New VCDS Hex-Net User
brknhalo
C?ID=209727
I am totally new to this type of device and have some questions. I figure I would try here before I call support.
Prerequisites:
I have been able to connect to the Hex-Net and clear a few codes after doing a tune-up on my car
I have a 2009 Audi A6 3.0T
Questions:
Which manual should I use for the Hex-Net?
How can I release my EPB so I can change the rear rotors and pads? The video for doing this is for the VCDS and not the Hex-Net and the fields are different.
NOTE: This was costly for me to do yesterday because I had rented a garage heater to do this and now I have to pay for another days rental and I lost precious hours trying to figure it out.
How can I DL the missing codes it says I will be prompted to do once the autoscan is complete?
How can i clear the "brake" and "Service Due" on my dash?
Do I plug this into my car when the car if off and then turn the key to the on position once this is done? I have done this so far with success.
Do I have to have the car running when I perform certain diagnostics?
I look forward to hearing back from anyone that can assist.
There is no manual per se. As a Beta product, the documentation currently consists of the FAQs and some videos. Also, the HEX-NET is an interface, a piece of hardware. I suppose you are asking about a manual for VCDS-Mobile? Use of VCDS-Mobile is very similar to VCDS.
How can I release my EPB so I can change the rear rotors and pads? The video for doing this is for the VCDS and not the Hex-Net and the fields are different.[/quote]
Have you been to our Wiki page for the EPB in your car? The only really significant difference should be a couple of extra button presses, for example:
[Select]
[53 - Parking Brake]
[Functions]
[Cloud Functions] (requires internet access)
[Basic Settings - 04]
Or, use the HEX-NET as an interface for the classic version of VCDS.
I hate to sound unsympathetic, but the HEX-NET and VCDS-Mobile are clearly sold as a BETA product.
Have you tried [Options] -> [Check for updates] with you HEX-NET connected to a network that has internet access?
Brake should clear once you've successfully finished your brake job. "Service Due" will require tweaking some adaptation channels in the instrument cluster. On 2008 and newer Audis, there are three separate counters that can trigger "Service Due"... The first is for the normal oil change service, but there's also one for a mileage-based inspection and another for a time-based inspection. It may be most expedient to use VCDS for this.
Shouldn't matter. The biggest caveat with the HEX-NET is that it may go into low-power sleep mode after a while if the ignition isn't on.
For some procedures it is necessary to have the engine running. For others, it is necessary to have it NOT running.
PS: Look what we found.. A previously unpublished video...
brknhalo
C?ID=209727
Update
I was able to perform the rear brake maintenance after figuring out that I could only do the EPB release procedure while in the "cloud". The cloud is where the main point of contention on this Hex-Net. I will keep working with it and learning.
I need to figure out what I need to do to get rid of the "Service Due" on my dashboard. I believe to remove the "brake" warning is to follow the procedure for the A8, which is inputting the new pad width. I will post when that is done.
Santos
My understanding is the A6 does not require pad thickness to be entered.
Did you run the function test? Basic settings 010.
Agreed, I 'm pretty sure only the old (D3 platform / 4E Chassis) A8 needed that; it was the original car with EPB, and I haven't heard of any other, newer EPB system has needed the pad thickness entered manually; I believe they figure it out themselves when you run a function test.
jakematic
NC USA
C?ID=129085
I can confirm pad thickness is not necessary on the C6.
Simply followed the wiki instructions last summer when replacing brakes on a 2008.
brknhalo
C?ID=209727
Update
I did perform the function test to no avail. I also ran another manual autoscan but found no fault codes pointing to that. I will be taking the car out today to run-in the new brakes and see if that clears anything up.
The parking brake is working fine as well.
Please post up a photo of whatever brake warning is still active in your instrument cluster, as we all an Auto-Scan from your car.
brknhalo
C?ID=209727
Pics
How do I attach a picture? To attach, I need to specify a URL?
This is all such a learning experience.
I did do the pad/rotor burnishing this morning (lots of smoke) but the pads icon and the brake warning are still there. I will also do another scan this morning.
What part, if not all, of the scan do you need me to copy in here? Would sending the pics and the scan be easier?
Regards,
brknhalo
C?ID=209727
I did do the pad/rotor burnishing before I took the pictures of the pad and brake icons on the dash. I am doing another scan right now. Did you want the entire scan in here or just particular portions of it? I can always email the pics and the scan as well.
Regards,
jakematic
NC USA
C?ID=129085
If you have a photo hosted at say Photobucket, you can copy and paste a link to it with the IMG tags surrounding it into a reply.
Otherwise click the Insert Image icon (3rd from right on reply, looks like a tree in a square) and it will attach to the post.
Santos
Imgur.com is a good quick image hosting site. It allows drag and drop uploads.
brknhalo
C?ID=209727
Requested Pics
Please let me know if this worked.
Regards,
EDIT: It did, but only after I fixed your tags, see instructions next messages down.
In order to post a picture, you put the URL in between IMG tags, like this:
[img]http://i.imgur.com/ovthCi3.gif[/img]
or graphically:
Uhh.. Ok...
All of it please. We like complete scans. We may not need it all, but it never hurts to post it all.
Uhh... No. ;)
brknhalo
C?ID=209727
VCDS Mobile 0.4012.0.4
Chassis Type:4F or FB
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 13 15 16 17 18 19 1E 20
	 28 34 36 37 3D 42 46 47 4C 4F 52 53 55 56 57 5F 61 62 65 67
	 69 6D 72 76 77
VIN: XXXXXXXXXXXXXXXXX
Address 01: Engine	Labels:4F-01.lbl
	Part Number SW: 4F1-910-551-A	HW: 4F1907551
	Component: 3.0l V6 TFSI         0060
	Revision: --H07---	Serial Number:
	Coding: 0105010A190F0160
	Shop #: WSC 09111 444 12583
	VCID: 21057687A8D3FAB46CB72
009728 - Coolant Pump Control Circuit
	P2600 - 000 - Open
		Mileage: 84708 km
		Date: 2014.03.02
		Time: 15:38:07
		RPM: 672 /min
		Mass Air / Rev.: 147.2 mg/str
		Temperature: 84.0°C
		Bin. Bits: 00000010
		Load: 13.7
Address 02: Auto Trans	Labels:4F-02.lbl
	Part Number SW: 4F1-910-156-K	HW: 09L927156C
	Component: AG6 09L 3,0TFSI USA  0020
	Revision: --H04---	Serial Number:        4484539
	Coding: 0000002
	Shop #: WSC 02325 785 00200
	VCID: 2C1B97B3DF1127DCCF41B
No fault codes found.
Address 03: ABS Brakes	Labels:4F0-910-517.lbl
	Part Number SW: 4F0-910-517-AL	HW: 4F0614517BA
	Component: ESP8 quattro    H01  0060
	Revision: 00000000	Serial Number: 00000000000000
	Coding: 0020921
	Shop #: WSC 01995 444 90131
	VCID: 6E9F5DBB298D15CCA1B51
Address 05: Acc/Start Auth.	Labels:4F0-910-852.clb
	Part Number SW: 4F0-910-852-B	HW: 4F0907335B
	Component: FBSAUDIC6 ELV   H05  0100
	Revision: 00H05000	Serial Number: 10602501187431
	Coding: 0000007
	Shop #: WSC 02324 785 00200
	VCID: 250D6297BCFB1694108F6
	Subsystem 1 - 	Part Number: 4F0-910-132-L
	Component: FBSAUDIC6 EZS   H03  0020
	Subsystem 2 - 	Part Number: 4F0-910-335-B
	Component: FBSAUDIC6 KSG   H02  0020
Address 07: Control Head	Labels:4F0-910-7xx-07-H.lbl
	Part Number SW: 4F0-910-732-R	HW: 4F1919611N
	Component: Interfacebox    H43  4610
	Coding: 0000003
	VCID: 322789CBFD35712C850D5
	Subsystem 1 - 	Part Number: 4F0-910-609-E
	Component: Bedienteil MMIC6H01  0060
Address 08: Auto HVAC	Labels:4F0-910-043.lbl
	Part Number SW: 4F0-910-043-A	HW: 4F1820043AG
	Component: KLIMABETAETIGUNGH30  0020
	Revision: 00000054	Serial Number: 00000030390330
	Coding: 0524326
	VCID: 1C7B47738FB1D75CBFE1B
Address 09: Cent. Elect.	Labels:4F0-910-279.lbl
	Part Number SW: 4F0-910-279-M	HW: 8K0955559A
	Component: ILM Fahrer      H22  0320
	Revision: 00000000	Serial Number: 4F0907279
	Coding: 0133123
	Shop #: WSC 01995 444 85737
	VCID: 33298CCF022F78248EFB8
	Subsystem 1 - 	Part Number: 4F1-910-113-D	Labels:1Kx-955-119.clb
	Component: Wischer AudiC6  H10  0040
	Coding: 0064784
	Subsystem 2 - 	Part Number: 8K0-910-557	Labels:8K0-955-559.clb
	Component: REGENLICHTSENSORH04  0003
	Coding: 0146221
Address 0e: Media Player 1  (R199)	Labels:4E0-035-785.lbl
	Part Number SW: 4E0-035-785-F	HW: 4E0-035-785-C
	Component: SG ext.Player H15 0850
	Revision: 00000000
	VCID: 2B1994AFDA1FA0E4C64B0
Address 0f: Digital Radio	Labels:4E0-910-593-SIR.lbl
	Part Number SW: 4E0-910-593-M	HW: 4E0035593F
	Component: SDAR SIRIUS     H07  0160
	Revision: 00000000	Serial Number: AUZ4Z7H0402625
	Coding: 0000100
	VCID: 312586C7F8334A34FC172
Address 15: Airbags  (J234)	Labels:4F-15.lbl
	Part Number SW: 4F0-910-655-M	HW: 4F0-959-655-F
	Component: Airbag AU1042 H06 0090
	Revision: --------
	Coding: 303142373034303030314A55304C34463053
	VCID: 312586C7F833D234FC172
	Subsystem 1 - 	Part Number: 4F0-910-339-B
	Component: BF-Gewichtss.H03  0060
	Serial Number: 5810000R000000306Uªª
	Subsystem 2 - 	Serial Number: 3574SRB400007E990212
	Subsystem 3 - 	Serial Number: 3584SRB400007E98F93Q
	Subsystem 4 - 	Serial Number: 35152RB402566ME153IB
	Subsystem 5 - 	Serial Number: 35252RB402L7EMTBA3V.
	Subsystem 6 - 	Serial Number: 3554NRB4000041D0C4C
Address 16: Steering wheel	Labels:4F0-910-549.lbl
	Part Number SW: 4F0-910-549-A	HW: 4F0953549D
	Component: J0527                0410
	Revision: 00H03000	Serial Number: 90055082530489
	Coding: 0012141
	VCID: 2711689FC6F704842273C
	Subsystem 1 - 	Part Number: XXX-XXX-XXX-XX
	Component: E0221           H02  0030
Address 17: Instruments  (J285)	Labels:4F0-920-xxx-17.clb
	Part Number SW: 4F0-920-983-C	HW: 4F0-920-983-C
	Component: KOMBIINSTR.   H06 0133
	Revision: 00100000
	Coding: 8B960A050B00CF05020201
	Shop #: WSC 02399 823 56573
	VCID: 2C1B97B3DF11A7DCCF41B
Address 19: CAN Gateway  (J533)	Labels:4F0-907-468.clb
	Part Number SW: 4F0-907-468-F	HW: 4F0-907-468-F
	Component: GW-BEM 4CAN-M H06 0024
	Revision: 4LA70021
	Coding: 000303
	VCID: 322789CBFD35F12C850D5
	Subsystem 1 - 	Part Number: 8K0-915-181-C
	Component: J367-BDM     H07 0100
Address 1e: Media Player 2	Labels:4E0-910-111.lbl
	Part Number SW: 4E0-910-110-C	HW: 4E0035110A
	Component: MP3-Changer     H46  0350
	Revision: 00046006	Serial Number: AUZ5ZBG3503505
	VCID: 18735B637B89BB7C9B097
Address 36: Seat Mem. Drvr  (J136)
	Part Number SW: 4F0-959-760-C	HW: 4F0-959-760-C
	Component: MEM-FS        H08 0062
	Revision: AA000000
	Coding: 00581B00004011110000
	VCID: 312586C7F833CA34FC172
Address 37: Navigation	Labels:4E0-910-88x-37.lbl
	Part Number SW: 4E0-910-888-M	HW: 4E0919887M
	Component: MNS US          H52  1100
	Revision: 00000000	Serial Number: 395I
	Shop #: WSC 01995 444 05005
	VCID: 3833BBE31B499B7CBBC97
Address 42: Door Elect, Driver  (J386)	Labels:4F0-959-793.clb
	Part Number SW: 4F0-959-793-R	HW: 8K0-959-793-D
	Revision:
	Coding: 011F57204E40410001
	VCID: 46CFC51B61BD7D8C39459
Address 46: Central Conv.	Labels:4F0-910-289.lbl
	Part Number SW: 4F0-910-289-N	HW: 4F0907289N
	Component: Komfortgeraet   H28  0240
	Revision: 02400028	Serial Number: 01157162500000
	Coding: 4618269
	Shop #: WSC 07117 444 11082
	VCID: 352DB2D70C5B6614A0EF6
	Subsystem 1 - 	Part Number: 1K0-951-605-C
	Component: LIN BACKUP HORN H03  1301
Address 47: Sound System	Labels:4F0-910-223-BO.lbl
	Part Number SW: 4F0-910-223-J	HW: 4F0035223G
	Component: DSP-High C6     H10  0240
	Revision: PROD_01 	Serial Number: 00000000116667
	Coding: 0000026
Address 4c: Tire Pressure II	Labels:4F0-910-274.clb
	Part Number SW: 4F0-910-274-B	HW: 4F0907274
	Component: J793  RKA+      H03  0110
	Revision: 00000276	Serial Number: 00002760052800
	Coding: 0623301
	VCID: 23097C8FB2CFE8A47E9B8
Address 4f: Centr. Electr. II	Labels:4F0-910-280.lbl
	Part Number SW: 4F0-910-280	HW: 4F0907280C
	Component: ILM Beifahrer   H12  0100
	Revision:         	Serial Number: 00000000245565
	Coding: 0002014
	VCID: DEFF8D7B592D054C91551
Address 52: Door Elect, Pass.  (J387)	Labels:4F0-959-792.clb
	Part Number SW: 4F0-959-792-R	HW: 8K0-959-792-D
	Revision:
	VCID: 45CDC2175CBB7694304F6
Address 53: Parking Brake	Labels:4F0-910-801.clb
	Part Number SW: 4F0-910-801-D	HW: 4F0907801B
	Component: EPB  CEFC0090   H05  0090
	Revision: --H05---
	Coding: 0000222
	Shop #: WSC 02145 785 00200
Address 55: Xenon Range	Labels:4F0-910-357.lbl
	Part Number SW: 4L0-910-357	HW: 4L0907357
	Component: AFS 1           H01  0040
	Revision: 00000001	Serial Number:
	Coding: 0000026
	VCID: E995AEA7906372F474E7A
	Subsystem 1 - 	Part Number: 4F0-941-329-D
	Component: AFS-Modul links H01  0010
	Subsystem 2 - 	Part Number: 4F0-941-329-D
	Component: AFS-Modul rechtsH01  0010
		Fault Status: 00101010
		Reset Counter: 87
		Mileage: 57123 km
		Date: 2012.12.11
		Time: 15:21:41
Address 56: Radio	Labels:4E0-910-541.lbl
	Part Number SW: 4E0-910-541-T	HW: 4F0035541N
	Component: TUNER EU/US/RDW H42  0630
	Revision: 00000000	Serial Number: 379I+087525743
	Coding: 0000002
Address 62: Door, Rear Left  (J388)	Labels:4F0-959-795.clb
	Part Number SW: 4F0-959-795-M	HW: 8K0-959-795-B
	Revision:
	Coding: 010E57204040220001
	VCID: 43C9DC0F528F48A41E5B8
Address 67: Voice Control	Labels:4E0-910-75x-67.lbl
	Part Number SW: 4E0-910-754-Q	HW: 4E0035753A
	Component: SDS 3501 US     H46  0630
	Revision: 00000000	Serial Number: 00000809020086
	Shop #: WSC 12336 024 394758
	VCID: 342B8FD307217F1C97F13
Address 72: Door, Rear Right  (J389)	Labels:4F0-959-795.clb
	Revision:
Address 77: Telephone	Labels:4E0-910-336.lbl
	Part Number SW: 4F0-910-336-H	HW: 4E0862335
	Component: Handyvorb2      H20  1130
	Revision: 00000000	Serial Number: 00000005060502
	Coding: 0010900
	Shop #: WSC 02256 785 00200
	VCID: 28136BA3CBE90BFC2B697
brknhalo
C?ID=209727
I also received a notice while doing the scan:
"ASAM Data missing for some modules in scan. You will be prompted to download the missing data after the scan"
I have not been prompted.
What kind of shape are your front brakes in? They probably have a simple pad-wear circuit that wired's to the instrument cluster. This normally just lights the warning and doesn't produce any fault codes.
Did the HEX-NET have an internet connection at that time? If not, have you done a [Check for Updates] since they while it did?
brknhalo
C?ID=209727
I just replaced the pads and rotors for both front and back. The front pads had the sensors on them as expected. I am hoping there is a way to clear that fault.
