Audi A7 2016 66 Reg Hidden Menu
satpat2
C?ID=255340
Hey folks
Can anyone help with me accessing my hidden menu, tried all combinations but none of them are working, I presume there is a work around with the MIB1/MIB2 but not sure where to start
Here is my log and thank you for the support
> Sunday,16,October,2016,09:25:25:17058
> VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
> VCDS Version: 16.8.3.1 (x64)
> Data version: 20161010 DS267.0
> [url]www.Ross-Tech.com[/url]
> VIN: WAUZZZ4G2HN036*** License Plate:
> Chassis Type: 4G (4G8)
> Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 30 34 36 3B 3C 42 44
> 46 52 53 55 5F 62 6C 6D 72 82 85 8B 8E 8F 90 AC
> VIN: WAUZZZ4G2HN036468 Mileage: 1240km-770miles
> 01-Engine -- Status: OK 0000
> 02-Auto Trans -- Status: OK 0000
> 03-ABS Brakes -- Status: OK 0000
> 04-Steering Angle -- Status: OK 0000
> 05-Acc/Start Auth. -- Status: OK 0000
> 08-Auto HVAC -- Status: OK 0000
> 09-Cent. Elect. -- Status: Malfunction 0010
> 10-Park/Steer Assist -- Status: OK 0000
> 13-Auto Dist. Reg -- Status: OK 0000
> 15-Airbags -- Status: OK 0000
> 16-Steering wheel -- Status: Malfunction 0010
> 17-Instruments -- Status: OK 0000
> 19-CAN Gateway -- Status: OK 0000
> 28-HVAC, Rear -- Status: OK 0000
> 30-Special Function II -- Status: OK 0000
> 34-Level Control -- Status: Malfunction 0010
> 36-Seat Mem. Drvr -- Status: OK 0000
> 3B-Sensor Elect. -- Status: OK 0000
> 3C-Lane Change -- Status: OK 0000
> 42-Door Elect, Driver -- Status: OK 0000
> 44-Steering Assist -- Status: OK 0000
> 46-Central Conv. -- Status: Malfunction 0010
> 52-Door Elect, Pass. -- Status: OK 0000
> 53-Parking Brake -- Status: OK 0000
> 55-Headlight Range -- Status: OK 0000
> 5F-Information Electr. -- Status: OK 0000
> 62-Door, Rear Left -- Status: OK 0000
> 6C-Back-up Cam. -- Status: OK 0000
> 6D-Trunk Elect. -- Status: OK 0000
> 72-Door, Rear Right -- Status: OK 0000
> 82-Heads Up Display -- Status: OK 0000
> 85-On Board Cam. -- Status: OK 0000
> 8B-Adaptive Cruise 2 -- Status: OK 0000
> 8E-Image Processing -- Status: OK 0000
> 8F-Pretens. Frt Left -- Status: OK 0000
> 90-Pretens. Frt Right -- Status: OK 0000
> AC-Reductant Control -- Status: OK 0000
> Address 01: Engine (J623-CZVA) Labels: None
> Part No SW: 4G2 907 311 B HW: 4G2 907 311 A
> Component: 3.0TDI MD1 H24 0003
> Revision: C4H24---
> Coding: 1A254012046601030800
> Shop #: WSC 02391 785 00200
> ASAM Dataset: EV_ECM30TDI0114G2907311B 001007
> ROD: EV_ECM30TDI0114G2907311B.rod
> VCID: 2447BADA2F995D62F8-8070
> No fault code found.
> Readiness: 0 0 0 0 0
> Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
> Part No SW: 4G0 927 166 K HW: 0B5 927 156 K
> Component: 0B5 30 TDIRdW H03 0006
> Revision: --H03---
> Coding: 100001
> ASAM Dataset: EV_TCMDL501021 001022
> ROD: EV_TCMDL501021_VW51.rod
> VCID: 3561779E9403D4EA5F-8060
> Address 03: ABS Brakes (J104) Labels: Redir Fail!
> Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
> Component: ESP9 Premium H01 0530
> Revision: -------- Serial number: --------------
> Coding: 17A6DE4BE8657BD29B00
> ASAM Dataset: EV_ESP9BOSCHAU57X 004018
> ROD: EV_ESP9BOSCHAU57X_VW51.rod
> VCID: 4189134ED0CB684AF3-8014
> Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
> Part No SW: 4H0 907 064 HN HW: 4H0 907 064 HN
> Component: BCM2 2.0 H61 0824
> Revision: 00002001
> Coding: 01BA704E000000000000
> VCID: 7CF7A2BAFFA9C5A2E0-8028
> Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
> Component: J764 ELV MLB H40 0046
> Serial number: 3216000137851013
> Address 08: Auto HVAC (J255) Labels: 4G0-820-043-4Z.clb
> Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
> Component: KLIMA 4 ZONEN H14 0113
> Serial number: 23081600040783
> Coding: 36231178350000
> ASAM Dataset: EV_AirCondiComfoUDS 003008
> ROD: EV_AirCondiComfoUDS_003.rod
> VCID: 63C5F9C66A171A5AC1-8036
> Address 09: Cent. Elect. (J519) Labels: Redir Fail!
> Part No SW: 4H0 907 063 GG HW: 4H0 907 063 AG
> Component: BCM1 2.0 H20 0368
> Revision: 14020001 Serial number: 00001421234801
> Coding:
> 0105C01441349FE2C9014083A0001800CF9DC30A2F0802010000089461001702004000090900
> 00
> VCID: 73E58986D2F78ADAB1-8026
> Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels:
> 1KX-955-119.CLB
> Component: WWS57X 160622 H38 0080
> Serial number: 160701112001
> Coding: 0045F7
> Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels:
> 8U0-955-559.CLB
> Component: G397_RLFS H06 0004
> Serial number: 62161523
> Coding: 02006E
> Subsystem 3 - Part No SW: 4G0 941 531 BG HW: 4G0 941 531 BG
> Component: E1 - LDS H07 0044
> Serial number: 12 07 2016 00001786
> Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
> Component: AQ_Hum_Sensor H01 0005
> Serial number: F1B9424800PAG0MUFU03
> 2 Faults Found:
> 01800 - Light Switch (E1)
> 004 - No Signal/Communication - Intermittent
> Freeze Frame:
> Fault Status: 00100100
> Fault Priority: 3
> Fault Frequency: 1
> Reset counter: 58
> Mileage: 713 km
> Time Indication: 0
> Date: 2016.10.06
> Time: 10:16:40
> 03280 - Switch Position of Light-Switch Knob
> 008 - Implausible Signal - Intermittent
> Freeze Frame:
> Fault Status: 00101000
> Fault Priority: 3
> Fault Frequency: 1
> Reset counter: 58
> Mileage: 713 km
> Time Indication: 0
> Date: 2016.10.06
> Time: 10:45:36
> Address 10: Park/Steer Assist (J791) Labels: None
> Part No SW: 4G0 919 475 H HW: 4H0 919 475 E
> Component: PARKHILFE PLA H06 0080
> Revision: -------- Serial number: 56231620100794
> Coding: B83B10
> ASAM Dataset: EV_EPHVA2CAU64X0000 001014
> ROD: EV_EPHVA2CAU64X0000.rod
> VCID: 366370928905DFF256-8062
> Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
> Part No SW: 4G0 907 561 B HW: 4G0 907 561
> Component: ACC3 H21 0055
> Serial number: 00000000000000
> Coding: 7E04010201
> ASAM Dataset: EV_AdaptCruisContrAU57X 002015
> ROD: EV_AdaptCruisContrAU57X_002.rod
> VCID: 2959ABEE48BB800ACB-807C
> Address 15: Airbags (J234) Labels: 4H0-959-655.clb
> Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
> Component: Airbag10.43 H82 0086
> Revision: -------- Serial number: 003P100AX60Z
> Coding: 30333046313130313137554A305234473853
> ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
> ROD: EV_AirbaAU10BPAAU64X_AU57.rod
> VCID: 3B7561A6B227029AA9-806E
> Crash sensor for side airbag: driver side:
> Serial number: 3575HRB400O5703KF0P6
> Crash sensor for side airbag: front passenger side:
> Serial number: 3585HRB400M5703K712I
> Crash sensor for side airbag: rear: driver side:
> Serial number: 3515JRB4014571NEKH61
> Crash sensor for side airbag: rear: passenger side:
> Serial number: 3525JRB40065744AE1IG
> Crash sensor for front airbag: driver side:
> Serial number: 3554VRB4006574IOOGI/
> Crash sensor for front airbag: front passenger side:
> Serial number: 3564VRB4006574IOMP9$
> Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
> Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
> Component: Lenks.Modul H04 0005
> Revision: -------- Serial number: 90372PG30003B
> Coding: 0000FC
> VCID: 377D7D96860F26FA4D-8062
> Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
> Component: E221 - MFL H08 0010
> Serial number: 20 07 2016 A0040505
> 1 Fault Found:
> 00457 - Control Module for Network (J519)
> 013 - Check DTC Memory - Intermittent
> Freeze Frame:
> Fault Status: 00101101
> Fault Priority: 6
> Fault Frequency: 1
> Reset counter: 58
> Mileage: 713 km
> Time Indication: 0
> Date: 2016.10.06
> Time: 10:18:49
> Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
> Part No SW: 4G8 920 988 D HW: 4G8 920 988 D
> Component: TDieGb Acc H14 0218
> Revision: 11001108 Serial number: 658010816596027
> Coding: 338F05021F532600010100
> ASAM Dataset: EV_RBD4K 004060
> ROD: EV_RBD4K.rod
> Address 19: CAN Gateway (J533) Labels: None
> Part No SW: 4G8 907 468 H HW: 4G8 907 468
> Component: J533--Gateway H15 0096
> Revision: -------- Serial number: 00000002350070
> Coding: C0CD078118
> ASAM Dataset: EV_GatewPkoUDS 002000
> ROD: EV_GatewPkoUDS_002.rod
> VCID: 3D716FBEAC330CAA97-8068
> Battery Monitoring Control Module:
> Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
> Component: J367-BDMHella H10 9070
> Serial number: 7598300804
> Voltage stabilizer:
> Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
> Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
> Component: KLIMA FOND H08 0113
> Serial number: 22081600040912
> Coding: 22
> ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
> ROD: EV_ClimaContrUnitRearUDS_003.rod
> Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
> Part No SW: 4H0 907 440 HW: 4H0 907 440
> Component: STS H06 0030
> Revision: S0H06000 Serial number: 00000000096483
> Coding: 01010101000000000001000202
> VCID: 64C7FADA67191D6238-8030
> Address 34: Level Control (J197) Labels: 4G0-907-553.clb
> Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
> Component: LUFE-DAEMPFER H19 0783
> Coding: 008002
> ASAM Dataset: EV_AirSuspe 003025
> ROD: EV_AirSuspe_VW51.rod
> VCID: 2F6D45F6765FEE3A15-807A
> 1 Fault Found:
> 403200 - Function Shut-Off Active
> C10C8 00 [008] - -
> Intermittent - Confirmed - Tested Since Memory Clear
> Freeze Frame:
> Fault Status: 00000001
> Fault Priority: 6
> Fault Frequency: 5
> Reset counter: 72
> Mileage: 16 km
> Date: 2016.09.22
> Time: 11:18:32
> Address 36: Seat Mem. Drvr (J136) Labels: None
> Part No SW: 4G8 959 760 HW: 4G8 959 760
> Component: MEM-FS H03 0157
> Revision: AA000000 Serial number: 00000213103628
> Coding: 0078130000006001000001010101102030303232203232
> VCID: 77FDBD96C68FE6FA8D-8022
> Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
> Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
> Component: SARA 6D H04 0056
> Revision: -------- Serial number: EJ1BPA820BZRH8
> Shop #: WSC 00000 000 00000
> ASAM Dataset: EV_SARA2 005012
> ROD: EV_SARA2_VW51.rod
> Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
> Part No SW: 4G0 907 566 M HW: 4H0 907 566 F
> Component: SWA Master H08 0070
> Serial number: 0410239592
> Coding: 040312
> ASAM Dataset: EV_LaneChangAssis 001028
> ROD: EV_LaneChangAssis_AU21.rod
> VCID: 39797BAEB81B308ABB-806C
> Lane Change Assistant 2:
> Subsystem 1 - Part No SW: 4G0 907 568 M HW: 4H0 907 568 F
> Component: SWA Slave H08 0070
> Serial number: 0409413292
> Coding: 040312
> Address 42: Door Elect, Driver (J386) Labels: None
> Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
> Component: TSG FA H04 0511
> Coding: 011F56035E21628002080413
> VCID: 4581075ECCE3446ACF-8010
> Address 44: Steering Assist (J500) Labels: None
> Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
> Component: RCevo H54 0202
> Revision: 00000001 Serial number: 0000194620
> Coding: 101101010001
> ASAM Dataset: EV_RCEPS 106007
> ROD: EV_RCEPS_106.rod
> VCID: 3A7B64A2BD1D3B92B2-806E
> Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
> Revision: 00002001 Serial number: 0412812716
> Coding: 017F0622A0B9B882C3200A840C010D470000000000000000000000000000
> Subsystem 1 - Part No: 4G0 951 177 B
> Component: Sensor, DWA 005 0002
> Subsystem 2 - Part No: 1K0 951 605 C
> Component: LIN BACKUP HO H05 1501
> Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
> Component: Dachelektroni H10 0100
> Serial number: 0000000AP00023851075
> Coding: 010000
> Subsystem 4 - Part No SW: 4G8 959 252 A HW: 4G8 959 252
> Component: HSP-SG H11 0031
> Serial number: WA124729000023711745
> 1 Fault Found:
> 03622 - Control Module 2 for Roof Shade
> Freeze Frame:
> Fault Status: 01100100
> Fault Priority: 2
> Fault Frequency: 1
> Reset counter: 3
> Mileage: 137 km
> Time Indication: 0
> Date: 2016.09.25
> Time: 11:12:17
> Address 52: Door Elect, Pass. (J387) Labels: None
> Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
> Component: TSG BF H03 0511
> Coding: 011F56035E21628002080402
> VCID: 46830052F1E54F72C6-8012
> Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
> Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
> Component: EPB-4 H05 0017
> Revision: -------- Serial number: 00000001936082
> ASAM Dataset: EV_ParkiBrake 001029
> ROD: EV_ParkiBrake_AU57.rod
> VCID: 3169438E606BF8CA03-8064
> Address 55: Headlight Range (J745) Labels: 4H4-907-357-V2.clb
> Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
> Component: MxB-ECU 001 0100
> Coding: 05FE02202A170200
> ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
> ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
> VCID: 34674A9A9F79CDE268-8060
> Led Headlamp Powermodule Left:
> Subsystem 1 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels:
> 3D0-941-329.CLB
> Component: LED LeiMo li. H07 7570
> Coding: E02100
> Led Headlamp Powermodule Right:
> Subsystem 2 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels:
> 3D0-941-329.CLB
> Component: LED LeiMo re. H07 7570
> Coding: E02100
> Matrix Headlamp Powermodule 1 Left:
> Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels:
> 3D0-941-329.CLB
> Component: MxB LeiMo li. H03 0031
> Coding: E02100
> Matrix Headlamp Powermodule 1 Right:
> Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels:
> 3D0-941-329.CLB
> Component: MxB LeiMo re. H03 0031
> Coding: E02100
> Address 5F: Information Electr. (J794) Labels: None
> Part No SW: 4G1 035 021 F HW: 4G1 035 021 D
> Component: MU-H-LND-EU 052 0670
> Serial number: A733H0G7504554
> Coding: 017503010000000013111102000A00332F000CE7F1700100DF
> ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
> ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
> VCID: 1D318F3E0CF36CAAB7-8048
> Data medium:
> Subsystem 1 - Part No SW: V03 959 801 FB HW: -----------
> Component: ECE 2016/2017 --- 0153
> Serial number: --------------------
> Display unit 1 for multimedia system:
> Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
> Component: DU8 C7 SV H63 0007
> Serial number: AUZ8Z9GY805Q1Y
> Multimedia Operating Unit:
> Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
> Component: E380 BDT C7 H20 0250
> Serial number: 90349PHC00014
> Compact Disc Database:
> Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
> Component: Gracenote2--- --- 1013
> Address 62: Door, Rear Left (J388) Labels: None
> Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
> Component: TSG HL H03 0511
> Coding: 010F14024021628002080002
> VCID: 49990B6EE0FBA00A2B-801C
> Address 6C: Back-up Cam. (J928) Labels: None
> Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
> Component: TopView H09 0361
> Revision: 11001001 Serial number: 82330JG0189229
> Coding: 0216000001000100000102000000
> ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
> ROD: EV_CamerSysteTopViewAUDI_008.rod
> Address 6D: Trunk Elect. (----) Labels: Redir Fail!
> Part No SW: 4G8 959 107 S HW: 4G8 959 107 H
> Component: HDSG-Modul H14 0049
> Revision: 11014001 Serial number: 196600373
> Coding: 0A3305C002
> ASAM Dataset: EV_HDSGAu573 001022
> ROD: EV_HDSGAu571.rod
> VCID: 4581075EC4E3446ACF-8010
> Address 72: Door, Rear Right (J389) Labels: None
> Component: TSG HR H03 0511
> Address 82: Heads Up Display (J898) Labels: None
> Part No SW: 4G8 919 604 N HW: 4G8 919 604 N
> Component: HeadUpDisplay H09 0306
> Revision: 00000000 Serial number: 00000000000000
> Coding: C60000
> ASAM Dataset: EV_HUDContiC7 001027
> ROD: EV_HUDContiC7.rod
> VCID: 3E7368B2A13517B28E-806A
> Address 85: On Board Cam. (J852) Labels: None
> Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
> Component: DPC-SG H27 0081
> Revision: -------- Serial number: 262130025421000
> Coding: EA160000
> ASAM Dataset: EV_OnBoardCamerDPC 001007
> ROD: EV_OnBoardCamerDPC.rod
> VCID: 2C5752FA4749952230-8078
> Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
> Part No SW: 4G0 907 541 B HW: 4G0 907 541
> Coding: 7E04010201
> ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
> ROD: EV_AdaptCruisContr2AU57X_002.rod
> VCID: 275DADD65EAFB67ADD-8072
> Address 8E: Image Processing (J851) Labels: 4H0-907-107-V2.clb
> Part No SW: 4H0 907 107 H HW: 4H0 907 107
> Component: BV-SG H34 0090
> Serial number: 005002452707167
> Coding: 03C23A181111
> ASAM Dataset: EV_BC7 001001
> ROD: EV_BC7.rod
> Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
> Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
> Component: RGS-VL H16 0080
> Coding: 0066E608031F0376070308004240C2010000
> ASAM Dataset: EV_RGS_L 002004
> ROD: EV_RGS_L.rod
> Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
> Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
> Component: RGS-VR H16 0080
> ASAM Dataset: EV_RGS_R 002004
> ROD: EV_RGS_R.rod
> VCID: 326B4C82656DC3D27A-8066
> Address AC: Reductant Control (J880) Labels: 4G0-907-355.clb
> Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
> Component: SCR-Stg-G2 H10 0013
> Revision: 00000000 Serial number: 161880754
> ASAM Dataset: EV_RDCMA00100 008040
> ROD: EV_RDCMA00100_008.rod
> End-------------------------(Elapsed Time: 06:28)--------------------------
> Regards
> Mr S Patel
rlarsen
Copenhagen, Denmark
C?ID=78998
No more possible with the VCDS cable.
satpat2
C?ID=255340
Hey Rlarsen
I thought there was a work around via MIB & MIB2, is there another way of accessing this ?
Thanks for your time
rlarsen
Copenhagen, Denmark
C?ID=78998
United States
satpat2,
I sent you a test file via e-mail.
-Dana
satpat2
C?ID=255340
I have ran an autoscan, hope this helps
Thursday,30,March,2017,14:35:26:17058
VCDS Version: 17.3.1.0 (x64)
Data version: 20170320 DS270.2
VIN: xxxx  License Plate: xxxx
VIN: xxxx   Mileage: 6923km-4301miles
   Revision: C4H24---
   VCID: 2447BADA2F995D60D9-8070
   Revision: --H03---
   Coding: 100001
   ROD: EV_TCMDL501021.rod
   VCID: 3561779E9403D4E87E-8060
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 4189134ED0CB6848D2-8014
   VCID: 7CF7A2BAFFA9C5A0C1-8028
   VCID: 63C5F9C66A171A58E0-8036
   Coding: 0105C01441349FE2C9014083A0001800CF9DC30A2F080201000008946100170200400009090000
   VCID: 73E58986D2F78AD890-8026
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Coding: 0045F7
   Coding: 02006E
   Coding: B83B10
   ROD: EV_EPHVA2CAU57X0000.rod
   VCID: 366370928905DFF077-8062
   Coding: 7E04010201
   VCID: 2959ABEE48BB8008EA-807C
   VCID: 3B7561A6B227029888-806E
   Coding: 0000FC
   VCID: 377D7D96860F26F86C-8062
   ROD: EV_RBD4K.rod
   Coding: C0CD078118
   VCID: 3D716FBEAC330CA8B6-8068
   Voltage stabilizer:
          U140B 00 [008] - -
                    Reset counter: 203
                    Mileage: 6337 km
                    Date: 2017.03.14
                    Time: 17:08:52
                    Voltage terminal 30: 11.3 V
                    Voltage terminal 15: 11.2 V
                    Control Module temperature: 27 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 1
   Coding: 22
   VCID: 64C7FADA67191D6019-8030
   Coding: 008002
   VCID: 2F6D45F6765FEE3834-807A
   VCID: 77FDBD96C68FE6F8AC-8022
   ROD: EV_SARA2.rod
   Coding: 040312
   VCID: 39797BAEB81B30889A-806C
   Coding: 040312
   VCID: 4581075ECCE34468EE-8010
Address 44: Steering Assist (J500)       Labels: 4G0-909-144.clb
   ROD: EV_RCEPS_106_AU57.rod
   VCID: 3A7B64A2BD1D3B9093-806E
   Coding: 017F0622A0B9B882C3A00A840C010D470000000000000000000000000000
                    Reset counter: 3
                    Mileage: 137 km
                    Date: 2016.09.25
                    Time: 11:12:17
   VCID: 46830052F1E54F70E7-8012
   VCID: 3169438E606BF8C822-8064
   VCID: 34674A9A9F79CDE049-8060
   Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Coding: E02100
   Subsystem 2 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Coding: E02100
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Coding: E02100
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Coding: E02100
   VCID: 1D318F3E0CF36CA896-8048
   Subsystem 1 - Part No SW: V03 959 801 FC    HW: -----------
   Component: ECE 2017  --- 0157
   VCID: 49990B6EE0FBA0080A-801C
   Coding: 0A3305C002
   VCID: 4581075EC4E34468EE-8010
   Coding: C60000
   ROD: EV_HUDContiC7_VW51.rod
   VCID: 3E7368B2A13517B0AF-806A
   Coding: EA160000
   VCID: 2C5752FA4749952011-8078
   Coding: 7E04010201
   VCID: 275DADD65EAFB678FC-8072
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
   VCID: 326B4C82656DC3D05B-8066
End-------------------------(Elapsed Time: 06:29)--------------------------
My auto window closure has not worked since I had the vehicle, do you know why eg: hold down lock or unlock for windows to open or close, I can't seem to figure this out even though searching a lot and following the tutorials
satpat2
C?ID=255340
Hey Folks
Made some progress, I have cleared all faults but one, need a little push in the right direction to fix this, also no more progress on the hidden menu, loosing my mind with accessing this menu even though developer mode has been activated
Thursday,30,March,2017,18:52:57:17058
VCDS Version: 17.1.3.0 (x64)
VIN:    License Plate:
VIN:    Mileage: 6923km-4301miles
   Revision: C4H24---
   VCID: 2447BADA2F995D61AD-8070
   Revision: --H03---
   Coding: 100001
   VCID: 3561779E9403D4E90A-8060
   VCID: 4189134ED0CB6849A6-8014
   VCID: 7CF7A2BAFFA9C5A1B5-8028
   VCID: 63C5F9C66A171A5994-8036
   VCID: 73E58986D2F78AD9E4-8026
   Coding: 0045F7
   Coding: 02006E
   Coding: B83B10
   VCID: 366370928905DFF103-8062
   Coding: 7E04010201
   VCID: 2959ABEE48BB80099E-807C
   VCID: 3B7561A6B2270299FC-806E
   Coding: 0000FC
   VCID: 377D7D96860F26F918-8062
   ROD: EV_RBD4K.rod
   Coding: C0CD078118
   VCID: 3D716FBEAC330CA9C2-8068
   Voltage stabilizer:
   Coding: 22
   VCID: 64C7FADA67191D616D-8030
   Coding: 008002
   VCID: 2F6D45F6765FEE3940-807A
   VCID: 77FDBD96C68FE6F9D8-8022
   Coding: 040312
   VCID: 39797BAEB81B3089EE-806C
   Coding: 040312
   VCID: 4581075ECCE344699A-8010
   VCID: 3A7B64A2BD1D3B91E7-806E
   Coding: 017F1622A0B9B882C3A00A840C010D470000000000000000000000000000
                    Reset counter: 183
                    Mileage: 6923 km
                    Date: 2017.03.30
                    Time: 18:30:09
   VCID: 46830052F1E54F7193-8012
   VCID: 3169438E606BF8C956-8064
   VCID: 34674A9A9F79CDE13D-8060
   Coding: E02100
   Coding: E02100
   Coding: E02100
   Coding: E02100
Address 5F: Information Electr. (J794)       Labels: User\4G1-035-021.clb
   VCID: 1D318F3E0CF36CA9E2-8048
   VCID: 49990B6EE0FBA0097E-801C
   Coding: 0A3305C002
   VCID: 4581075EC4E344699A-8010
   Coding: C60000
   VCID: 3E7368B2A13517B1DB-806A
   Coding: EA160000
   VCID: 2C5752FA4749952165-8078
   Coding: 7E04010201
   VCID: 275DADD65EAFB67988-8072
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
   VCID: 326B4C82656DC3D12F-8066
End-------------------------(Elapsed Time: 06:20)--------------------------
United States
FWIW I could not locate another scan in our e-mail database with that exact Coding in Address 42 or 52. I'm not saying it is incorrect - but I am wondering if that was truly the factory condition. Did you buy this car new or used?
Either way, please makes sure MVB 002 shows the Auto run positions in each address (42 and 52) the next time you are connected to the car.
002,1,WR-Button (E40),Drivers Door,Range: Auto Open/Auto Close/Manual Open/Manual Close/Not Oper.
002,2,WR-Button (E81),Passenger Door,Range: Auto Open/Auto Close/Manual Open/Manual Close/Not Oper.
002,3,WR-Button (E53),Rear Left Door,Range: Auto Open/Auto Close/Manual Open/Manual Close/Not Oper.
002,4,WR-Button (E55),Rear Right Door,Range: Auto Open/Auto Close/Manual Open/Manual Close/Not Oper.
VW data coding note. I think Byte 02, bit 4 = Automatic Run active but that's already enabled
satpat2
C?ID=255340
I bought the car brand new, I have sent you an email with the first scan since I bought it and the current scan, hope this helps, I will re do a scan tomorrow, thank you for your help
satpat2
C?ID=255340
Here is my new auto scan
Friday,31,March,2017,10:07:10:17058
VIN:    License Plate:
VIN:    Mileage: 6975km-4334miles
   Revision: C4H24---
   Revision: --H03---
   Coding: 100001
   Coding: 0045F7
   Coding: 02006E
   Coding: B83B10
   Coding: 7E04010201
   Coding: 0000FC
   ROD: EV_RBD4K.rod
   Coding: C0CD078118
   Voltage stabilizer:
   Coding: 22
   Coding: 008002
   Coding: 040312
   Coding: 040312
                    Reset counter: 183
                    Mileage: 6975 km
                    Date: 2017.03.31
                    Time: 09:26:39
   Coding: E02100
   Coding: E02100
   Coding: E02100
   Coding: E02100
   Coding: 0A3305C002
   Coding: C60000
   Coding: EA160000
   Coding: 7E04010201
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
End---------------------(Elapsed Time: 06:25, udsna)-----------------------
satpat2
C?ID=255340
VIN:    License Plate:
   Revision: C4H24---
   Revision: --H03---
   Coding: 100001
   Coding: 0045F7
   Coding: 02006E
   Coding: B83B10
   Coding: 7E04010201
   Coding: 0000FC
   ROD: EV_RBD4K.rod
   Coding: C0CD078118
   Voltage stabilizer:
   Coding: 22
   Coding: 008002
   Coding: 040312
   Coding: 040312
                    Reset counter: 183
                    Mileage: 6975 km
                    Date: 2017.03.31
                    Time: 09:26:39
   Coding: E02100
   Coding: E02100
   Coding: E02100
   Coding: E02100
   Coding: 0A3305C002
   Coding: C60000
   Coding: EA160000
   Coding: 7E04010201
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
   ROD: EV_RGS_R.rod
Hey UWE
Did I forget to remove something, what is code tags ?
Any luck with this ?
rlarsen
Copenhagen, Denmark
C?ID=78998
You probably forgot to put the
 tags around - this tag is available in the advanced edit mode
CODE tags are explained here, just under the video.
satpat2
C?ID=255340
Thanks UWE, I shall do this in the future
United States
We might want to move the Auto run window discussion to another thread in the car repair sub-forum but please let us know what MVB 002 showed in each of those door modules. Using [Add to Log] will allow you to paste the info here and we just need to make sure all positions including Auto register in 42 and 52.
While you are in each module I suppose Sequential Output Tests couldn't hurt so the windows can roll up/down through the entire range of motion just in case that de-confuses one tough functions.
I did not spot anything entirely obvious based on the original and current condition scans but I would be tempted to paste the original 46 module coding back in to rule out a potential conflict with any of the tweaks. For example, I know Byte 02, Bit 4 Comfort Operation: Window Regulator Button active won't cause harm in a VW but I don't know if it could conflict in this car type.
Original condition 46:
   Coding: 013B0622A0B9B880C3200A840C010D470000000000000000000000000000
   VCID: 7CF7A2BAFFA9C5A2FF-8028
satpat2
C?ID=255340
Hey Dana
here is the Measuring Blocks log for 42 and 52, carried out the output test and window going down and up on 42 and 52 as well as folding door mirrors
Wednesday,05,April,2017,10:14:14:17058
Mileage:    Repair Order: Log 42
                Address 42: Door Elect, Driver  (4G8 959 793 H)
10:13:59 Group 001
  00000000  Bin. Bits
  00000000  Bin. Bits
      0101  Bin. Bits
  12.00 V  Voltage
10:13:59 Group 002
  Not Oper.
  Not Oper.
  Not Oper.
  Not Oper.
10:13:59 Group 003
  0.0 %  Load
  11.0°C  Temperature
      1101  Bin. Bits
  Still
Wednesday,05,April,2017,10:23:08:17058
Mileage:    Repair Order: 52
                Address 52: Door Elect, Pass.  (4G8 959 792 J)
10:23:02 Group 001
  00000000  Bin. Bits
  00000000  Bin. Bits
      0101  Bin. Bits
  12.16 V  Voltage
10:23:02 Group 002
  Not Oper.
  Not Installed
  Not Installed
  Not Installed
10:23:02 Group 003
  0.0 %  Load
  10.0°C  Temperature
      1101  Bin. Bits
  Still
satpat2
C?ID=255340
I don't think I know how to do what your asking as I haven't done this, can you please help me so I get the info you require, been through a few options but I don't think it's right
satpat2
C?ID=255340
I think this info is correct but please correct me if it isn't
42 - MVB
MVB 002 - Not Oper. - Not Oper. - Not Oper. - Not Oper.
52 - MVB
MVB 002 - Not Oper. - Not Installed - Not Installed - Not Installed
5F - MVB
Wednesday,05,April,2017,10:49:41:17058
VCDS Version: Release 17.1.3 (x64) Running on Windows 8 x64
                Address 5F: Information Electr.       Labels: User\4G1-035-021.clb
Control Module Part Number: 4G1 035 021 F    HW: 4G1 035 021 D
  Component and/or Version: MU-H-LND-EU   052 0670
           Software Coding: 017503010000000013111102000A00332F000CE7F1700100DF
            Work Shop Code: WSC 02391 785 00200
              ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115 (AU57)
7181 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 183
                    Mileage: 6976 km
                    Date: 2017.04.01
                    Time: 07:19:08
                    Voltage terminal 30: 14.2 V
                    BAP-BAP_Function_ID: 02
I don't have a roof shade installed ?
Also rescanned and 5f is now an issue, only thing I have done in 5F is the file you asked to put into users file and change developer mode to activated
satpat2
C?ID=255340
Tried a rescan with the 5F mod not activated and still same 5F issue, has there been a mod for the developer/hidden menu yet folks or anything I do to help to make this mod eg from my vehicle
