- May 1, 2014
- 57
- 52
- Northern Ireland
- C?ID=109519
Tuesday,08,November,2016,08:51:45:49196
VCDS Version: 16.8.3.1 (x64)
Workshop Code: 210 00899 089553
VIN: WVWZZZ3CZGE197824 License Plate: PASSAT
Mileage: 12958km-8051mi Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 5F
VIN: WVWZZZ3CZGE197824 Mileage: 12958km-8051miles
Address 01: Engine (J623-DCXA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 026 GJ HW: 04L 907 309 R
Component: R4 1.6l TDI H22 1991
Revision: B5H22---
Coding: 01190012030519093000
Shop #: WSC 05311 115 00306
ASAM Dataset: EV_ECM16TDI01104L906026GJ 002002
ROD: EV_ECM16TDI01104L906026GJ.rod
VCID: 78FB902EC313678284-802C
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 60626000001983
Coding: 0EEC928F34290B73077F060241C74970492CD0E0608292F10040F078C002
Shop #: WSC 00015 115 08193
ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
VCID: 79FD952AF8197E8AFB-802C
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0710
Revision: 00026000 Serial number: 0396906741
Coding: 000F0F0E03
VCID: 397D552AB899BE8ABB-806C
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5G0 907 426 AF HW: 5G0 907 426 AF
Component: AC Manuell H03 1202
Revision: 00001K06
Coding: 11120104202100001000400000000002
ASAM Dataset: EV_ACManueBHBVW37X 003129
ROD: EV_ACManueBHBVW37X_SK48.rod
VCID: 6FE9AB72B65D203A55-803A
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 086 AH HW: 5Q0 937 086 AH
Revision: -------- Serial number: 8658060316006L
Coding: 03010842C2C1005703A04084B10007081880000000000000000000000000
Shop #: WSC 05311 115 00091
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 000BF8CE9BC32F42BC-8054
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160206 043 0607
Serial number: 160218105741
Subsystem 2 - Part No SW: 3G0 941 633 C HW: 3G0 941 633 C
Component: E1 - LDS MQB H01 0032
Serial number: 13 07 2015 10000963
Serial number: 000000000ZY1105301FG
Serial number: 00000000000065079511
Part No SW: 3Q0 959 655 BB HW: 3Q0 959 655 BB
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003STP4J6MT-
Coding: 98FCC0C0000000005C5400CC008800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F097B32E63D50BAC5-802A
Subsystem 1 - Part No SW: ----------- HW: 454 000 203 16
Serial number: 3576U0000007E9A4991S
Subsystem 2 - Part No SW: ----------- HW: 454 000 203 16
Serial number: 3586U0000008701D991E
Subsystem 3 - Part No SW: ----------- HW: 454 800 802 16
Serial number: 3516R3965000A000000W
Subsystem 4 - Part No SW: ----------- HW: 454 800 702 16
Serial number: 3526R5760000A000000S
Subsystem 5 - Part No SW: ----------- HW: 454 800 402 16
Serial number: 3556V4A8D200A000000B
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 3Q0 953 521 CS HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF034034 Serial number: 20160130501021
Coding: 0000
Shop #: WSC 00015 115 00001
ROD: EV_SMLSVALEOMQB.rod
VCID: 0301F7C28AD5345AA1-8056
Part No SW: 3G0 920 941 A HW: 3G0 920 941 A
Component: KOMBI 207 7653
Coding: 27A402102380260001082B001000000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009005
ROD: EV_DashBoardJCIMQBAB_VW48.rod
VCID: 2443945E2F1BD362F8-8070
Part No SW: 5Q0 907 530 AH HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2246
Revision: -------- Serial number: 08031610801068
Coding: 030300045F085900FB000048080F00010001070000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 77F99312CE0D68FA8D-8022
Subsystem 2 - Part No SW: 5G0 959 442 H HW: 5G0 959 442 H
Component: E221__MFL-DC1 H17 0103
Serial number: 29160000476290126101
Coding: 24FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 5680389403
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 1702201600010151
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000031707007
Coding: 0000000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71EDAD0AA06936CA43-8024
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 010216EAU01279
Coding: 00300A208001020000001000
VCID: 418D3DCAD049E64AF3-8014
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000003164932
Coding: 0D0000
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: 0103
Shop #: WSC 00015 115 00306
VCID: 448334DECF5BF362D8-8010
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 090216EAU07024
Coding: 003000208001020000001000
VCID: 408B38CEDB43EF42FC-8014
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000003162422
Coding: 050000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 820 A HW: 3Q0 035 820 A
Component: MU-S-D-ER 523 0624
Coding: 02840100FF00000051111101008808001F0100C60120010001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 275983525E2D387ADD-8072
Subsystem 1 - Part No SW: 3G0 919 605 HW: 3G0 919 605
Component: ABT_Std-2 H43 4064
Serial number: VWZ6Z9S0670575
End-------------------------(Elapsed Time: 03:31)--------------------------
