2.0 TDI will not rev above 2K
Lgibson
C?ID=41716
Went to help a veteran today.
Here is a scan and a brief log.
Is the egr not being ready responsible for the limiting of revs? Is there a readiness script here? We were able to set the steering sensor.
11	November	11:48:58:34689-VCID:78F47EFB0B54CA8284-802C	Data version: 20161010 DS267.0
ADVMB	R4 2.0L EDC G000AG  2260
	G003	G003	G003	F3	G011	G011
TIME	Group 3 - Field 1	Group 3 - Field 2	Group 3 - Field 3	TIME	Group 11 - Field 1	Group 11 - Field 2
STAMP	Exhaust Gas - Recirculat. (spec.)	Exhaust Gas - Recirculat. (actual)	Exhaust Gas - Recirc. Duty Cycle	STAMP	Boost Pressure - (specified)	Boost Pressure - (actual)
	 mg/str	 mg/str	 %		 mbar	 mbar
0.12	505	270	100	0.01	1004.3	859.1
0.37	440	255	100	0.25	1004.3	859.1
0.64	470	285	100	0.51	1004.3	859.1
0.89	460	290	100	0.76	1004.3	859.1
1.15	415	255	100	1.03	1004.3	859.1
1.4	345	265	87.8	1.28	1016.4	859.1
1.67	345	275	90.2	1.54	1016.4	859.1
1.92	335	275	89.8	1.79	1016.4	859.1
2.18	315	265	88.6	2.06	1016.4	859.1
Friday,11,November,2016,11:22:32:34689
VCDS Version: 16.8.3.1
VIN: 3VWLL7AJ2CM361667   License Plate:
Readiness Status: 00000000 00001111 11101011 11101011
MIL Status: MIL OFF
Comprehensive Components: Passed
Fuel System: Passed
Exhaust Gas Recirculation: Failed or Incomplete
Number of EOBD-related DTC(s): 0
                Address 01: Engine  (03L 906 019 HH)
11:24:37
  828 /min   Engine Speed (G28)
  290.0 mg/str   Exhaust Gas Recirculat. (spec.)
  300.0 mg/str   Exhaust Gas Recirculat. (actual)
  78.0 %   Exhaust Gas Recirc. Duty Cycle
Chassis Type: AJ (6N0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 44 47 56
VIN: 3VWLL7AJ2CM361667   Mileage: 120320km-74763miles
   Part No SW: 03L 906 019 HH    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000AG  2260
   Revision: 12H14---    Serial number:
   Coding: 0050078
   Shop #: WSC 00066 000 00000
   VCID: 78F47EFB0B54CA8284-802C
   Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 3102
   Revision: 05351113    Serial number: 00001111070521
   Shop #: WSC 02069 000 90108
   VCID: 2648608391608C72E6-8072
   Revision: 00H31001
   Coding: B14B400C492800FB8D1102EA92200042A71000
   VCID: 7DFA6FEFE476EFAAD7-8028
                    Reset counter: 58
                    Mileage: 120321 km
                    Date: 2016.11.06
                    Time: 00:01:16
                    Count: 2
                    Count: 14
                    Count: 29184
                    Count: 16390
                    Count: 50688
                    Count: 65532
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 B
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0156976223
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_VW01.rod
   VCID: 346C8ACB9FBCEEE268-8060
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 AQ    HW: 5C0 820 047 AQ
   Component: J301  Klimaanlage   0203
   Revision: 2001010S    Serial number: 00000000739057
   VCID: 6FE645A77E1A8D3A55-803A
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0251
   Revision: B2066001    Serial number: 04371343110238
   Coding: 7B994B9A08AB0B0008382000240884C50082502E6000000030A000000000
   VCID: 2F6685A77E9ACD3A15-807A
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3464
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3464
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H09 0007
   Serial number:     WRH0003L2C8
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0785742
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3464
   Coding: 800000
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   014 0808
   Serial number: 003GTM03BVSE
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
   ROD: EV_AirbaVW10SMEVW360.rod
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H10 0045
   Serial number: 6940000Y1100009P2P0U
   Coding: 303036
   Serial number: 3572MSME17584165ZZZU
   Serial number: 3582MSME212B0065ZZZL
   Serial number: 3516KSME230B2415ZZZH
   Serial number: 3526KSME5B143615ZZZQ
   Serial number: 3556LSME1A0D5411ZZZT
   Serial number: 3566LSME10095411ZZZG
   Part No SW: 5C6 920 951 A    HW: 5C6 920 951 A
   Component: KOMBI         H04 0604
   Coding: 270A01
   Shop #: WSC 00066 000 00123
   VCID: 29526BBF487EA30ACB-807C
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0251
   Revision: B2066001
   Coding: 102200
   VCID: 70E446DBA32492C24C-8024
   Component: IMMO          H04 0604
   Coding: 000007
   VCID: 6AD054B38DF8681202-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000237186001
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E5898A37190C4321E-807A
   Revision: A1001003    Serial number: 7660909429
   Coding: 020000
   VCID: 29526BBF407EA30ACB-807C
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H33 0265
   Serial number: VWZAZ2L8482754
   Coding: 04090001010006000000100A
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 234E79972A52795A81-8076
   Component: NAR_V7N  0060
1048669 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 23
                    Mileage: 119004 km
                    Date: 2016.10.21
                    Time: 19:56:59
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 70     3301
   Revision: 00H22000
   VCID: 356AB7CF5CC6F7EA5F-8060
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.1 V
                        PD
                    Temperature: 19.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 3T0 035 456 B    HW: 3T0 035 456 B
   Component: KonzernAmp10K H06 0362
   Revision: --------    Serial number: BP225311000754
   ROD: EV_AudioVerst10KanalSTT3.rod
   VCID: 306486DB6BA4D2C20C-8064
End-------------------------(Elapsed Time: 03:12)--------------------------
automech
Poland
C?ID=14925
Rev limit at 2-2.5k RPM when stand still is normal behaviour of the CR TDI engines.
Lgibson
C?ID=41716
Problem is, the vehicle will not go more than about 15 mph. IIRC the DSG did go into 2nd while testing.
automech
Poland
C?ID=14925
Sounds like Transport mode. Worth to try turning it OFF again.
Lgibson
C?ID=41716
Any idea how it would get into Transport Mode?
