need some help. replaced abs controller. i have the original coding from the old unit. every time i enter the new coding it accepts it but then it doesnt next time you check the coding is back to all zeros (00000000) am i doing something wrong
Thursday,03,November,2016,16:58:07:11898
VCDS Version: 16.8.3.1 (x64)
Dealer/Shop Name: Sterling Garage Ltd
VIN: WVWZZZ1KZ9W048546 License Plate:
Mileage: 189040km-117464mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9W048546 Mileage: 189040km-117464miles
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 PM HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 1136
Revision: --H08--- Serial number: VWX7Z0H53NU0LG
Coding: 0000071
Shop #: WSC 01279 785 00200
VCID: 79F3DF9930F7288AFB-802C
005705 - Powertrain Data Bus
P1649 - 000 - Missing Message from ABS Controller - Intermittent
Mileage: 189045 km
Time: 00:10:34
Voltage: 12.16 V
Bin. Bits: 00101100
Torque: 0.0 Nm
Bin. Bits: 00000000
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 00066 000 00000
VCID: 74EDEEADD79555E2A8-8020
01169 - Door Contact Switch Driver Side (F2)
Reset counter: 23
Mileage: 277391 km
Count: 32768
Count: 4608
Count: 147
Count: 51255
Count: 260
Fault Status: 01100101
Reset counter: 132
Mileage: 189045 km
Count: 3
Count: 2
Count: 12288
Count: 279
Count: 39168
Reset counter: 132
Mileage: 189045 km
Count: 3
Count: 2
Count: 12288
Count: 295
Count: 39168
Reset counter: 132
Mileage: 189045 km
Count: 3
Count: 2
Count: 12288
Count: 270
Count: 39168
Reset counter: 133
Mileage: 189045 km
Count: 3
Count: 2
Count: 12288
Count: 195
Count: 39168
Part No: 1K0 820 047 GK
Component: Climatic PQ35 120 0606
VCID: 73EFEDB1129B52DAB1-8026
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000008468641
Coding: E4890F2700041500471400001400000000087B075C000100000000000000
Shop #: WSC 00000 785 00200
VCID: 326128B5AD011BD27A-8066
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 170608 021 0501
Coding: 00038805
Component: RLS 010708 054 0402
Coding: 00209069
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1WE7X7
Coding: 0013112
VCID: 3D7B0B89645FD4AA97-8068
Subsystem 1 - Serial number: 6332MSME2F61790FQ
Subsystem 2 - Serial number: 6342MSME3B436914D
Subsystem 3 - Serial number: 6352QSME64363D29N
Subsystem 4 - Serial number: 6362QSME7D323551H
Part No SW: 1K0 953 549 CB HW: 1K0 953 549 CB
Component: J0527 051 0101
Coding: 0002022
VCID: 74EDEEAD179555E2A8-8020
Component: E0221 002 0010
Part No SW: 1K0 920 974 B HW: 1K0 920 974 B
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0002000 Serial number: VWX7Z0H53NU0LG
Coding: 0003403
Shop #: WSC 01286 386 08256
VCID: 2D5B3BC9B43F442A27-8078
Reset counter: 172
Mileage: 189045 km
Time: 00:10:33
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 260608F2000573
Coding: E9807F060002020003
VCID: 356B13A95C6F0CEA5F-8060
Component: IMMO VDD 2416
Shop #: WSC 00137 211 56823
00003 - Control Module
014 - Defective
Fault Status: 01101110
Mileage: 188970 km
Time: 19:52:31
Address 42: Door Elect, Driver Labels: None
Part No SW: 1K0 959 701 AK HW: 1K0 959 701 AK
Component: Tuer-SG 006 1204
Coding: 0000692
VCID: 77F7D9A106E33EFA8D-8022
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 69 2301
Revision: 00H15000
VCID: 2A5130D585D15312C2-807E
Fault Status: 00101101
Reset counter: 182
Mileage: 189043 km
Time: 00:41:13
Voltage: 14.00 V
DU
Temperature: 33.0°C
RPM: 1830 /min
Speed: 16.0 km/h
Speed: 16.0 km/h
Reset counter: 182
Mileage: 189045 km
Time: 00:10:36
Voltage: 12.13 V
DU
Temperature: 27.0°C
Speed: 50.0 km/h
Speed: 50.0 km/h
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 819002005103087F2D04840570085FC690FC00
VCID: 030FBD71423B625AA1-8056
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
Reset counter: 133
Mileage: 189033 km
Time: 00:06:36
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Component: Tuer-SG 006 1220
Coding: 0000692
VCID: 39731F997077E88ABB-806C
Part No: 1K0 035 186 AF
Component: Radio GR0 036 0034
Revision: 0003606S Serial number: VWZ2Z2H1160322
Coding: 0040402
Shop #: WSC 00339 210 77419
VCID: 6AD1F0D54551931202-803E
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1302
Coding: 0000144
Shop #: WSC 01279 785 1012552
VCID: 38751A9D4B7DF18244-806C
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Component: Tuer-SG 006 1305
Coding: 0000144
End-------------------------(Elapsed Time: 01:42)--------------------------
