2007 Jetta 2.5L BGQ
MattF-MN
C?ID=134881
Monday,14,November,2016,09:54:17:48394
VCDS Version: 16.8.3.1  HEX-NET CB: 0.4323.4
VIN: 3VWEF71K97M161027   License Plate:
Mileage: 252370km-156815mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWEF71K97M161027   Mileage: 252370km-156815miles
08-Auto HVAC -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 S    HW: 07K 906 032 Q
   Component: 2.5l R5/4V      G   9652
   Revision: --H01---    Serial number: VWZ7Z0G9049011
   Coding: 0000003
   Shop #: WSC 00066 000 00000
   VCID: 393AE29970E4988ABB-806C
001152 - Coolant Fan Control Circuit 1
               P0480 - 004 - Electrical Malfunction - Intermittent
                    Fault Frequency: 178
                    Mileage: 239808 km
                    Time: 00:37:07
                    RPM: 2226 /min
                    Load: 81.1 %
                    Speed: 108.0 km/h
                    Temperature: 87.0°C
                    Temperature: 40.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.970 V
006481 - Radiator Fan 2 (V177)
               P1951 - 002 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 242
                    Mileage: 239808 km
                    Time: 00:54:53
                    RPM: 1996 /min
                    Load: 19.6 %
                    Speed: 97.0 km/h
                    Temperature: 82.0°C
                    Temperature: 34.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.097 V
   Part No SW: 09G 927 750 FL    HW: 09G 927 750 FL
   Component: AQ 250 6F           0920
   Revision: 00H69000    Serial number:
   Coding: 0000072
   VCID: 004C4F7D53BE0942BC-8054
   Revision: 00H11001
   Coding: 0021122
   VCID: 73A610B1120822DAB1-8026
   Part No: 1K0 820 047 GS
   Component: Climatic PQ35   120 0606
   VCID: 7BB638913A586A9AE9-802E
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000000565533
   Coding: 14058E234004150007140000001400000008730B5C0000
   VCID: 6B9608D14A38FA1A79-803E
   Component: Wischer 030407 020  0501
   Coding: 00038805
                    Fault Status: 00101010
                    Reset counter: 90
                    Mileage: 247107 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.35 V
                    Reset counter: 94
                    Mileage: 244105 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.70 V
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M01GL93
   Coding: 0013889
   VCID: 6C940BCD4F36FD2270-8038
   Subsystem 1 - Part No: 1K0 959 339 F
   Component: BF-Gewichtsens. 007 0005
   Subsystem 2 - Serial number: 6332MSME167109454
   Subsystem 3 - Serial number: 6342MSME166E172FO
   Subsystem 4 - Serial number: 6351HSME0C6E5445H
   Subsystem 5 - Serial number: 6361HSME0C70490CC
   Subsystem 6 - Serial number: 63727SME0C10426E%
   Subsystem 7 - Serial number: 63827SME0C6D67106
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenksäulenmodul 036 0070
   Coding: 0010021
   Part No SW: 1K0 920 953 P    HW: 1K0 920 953 P
   Component: KOMBIINSTRUMENT 3HL 1610
   Revision: V0003000    Serial number: VWZ7Z0G9049011
   Coding: 0023207
   Shop #: WSC 02407 444 53832
   VCID: 383CE79D4BEE818244-806C
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 110307F2000510
   Coding: 3FBF034007001002
   VCID: 2F2EDCC1BEA0463A15-807A
                    Fault Status: 00110100
                    Reset counter: 94
                    Mileage: 244105 km
                    Time: 06:25:00
                    Reset counter: 97
                    Mileage: 249673 km
                    Time: 23:57:31
   Component: IMMO            3HL 1610
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000072378305
   Coding: 0001205
   VCID: 3B36F8917AD8AA9AA9-806E
00105 - Signal Central Locking SAVE/LOCK Drivers Side
                    Reset counter: 99
                    Mileage: 249743 km
00109 - Left Mirror Turn Signal Lamp (L131)
                    Fault Status: 00101100
                    Reset counter: 129
                    Mileage: 240718 km
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   Shop #: WSC 02069 000 90108
   VCID: 3424D3AD578665E268-8060
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Component:    KSG PQ35 RDK 052 0218
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   VCID: 0444436D47A6156298-8050
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000582878303
   Coding: 0001204
   VCID: 3C34FB8D7FD6ADA2A0-8068
00110 - Right Mirror Turn Signal Lamp (L132)
                    Reset counter: 129
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 B    HW: 1K0 035 161 B
   Component: Radio DE2       014 0017
   Revision: 00014000    Serial number: VWZ4Z7G6239239
   Coding: 0040401:thanks:
   VCID: 1E701105C90ADFB2AE-804A
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000001242965
   Coding: 0001168
   VCID: 3E30F18569CABFB28E-806A
   Component:    RDK              0440
   Coding: 0100101
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000001282131
   Coding: 0001168
   VCID: 3FCE8C816EC0B6BA85-806A
End----------(Elapsed Time: 01:18, VBatt start/end: 12.4V/12.4V)-----------
Address 01: DTCs cleared
VCDS Release 16.8.3:  SRI Reset
Control Module Part Number: 1K0 920 953 P       Labels:  1K0-920-xxx-17.lbl
Component:KOMBIINSTRUMENT 3HL 1610, Coding:0023207
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	1             	---
40       	Distance since Service                            	miles x100	133           	---
41       	Time since Service                                	Days      	321           	---
42       	Minimum Distance to Service                       	---       	---           	---
43       	Maximum Distance to Service                       	---       	---           	---
44       	Maximum Time to Service                           	---       	---           	---
45       	Oil Quality                                       	          	1             	---
47       	Soot Quantity                                     	km x100   	0             	---
48       	Thermal Load                                      	km x100   	0             	---
49       	Minimum Time to Service                           	---       	---           	---
50       	Basic Distance Value for Oil Change               	miles x100	50            	---
51       	Basic Time Value for Oil Change                   	Days      	372           	---
Operation: General Service Reset
02       	Service Reminder Status                           	          	1             	0
Address 17,1K0 920 953 P,channel 2,adapted from,1,to,00000,
