- Jun 27, 2016
- 21
- 13
- N Wales, UK
- C?ID=249332
Sunday,23,October,2016,10:42:07:37770
VCDS Version: 16.8.3.1
VIN: WVWZZZ3CZFE449009 License Plate:
Mileage: 31114km-19333mi Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F BB BC
VIN: WVWZZZ3CZFE449009 Mileage: 31114km-19333miles
Address 01: Engine (J623-CRLB) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 026 AS HW: 04L 907 309 R
Component: R4 2,0L EDC H21 1147
Revision: B5H21---
Coding: 01190012034505083000
Shop #: WSC 49033 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906026AS 001006
ROD: EV_ECM20TDI01104L906026AS.rod
VCID: 7BF5B897F276EA9AE9-802E
Part No SW: 3Q0 907 379 F HW: 3Q0 907 379 F
Component: ESC H42 0609
Revision: 00000000 Serial number: 60105000000671
Coding: 0FEC928F34240B750777060041CC49F0492CD0E0608292F11460F078C002
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
VCID: 3D71768FACE224AA97-8068
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 3Q0 959 435 HW: 3Q0 959 435
Component: VWKESSYMQB 023 0522
Revision: 00023000 Serial number: 0357391858
Coding: 000F0F0603
Shop #: WSC 05311 115 00321
ASAM Dataset: EV_KessyHellaMQBAB 004027
VCID: 77FDA4A7CE5ECEFA8D-8022
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 AH HW: 5G0 907 044 AH
Component: Climatronic H03 1001
Revision: 00001K10
Coding: 12120104202100012015500000101802
ROD: EV_ACClimaBHBVW37X_004_VW48.rod
VCID: 6DD186CFBC02742A67-8038
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 086 BC HW: 5Q0 937 086 BC
Component: BCM PQ37BOSCH 028 0146
Revision: -------- Serial number: 86580501151197
Coding: 03010846C24102FF0B844084B11407281880000000000000000000000000
ROD: EV_BCMBOSCH_014.rod
VCID: 7CF7BB8BF778EDA2E0-8028
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 141207 043 0607
Serial number: 141212163431
Component: RLHS 037 0059
Serial number: S4Y15M01D14H11M43S37
Coding: 00A8DD
Subsystem 3 - Part No SW: 3G0 941 633 HW: 3G0 941 633
Component: E1 - LDS MQB H01 0032
Serial number: 12 12 2014 00001146
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY143440AMW
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000061403117
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 246
Mileage: 1048574 km
Date: 2016.10.22
Time: 18:45:09
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 H HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0053
Revision: -------- Serial number: 39331436405062
Coding: 0071051001
Shop #: WSC 05311 115 00080
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 408F0F7BDB104942FC-8014
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 3Q0 907 572 A HW: 3Q0 907 572 A
Component: ACC BOSCH MQB H04 0126
Coding: 2A40608110FFC428949C804C
ASAM Dataset: EV_ACCBOSCHVW48X 001007
ROD: EV_ACCBOSCHVW48X.rod
VCID: 336550B79AA6E2DA71-8066
Part No SW: 3Q0 959 655 AE HW: 3Q0 959 655 AE
Component: Airbag VW20 012 0195
Revision: -------- Serial number: 003R1P03TSRE
Coding: 98FCC0C0000000005C5400CC008800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0109CA7F909A804AB3-8054
Belt Pretensioner left:
Serial number: 3G2857705C0012P00629
Coding: 80000A
Belt Pretensioner right:
Serial number: 3G2857706C0014P00039
Coding: 80000A
Subsystem 3 - Part No SW: ----------- HW: 454 000 601 15
Serial number: 3576U00000026A05821%
Subsystem 4 - Part No SW: ----------- HW: 454 000 601 15
Serial number: 3586U00000067350721/
Subsystem 5 - Part No SW: ----------- HW: 454 801 001 15
Component: SideSensor_Dr 111 0148
Serial number: 3516RAF598905000000H
Subsystem 6 - Part No SW: ----------- HW: 454 800 701 15
Component: SideSensor_Pr 111 0148
Serial number: 3526R77F28E05000000F
Subsystem 7 - Part No SW: ----------- HW: 454 800 301 15
Component: FrontSensor_D 114 0149
Serial number: 3556V25C766050000007
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 3Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150116400691
Coding: 0400
Shop #: WSC 00015 115 08193
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 3G0 920 951 HW: 3G0 920 951
Component: KOMBI 306 5310
Coding: 27A409102780260001886A001000000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009003
ROD: EV_DashBoardJCIMQBAB_VW48.rod
VCID: 64C7E3EB6FC8356238-8030
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 19121410802415
Coding: 030300044F087300EF00025C080F00010001070000000000000000000000
ROD: EV_GatewConti_011.rod
VCID: 72EB95B3A53CABD2BA-8026
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K
Component: E221__MFL-DC1 H16 0040
Serial number: 36150000004590095021
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 3862775203
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 1712201400010254
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 14000316159006
Coding: 0000000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71E99ABFA03A90CA43-8024
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 231214BLN11322
Coding: 003F0A20D001028000001000
VCID: 428B0573D51C5B52EA-8016
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 8103
Shop #: WSC 00015 115 00321
VCID: 43850077CA06525AE1-8016
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 090115BKU11823
Coding: 003F0020D001028000001000
VCID: 41890A7FD01A404AF3-8014
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 874 HW: 3Q0 035 874
Component: MU-S-ND-ER H10 0138
Serial number: VWZAZ2R0003002
Coding: 02840201FF00000011111201000808001F0100C601200100CC
ASAM Dataset: EV_MUStd4CTSAT 001018
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 6FED9CC7B60E863A55-803A
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H42 1017
Serial number: VWZ8Z9RD800SQN
Subsystem 2 - Part No SW: 3G0 919 866 E HW: -----------
Component: ECE 2015 --- 0335
Address BB: Door Rear Drv (J388) Labels: None
Part No SW: 5Q0 959 595 D HW: 5Q0 959 595 B
Component: TSG HFS 020 0028
Serial number: 070115BA700929
Coding: 000E00200101028000001000
VCID: 4487036BCF085562D8-8010
Address BC: Door Rear Pass (J389) Labels: None
Component: TSG HBFS 020 0028
Serial number: 070115BA616041
End-------------------------(Elapsed Time: 05:22)--------------------------
Regards,
Mel
