The temperature gauge on my MY2005 A8 D3 has started 'wandering' recently. I'd like to identify whether it's the thermostat or a sensor.
Obviously the panel ECU gets the temperature, but which ECU is the cooling circuit temperature sensor connected to? [The engine is a V6 3.0 TDI - "ASB"].
As a starting point, I plan to monitor the appropriate measurement block on a long journey with VCDS saving to disk. Any clues which block I should be looking at?
Thanks - Julian
Autoscan added below retroactively
Thanks - Julian
Wednesday,05,October,2016,18:49:05:53697
VCDS Version: 16.8.2.3
Data version: 20160926 DS261.0
VIN: WAUZZZ4E35N011492 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 18 19 1D 1E 25 34 36 37
38 42 46 47 4F 52 53 56 57 61 62 72 76 77
VIN: WAUZZZ4E35N011492 Mileage: 360110km-223761miles
1D-Driver Ident. -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4E0 910 401 J HW: 4E0 907 401 B
Component: 3.0L V6TDI G000AG 0020
Revision: --H01--- Serial number: AUX3Z0D9353518
Coding: 0011973
Shop #: WSC 02313 785 00200
VCID: 224B8DE9FD1E305282-8076
17983 - Right Engine Mount Solenoid Valve (N145)
P1575 - 001 - Short to Plus
RPM: 756 /min
Torque: 39.0 Nm
Voltage: 13.07 V
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
Temperature: 64.8°C
18276 - Transmission Mount Valve 1 (N262)
P1868 - 001 - Short to Plus
RPM: 756 /min
Torque: 39.0 Nm
Duty Cycle: 1.0 %
Voltage: 13.07 V
Bin. Bits: 00101100
Torque: 249.6 Nm
Temperature: 64.8°C
18281 - Transmission Mount Valve 2 (N263)
P1873 - 001 - Open Circuit - Intermittent
RPM: 756 /min
Torque: 74.1 Nm
Voltage: 13.45 V
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
Temperature: 64.8°C
Part No SW: 4E0 910 156 F HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0070
Revision: --H01--- Serial number: 0070658
Coding: 0000001
VCID: 254196F5EC30C76AE7-8070
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008357
Shop #: WSC 02313 000 00000
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0D9353518
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: 58BFEF01EBC2AA82AC-800C
Component: ELV XXXX
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3670112
VCID: 234588EDE204395A89-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300KS047541498
Shop #: WSC 00045 210 90242
VCID: 3A7B5589758E5892BA-806E
Subsystem 1 - Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Subsystem 2 - Serial number: 318IE047510004
Subsystem 3 - Serial number: 7409.09.0400000000218B0053ÿ
Subsystem 4 - Serial number: 8B0053ÿ
Part No SW: 4E0 910 043 A HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 016 0340
Revision: 00000029 Serial number: 00000000057290
Coding: 1067041
VCID: 1B35B00DDA74019A41-804E
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H12 0210
Coding: 0000001
VCID: 316972A5A8F89BCA0B-8064
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000037
Shop #: WSC 02313
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD6029817
VCID: 1C37B311DF7A06A248-8048
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
VCID: 63C5C8EDA284795AC9-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112141
VCID: 65C1D6F5ACB0076A27-8030
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 F HW: 4E0 920 950 F
Component: KOMBIINSTR. VDO H49 0200
Revision: D03 Serial number: AUDID3DN000886
Coding: 0000418
Shop #: WSC 00028 210 01865
VCID: 275D9CFD963CD57AD5-8072
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 E
Component: Heizgeraet H07 0100
Revision: 0000000B Serial number: 00000009006406
Coding: 0000001
VCID: 1A3BB509D54E78925A-804E
01406 - No Flame
02251 - Heater Unit Locked
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0070
Revision: 07 Serial number: 160030482517A7
Coding: FCFF5BDE3B3504
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 HW: 4E2 905 218
Component: FPI_1 H07 0060
Revision: 06000107 Serial number: 23092004154705
VCID: 5EB3F91989E654B2E6-800A
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Component: SG ext.Player H20 0850
Revision: 00000000
VCID: 2B5560CD4AD4F11A31-807E
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 285F9FC19B22DA02DC-807C
Component: Sitzmemory FS H08 0060
Coding: 3670126
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H43 1060
Revision: 00000000 Serial number: 353K0047589079
VCID: 3B75508D7AB4619AA1-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000430200115
Coding: 0035904
VCID: 1D31BE15C4600FAABF-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRM002 0060
Coding: 0026914
VCID: 204F87E1F312224294-8074
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040411110043
Coding: 0000249
Component: Heckdeckel P14H06 0070
Component: Neigungssensor H03 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial number: 00000000008586
Coding: 0000013
VCID: 2A5B65C9852EE812CA-807E
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000051553
Coding: 0010001
VCID: 1E33B919C96614B2A6-804A
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRM002 0060
Coding: 0026914
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000221
Shop #: WSC 13765 210 01865
Part No SW: 4E0 910 541 T HW: 4E0 035 541 B
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 304KJ047604701
Coding: 0000001
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 G HW: 4E0 919 146 A
Component: TV analog TUNER H13 0300
Revision: 00000024 Serial number: 00000000008454
Coding: 0000003
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H11 0510
Revision: 00000000 Serial number: 00000000014066
Subsystem 1 - Part No: 4E0 915 105 DL
Component: von VA0 310314E07G
Coding: 344530393135313035444C56413033313033313445303747
Shop #: WSC 00011 888 06946
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0026914
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0026914
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08720430201074
Coding: 0101008
VCID: 214982E5F8182B4A9B-8074
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 B
Component: TELEFONMODUL EU 0770
Revision: 00000001 Serial number: 00000000000000
Coding: 0000004
End-------------------------(Elapsed Time: 03:47)--------------------------
