- Oct 3, 2016
- 88
- 36
- Stockholm Sweden
- C?ID=172802
Hi!
Car shows "Break Fault" within startup, ABS and ESP lights. What do I look for? Check wiring and electrical connections to J646? Is it the same module as the "AWD Controller"? Were is it located? Broken ABS wheel sensor?
Scan below is made after attempt to clearing faults.
Thank you.
//AndySwede
Thank you.
//AndySwede
Sunday,06,November,2016,17:23:24:51824
VCDS Version: 16.8.3.1 (x64)
VIN: WVGZZZ7LZ3D009264 License Plate: UAF325
Mileage: 171931km-106832mi Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ3D009264 Mileage: 171930km-106832miles
Address 01: Engine Labels: 022-906-032-BMX.lbl
Part No SW: 022 906 032 BE HW:
Component: MOTRONIC ME7.1.1G 0008
Coding: 0001133
Shop #: WSC 40090 222 00545
VCID: 4F954C47DD175C3A75-FFFE
18053 - Powertrain Data Bus
P1645 - 008 - Missing Message from AWD Controller
Readiness: 0010 1101
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No: 09D 927 750 A
Component: AL 600 6Q 0584
Coding: 0004136
Shop #: WSC 40231 222 91635
VCID: 2C6F3BCB8CC1472230-FFFE
02053 - Control Module for Transfer Case (J646)
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 B
Component: ESP ALLRAD MK25 0106
Coding: 0014593
Shop #: WSC 31414 000 00000
VCID: 3847179B4899FB8244-FFFE
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 131 T HW: 5WK 470 21
Component: Kessy 6120
Coding: 0000232
VCID: 325325B3AEE511D27A-FFFE
Component: ELV XXXX
00172 - Key 2 not learned
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 D
Component: CLIMAtronic R/L 0302
Coding: 0001020
VCID: 31512ABFABE32ACA03-FFFE
02100 - Footwell Flap Motor (V261)
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 K
Component: 2701
Coding: 0105637
VCID: 44BF736B0451AF62D8-FFFE
01117 - Generator Terminal DF Load Signal
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 B
Component: 4 Airbag 8.4E+ H07 0641
Coding: 0008244
VCID: 2273D5F3FE0581528A-FFFE
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 B
Component: Lenksäulenmodul 3201
Coding: 0000011
VCID: 3E4B01836ABDC5B28E-FFFE
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 880
Component: KOMBIINSTRUMENT RB4 2835
Coding: 0007111
VCID: 74DFE3AB14715FE2A8-FFFE
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70D7EFBB606963C24C-FFFE
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) X012
Coding: 0000003
VCID: 66FB89E352ADBD7226-FFFE
00492 - Body Pitch Angle from Level Control Module
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L6 907 553 B
Component: LUFTFDR.-CDC- 3C1P1 3650
Coding: 0015520
Shop #: WSC 40060 222 12826
01324 - Control Module for All Wheel Drive (J492)
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) X012
Coding: 0000003
VCID: 67E584E755A7A47A1D-FFFE
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 C
Component: 4N HSG 3214
Coding: 0000065
VCID: 3C4F0B8B7CA1D7A2A0-FFFE
Subsystem 1 - Part No: 7L0 959 701 H
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702
Component: Tuersteuergeraet BF 0104
Subsystem 3 - Part No: 7L0 959 703
Component: Tuersteuergeraet HL 0104
Subsystem 4 - Part No: 7L0 959 704
Component: Tuersteuergeraet HR 0104
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 7L6 035 195
Component: Radio DE2 0003
Coding: 0001405
Subsystem 1 - Part No: 7L6 035 195
No Faults Found
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000002
Shop #: WSC 31414 000 376832
VCID: 374514A74587F4FA4D-FFFE
End-------------------------(Elapsed Time: 13:10)--------------------------
