Help with Long Coding for Polo 6R ABS Module please
atif
C?ID=212220
Hi All,
car came in from body shop with ABS light on, scanning with VCDS shows module not coded, can someone please help generate long code.
many thanks in advance.
Wednesday,02,July,2014,09:36:51:05329
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WVWZZZ6RZBY325004   License Plate:
Mileage:    Repair Order: MMPOLO
Chassis Type: 6R (6R0)
Scan: 01 03 08 09 15 17 19 25 44 56 61
Address 01: Engine (J0000-CFWA)       Labels: 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 C    HW: 03P 907 425
   Component: R3 1.2 DCM3.7 H06 8403
   Revision: 12005001    Serial number:
   Coding: 00114014032501080000
   ASAM Dataset: EV_ECM12TDI03103P906021C 001013
   ROD: EV_ECM12TDI03103P906021B.rod
   VCID: 285FF4A053E7CA5EF37-807D
Readiness: 1110 1000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 00788 648 00255
   VCID: 871D171C323965265AD-80D2
03306 - Coding Not Valid
                    Fault Frequency: 53
                    Reset counter: 175
                    Mileage: 3085 km
                    Date: 2012.14.24
                    Time: 00:00:06
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x1209
                    Hex Value: 0x1492
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Frequency: 109
                    Reset counter: 175
                    Mileage: 3071 km
                    Date: 2010.14.10
                    Time: 19:40:55
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x1211
                    Hex Value: 0x1498
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
                    Fault Status: 01100101
                    Fault Frequency: 80
                    Reset counter: 175
                    Mileage: 3075 km
                    Date: 2011.14.23
                    Time: 00:00:10
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x12E1
                    Hex Value: 0x20B7
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Reset counter: 208
                    Mileage: 3071 km
                    Date: 2010.14.09
                    Time: 23:59:09
                    Hex Value: 0x0003
                    Hex Value: 0x0002
                    Hex Value: 0x3211
                    Hex Value: 0x2593
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7D00
                    Reset counter: 208
                    Mileage: 3071 km
                    Date: 2010.14.09
                    Time: 23:59:09
                    Hex Value: 0x4002
                    Hex Value: 0x0002
                    Hex Value: 0x32A7
                    Hex Value: 0x2A91
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7E03
                    Reset counter: 213
                    Mileage: 3084 km
                    Date: 2012.14.18
                    Time: 05:39:41
                    Hex Value: 0x0007
                    Hex Value: 0x0003
                    Hex Value: 0x1224
                    Hex Value: 0x0364
                    Hex Value: 0x007F
                    Hex Value: 0x7F81
                    Hex Value: 0x7B00
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045.clb
   Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 326B16C86D3BB08E5D3-8067
                    Fault Status: 01100010
                    Reset counter: 175
                    Mileage: 3085 km
                    Date: 2013.14.08
                    Time: 20:32:14
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 088 D    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H46 0322
   Revision: BU046001    Serial number: 0379 126110896
   Coding: 64B02BBF08A10000002009B03C2B0CD0CF80610F7E860441A00000000000
   Shop #: WSC 12469 483 00190
   VCID: 3F8D4FFCAE696DE6A2D-806A
   Subsystem 1 - Part No SW: 6R0 959 802 R    HW: 6R0 959 802 R  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  006 0903
   Coding: 18BC30
                    Reset counter: 175
                    Mileage: 3085 km
                    Date: 2013.14.08
                    Time: 20:32:18
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag027 H09 0020
   Revision: --------    Serial number: 003GX00LT4W9
   Coding: 003237
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9B6E28EDABD84E053-801F
   Serial number: 357  RB4000000000004
   Serial number: 358  RB4000000000005
   Serial number: 3515RRB405N0I4AGAHAO
   Serial number: 3525RRB40630G942MGLB
9443091 - Driver's Side Airbag Crash Sensor
          B1017 13 [137] - Open Circuit
                    Mileage: 3085 km
                    Date: 2013.14.08
                    Time: 20:32:18
9451027 - Crash sensor side airbag; passenger side
          B1036 13 [137] - Open Circuit
                    Mileage: 3085 km
                    Date: 2013.14.08
                    Time: 20:32:18
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 3085 km
                    Date: 2013.14.08
                    Time: 20:32:19
   Part No SW: 6R0 920 961 F    HW: 6R0 920 961 F
   Component: KOMBI         H05 0304
   Coding: 440A00
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 397921E4B84D43D69C9-806C
Address 19: CAN Gateway (J533)       Labels: 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H38 0025
   Revision:   H38       Serial number: 300111F1003769
   Coding: 2500C3
   VCID: 336513CC9221B986565-8066
03406 - Control Module for Battery Monitoring
                    Reset counter: 175
                    Mileage: 3085 km
                    Date: 2013.14.08
                    Time: 20:33:15
   Component: IMMO          H05 0304
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EADB4EA80D6BB84EA53-80BF
   Part No: 6Q0 423 156 S
   Component: LenkhilfeTRW        V260
   Coding: 11250
   Shop #: WSC 70400
   VCID: 3F8D4FFC3A696DE6A2D-806A
01288 - Terminal 30; Steering Assist
            06-10 - Signal too High - Intermittent
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2L0408482
   Coding: 0500040002
   VCID: 6BD5CBAC8A9121465E5-803E
                    Reset counter: 175
                    Mileage: 3085 km
                    Date: 2013.14.08
                    Time: 20:32:24
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H38 0025
   Coding: 030B1A5A
   VCID: F4E750D057AF7EBE0FF-80A1
02071 - Local Databus
                    Fault Status: 01101100
                    Reset counter: 175
                    Mileage: 3085 km
                    Date: 2013.14.08
                    Time: 20:33:16
I know we do not have enough information at this time to build long coding for MK60EC1 ABS/ESP modules and I'm pretty sure that same applies to that RoW specific ESP8.2i system as well.
If that is a regular customer of yours please search the Logs folder to see if you have an Auto-Scan saved prior to the lost coding and we should be able to help you re-enter it. If you do not have a scan with the original coding I would send this one off to the dealer for online SVM coding. If you go that route please try to save and post the final scan here after the controller is coded properly.
Gone But Not Forgotten
Try these maybe.......
210228E3216E00B8842514EA84D800401100
210228E3417500B9842B14E282D200421100
210228E3417000B9842E14EA82D800521300
210228E3417400B7842A14E382D500521300
210224E3217500B5842D24E984D600401300
110248DB837100BB882E12E2C1D800421700
