Q3 retrofit APS+ but no OPS Settings?
sers77
Norway
C?ID=26140
I need the long coding for:
5F-Information Electr.
01000600020151070833000103010000010000
To get the "Settings" to work (on RMC screen).
After the scan (posted below) I found a scan in this forum, put it in my 5F and got the OPS to work (but the rest was a mess).
Then I put the original code back and changed one digit @ a time
Finally i changed digit nr. 14 from 1 to 3 (se below) and got the OPS activated, but the on-screen settings are empty (i now need vcds to change the beeping, volume and the rest).
0100060002015 1 070833000103010000010000
I would love to not go through trillions of digit combinations...
Friday,07,October,2016,18:51:44:07409
VCDS Version: 16.8.2.3 (x64)
 Data version: 20160926 DS261.0
 VIN: WAUZZZ8U5ER080663 License Plate:
 Chassis Type: 8U (8U0)
 Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 53 55 5F 62 69 72
 VIN: WAUZZZ8U5ER080663 Mileage: 43070km-26762miles
 Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
 Part No SW: 03L 906 018 CN HW: 03L 906 018 ES
 Component: R4 2,0L EDC H28 4960
 Revision: 41H28--- Serial number:
 Coding: 00190012043401080000
 Shop #: WSC 00049 770 00119
ASAM Dataset: EV_ECM20TDI01103L906018CN 003006
 ROD: EV_ECM20TDI01103L906018CM.rod
 VCID: 78FB1034C3CFBA828C-802C
 Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
 Part No SW: 5N0 614 109 BL HW: 5N0 614 109 BL
 Component: J104 C6 450M V49B 0151
 Revision: --H07--- Serial number: 00000007894860
 Coding: 0050308
 Shop #: WSC 00049 770 00151
 VCID: 76E71E0C01DBCCF29E-8022
 Part No SW: 8U0 820 043 E HW: 8U0 820 043 E
 Component: E87 Klimavoll 0100
 Revision: 00H04000 Serial number: 8U0820043E
 VCID: 3361E718522999DA79-8066
 Address 09: Cent. Elect. (J519) Labels: 8X0-907-063.clb
 Part No SW: 8X0 907 063 N HW: 8X0 907 063 N
 Component: BCM PQ35 M 112 0775
 Revision: AH112775
 Coding: 06000A2CE805E3C0201841C00100094C47FF85AA207F912BE4 0087A400C1
 Shop #: WSC 00049 770 00008
 VCID: 4799A3C8F6B1057A35-8012
 Subsystem 1 - Part No SW: 8U1 955 119 HW: 8U1 955 119
 Component: WWS316 140207 H37 0085
 Serial number: 140212062840
 Coding: 0047F7
 Component: G397_RLFS H06 0002
 Serial number: 22285895
 Coding: 02006E
 Subsystem 3 - Part No: 8X0 951 177
 Component: DWA-Sensor H0 H01 0020
 Address 10: Park/Steer Assist (J446) Labels: 8X0-919-475.clb
 Part No SW: 8X0 919 475 R HW: 4H0 919 475 C
 Component: PARKHILFE 8K H07 0050
 Revision: 11001001 Serial number: 55961525100817
 Coding: 090204
ASAM Dataset: EV_EPHVA18AU21X0000 002005
 ROD: EV_EPHVA18AU21X0000.rod
 VCID: 55A57980341DA7EAB7-8000
 Address 15: Airbags (J234) Labels: 8X0-959-655.clb
 Part No SW: 8U0 959 655 B HW: 8U0 959 655 B
 Component: AirbagVW-AU10 H08 0520
 Serial number: 003LRR07KXMV
 Coding: 30353132313030303030554A304C38553053
ASAM Dataset: EV_AirbaAU10SMEAU316 001005
 ROD: EV_AirbaAU10SMEAU316_001.rod
 VCID: 4687AECCF9BB1C72CE-8012
 Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
 Serial number: 3496KSME447B182CZZZ2
 Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
 Serial number: 3506KSME0956202CZZZO
 Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
 Serial number: 3516KSME3B421F2CZZZ$
 Serial number: 3526KSME2058202CZZZL
 Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
 Serial number: 3555USME27490C2BZZZ6
 Address 16: Steering wheel (J527) Labels: 8X0-953-569.clb
 Part No SW: 8X0 953 501 D HW: 5K0 953 569 AL
 Component: LENKS.MODUL 016 0140
 Revision: FF010018 Serial number: 20140305200115
 Coding: 1184204000
 VCID: 3B71CF38B279519AA1-806E
 Subsystem 1 - Part No SW: 8U0 951 528 E HW: 8U0 951 528 E
 Component: E221 - MFL H09 0010
 Address 17: Instruments (J285) Labels: 8X0-920-xxx-17.clb
 Part No SW: 8U0 920 940 E HW: 8U0 920 940 E
 Component: KOMBI_COLOUR H01 0230
 Coding: 12CF00
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
 VCID: 3A7FCA3CBD436892BA-806E
 Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
 Part No SW: 8U0 907 468 Q HW: 8U0 907 468 G
 Component: GAT 4CAN 1L M H13 0063
 Revision: 1P120037 Serial number: 3741P1421507FB
 Coding: FBCF1A5A000100610253
 VCID: 50AB889403FFC2C264-8004
 Component: J367-BDM H07 0180
 Serial number: 41063546381491885720
 Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
 Component: J532_DCDCStab H17 0042
 Serial number: 14062001568011200181
 Component: IMMO H01 0230
 Coding: 000002
 ROD: EV_Immo_UDS_VDD_AU10.rod
 Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
 Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
 Component: TSG FA H10 0415
 Coding: 011806200000000000
 VCID: 52AF829C0DF3B0D252-8006
 Address 44: Steering Assist Labels: 5N1-909-144.clb
 Part No SW: 5N1 909 144 R HW: 5N1 909 148 J
 Component: J500__APA-BS KL.377 1401
 Revision: 1BH04841 Serial number: 00140300195901
 Coding: 0000258
 VCID: 418DBDD018953B4AFB-8014
 Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
 Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
 Component: TSG BF H10 0415
 VCID: 51AD8D9008F5CBCA6B-8004
 Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
 Component: J540 EPB4 VW-86594 0010
 Revision: H19 Serial number: 00000001957623
 Coding: 0025166
 VCID: 3667DE0C415B8CF25E-8062
 Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
 Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
 Serial number: 140303-0002-042
 Coding: 1157941010022500
 ROD: EV_HeadlRegulBasic.rod
 VCID: 428FB2DCD5932052E2-8016
 Part No SW: 8U0 035 183 C HW: 8U0 035 183 A
 Component: RMC Cnct H55 0801
 Coding: 01000600020151070833000103010000010000
 VCID: 3463E40497279EE260-8060
 Subsystem 1 - Part No SW: 8U0 919 603 A HW: 8U0 919 603 A
 Component: DUBasic AU316 H42 0018
 Serial number: AUZ8ZDEM500PLRU
 Address 62: Door, Rear Left (J388) Labels: None
 Part No SW: 8X0 959 795 C HW: 8X0 959 795 C
 Component: TSG HL H07 0415
 Coding: 010006200000000000
 VCID: 4FA98BE81EC1DD3A7D-801A
 Address 69: Trailer (J345) Labels: 7N0-907-383.clb
 Part No SW: 7N0 907 383 HW: 7N0 907 383
 Component: Anhaenger H09 0120
 Revision: 3I001003 Serial number: 00000327576674
 Coding: 0109080000000000
 VCID: 73E12718D2A9D9DAB9-8026
 Address 72: Door, Rear Right (J389) Labels: None
 Component: TSG HR H07 0415
 End-------------------------(Elapsed Time: 02:38)--------------------------
sers77
Norway
C?ID=26140
Kufatec doesn't even know how to do this...
So i guess it is as good as it gets...
Mrclopec
Nipomo, CA
C?ID=149231
Module 10. Try 190204
sers77
Norway
C?ID=26140
Thank you, will try that :)
sers77
Norway
C?ID=26140
Vcds did not accept that code..
The longcode from kufatec (for 5f) didn't help either...
New code: 01000600020153070833020103010000010000
So when I press settings in ops-mode there is just an "empty" screen.
