vbb
Tuesday,18,October,2016,18:35:28:54995
VCDS Version: 16.8.2.3 (x64) HEX-NET CB: 0.4323.4
Data version: 20160926 DS261.0
VIN: 3VW447AUXHM004496 License Plate: TONITTO
Mileage: 1251km-777mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 32 42 44 52 55 5F 75 A9
VIN: 3VW447AUXHM004496 Mileage: 1251km-777miles
Address 01: Engine (J623-CXCB) Labels: None
Part No SW: 5G0 906 259 L HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 091D00124424002F1000
Shop #: WSC 00066 790 00206
ASAM Dataset: EV_ECM20TFS0205G0906259L 001003
ROD: N/A
VCID: 373EE73C8E9B57FA45-8062
No ASAM data for: "EV_ECM20TFS0205G0906259L" (VW37)
Part No SW: 0D9 300 020 L HW: 02E 927 770 AQ
Component: DQ250-6V MQB H54 4902
Revision: 06354004 Serial number: TFK01606100392
Shop #: WSC 00066 790 00149
ROD: EV_TCMDQ250021.rod
VCID: 1E701298016106B2A6-804A
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 AF HW: 5Q0 614 517 AF
Component: ESC H62 0398
Revision: 00000000 Serial number: 51646000000957
Coding: 01FA6BA154200970807B020941C96880D62A90014082163600430051C00903
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
ROD: EV_Brake1UDSContiMK100ESP_035_VW37.rod
VCID: 75A22D34D417E5EA97-8020
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0405585709
Coding: 032C0C
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3B36FB0CB2B3739AA1-806E
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5GM 907 426 C HW: 5GM 907 426 C
Component: AC Manuell H03 1601
Revision: 00001K03
Coding: 00020004200100000000000000000002
ASAM Dataset: EV_ACManueBHBVW37X 004132
ROD: EV_ACManueBHBVW37X_002_VW37.rod
VCID: 48DC94C0F36528023C-801C
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 865827061600V1
Coding: 00011A464041A04169E44000001407201800000000000000000000000000
ROD: EV_BCMBOSCH_015_VW37.rod
VCID: 7AB83E08FD098A92FA-802E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160422 043 0581
Serial number: 160716095842
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR051A2X
Shop #: WSC 00066 790 00211
VCID: 47DE97FCFE7B277A35-8012
Occupant Detection:
Component: BF-Gewichtss. H12 0021
Serial number: IBH000000000005DS5FQ
Coding: 30305A
Subsystem 2 - Part No SW: ----------- HW: 480 002 505 16
Serial number: 357000000004E5416B1I
Subsystem 3 - Part No SW: ----------- HW: 480 002 505 16
Serial number: 35800000000CFA312B1S
Subsystem 4 - Part No SW: ----------- HW: 480 402 805 16
Serial number: 3510002C320FC73452D3
Subsystem 5 - Part No SW: ----------- HW: 480 402 805 16
Serial number: 35200029D2057295E15+
Subsystem 6 - Part No SW: ----------- HW: 480 401 406 16
Serial number: 3550002B921160C471D$
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 406 16
Component: FrontSensor_P 001 6149
Serial number: 3560002BB21160C3611S
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20160627400514
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 044440F08FCDCC6290-8050
Part No SW: 5G1 920 856 B HW: 5G1 920 856 B
Component: KOMBI 344 8311
Coding: 0BAD091AA980CF0502086A001000000000000000
VCID: 2D12C5547CC7ED2A2F-8078
U1110 00 [008] - -
Reset counter: 80
Mileage: 70 km
Date: 2011.03.11
Time: 20:56:35
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 08061610521316
Coding: 0101000830085900FB00002B1C0F00000001050000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 7CB43810F73DB4A2E8-8028
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q
Component: E221__MFL-DC1 H11 0103
Serial number: 29160000834890086165
Coding: 31FFFF
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000096311001
Coding: 5D00000000000000
Shop #: WSC 00066 790 00322
VCID: 3424D0309FEDBCE260-8060
Address 32: Differential Locks (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8042
Serial number: HA1-00024.05.16
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
Component: TSG FS 020 0041
Serial number: 170616060500O4
Coding: 003E13200000020000000000
VCID: 43C683ECCA430B5AE9-8016
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000013026699
Coding: 011000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8102
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A38FE08BD894A92BA-806E
Component: TSG BFS 020 0041
Serial number: 250616060504AP
VCID: 42C886E8D5590252E2-8016
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000003695763
Coding: 091000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 021801010B000400
VCID: 40CC8CE0DB551042F4-8014
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 844 A HW: 3Q0 035 844 A
Component: MU-S-S-US 710 0751
Coding: 02730000FF00000051220001001808009F0203D40120010002
ROD: EV_MUStd4CDELP_VW26.rod
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H53 1031
Serial number: VWZ8Z9SJW00QMV
6720 - Rear View Camera
B1102 31 [008] - No Signal
Reset counter: 75
Mileage: 71 km
Date: 2011.03.11
Time: 21:02:18
Voltage terminal 30: 13.9 V
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02730002C2821A017F1E06000000
ROD: EV_OCULowMQB.rod
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 160505202175
VCID: 6B960B4C8253231A71-803E
End----------(Elapsed Time: 01:27, VBatt start/end: 12.6V/12.6V)-----------
Address 17: DTCs cleared
