Fault Priority: 6
> Fault Frequency: 1
> Reset counter: 58
> Mileage: 713 km
> Time Indication: 0
> Date: 2016.10.06
> Time: 10:18:49
> Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
> Part No SW: 4G8 920 988 D HW: 4G8 920 988 D
> Component: TDieGb Acc H14 0218
> Revision: 11001108 Serial number: 658010816596027
> Coding: 338F05021F532600010100
> ASAM Dataset: EV_RBD4K 004060
> ROD: EV_RBD4K.rod
> Address 19: CAN Gateway (J533) Labels: None
> Part No SW: 4G8 907 468 H HW: 4G8 907 468
> Component: J533--Gateway H15 0096
> Revision: -------- Serial number: 00000002350070
> Coding: C0CD078118
> ASAM Dataset: EV_GatewPkoUDS 002000
> ROD: EV_GatewPkoUDS_002.rod
> VCID: 3D716FBEAC330CAA97-8068
> Battery Monitoring Control Module:
> Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
> Component: J367-BDMHella H10 9070
> Serial number: 7598300804
> Voltage stabilizer:
> Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
> Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
> Component: KLIMA FOND H08 0113
> Serial number: 22081600040912
> Coding: 22
> ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
> ROD: EV_ClimaContrUnitRearUDS_003.rod
> Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
> Part No SW: 4H0 907 440 HW: 4H0 907 440
> Component: STS H06 0030
> Revision: S0H06000 Serial number: 00000000096483
> Coding: 01010101000000000001000202
> VCID: 64C7FADA67191D6238-8030
> Address 34: Level Control (J197) Labels: 4G0-907-553.clb
> Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
> Component: LUFE-DAEMPFER H19 0783
> Coding: 008002
> ASAM Dataset: EV_AirSuspe 003025
> ROD: EV_AirSuspe_VW51.rod
> VCID: 2F6D45F6765FEE3A15-807A
> 1 Fault Found:
> 403200 - Function Shut-Off Active
> C10C8 00 [008] - -
> Intermittent - Confirmed - Tested Since Memory Clear
> Freeze Frame:
> Fault Status: 00000001
> Fault Priority: 6
> Fault Frequency: 5
> Reset counter: 72
> Mileage: 16 km
> Date: 2016.09.22
> Time: 11:18:32
> Address 36: Seat Mem. Drvr (J136) Labels: None
> Part No SW: 4G8 959 760 HW: 4G8 959 760
> Component: MEM-FS H03 0157
> Revision: AA000000 Serial number: 00000213103628
> Coding: 0078130000006001000001010101102030303232203232
> VCID: 77FDBD96C68FE6FA8D-8022
> Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
> Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
> Component: SARA 6D H04 0056
> Revision: -------- Serial number: EJ1BPA820BZRH8
> Shop #: WSC 00000 000 00000
> ASAM Dataset: EV_SARA2 005012
> ROD: EV_SARA2_VW51.rod
> Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
> Part No SW: 4G0 907 566 M HW: 4H0 907 566 F
> Component: SWA Master H08 0070
> Serial number: 0410239592
> Coding: 040312
> ASAM Dataset: EV_LaneChangAssis 001028
> ROD: EV_LaneChangAssis_AU21.rod
> VCID: 39797BAEB81B308ABB-806C
> Lane Change Assistant 2:
> Subsystem 1 - Part No SW: 4G0 907 568 M HW: 4H0 907 568 F
> Component: SWA Slave H08 0070
> Serial number: 0409413292
> Coding: 040312
> Address 42: Door Elect, Driver (J386) Labels: None
> Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
> Component: TSG FA H04 0511
> Coding: 011F56035E21628002080413
> VCID: 4581075ECCE3446ACF-8010
> Address 44: Steering Assist (J500) Labels: None
> Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
> Component: RCevo H54 0202
> Revision: 00000001 Serial number: 0000194620
> Coding: 101101010001
> ASAM Dataset: EV_RCEPS 106007
> ROD: EV_RCEPS_106.rod
> VCID: 3A7B64A2BD1D3B92B2-806E
> Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
> Revision: 00002001 Serial number: 0412812716
> Coding: 017F0622A0B9B882C3200A840C010D470000000000000000000000000000
> Subsystem 1 - Part No: 4G0 951 177 B
> Component: Sensor, DWA 005 0002
> Subsystem 2 - Part No: 1K0 951 605 C
> Component: LIN BACKUP HO H05 1501
> Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
> Component: Dachelektroni H10 0100
> Serial number: 0000000AP00023851075
> Coding: 010000
> Subsystem 4 - Part No SW: 4G8 959 252 A HW: 4G8 959 252
> Component: HSP-SG H11 0031
> Serial number: WA124729000023711745
> 1 Fault Found:
> 03622 - Control Module 2 for Roof Shade
> Freeze Frame:
> Fault Status: 01100100
> Fault Priority: 2
> Fault Frequency: 1
> Reset counter: 3
> Mileage: 137 km
> Time Indication: 0
> Date: 2016.09.25
> Time: 11:12:17
> Address 52: Door Elect, Pass. (J387) Labels: None
> Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
> Component: TSG BF H03 0511
> Coding: 011F56035E21628002080402
> VCID: 46830052F1E54F72C6-8012
> Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
> Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
> Component: EPB-4 H05 0017
> Revision: -------- Serial number: 00000001936082
> ASAM Dataset: EV_ParkiBrake 001029
> ROD: EV_ParkiBrake_AU57.rod
> VCID: 3169438E606BF8CA03-8064
> Address 55: Headlight Range (J745) Labels: 4H4-907-357-V2.clb
> Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
> Component: MxB-ECU 001 0100
> Coding: 05FE02202A170200
> ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
> ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
> VCID: 34674A9A9F79CDE268-8060
> Led Headlamp Powermodule Left:
> Subsystem 1 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels:
> 3D0-941-329.CLB
> Component: LED LeiMo li. H07 7570
> Coding: E02100
> Led Headlamp Powermodule Right:
> Subsystem 2 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels:
> 3D0-941-329.CLB
> Component: LED LeiMo re. H07 7570
> Coding: E02100
> Matrix Headlamp Powermodule 1 Left:
> Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels:
> 3D0-941-329.CLB
> Component: MxB LeiMo li. H03 0031
> Coding: E02100
> Matrix Headlamp Powermodule 1 Right:
> Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels:
> 3D0-941-329.CLB
> Component: MxB LeiMo re. H03 0031
> Coding: E02100
> Address 5F: Information Electr. (J794) Labels: None
> Part No SW: 4G1 035 021 F HW: 4G1 035 021 D
> Component: MU-H-LND-EU 052 0670
> Serial number: A733H0G7504554
> Coding: 017503010000000013111102000A00332F000CE7F1700100DF
> ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
> ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
> VCID: 1D318F3E0CF36CAAB7-8048
> Data medium:
> Subsystem 1 - Part No SW: V03 959 801 FB HW: -----------
> Component: ECE 2016/2017 --- 0153
> Serial number: --------------------
> Display unit 1 for multimedia system:
> Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
> Component: DU8 C7 SV H63 0007
> Serial number: AUZ8Z9GY805Q1Y
> Multimedia Operating Unit:
> Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
> Component: E380 BDT C7 H20 0250
> Serial number: 90349PHC00014
> Compact Disc Database:
> Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
> Component: Gracenote2--- --- 1013
> Address 62: Door, Rear Left (J388) Labels: None
> Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
> Component: TSG HL H03 0511
> Coding: 010F14024021628002080002
> VCID: 49990B6EE0FBA00A2B-801C
> Address 6C: Back-up Cam. (J928) Labels: None
> Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
> Component: TopView H09 0361
> Revision: 11001001 Serial number: 82330JG0189229
> Coding: 0216000001000100000102000000
> ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
> ROD: EV_CamerSysteTopViewAUDI_008.rod
> Address 6D: Trunk Elect. (----) Labels: Redir Fail!
> Part No SW: 4G8 959 107 S HW: 4G8 959 107 H
> Component: HDSG-Modul H14 0049
> Revision: 11014001 Serial number: 196600373
> Coding: 0A3305C002
> ASAM Dataset: EV_HDSGAu573 001022
> ROD: EV_HDSGAu571.rod
> VCID: 4581075EC4E3446ACF-8010
> Address 72: Door, Rear Right (J389) Labels: None
> Component: TSG HR H03 0511
> Address 82: Heads Up Display (J898) Labels: None
> Part No SW: 4G8 919 604 N HW: 4G8 919 604 N
> Component: HeadUpDisplay H09 0306
> Revision: 00000000 Serial number: 00000000000000
> Coding: C60000
> ASAM Dataset: EV_HUDContiC7 001027
> ROD: EV_HUDContiC7.rod
> VCID: 3E7368B2A13517B28E-806A
> Address 85: On Board Cam. (J852) Labels: None
> Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
> Component: DPC-SG H27 0081
> Revision: -------- Serial number: 262130025421000
> Coding: EA160000
> ASAM Dataset: EV_OnBoardCamerDPC 001007
> ROD: EV_OnBoardCamerDPC.rod
> VCID: 2C5752FA4749952230-8078
> Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
> Part No SW: 4G0 907 541 B HW: 4G0 907 541
> Coding: 7E04010201
> ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
> ROD: EV_AdaptCruisContr2AU57X_002.rod
> VCID: 275DADD65EAFB67ADD-8072
> Address 8E: Image Processing (J851) Labels: 4H0-907-107-V2.clb
> Part No SW: 4H0 907 107 H HW: 4H0 907 107
> Component: BV-SG H34 0090
> Serial number: 005002452707167
> Coding: 03C23A181111
> ASAM Dataset: EV_BC7 001001
> ROD: EV_BC7.rod
> Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
> Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
> Component: RGS-VL H16 0080
> Coding: 0066E608031F0376070308004240C2010000
> ASAM Dataset: EV_RGS_L 002004
> ROD: EV_RGS_L.rod
> Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
> Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
> Component: RGS-VR H16 0080
> ASAM Dataset: EV_RGS_R 002004
> ROD: EV_RGS_R.rod
> VCID: 326B4C82656DC3D27A-8066
> Address AC: Reductant Control (J880) Labels: 4G0-907-355.clb
> Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
> Component: SCR-Stg-G2 H10 0013
> Revision: 00000000 Serial number: 161880754
> ASAM Dataset: EV_RDCMA00100 008040
> ROD: EV_RDCMA00100_008.rod
> End-------------------------(Elapsed Time: 06:28)--------------------------
> Regards
> Mr S Patel
