Hi Guys ,
I have a few issues with an Audi A3 , the 1st one I need to sort out is the windows.
I thought I'd look for advice before I start heading in the wrong direction.
The windows all work if you operate via vagcom apart from the rear drivers side (I think it's that one)
I've pasted the scan I ran after I'd cleared dtc's.
I also have a new convenience unit which is located drivers side boot if that helps, i plugged it in but no change but not sure if it needs coding ?
I have the car in the workshop so I can get any details that may help
Many Thanks
Anthony
Auto Elite
Many Thanks
Anthony
Auto Elite
Tuesday,25,October,2016,16:59:54:62149
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WAUZZZ8P25A161516 License Plate:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
VIN: WAUZZZ8P25A161516 Mileage: 234160km-145500miles
46-Central Conv. -- Status: Malfunction 1010
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FF HW: 028 101 147 7
Component: R4 2,0L EDC G000SG 6337
Revision: 12345678 Serial number: XXXXXXXXXXXXXX
Coding: 0000072
Shop #: WSC 00000 028 00001
VCID: 6CD7EA774F79325EB2-8038
18048 - Internal Control Module
P1640 - 000 - EEPROM Error - MIL ON
Torque: 74.0 Nm
Bin. Bits: 10111000
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00100000
18107 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics
Torque: 74.0 Nm
Voltage: 12.01 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 1.0
Readiness: 1 1 0 1 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023174
Shop #: WSC 06314 000 00000
VCID: 3A7B1C2F75AD5CEE70-806E
Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
Component: KlimavollautomatH14 0180
Revision: 179531 Serial number: 8P0820043H
VCID: 31693B03A8DB9FB6C1-8064
Reset counter: 184
Mileage: 234165 km
Date: 2016.06.11
Time: 20:27:11
Reset counter: 184
Mileage: 234165 km
Date: 2016.06.11
Time: 20:31:43
Reset counter: 184
Mileage: 234165 km
Voltage: 8.50 V
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H37 0301
Revision: 00H37000 Serial number: 00000001779326
Coding: 01884F02B214100000160000160000000000FE075C
Shop #: WSC 06314 000 08192
VCID: 3D71173364836BD655-8068
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 00362002UGP+
Coding: 0034622
VCID: 428B64CF1D7D142E28-8016
Subsystem 1 - Serial number: 6332DRB4014BCC2D
Subsystem 2 - Serial number: 6342DRB4014BC7A1U
Subsystem 3 - Serial number: 63528RB4005E85AE-
Subsystem 4 - Serial number: 63628RB40059E48DY
Subsystem 5 - Serial number: 63729RB4006003877
Subsystem 6 - Serial number: 63829RB40061B21BG
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
Fault Status: 11101010
Mileage: 234166 km
Date: 2016.07.18
Time: 00:11:08
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
Mileage: 234166 km
Date: 2016.07.18
Time: 00:11:08
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 021 0050
Coding: 0000012
VCID: 35610F135CB3B3969D-8060
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 A HW: 8P0 920 981 A
Component: KOMBIINSTR. VDO H73 0300
Revision: D06 Serial number: 2243ED06008520
Coding: 0004443
Shop #: WSC 00441 210 91426
VCID: 3663081F41B5B88E94-8062
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 2500105407895E
Coding: 3D3F0B42072103
VCID: 285FD6679B01DE7E16-807C
Reset counter: 184
Mileage: 234166 km
Date: 2016.07.18
Time: 00:35:55
Address 25: Immobilizer
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0030
Coding: 0000048
00939 - Mirror Adjust Motor; Drivers Side (V149)
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3467321757C9AA9EAA-8060
02546 - Steering Limit Stop
Mileage: 4160 km
Temperature: 12.0°C
Voltage: 12.00 V
Voltage: 11.80 V
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 C
Component: KSG H04 0050
Coding: 198000187F088505489FC63000
Shop #: WSC 31414 210 01865
VCID: 3C771A377F9962DE62-8068
Subsystem 2 - Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H03 0020
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH03 0180
Revision: 00002 Serial number: 10000001241577
VCID: 71E9FB03685BDFB681-8024
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 E
Component: Tuersteuerger. H10 0040
Coding: 0000048
Shop #: WSC 06314 210 01865
VCID: 3E73103F698570CE4C-806A
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H51 0100
Revision: 01S Serial number: AUZ2Z3E2260337
Coding: 0001001
Shop #: WSC 06435 000 00000
VCID: 326B340FADDDA4AEB8-8066
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 B
Component: Tuer-SG 010 0030
Coding: 0000144
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 B
Coding: 0000144
VCID: 3F8D6D3B6E8F79C647-806A
Component: PTC-Element 0404
VCID: 2D512773B4E3FB56E5-8078
End-------------------------(Elapsed Time: 01:46)--------------------------
