- Apr 28, 2014
- 52
- 31
- New Zealand
- C?ID=213797
Some idiot (me) thought he had a log of the car before replacing the EPB module. Turns out i didn't! So now i need the coding for the ABS. See log
thanks
thanks
Friday,11,November,2016,10:54:50:55685
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
VIN: WVWZZZ3CZ8E130128 License Plate: JCH951
Mileage: 63950km-39736mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 55 62 72
VIN: WVWZZZ3CZ8E130128 Mileage: 63950km-39736miles
08-Auto HVAC -- Status: Malfunction 1010
Address 01: Engine ( ) Labels: 06J-907-115-BZB.clb
Part No SW: 06J 906 026 A HW: 06J 906 026
Component: MED17.5 1757
Revision: A8H03--- Serial number: VWZCZ000000000
Coding: 0404000319070160
Shop #: WSC 05314 000 00000
VCID: 285FEADB9B2A9E02D4-807C
049508 - No Communications with HVAC Control Module (J301)
U0164 - 000 - - Intermittent
Date: 2047.15.31
Time: 31:63:63
Load: 0.0 %
Temperature: 76.0°C
Temperature: 51.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.938 V
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 -
Fault Frequency: 7
Mileage: 63955 km
Time: 09:48:34
Load: 0.0 %
Temperature: 16.0°C
Temperature: 18.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.938 V
U1017 - 000 - - MIL ON
Fault Status: 11100000
Mileage: 63955 km
Time: 09:48:38
Load: 0.0 %
Temperature: 16.0°C
Temperature: 18.0°C
Voltage: 11.938 V
Part No SW: 09G 927 750 JJ HW: 09G 927 750 JJ
Component: AQ 250 6F 1178
Revision: 00H76000 Serial number:
Coding: 0000328
Shop #: WSC 05311 000 00000
VCID: 020B98735DD69452AA-8056
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000776557334
Coding: 0010000
VCID: 1F4DF107CE6459BAA5-804A
Reset counter: 89
Mileage: 63955 km
Time: 10:16:38
Hex Value: 0x0000
Voltage: 11.75 V
Bin. Bits: 00011111
Count: 150
Reset counter: 89
Mileage: 63955 km
Time: 10:16:38
Reset counter: 89
Mileage: 63955 km
Time: 10:16:38
Reset counter: 89
Mileage: 63955 km
Time: 10:16:38
Reset counter: 89
Mileage: 63955 km
Time: 10:16:38
Reset counter: 89
Mileage: 63955 km
Time: 10:16:38
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 CR HW: 3C0 907 044 CR
Component: ClimatronicPQ46 132 0811
Revision: 00132023 Serial number: 00000000000000
VCID: 73E5CDB7126CADDAB1-8026
Fault Status: 00111110
Fault Frequency: 6
Reset counter: 101
Mileage: 63150 km
Time: 14:05:43
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Revision: 00H54000 Serial number: 01000007769541
Coding: 038E0F0700041A00470A00000F000000000B5D435C000100000000000000
Shop #: WSC 05124 000 00000
VCID: 71E9C7BF68709FCA43-8024
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 071107 022 0601
Coding: 00046997
Shop #: WSC 05124
Reset counter: 129
Mileage: 63955 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.00 V
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__00F VW10 HI 1815
Revision: 19013000 Serial number: 0039BPPB1UXJ
Coding: 0012358
VCID: 7AFBE0933506DC92F2-802E
Subsystem 1 - Serial number: 6333FTS640793097
Subsystem 2 - Serial number: 6343FTS614483007
Subsystem 3 - Serial number: 6353ETS629L7SVNP
Subsystem 4 - Serial number: 6363ETS6JJL7SVNH
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 AB HW: 3C0 953 549 AB
Component: J0527 0020
Revision: 00026000 Serial number: 3C9953507AP
Coding: 0001014
VCID: 6CD7D6CB4F52722270-8038
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 860 M HW: 3C0 920 860 M
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007505
Shop #: WSC 48370 000 1048576
VCID: 2C5716CB8FD2B22230-8078
Address 19: CAN Gateway Labels: 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P07B17068D
Coding: FD817F060000022003
Shop #: WSC 84010 981 60366
VCID: 2345FDF7E20C7D5A81-8076
Reset counter: 129
Mileage: 63955 km
Time: 09:56:24
Part No SW: 3C0 959 433 S HW: 3C0 959 433 S
Component: IMMO 041 0383
Revision: 00041000 Serial number: VWZCZ000000000
VCID: 3A7B209375861C92B2-806E
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1132
Revision: 31008001 Serial number: 00000076679103
Coding: 0000695
VCID: 3C77268B7FB222A2A0-8068
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.134 H08 1901
Shop #: WSC 02069 000 90108
VCID: 366334A3419EF8F256-8062
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 041 0472
Coding: 0091020051030E763004941570085F0B6078A0
Reset counter: 129
Mileage: 63955 km
Time: 09:56:25
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1132
Revision: 31008001 Serial number: 00000039079026
Coding: 0000694
VCID: 3D712B8F64A82BAA97-8068
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000311304
Coding: 0000057
VCID: 2959EFDF8020A70ACB-807C
03200 - Switch for Electric Parking Brake (E538)
Fault Status: 11111100
Reset counter: 89
Voltage: 11.80 V
Count: 10
Hex Value: 0x0150
Hex Value: 0x0082
Hex Value: 0x0101
000 - - - MIL ON
Fault Status: 11110000
Reset counter: 89
Mileage: 63955 km
Voltage: 11.70 V
Count: 43
Hex Value: 0x1240
Hex Value: 0x0001
Hex Value: 0x0101
01316 - ABS Control Module
Fault Status: 11101101
Reset counter: 89
Mileage: 63955 km
Voltage: 11.60 V
Count: 71
Hex Value: 0x1240
Hex Value: 0x0021
Hex Value: 0x0101
Fault Status: 11110101
Reset counter: 89
Mileage: 63955 km
Voltage: 11.70 V
Count: 101
Hex Value: 0x1240
Hex Value: 0x0001
Hex Value: 0x0101
Part No SW: 5M0 907 357 B HW: 5M0 907 357 B
Component: AFS-Steuergeraet X024
Revision: 00H01000 Serial number:
Coding: 2311425
VCID: 33650DB752ECEDDA71-8066
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0002
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0002
Coding: 00000035
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000000051406
Coding: 0000144
VCID: 70EFC2BB637A96C24C-8024
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000000047245
Coding: 0000144
End-------------------------(Elapsed Time: 01:58)--------------------------
