2017 Skoda superb scan issue
sherlock
C?ID=78933
Hi all, Having trouble with the long coding on the engine ecu as i keep getting a message everytime i do a scan "unable to find a rod file for EV_ECM20TDI01104L906026MT004001(SK48)" and when you open the long coding on 01 (engine) up it hasnt got any info, so as per request here is the scan details my thoughts are its because its a 2017 model year car and no info is available yet. any help would be great, i am using the latest 16.8.3 download and also using a genuine vagcom lead. Cheers Phil
Saturday,05,November,2016,13:11:04:14782
VCDS Version: 16.8.3.1 (x64)
VIN: TMBMJ7NP0H7033063   License Plate:
Mileage: 761km-472mi   Repair Order:
Chassis Type: NP (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 42 44 52 55 5F
          69 6D BB BC
VIN: TMBMJ7NP0H7033063   Mileage: 761km-472miles
Address 01: Engine (J623-DFCA)       Labels: None
   Part No SW: 04L 906 026 MT    HW: 04L 907 309 M
   Component: R4 2.0l TDI   H24 3076
   Revision: B4H24---
   Coding: 011D0012047701083000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM20TDI01104L906026MT 004001
   ROD: N/A
   VCID: 081BD544B30A8502F4-805C
No ASAM data for: "EV_ECM20TDI01104L906026MT" (SK48)
   Part No SW: 0D9 300 013 A    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H54 4905
   Revision: 06354004    Serial number: TFK01608191713
   ROD: EV_TCMDQ250021.rod
   VCID: 15258C30F4B828EA7F-8040
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 62446000000031
   Coding: 1E07929C34230B6F4777070641C64978492CD0E2E082927518615078C20902
   ROD: EV_Brake1UDSContiMK100IPB_035_SK37.rod
   VCID: 7BF1BA88F2DCDE9AE9-802E
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0416932305
   Coding: 032C0C0F03
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   VCID: 3C737994B75219A2A0-8068
Address 08: Auto HVAC (E87)       Labels: 3V0-907-044.clb
   Part No SW: 3V0 907 044 BP    HW: 3V0 907 044 BP
   Component: AC Automat    H34 4003
   Revision: 20K07000    Serial number: 00000B00249390
   Coding: 1211010400241001100500010010100A
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ACClimaPrehVW37X 002014
   ROD: EV_ACClimaPrehVW37X_SK48.rod
   VCID: 0301C2688A2CA65AA1-8056
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
                    Reset counter: 78
                    Mileage: 716 km
                    Date: 2016.11.02
                    Time: 07:32:20
                    Voltage terminal 30: 14.4 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
                    Auxiliary heater: in stages-Act.value: 2
                    Auxiliary heater: in stages-Specified value: 3
                    Auxiliary heater: in stages-Specified value for control: 3
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001626100875
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F094E98E6C4C2BAC5-802A
   Subsystem 1 - Part No SW: 3V2 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x RL 160831  032 0121
   Serial number: 00000001608290304924
   Coding: 165DDD
   Component: RLHS  042 0105
   Serial number: S4Y16M09D21H14M10S11
   Coding: 0088DF
   Serial number: 000000000ZY162223D5K
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000036372628
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39361625704495
   Coding: 0071051951
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 44830174CFA26162D8-8010
Address 13: Auto Dist. Reg (J428)       Labels: 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Coding: 3200678A51FFC428949C8045
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 346351B49F02D1E268-8060
   Part No SW: 5Q0 959 655 AK    HW: 5Q0 959 655 AK
   Component: AirbagVW21    005 0130
   Serial number: 003Q5R24L4RX
   Coding: 98CCC0C0000000005C5400CF00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   ROD: EV_AirbaVW20SMEVW37X_SK48.rod
   VCID: 091DD040A800FC0AEB-805C
   Subsystem 1 - Part No SW: -----------    HW: 480 001 309 16
   Serial number: 357000000008B2114E1E
   Subsystem 2 - Part No SW: -----------    HW: 480 001 509 16
   Serial number: 35800000000E38D03E1T
   Subsystem 3 - Part No SW: -----------    HW: 480 400 909 16
   Serial number: 3510002C9215E1D2229/
   Subsystem 4 - Part No SW: -----------    HW: 480 400 609 16
   Serial number: 3520002B3215E1D152F%
   Subsystem 5 - Part No SW: -----------    HW: 480 400 609 16
   Serial number: 3550002AD215E1D510B5
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 EF    HW: 5Q0 953 569 A
   Revision: FF035035    Serial number: 20160919400383
   Coding: 6410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 78FBA584C3EAF58284-802C
   Part No SW: 3V0 920 911 A    HW: 3V0 920 911 A
   Component: KOMBI         304 8311
   Coding: 27A5081AAF80A60001886B011000000000000000
   Shop #: WSC 73430 031 00063
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 306B5DA46B1AEDC20C-8064
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 17091610801635
   Coding: 030100345F087300EB00025A1C0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00114
   ROD: EV_GatewConti_013.rod
   VCID: 7CF3B994F7D2D9A2E0-8028
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000D0069030916
   Serial number: 2204760904
   Serial number: HA1-00010.08.16
   Coding: 0301
   VCID: 4A9F2F4CED86B71222-801E
   Serial number: 16000209875012
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71ED98A0A090A4CA43-8024
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0020
   Serial number: Y0006PI227635
   Coding: 0014000000000500018280808080000000008181000000D400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide_VW37.rod
   Component: TSG FS        010 0032
   Serial number: 0000219248383
   Coding: 001D0820DE01040000001100
   VCID: 47991678FE944A7A3D-8012
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45851C70C498586ACF-8010
   Component: TSG BFS       010 0032
   Serial number: 0000218958908
   Coding: 001D0220DE01040000001100
   VCID: 46871B7CF99E5372C6-8012
   Coding: 06EE00003F010000
   VCID: 408B0D64DBBA7D42FC-8014
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0006
   Coding: B20000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: B20000
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 020 C    HW: 3V0 035 020
   Component: MU-H-ND-EU    H50 0702
   Serial number: A676I0G7520467
   Coding: 03840201FF00000051111201008808002F0100C601208100DE
   ROD: EV_MUHig4CGen2HBAS_SK37.rod
   VCID: 2647BBFC59DEB372E6-8072
   Subsystem 1 - Part No SW: 3V0 919 606     HW: 3V0 919 606
   Component: ABT_High-2  H47 1031
   Serial number: SKZ8Z9SLU00GD0
   Subsystem 2 - Part No SW: V03 959 801 JL    HW: -----------
   Component: ECE 2016/2017  --- 0153
   Compact Disc Database:
   Component: Gracenote2---  --- 1013
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 H    HW: 5Q0 907 383 C
   Component: Anhaenger     H21 0204
   Revision: 8B001003    Serial number: 0416488688
   Coding: 0100000202000000
Address 6D: Trunk Elect. (J605)       Labels: 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30949220700000
   Coding: 0D88
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   VCID: 3F890E98A64402BA85-806A
Address BB: Door Rear Drv (J388)       Labels: None
   Part No SW: 5Q4 959 395 E    HW: 5Q4 959 395 B
   Component: TSG HFS       011 0032
   Serial number: 0000218259558
   Coding: 001800208001040000001100
   ASAM Dataset: EV_DCURearDriveMAXCONT 006001
Address BC: Door Rear Pass (J389)       Labels: None
   Component: TSG HBFS      011 0032
   Serial number: 0000218259489
   ASAM Dataset: EV_DCURearPasseMAXCONT 006001
End-------------------------(Elapsed Time: 05:05)--------------------------
NEtech
Denmark
C?ID=56995
That will probably be changed with next update.
What do you need to change in Engine Coding ?
sherlock
C?ID=78933
Thanks for your reply, When do you think the next update will be available. The thing i was looking to change was a setting that alters the throttle response. You change from skoda to audi by going into controller 01 engine, 07 coding, byte 0, bit 2. ive done it on a earlier mk3 skoda superb and it really does alter the throttle response but this new sportline obviously is a little new at the momment. Regards Phil.
Missing ASAM data should not prevent you from changing that bit.
However, not all ECUs support changing it.
VW_FI
Finland
C?ID=21939
I'm having similar problems with 2016 Skoda Superb and having alot of (trouble) codes.
Just update my cable.
Let's see if I succeed with the code wrap:
Sunday,22,January,2017,16:48:14:34924
VCDS Version: 17.1.2.0 (x64)
Data version: 20170107 DS267.0
VIN: TMBCJ7NP4G703----   License Plate:
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 3C 42 44 52 55
          5F 6D A5
VIN: TMBCJ7NP4G703----   Mileage: 8709km-5411miles
Address 01: Engine (J623-DFCA)       Labels: 04L-907-309-V1.clb
   Component: R4 2.0l TDI   H23 3076
   Revision: B4H23---
   Coding: 011D0032036601083000
   Shop #: WSC 32685 001 1048576
   ROD: N/A
   VCID: 8814319F33BBD7012B-80DC
17149 - ROD - Unknown Error Code
          - 00 [167]
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
21605 - ROD - Unknown Error Code
          - 00 [039]
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:12
7150 - ROD - Unknown Error Code
          - 00 [039]
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:12
   Component: DQ250-6A MQB  H53 4905
   Revision: 06253104    Serial number: TFK01509242081
   Shop #: WSC 33361 790 00999
   VCID: 952A68EB74097AE9A0-80C0
   Revision: 00000000    Serial number: 62785000001302
   Coding: 1D076A9C34230B6C0780070341C949B8562CD0E0E08292F538615078C289
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: FAF05B577D57B5912D-80AE
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 15
                    Date: 2016.12.17
                    Time: 03:39:12
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [009] - -
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:14
16411 - Display for Tire Pressure Monitoring
          C1146 02 [137] - Signal Failure
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:21
16412 - Display for Tire Pressure Monitoring
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:21
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:21
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0710
   Revision: 00036000    Serial number: 0382890951
   Coding: 030C0C0703
   VCID: BA709B573DD775916D-80EE
   Subsystem 1 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
   Component: GEB.F.Heckoef  H16 0813
   Serial number: 65032616
   Part No SW: 3V0 907 044 AR    HW: 3V0 907 044 AR
   Component: AC Automat    H32 3601
   Revision: 20K04000    Serial number: 00000B00030960
   Coding: 11010104002100011005000000101002
   ASAM Dataset: EV_ACClimaPrehVW37X 002009
   VCID: 840C25AF0F93F36147-80D0
459527 - Databus
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061528702905
   Coding: 0C011B56C2C722FB57E440040018172C0800000000000000000000000000
   ROD: EV_BCMBOSCH_016_AU37.rod
   VCID: 8912349B28B1AE0934-80DC
   Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 150914  032 0121
   Serial number: 00000001509100305421
   Coding: 165DDD
   Component: RLHS  037 0059
   Serial number: S5Y15M10D21H05M48S06
   Coding: 00084D
137217 - Outside temperature sensor
          B103F 1B [009] - Resistance Too High
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
786954 - Heater for Spray Nozzles
          B1224 15 [009] - Open or Short to Plus
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183615283
   Coding: 0271065851
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000_009.rod
   VCID: 8D1A008B5CD9B22918-80D8
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [009] - Open Circuit
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:12
13637888 - Databus
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
13637426 - Databus
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
13679388 - Databus
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:16
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 05101503273296
   Coding: 00000100FE0739
   Shop #: WSC 00028 028 00066
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   ROD: N/A
No ASAM data for: "EV_ACCMRRBoschVW372" (SK48)
7 Faults Found:
15360768 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
1058 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
1059 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
1054 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
1078 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
1094 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
1043 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
   Serial number: 003Q5R16BP2K
   Coding: 98CCC0C0000000005C5400CF004800000065
   Subsystem 1 - Part No SW: -----------    HW: 480 000 810 15
   Serial number: 357000000004E27DD61W
   Subsystem 2 - Part No SW: -----------    HW: 480 000 110 15
   Serial number: 3580000000079B81E61U
   Subsystem 3 - Part No SW: -----------    HW: 480 400 710 15
   Serial number: 3510002C11CCEA05C318
   Subsystem 4 - Part No SW: -----------    HW: 480 400 610 15
   Serial number: 3520002B71CF2D70C1AH
   Subsystem 5 - Part No SW: -----------    HW: 480 402 208 14
   Serial number: 3550002AD16FC221E106
          B1000 1B [137] - Resistance Too High
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:12
9437723 - Igniter for Passenger's Airbag
          B1002 1B [137] - Resistance Too High
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:12
9440283 - Driver side knee airbag igniter
          B100C 1B [137] - Resistance Too High
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:12
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [137] - Open or Short to Plus
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:13
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [137] - Open or Short to Plus
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:13
1054981 - Databus
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:16
   Part No SW: 3Q0 953 521 BA    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20151014400977
   Coding: 6010
   VCID: F0E4797F2B2BFFC193-80A4
   Part No SW: 3V0 920 751     HW: 3V0 920 751
   Component: KOMBI         312 6422
   Coding: 07A5001AAF84000801886A095001000000000000
   Shop #: WSC 73430 031 00999
   VCID: F1E27C7B2021F6C99C-80A4
13639936 - Databus
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 14101510800369
   Coding: 030100045F087300EB00025A1C0F00010001070000000000000000000000
   VCID: F9F2445B7851BE8924-80AC
   Subsystem 2 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
   Serial number: 6092598103
197169 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:12
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: On
          U1101 00 [009] - Active
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:12
                    Terminal 15: On
   Serial number: HA1-00002.09.15
   Coding: 0301
   VCID: CA90CB976D37E511FD-809E
   Serial number: 15000088734017
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006OIN17696
   Coding: 001000000000010001A080808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_SK37.rod
   VCID: BB7E9E5332ED4C9976-80EE
Address 3C: Lane Change (J1086)       Labels: None
   Component: HRE_Master    H11 0071
   Serial number: 0381847817
   Coding: 02011103
   ROD: EV_HREntryHella.rod
   VCID: BC7C9D4F37E34BA17F-80E8
   Lane Change Assistant 2:
   Serial number: 150615BFE12746
   Coding: 001D0920DE00040000001100
   VCID: C38EE6B34A1D34593E-8096
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000007577658
   Coding: 110200
Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2033
   Revision: 00000000    Serial number: 0000399367
   Coding: 01010011005001
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_SK37.rod
3158336 - Databus
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
                    valid
5262640 - Steering angle sensor
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
                    valid
5262656 - Steering Angle Sensor
          B1168 F2 [137] - Not Initialized
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
                    valid
   Serial number: 120615BFC11686
   Coding: 001D0320DE00040000001100
   VCID: C280E3B755073D5135-8096
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000007662170
   Coding: 090200
   Coding: 06EA00003F010000
   VCID: C084E9BF5B0B2F4123-8094
   Component: LeiMo links  H01 0005
   Coding: B20000
   Component: LeiMo rechts  H01 0005
   Coding: B20000
13705992 - Databus
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 864 A    HW: 5Q0 035 864 A
   Component: MU-S-N-ER     H24 0245
   Serial number: SKZAZ2R8921301
   Coding: 038401010000000011110002000808002F0200E40120810086
   ROD: EV_MUStd4CTSAT_SK26.rod
   VCID: B162BC7BE0A1B6C9DC-80E4
   Subsystem 1 - Part No SW: 3V0 919 605 A    HW: 3V0 919 605 A
   Component: ABT_Std-2_Nav  H44 1028
   Serial number: SKZ8Z9RE6007A5
   Subsystem 2 - Part No SW: 5L0 051 236 E    HW: -----------
   Component: ECE 2015/16  --- 0430
   Part No SW: 5Q0 959 107 G    HW: 5Q0 959 107 G
   Component: HDSG-Modul    H12 0250
   Revision: --------    Serial number: 30286791600000
   Coding: 1008
   ASAM Dataset: EV_DeckLidCONTIAU736 001011
0066 - Databus
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:11
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 D    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0024
   Serial number: 29091511K20974
   Coding: 020408010000040100221346C040A00010000E100020
   Shop #: WSC 32684 001 1048576
   ROD: EV_MFKBoschMQBB.rod
   VCID: B874815F03DB67819B-80EC
1123173 - Databus
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:12
                    Control Module temperature: 23 °C
                    Outside air temperature: ERROR
                    Vehicle speed: 0.00 km/h
                    System run time: 16.6 s (second)
                    Voltage terminal 15: 11.8 V
                    mid: 02 DD
                    Camera_state: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 4
                    Software_Info_3: 2
                    Software_Info_2: 0
                    Software_Info_1: 0
1123175 - Databus
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:12
                    System run time: 17.0 s (second)
                    mid: 02 86
                    Software_Info_4: 4
                    Software_Info_3: 2
                    Software_Info_2: 0
                    Software_Info_1: 0
1123184 - Databus
                    Reset counter: 15
                    Mileage: 8709 km
                    Date: 2016.12.17
                    Time: 03:39:16
                    System run time: 20.9 s (second)
                    mid: 02 DF
                    Software_Info_4: 4
                    Software_Info_3: 2
                    Software_Info_2: 0
                    Software_Info_1: 0
End-------------------------(Elapsed Time: 05:18)--------------------------
Since you have exactly the same ECU part number and ASAM ID as sherlock, I guess the change to this ECU software wasn't exactly coincident with the 2016 -> 2017 model year change.
Do any of these faults show up in Generic OBD-II, either Mode 3 or Mode 7?
Gizmo
S.E.Kent UK
C?ID=49193
I coded a 2017 280 SportLine last weekend without issue... took the Audi code.
