There is a problem at the gearbox , when I start the car everything is well , after a while it pass the first , third and fifth gear
Switch it off and try again , it work probably ,after a time it pass the first , third and fifth gear
Is that a problem at the mechatronic control or the clutch 1 ????
The auto scan
The auto scan
Saturday,29,October,2016,15:02:26:22511
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: TMBAC4NE4E0098772 License Plate:
Mileage: 126778km-78776mi Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBAC4NE4E0098772 Mileage: 126778km-78776miles
Address 01: Engine (J623-CHPA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 M HW: 04E 907 309 A
Component: 1,4l R4 TSI H08 5762
Revision: WAH08---
Coding: 01250012232400080000
Shop #: WSC 73430 031 00121
ASAM Dataset: EV_ECM14TFS01104E906016M 002008
ROD: EV_ECM14TFS01104E906016M.rod
VCID: AC144094C75C585E72-80F8
17158 - Databus
Mileage: 126776 km
Date: 2016.10.27
Time: 00:20:44
U0428 00 [032] - -
Mileage: 126776 km
Date: 2016.10.27
Time: 00:20:44
10577 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [039] - -
Mileage: 126776 km
Date: 2016.10.27
Time: 00:47:41
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 045 HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 4530
Revision: 00043014 Serial number: CU501310097280
ROD: EV_TCMDQ200021_SK25.rod
VCID: F6A0A2FC4990528ED4-80A2
10719 - Unable to Engage Gear 3 -or- Synchronization Gear 3 aborted
P074B 00 [136] - -
Mileage: 126776 km
Date: 2016.10.27
Time: 00:44:01
10803 - Transmission Driving Direction Implausible
P1727 00 [072] - -
Mileage: 126776 km
Date: 2016.10.27
Time: 00:44:04
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 629330000004B2
Coding: 1A076A9124291174007E060741C5245856248800608224B0002300004002
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_SK37.rod
VCID: CBD6230862927F665B-809E
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 58
Date: 2016.10.27
Time: 00:20:43
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5E0 907 044 E HW: 5E0 907 044 E
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 01010004000100010005000000100000
ASAM Dataset: EV_ACClimaBHBVW37X 003017
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: A71EBFB8DEBA7B069F-80F2
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 S HW: 5Q0 937 084 S
Component: BCM MQBAB M H14 0112
Serial number: 00011328400065
Coding: 0C101842404702FB07A04000000007000000000000000000000000000000
Shop #: WSC 73430 790 00121
ROD: EV_BCMBOSCH_AU37.rod
VCID: C8DC1C0473E4947E76-809C
Slave 1:
Subsystem 1 - Part No SW: 5E1 955 119 HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 131021 041 0570
Serial number: 131022225124
Coding: 065DDD
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M10D24H14M19S28S1
Coding: 02805D
Subsystem 3 - Part No SW: 6R0 959 591 B HW: 6R0 959 591 B
Component: J245 PS72.023 H02 0007
Serial number: WOO24711290
Coding: 981803
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H02 0033
Revision: -------- Serial number: 94231329200418
Coding: 0010050011
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_EPHVA18AU3700000 002019
ROD: EV_EPHVA18AU3700000_SK37.rod
VCID: BB3673C83232CFE6EB-80EE
13637426 - Databus
Reset counter: 58
Mileage: 126776 km
Date: 2016.10.27
Time: 00:20:42
Part No SW: 3Q0 959 655 AD HW: 3Q0 959 655 AD
Component: Airbag VW20 011 0189
Revision: -------- Serial number: 003P5PM9C3L$
Coding: 88C0C00000000000400000CC000800000065
ROD: EV_AirbaVW20TS6VW48X_SK37.rod
VCID: 804CC4241B546C3EFE-80D4
Subsystem 1 - Part No SW: ----------- HW: 454 001 310 13
Serial number: 3576U000000825D8FD0T
Subsystem 2 - Part No SW: ----------- HW: 454 001 410 13
Serial number: 3586U000000487B8FD0W
Subsystem 3 - Part No SW: ----------- HW: 454 800 810 13
Component: SideSensor_Dr 111 0148
Serial number: 3516R76E30F020000003
Subsystem 4 - Part No SW: ----------- HW: 454 801 210 13
Component: SideSensor_Pr 111 0148
Serial number: 3526R3FE41E02000000A
Subsystem 5 - Part No SW: ----------- HW: 454 802 109 13
Component: FrontSensor_D 114 0149
Serial number: 3556VEBB60302000000B
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 E HW: 5Q0 953 549 A
Revision: -------- Serial number: 25101304400033
Coding: 1000
ROD: EV_SMLSKLOMQB_SK37.rod
VCID: B83C6CC40304E4FE06-80EC
Part No SW: 5E0 920 861 B HW: 5E0 920 861 B
Component: KOMBI 233 2210
Coding: 07A402082080000801080A00000000
VCID: A600B2BCD9B0620EA4-80F2
Part No SW: 5Q0 907 530 L HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1144
Revision: -------- Serial number: 0001190899
Coding: 0101000020086400EF0002081C0F00000001000000000000000000000000
ROD: EV_GatewLear.rod
VCID: BA3876CC3D08F6EEF0-80EE
Subsystem 2 - Part No SW: 5E0 919 719 HW: 5E0 919 719
Component: E221__MFL-PR6 H04 0120
Serial number: 000000000A1140141013
Part No SW: 5Q4 959 593 HW: 5Q4 959 593
Component: TSG FS 007 0006
Serial number: 0000076265702
Coding: 00150020D000020000001100
ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
VCID: 8248CE2C15587E2EE8-80D6
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Component: FOND_FHSG_DRV 005 0004
Serial number: 00000000000000874971
Coding: 010200
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 0102
ROD: EV_SteerAssisMQB.rod
VCID: C1CA012050DEA536B1-8094
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000080231616
ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
VCID: 814AC120105E6536F1-80D4
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000928085
Coding: 190200
Address 5F: Information Electr. (J794) Labels: 5E0-035-MIB-ENT1.clb
Part No SW: 5E0 035 887 HW: 5E0 035 887
Component: MU-E--ER 171 0141
Revision: -------- Serial number: 000085595901000
Coding: 03730100FF0000005011000100110000000000840000010000
ASAM Dataset: EV_MUEnt4CCONT 004052
ROD: EV_MUEnt4CCONT_AU37.rod
VCID: E99AF980082E8D7649-80BC
End-------------------------(Elapsed Time: 01:47)--------------------------
