Hi everyone,
Should've become a member a long time ago here, i'm from Montreal Canada and been using Ross-Tech interfaces for about 6-7 years now.
I maintain a lot of VW and Audis for fun and for friends.
I've hit a wall with a particular issue of a car i'm working on for myself, it's a 2009 Passat Highline 2.0T 6MT
When i got the car, its famous Dynaudio amplifier was taken out and on the back seat, i tracked down the previous owner who tells me its toast and need a new one
After playing around with it a bit, i discovered some of the power leads were corroded beyond any possible contact and i addressed that issue by making sure current now can get to where it needs to go
on the main amplifier plug.
The head unit is an RNS 510 with Navigation, part #3C0 035 684A Long Coding, since i have the car, there's no sound coming out of any speakers no matter what i try
So knowing i don't have any electrical issues, i picked up a used (good known working) amplifier for the Dynaudio system from an Eos and tried it on.
Although with VAG Com i'm able to go into the amplifier under Sound system and see 2 speakers (1 open circuit, 1 short) not working, the rest have tested good and still no sound.
I have tried the long coding editor for the RNS510 it is currently set to Dynaudio system on byte 1, however there is a 2nd option Dynaudio (BAS DSP), no idea what would be the difference between the 2.
I have tried changing the coding to any other in the list and i get Error 31 Rejected, read on other forums you can add 2x 00 at the end of the string and it should accept it, that didn't work.
Also tried putting in a non zero importer code and equipment number, still won't take it.
What am I doing wrong? I did update to the latest Vag com version just recently, believe its 16.8.
Just for fun i tried the soft reset on the head unit with the 3 key press simultaneously, sure enough i heard the speakers pop for a quick second at the first init of the radio.
How and where could i be losing my input signal from the radio when it's already set for the correct sound system?
Any help, thoughts appreciated, i'm breaking my head with this not sure what direction to take on next
