Error: 01543 - Parking Aid Warning Chime (H15)
aqxavier
Brazil
C?ID=152022
Hello.
I have a Tiguan 2010 and I lost of ParkAssist and the monitoring of the parking sensors.
The fault is intermittent ... It seems to be some bad contact.
Has anyone had this error and can you help me solve it?
The following is the log scan with error
Thursday,10,November,2016,17:48:32:40275
VCDS Version: 16.8.2.3 (x64)
Data version: 20160926 DS261.0
Chassis Type: 5N (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 1C 22 25 2E 42 44 46 4F 52 53
          55 56 62 6C 72 77
VIN: WVGSV65N1BW508488   Mileage: 61110km-37971miles
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 06J 906 026 CT    HW: 06J 906 026 AF
   Component: MED17.5 TFSI 2,0    6996
   Revision: AAH18---    Serial number:
   Coding: 0423010A190F0160
   VCID: 7EF67BDD296A26B2C6-802A
Readiness: 0000 0001
   Part No SW: 09G 927 750 LQ    HW: 09G 927 750 LQ
   Component: AQ 250 6F           1771
   Revision: 00H90000    Serial number:
   Coding: 0000328
   VCID: 0B1022096AD8031AD1-805E
Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
   Part No SW: 5N0 614 109 Q    HW: 5N0 614 109 Q
   Component: J104    C4 450 V233 0006
   Revision: --H28---    Serial number: 00000003020605
   Coding: 0011540
   VCID: 397CA8C170C4C18AB3-806C
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0100000008
   VCID: 7EF67BDDE16A26B2C6-802A
   Part No SW: 5K0 937 087 H    HW: 5K0 937 087 H
   Component: BCM PQ35 H    011 0035
   Revision: BE011001
   Coding: 4A180A3BE825F3C040480080340009A443753089736D8D605C8000000040
   VCID: 3A7EB7CDB5C2CA92BA-806E
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 22061  012 0203
   Serial number: N1955119   °203!
   Coding: 009795
   Component: RLS 240710 05  54  0403
   Coding: 032020
Address 10: Park/Steer Assist (J791)       Labels: 1T0-919-475.clb
   Part No SW: 1T0 919 475 H    HW: 1T0 919 475
   Component: PARKHILFE PLA H07 0110
   Revision: --------    Serial number: 88591015806993
   Coding: 300103
   VCID: 408AC525D31E9042F4-8014
                    Fault Status: 00101001
                    Fault Frequency: 18
                    Reset counter: 91
                    Time Indication: 15
                    Temperature: 23.0°C
   Part No SW: 5N0 959 655 N    HW: 5N0 959 655 N
   Component: J234__200 VW10 HI   1916
   Revision: 21014000    Serial number: 003GHPEF1ZYV
   Coding: 0012336
   VCID: 489ADD053B2EA8023C-801C
   Subsystem 1 - Serial number: 6332MTS614871550
   Subsystem 2 - Serial number: 6342MTS652311540
   Subsystem 3 - Serial number: 6351HTS6DQTQB6KR
   Subsystem 4 - Serial number: 6361HTS6FU0UA6KR
   Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
   Component: LENKS.MODUL   009 0135
   Revision: FF010036    Serial number: 20100713200576
   Coding: 199A140000
   VCID: 7CF271D5F77634A2E8-8028
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Coding: 830000
   Part No SW: 5N0 920 872     HW: 5N0 920 872
   Component: KOMBI         H03 0406
   Coding: 110F01
   VCID: 6FE85699B6005F3A5D-803A
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H25 0602
   Revision:   H25       Serial number: 250610F1002997
   Coding: FDA37F0600561300006002
   VCID: 2E568B9DB98A163216-807A
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223R9GP406
   Coding: 0000002
   Part No SW: 0AY 907 554 D    HW: 0AY 907 554 D
   Component: Haldex 4Motion      0042
   Coding: 0000005
   VCID: 4C92E1152F56442218-8018
   Component: IMMO          H03 0406
   VCID: 6ADE478D8DE2BA120A-803E
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668127926
   VCID: 27587EB95670477AD5-8072
   Part No SW: 5N0 959 701 E    HW: 5N0 959 701 E
   Component: Tuer-SG         009 2101
   Coding: 0004286
   VCID: 3778AEF946D0D7FA45-8062
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.221 0802
   Revision: 1AH03831    Serial number: 00102010450901
   Coding: 0000258
   Shop #: WSC 00000 028 00001
   VCID: 3B70B2C97AF8F39AA1-806E
   Component: EZE_2         H25 0602
   Coding: 050B0500
   VCID: 6FE85699BE005F3A5D-803A
   Component: J245EE20SKB13  H02 0220
   Part No SW: 5N0 959 702 E    HW: 5N0 959 702 E
   Coding: 0004542
   VCID: 387AADC54BCED8824C-806C
   Part No SW: 3AA 907 801 D    HW: 3AA 907 801 D
   Component: J540 EPB4  VW-53083 0006
   Revision:   H18       Serial number: 00000000045739
   Coding: 0023057
   VCID: 326E9FEDADB232D272-8066
   Component: AFS-Steuergeraet    0142
   Coding: 1361094
   VCID: 346299F557A63CE260-8060
   Coding: 00000020
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000020
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190     HW: 5K0 035 190
   Component: Radio RCD510  040 0167
   Revision: 00000001    Serial number: VWZ1Z3K3544830
   Coding: 0100041004
   VCID: 62CE2FAD7DD2E252C2-8036
   Part No SW: 5N0 959 703 D    HW: 5N0 959 703 D
   Component: Tuer-SG         007 2102
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Part No SW: 5N0 907 441 A    HW: 5N0 907 441 A
   Component: J772__Rearview      0020
   Revision: 00H08000    Serial number: 525PA8-J062253
   Coding: 0020010
   VCID: 2D548C91B48C6D2A2F-8078
   Part No SW: 5N0 959 704 D    HW: 5N0 959 704 D
   Coding: 0000144
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668924752
   Coding: 0600000000010110
   Shop #: WSC 12345 444 00000
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 326E9FED65B232D272-8066
End-------------------------(Elapsed Time: 03:27)--------------------------
Regards,
Alexandre
