3C Passat ABS coding
HCAE
New Zealand
C?ID=213797
Some idiot (me) thought he had a log of the car before replacing the EPB module. Turns out i didn't! So now i need the coding for the ABS. See log
thanks
Friday,11,November,2016,10:54:50:55685
VCDS Version: 16.8.3.1 (x64)
VIN: WVWZZZ3CZ8E130128   License Plate: JCH951
Mileage: 63950km-39736mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 55 62 72
VIN: WVWZZZ3CZ8E130128   Mileage: 63950km-39736miles
Address 01: Engine (   )       Labels: 06J-907-115-BZB.clb
   Part No SW: 06J 906 026 A    HW: 06J 906 026
   Component: MED17.5             1757
   Revision: A8H03---    Serial number: VWZCZ000000000
   Coding: 0404000319070160
   Shop #: WSC 05314 000 00000
   VCID: 285FEADB9B2A9E02D4-807C
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 76.0°C
                    Temperature: 51.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.938 V
               U1017 - 000 -
                    Mileage: 63955 km
                    Time: 09:48:34
                    Temperature: 16.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.938 V
               U1017 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 63955 km
                    Time: 09:48:38
                    Temperature: 16.0°C
                    Temperature: 18.0°C
                    Voltage: 11.938 V
   Part No SW: 09G 927 750 JJ    HW: 09G 927 750 JJ
   Component: AQ 250 6F           1178
   Revision: 00H76000    Serial number:
   Coding: 0000328
   Shop #: WSC 05311 000 00000
   VCID: 020B98735DD69452AA-8056
   Part No SW: 3C0 614 109 D    HW: 3C0 614 109 D
   Component: J104    C4 440 V2   0003
   Revision: --020---    Serial number: 00000776557334
   Coding: 0010000
   VCID: 1F4DF107CE6459BAA5-804A
            000 -  -
                    Reset counter: 89
                    Mileage: 63955 km
                    Time: 10:16:38
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 150
                    Reset counter: 89
                    Mileage: 63955 km
                    Time: 10:16:38
                    Reset counter: 89
                    Mileage: 63955 km
                    Time: 10:16:38
                    Reset counter: 89
                    Mileage: 63955 km
                    Time: 10:16:38
                    Reset counter: 89
                    Mileage: 63955 km
                    Time: 10:16:38
                    Reset counter: 89
                    Mileage: 63955 km
                    Time: 10:16:38
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 CR    HW: 3C0 907 044 CR
   Component: ClimatronicPQ46 132 0811
   Revision: 00132023    Serial number: 00000000000000
   VCID: 73E5CDB7126CADDAB1-8026
                    Fault Status: 00111110
                    Reset counter: 101
                    Mileage: 63150 km
                    Time: 14:05:43
   Revision: 00H54000    Serial number: 01000007769541
   Coding: 038E0F0700041A00470A00000F000000000B5D435C000100000000000000
   Shop #: WSC 05124 000 00000
   VCID: 71E9C7BF68709FCA43-8024
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 071107 022  0601
   Coding: 00046997
   Shop #: WSC 05124
                    Reset counter: 129
                    Mileage: 63955 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.00 V
   Part No SW: 5N0 959 655     HW: 5N0 959 655
   Component: J234__00F VW10 HI   1815
   Revision: 19013000    Serial number: 0039BPPB1UXJ
   Coding: 0012358
   VCID: 7AFBE0933506DC92F2-802E
   Subsystem 1 - Serial number: 6333FTS640793097
   Subsystem 2 - Serial number: 6343FTS614483007
   Subsystem 3 - Serial number: 6353ETS629L7SVNP
   Subsystem 4 - Serial number: 6363ETS6JJL7SVNH
   Part No SW: 3C0 953 549 AB    HW: 3C0 953 549 AB
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C9953507AP
   Coding: 0001014
   VCID: 6CD7D6CB4F52722270-8038
   Part No SW: 3C0 920 860 M    HW: 3C0 920 860 M
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007505
   Shop #: WSC 48370 000 1048576
   VCID: 2C5716CB8FD2B22230-8078
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P07B17068D
   Coding: FD817F060000022003
   Shop #: WSC 84010 981 60366
   VCID: 2345FDF7E20C7D5A81-8076
                    Reset counter: 129
                    Mileage: 63955 km
                    Time: 09:56:24
   Part No SW: 3C0 959 433 S    HW: 3C0 959 433 S
   Component:    IMMO         041 0383
   Revision: 00041000    Serial number: VWZCZ000000000
   VCID: 3A7B209375861C92B2-806E
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1132
   Revision: 31008001    Serial number: 00000076679103
   Coding: 0000695
   VCID: 3C77268B7FB222A2A0-8068
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.134 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 366334A3419EF8F256-8062
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 041 0472
   Coding: 0091020051030E763004941570085F0B6078A0
                    Reset counter: 129
                    Mileage: 63955 km
                    Time: 09:56:25
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1132
   Revision: 31008001    Serial number: 00000039079026
   Coding: 0000694
   VCID: 3D712B8F64A82BAA97-8068
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000311304
   Coding: 0000057
   VCID: 2959EFDF8020A70ACB-807C
                    Fault Status: 11111100
                    Reset counter: 89
                    Voltage: 11.80 V
                    Count: 10
                    Hex Value: 0x0150
                    Hex Value: 0x0082
                    Hex Value: 0x0101
            000 -  -  - MIL ON
                    Fault Status: 11110000
                    Reset counter: 89
                    Mileage: 63955 km
                    Voltage: 11.70 V
                    Count: 43
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 11101101
                    Reset counter: 89
                    Mileage: 63955 km
                    Voltage: 11.60 V
                    Count: 71
                    Hex Value: 0x1240
                    Hex Value: 0x0021
                    Hex Value: 0x0101
                    Fault Status: 11110101
                    Reset counter: 89
                    Mileage: 63955 km
                    Voltage: 11.70 V
                    Count: 101
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No SW: 5M0 907 357 B    HW: 5M0 907 357 B
   Component: AFS-Steuergeraet    X024
   Revision: 00H01000    Serial number:
   Coding: 2311425
   VCID: 33650DB752ECEDDA71-8066
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0002
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0002
   Coding: 00000035
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0307
   Revision: 41004101    Serial number: 00000000051406
   Coding: 0000144
   VCID: 70EFC2BB637A96C24C-8024
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0307
   Revision: 41004101    Serial number: 00000000047245
   Coding: 0000144
End-------------------------(Elapsed Time: 01:58)--------------------------
HCAE
New Zealand
C?ID=213797
Thanks, that particular code is 'out of range'
NEtech
Denmark
C?ID=56995
Then try and find a 2008 Autoscan like yours, with engine BZB,
Engine PR-code TJ2 / D67, Gearbox PR-code G1A.
Or let the Volkswagen dealer do it online.
Peter and I dug into this and I came up with 0003384 ..... but I'm not entirely confident. A scan from the identical config or the dealer would be best.
Edit, these were my notes:
0D38 | 0003384 = my suggestion
Vehicle Identification No. WVWZZZ3CZ8E130128
Model passat squareback
PA
Date of production 30.11.2007
Year 2008
Sales type 3C51J6
Engine Code BZB
Transmission Code KGV
TJ2 4-cylinder gasoline engine 1.8 L unit 06J.1
G1A 6-speed automatic transmission
1X0 Front wheel drive
L0R Right-hand drive vehicle
7K6 Reifenplattrollanzeige
OK did they code it to my value? If so - the feedback would be excellent so we can add it to our internal data .. which will eventually hit VCDS for customer use.
Thanks,
This afternoon was hectic so please excuse me for the drr moment. :) I think you already confirmed 0003384 was what the dealer ended up with and I passed the baseline scan data I used to build it along to NETech and Seb. Have a great weekend.
HCAE
New Zealand
C?ID=213797
Yes, they logged in and got the code, when I returned to my workshop I saw this post and thought, oh bugger, wasted that money on the dealer!! Oh well!
