2014 S4 Avant
Dukedesmo
C?ID=288946
Newcomer to VCDS so just learning. First used yesterday for a scan, hopefully doing this right?
Tuesday,15,November,2016,12:38:47:24986
VCDS Version: 16.8.3.1
VIN: WAUZZZ8K7EA150192   License Plate:
Mileage: 27250km-16932mi   Repair Order:
Chassis Type: 8K (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 30 36 42 44 46 47 52 53 56 5F
          62 6D 72 A9
VIN: WAUZZZ8K7EA150192   Mileage: 27250km-16932miles
Address 01: Engine (J623-CGWC)       Labels: 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 D    HW: 4H0 907 551
   Component: 3.0l V6 TFSIH07 0004
   Revision: --H07---
   Coding: 12250034052701020800
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551D 001004
   ROD: EV_ECM30TFS0218K5907551D.rod
   VCID: 377CA0AB8E2C1EFA4D-8062
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 8K5 927 156 B    HW: 0B5 927 156 K
   Component: 0B5 30TFSIRdW H03 0003
   Revision: --H03---
   Shop #: WSC 04742 780 00200
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021_VW51.rod
   VCID: 387EA3978332118244-806C
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 291DCC01
   Shop #: WSC 06335 000 00000
   VCID: 09181653A058D80AEB-805C
   Part No SW: 8K0 907 064 JG    HW: 8K0 907 064 JG
   Component: BCM2 2.0      H14 0650
   Coding: 01B24040000000000000
   VCID: 7EF2758FE996EFB2CE-802A
   Subsystem 1 - Part No SW: 8K0 959 754 BH    HW: 8K0 959 754 BH
   Serial number: 0514000046829005
   Serial number: 0214000068278002
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01100420140302
   Coding: 6624028000
   VCID: 78FE6397CBB2D18284-802C
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000789946701
   Coding: 260000108034AFC00081404300001D0D0F1D470A27090201000008004400030100000024000000
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 010414  H06 0080
   Serial number: SWF14044015610
   Coding: 00FD11
   Serial number: 22487512
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000104144832
   Serial number: FA780227000000000001
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KFDC0WUTP
   Coding: 30534435363030303030554A3052384B3053
   Shop #: WSC 60782 001 1048576
   VCID: 489ED357F3D2610234-801C
   Serial number: 6334MSME443A333AD
   Serial number: 6344MSME443C6E75T
   Serial number: 6352QSME1E400648E
   Serial number: 6362QSME1A401B6EP
   Serial number: 63732SME40404A66X
   Serial number: 63832SME4F400F689
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NDE001IC
   Coding: 000037
   VCID: 489ED357FBD2610234-801C
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 982 T    HW: 8K0 920 982 T
   Component: KOMBIINSTR.   H35 0564
   Revision: 00100000    Serial number: ZAE62M34F
   Coding: 33A7110003012600010000
   VCID: 4580DA63CCC07C6ACF-8010
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y143310158
   Coding: 80CF07FF00
   VCID: 4A9AE95FE5DE931222-801E
   Serial number: 9802233103
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 14099003849011200410
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0020
   Revision: S0H04000    Serial number: 00000000084090
   Coding: 01010101000000000001000102
   VCID: 2D5082C37470A42A27-8078
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000097259421
   Coding: 01781300000000000000
   VCID: 3B74BC9BBA043A9AA9-806E
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000098884238
   Coding: 011C02205E21410001
   VCID: 4FACF84B1EBCB63A75-801A
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0003457337
   Coding: 100000000001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3560AAA39420ECEA5F-8060
   Revision: 00002001    Serial number: 0332027708
   Coding: 013B0622A0B938948330023680000047
   Subsystem 3 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J245 PS151  H08 0043
   Subsystem 4 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J394 PS240  H08 0043
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Revision: 00005001    Serial number: 94813028507104
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000098720192
   VCID: 4E92E54F19B6BF327E-801A
   Component: EPB-4         H01 0005
   Revision: --------    Serial number: 20000000431915
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3A7AB99FBD3E0392B2-806E
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109D20E7915856
   Coding: 010103010000000001
   VCID: 285E73D75B928102D4-807C
   Part No SW: 8R2 035 666 E    HW: 8R2 035 666 C
   Component: H-BN-EU       H47 0793
   Revision: --------    Serial number: 206DZ0E7560780
   Coding: 110101010206A1ED41808B5E00000403E40100020000000000
   Subsystem 1 - Part No: 8R0 060 884 BK
   Component: EUR 2014  1703
   Component: DU7 High  H42 0104
   Serial number: A130DI0E3000809
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000001824649
   Component: CD-Database  5571
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000098922402
   Coding: 010C02204021210001
   VCID: 4682DD6FF1C67772C6-8012
   Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
   Component: J605  Master  H53 0330
   Revision: --------    Serial number: 8K9827851C
   VCID: 3E72B58FA9162FB28E-806A
   Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
   Component: J756  Slave  H53 0330
   Serial number: 8K9827852C
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000098919842
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 140301200807
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: 72EA51BFA5CEBBD2BA-8026
End-------------------------(Elapsed Time: 04:42)--------------------------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
OK, do not worry, when Ross Team proceed, You are become "green". Your's nick-name will be in green color. ;)
