ABS Light on Dash, ABS Pump Supply Voltage 1201
Alan_Harrington
Ireland
C?ID=268223
Audi A4 B7 (2005) 1.9 TDi
Have an ABS issue with lights on dash, the fault which kept appearing was ABS Voltage Supply 1201. When doing output tests the pump also will not activate. I checked the connector and two wires (Supply) had Vbattery and two wires on other end were grounds. I changed the pump adapted module with same fault. I then checked all wiring again and removed ground cleaned them up with sand paper and tried ground somewhere else. Problem still remained. Did a continuity check earlier on ground with no issues. Have no idea what issue could be any help appreciated thanks.
This is the last auto scan please note the module needs adaptation with steering angle sensor, some faults ABS related are due to it being unplugged with ignition on. The voltage supply issue had been cancelled hence not being in the full auto scan. The last scan of the ABS module attached has the DTC I cannot get rid of.
Friday,04,November,2016,17:36:40:28282
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
VIN: WAUZZZ8EX5A417089   License Plate: A4 GOLD 2005
Mileage: 245710km-152677mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8EX5A417089   Mileage: 245710km-152677miles
Address 01: Engine        Labels: 03G-906-016-BKE.lbl
   Part No SW: 03G 906 016 FE    HW: 028 101 212 7
   Component: R4 1,9L EDC G000SG  7002
   Revision: 12345678    Serial number: AUX6Z0D0434975
   Coding: 0000071
   Shop #: WSC 00000 785 00200
   VCID: 6BD5AC1849EB8A1A65-5140
18107 - Powertrain Data Bus
            P1699 - 000 - Missing Message from Steering Wheel Electronics
                    Torque: 85.4 Nm
                    Voltage: 12.01 V
                    Bin. Bits: 11001100
                    Bin. Bits: 00000000
                    (no units): 1.0
18049 - Please check DTC Memory of A/C Controller
            P1641 - 000 -
                    Torque: 85.4 Nm
                    Voltage: 12.01 V
                    Bin. Bits: 11001100
                    Temperature: 9.0∞C
                    (no units): 144.0
18057 - Powertrain Data Bus
            P1649 - 000 - Missing Message from ABS Controller
                    Torque: 85.4 Nm
                    Voltage: 12.01 V
                    Bin. Bits: 11001100
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
Readiness: 0 0 1 1 1
   Part No SW: 8E0 910 517 B    HW: 8E0 614 517 AT
   Component: ESP8 front      H04 0180
   Coding: 0004401
   Shop #: WSC 06335 000 00000
   VCID: 26439D2C91897772FA-8072
                    Fault Status: 01100101
                    Hex Value: 0x0000
                    Hex Value: 0x6222
                    Hex Value: 0x00FF
                    Hex Value: 0xFFAE
                    Hex Value: 0x00FF
                    Fault Status: 00101101
                    Hex Value: 0x0000
                    Hex Value: 0x6222
                    Hex Value: 0x00FF
                    Hex Value: 0xFFAE
                    Hex Value: 0x00FF
   Part No: 8E0 820 043 AJ
   Component:   A4 Klimaautomat   2831
   Coding: 00000
   VCID: 69D9D6101317980A17-5140
            30-00 - Open or Short to Plus
   Part No: 8E0 907 279 K
   Component: int. Lastmodul  ECE 0504
   Coding: 00001
   Shop #: WSC 06335
   VCID: 3A7B595C2631E392AE-4B00
01794 - Control Module - Incorrect Chassis (VIN) Number
            35-00 -  -
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H11 3530
   Revision: 91H1135    Serial number: 0036M0047AKT
   Coding: 0030622
   VCID: 3B755C587A0BDA9AB5-806E
   Subsystem 1 - Serial number: 6332DRB4019B0A1DS
   Subsystem 2 - Serial number: 6342DRB4019C0F8B/
   Subsystem 3 - Serial number: 6352ARB40057B2F9V
   Subsystem 4 - Serial number: 6362ARB4005BE01BP
   Subsystem 5 - Serial number: 63729RB40069BDDA2
   Subsystem 6 - Serial number: 63829RB40069BB8F1
                    Reset counter: 39
   Part No: 8E0 953 549 S
   Component: Lenks·ulenmodul     0611
   Coding: 00001
   VCID: 438524B851FBA25AFD-4AE8
   Part No SW: 8E0 920 950 Q    HW: 8E0 920 950 Q
   Component: KOMBI+WFS 3     H12 0020
   Revision: 0020        Serial number: AUX6Z0D0434975
   Coding: 0004404
   Shop #: WSC 00006 210 03797
   VCID: 377D40684523FEFA51-5140
   Coding: 0004404
Address 46: Central Conv.        Labels: 8E0-959-433-MIN.lbl
   Part No: 8E0 959 433 BP
   Component: Komfortger·t T85    3332
   Coding: 06896
   Shop #: WSC 06335
   VCID: 000FEBB4006D7942A0-4AE8
   Subsystem 1 - Part No: 8E2959802B
   Component: Tırsteuer.FS BRM 1215
   Subsystem 2 - Part No: 8E2959801B
   Component: Tırsteuer.BF BRM 0205
   Part No: 8E0 035 186 D
   Component: concert II  GRO    0004
   Coding: 01001
   Shop #: WSC 06335
   VCID: 285F9314C89D6102C8-4B00
End-------------------------(Elapsed Time: 07:11)--------------------------
Friday,04,November,2016,17:44:51:28282
          67 69 75 76 77
Control Module Part Number: 8E0 910 517 B    HW: 8E0 614 517 AT
  Component and/or Version: ESP8 front      H04 0180
           Software Coding: 0004401
            Work Shop Code: WSC 06335 000 00000
01201 - ABS Pump Supply Voltage
            000 -  -
                    Hex Value: 0x0C00
                    Hex Value: 0x4002
                    Hex Value: 0x00FF
                    Hex Value: 0xFFAA
                    Hex Value: 0x00FF
Moving to Car Repair Support. "General" is for things not VCDS isn't pertinent to.
DrPeter
16.4905° S, 151.7375° W
- According to my research, there are three power and two ground connections to the J104- ABS Controller.
If these are 100% correct, the V39-Pump is functional (you can remotely power it) and your 'problem' / fault code still remains the ABS Controller is the only other possible source of the fault code.
- I suggest to make sure the V39-pump can run on the bench and double check all the connectors/wiring to the ABS controller, there needs to be good/strong powers and grounds for the ABS controller to operate the system and if you have a voltage drop under load, that is a problem.
- Always refer to the factory repair manuals for information:
Official Factory Repair Information
Hope this helps,
drpeter
WordBank
C?ID=52953
          67 69 75 76 77
            000 -  -
                    Hex Value: 0x0C00
                    Hex Value: 0x4002
                    Hex Value: 0x00FF
                    Hex Value: 0xFFAA
                    Hex Value: 0x00FF
Where you checking voltage to the module or to the pump itself? This is one with internal wiring to the pump right not the external connector just for the pump power?
Did you replace the entire unit with control module and distribution block/ pump or just the pump/block? Are you getting power through them module to where it connects to the pump/block?
Alan_Harrington
Ireland
C?ID=268223
Yeah there are two grounds which are grounded underneath the pump, I cleaned these up with sandpaper and even tried grounding them at an alternative location but was no good. When checking the plug against another identical Audi A4 B7 the resistance to ground of each the the grounds was identical.
I found 5 pins had voltages over 10.5V, with 3 of them having battery voltage. I have a diagram at home I drew when comparing.
Just lastnight I removed the windscreen washer reservoir and plugged the ABS Pump (with module) into an identical Audi A4, the pump worked when I activated it through Output Tests and had no DTCs. Ruling the pump out.
I must have a problem with my wiring has to be a problem with one of the three supplies
Alan_Harrington
Ireland
C?ID=268223
I can't find where the power supplies orginate from. I have seen on the internet that a 40A fuse near the ECU is for the module. I ruled all relays and fuses out already.
Another problem (more than likely unrelated) is the interior lighting will not work
How do you mean can the leads carry the actual current ? Surely if they have the correct voltages the wiring should be good ? Or should I find where they originate from and carry out a resistance check of the wire ?
Alan_Harrington
Ireland
C?ID=268223
All references I made are to the connector to the module. It's a Bosch 8.0 control module. All wiring goes through the connector. I changed the entire unit twice, I also verified the other units are good.
I checked the pins in the connector and they all look good and do not look damaged or like they would not make contact when connected to the module
Westbury, UK
Check out the WD, then try running a suitably sized wire from the connector on the pump to the relay/fuse where it should be powered from.
It's possible that a crimp in the harness may be high resistance or the wire is damaged - both could cause a voltage drop when the pump runs and draws many amps.
Gone But Not Forgotten
This is where a tone generator comes in very handy........
So you are saying you plugged in another complete module and it worked right in this car or it has the same error?
Please advise......
Alan_Harrington
Ireland
C?ID=268223
In the car which has a problem two different complete ABS Pump (&Module) were fitted.
I then took one of these and plugged it into a good car with no faults for peace of mind and the units work perfect
Probably didn't explain that well enoigh
Alan_Harrington
Ireland
C?ID=268223
That is what I am going to try that has to be my problem. More than likely one of the 3 power supplies has too much resistance as you say only noticed when a lot of current is drawn
Okay lets have a look here.
photo share
https://s11.postimg.org/u12hsd5bn/J104.png
Alan_Harrington
Ireland
C?ID=268223
I meant to reply last week,
I put a Halgoen bulb on each of the power supplies and found a large voltage drop on one of the supplies. I ran a new supply with wire of the cross section. Obviously when measuring with the multi meter there wasn't enough current flowing to see a voltage drop.
Thanks very much to everyone who replied. I will know for future to test correctly, had I done so it would have saved a lot of time
