2002 Passat 4.0L BDP
MattF-MN
C?ID=134881
  Wednesday,16,November,2016,08:48:25:48394
VCDS Version: 16.8.3.1  HEX-NET CB: 0.4323.4
VIN: WVWUK63B12P302399   License Plate:
Mileage: 194910km-121111mi   Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWUK63B12P302399   Mileage: 194910km-121111miles
Address 01: Engine        Labels: 07D-906-018-BDP.lbl
   Part No: 07D 906 018 E
   Component:  B5S-4.0L-AG-LEVG   5088
   Coding: 00173
   Shop #: WSC 02402
   VCID: 281C37DDCA4E1102D4-5184
   WVWUK63B12P302399     VWZ7Z0A4567095
17700 - Map Controlled Engine Cooling Thermostat (F265)
            P1292 - 35-10 - Open Circuit - Intermittent
16839 - EVAP System
            P0455 - 35-00 - Large Leak Detected
18613 - Performance Malfunction in Cooling System
            P2181 - 35-00 -
16455 - Sensor for Ambient Air Temperature (G17)
            P0071 - 35-00 - Implausible Signal
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 3B0 927 156 T
   Component: AG5 01V 4.0lWR8 USA 2222
   Coding: 01102
   Shop #: WSC 02402
   VCID: 373EE4A117F08EFA4D-5184
17125 - Torque Converter Clutch
            P0741 - 35-00 - Stuck OFF / No Power being transferred
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 AA
   Component: ABS/ESP allrad      2329
   Coding: 05397
   Shop #: WSC 02415
   VCID: 608C6FFDE2FEA942DC-5184
01119 - Gear Recognition Signal
            35-10 -  -  - Intermittent
   Part No: 3B7 907 044
   Component: CLIMATRONIC B5W8    0005
   Coding: 27210
   Shop #: WSC 00028
   VCID: 648463EDF6E6B56238-51A8
00792 - A/C Pressure Switch (F129)
            35-00 -  -
00603 - Footwell/defroster Flap Positioning Motor (V85)
            37-00 - Faulty
01271 - Positioning Motor for Temperature Flap (V68)
            37-00 - Faulty
01272 - Positioning Motor for Central Flap (V70)
            37-10 - Faulty - Intermittent
            37-00 - Faulty
            79-00 - Please Check Fault Codes
   Part No: 1C0 909 605 C
   Component: 0C AIRBAG VW61 04   0001
   Coding: 12355
   Shop #: WSC 00402
   VCID: 240423EDB666F562F8-5160
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0003
   Coding: 00118
   Shop #: WSC 02402
   VCID: 2F2EDCC1EFA0463A15-5216
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B7 920 946 E
   Component: KOMBI+WEGFAHRSP VDO V07
   Coding: 23236
   Shop #: WSC 02667
   VCID: 2F2EDCC1EFA0463A15-5160
            29-00 - Short to Ground
01326 - Control Module for Multi-Function Steering Wheel (J453)
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00028
   VCID: 70AC1FBD321E19C24C-5160
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 E
   Component: Sitzverstellung     0301
   VCID: 2F2EDCC1BFA0463A15-5160
01008 - Note; Emergency OFF Switch is Active!
            000 -  -
   Part No: 1C0 959 799 C
   Component: 09 Komfortgerát HLO 0003
   Coding: 00258
   VCID: 373EE4A117F08EFA4D-4B3C
   Subsystem 1 - Part No: 1C0959801
   Component: 09 Tõrsteuer.FS KLO 0002
   Subsystem 2 - Part No: 1C0959802A
   Component: 09 Tõrsteuer.BF KLO 0004
   Subsystem 3 - Part No: 1C0959811
   Component: 09 Tõrsteuer.HL KLO 0004
   Subsystem 4 - Part No: 1C0959812
   Component: 09 Tõrsteuer.HR KLO 0004
00912 - Window Regulator Switch; Front Left (E40)
            27-00 - Implausible Signal
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D07
   Coding: 00008
   Shop #: WSC 00028
   VCID: 0444436D16A6156298-4BBA
            30-00 - Open or Short to Plus
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180 C
   Component:    Radio NP2        0011
   Coding: 05035
   Shop #: WSC 00028
   VCID: 200C2FFDA27EE9429C-5160
Address 58: Aux Fuel Tank        Labels: 3B7-906-268.lbl
   Part No: 3B7 906 268
   Component: Kraftst. Zusatztank 0004
   VCID: 6B9608D11B38FA1A79-5160
End----------(Elapsed Time: 05:15, VBatt start/end: 12.3V/11.9V)-----------
