- Apr 17, 2015
- 179
- 58
- South Africa
- C?ID=133909
I need to regenerate the DPF but I need a security code. Starts difficult at times but cannot rev up to test drive & regenerate the DPF.
Any suggestions?
Any suggestions?
Tuesday,25,October,2016,16:18:29:65476
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
VIN: WVWZZZ1KZBW333634 License Plate: BK20LRGP
Mileage: 217210km-134968mi Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 62 72
VIN: WVWZZZ1KZBW333634 Mileage: 217210km-134968miles
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MN HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 9970
Revision: --H43--- Serial number: 00000000000000
Coding: 08114014032501080000
ASAM Dataset: EV_ECM16TDI02103L906023MN 003010
ROD: EV_ECM16TDI02103L906023MN.rod
VCID: 7EF546F6E108B1B2D2-802A
16856 - Diesel Particle Filter
P2463 00 [175] - Excessive Soot Accumulation
Mileage: 217211 km
Date: 2016.10.25
Time: 00:31:33
Engine speed: 0.00 /min
Coolant temperature: 42 °C
Intake air temperature: 30 °C
Ambient air pressure: 930 mbar
Voltage terminal 30: 11.972 V
Particle filter: soot mass measured-MASS_SOOT_PHY_PF: 28.28 g
Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 40.00 g
Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 357 km
Counter for regeneration time of diesel particle filter-T_INT_RGN_ACT_INI_PF_ENVD_H: 504.6272 s
Particle filter: difference pressure-DIP_PF: 92.04 hPa
Particle filter: offset for differential press.-DIP_PF_AD[0]: 0.00 hPa
Service regeneration: Release conditions 3-FRF_STATE_RGN: 1
9867 - Coolant Pump 2
P261A 00 [175] - Open circuit
Mileage: 217211 km
Date: 2016.10.25
Time: 00:35:14
Engine speed: 662.00 /min
Normed load value: 89.8 %
Coolant temperature: 51 °C
Voltage terminal 30: 13.666 V
Coolant temperature at radiator outlet: actual value-TCO_2: 45 °C
Battery voltage: 13.9 V
9870 - Coolant pump 2
P261B 00 [039] - Implausible signal
Mileage: 217211 km
Date: 2016.10.25
Time: 00:45:37
Engine speed: 540.00 /min
Normed load value: 89.0 %
Coolant temperature: 89 °C
Intake air temperature: 32 °C
Voltage terminal 30: 12.649 V
Coolant temperature at radiator outlet: actual value-TCO_2: 68 °C
Battery voltage: 12.6 V
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 133B200D092500FDC81104E7901D0091310000
VCID: 76E55ED6C138F9F28A-8022
Fault Status: 00101101
Reset counter: 66
Mileage: 217211 km
Count: 2
Count: 2
Count: 20736
Count: 8196
Count: 40960
Count: 64768
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 K HW: 7N0 907 426 K
Component: AC Manuell H17 0202
Revision: 00001012
Coding: 0000001003
ROD: EV_ClimaBasis_VW36.rod
VCID: 3C718CFEB79463A2BC-8068
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 084 D HW: 1K0 937 084 D
Component: BCM PQ35 B 103 0615
Revision: 00103 AE
Coding: 48180A3A8025F1C040080080100000E441010088424D8160648087200041
Shop #: WSC 01398 996 13671
VCID: 2F6BABB27EE2883A09-807A
Subsystem 1 - Part No: 5K2 955 119
Component: Wischer 29041 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K8 951 171
Subsystem 3 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Reset counter: 106
Mileage: 217211 km
Date: 2016.10.25
Time: 00:00:01
Voltage: 11.20 V
Term 50 On
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RA4W5EU
Coding: 00003954
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 316FADCA60D69ECA1F-8064
Serial number: 3572MSME7B6B525FZZZC
Serial number: 3582MSME654E235FZZZ5
Serial number: 3512QSME66240759ZZZU
Serial number: 3522QSME64360B18ZZZV
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Revision: -------- Serial number: 90440KE20018Q
Coding: 1082140000
ROD: EV_SMLSNGKUDS_VW36.rod
VCID: 72ED62C6A550E5D2A6-8026
Component: E221__MFL-TK6 H06 0022
Serial number: 70000000000000232304
Coding: E20000
Part No SW: 5K0 920 871 A HW: 5K0 920 871 A
Component: KOMBI H20 0420
Coding: 170B00
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 2C51BCBE47F4F3222C-8078
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H41 1623
Revision: H41 Serial number: 210112F1000267
Coding: 350003
VCID: 3E7586F6A98871B292-806A
Reset counter: 106
Mileage: 217211 km
Date: 2016.10.25
Time: 01:06:32
Reset counter: 66
Mileage: 217211 km
Date: 2016.10.25
Time: 00:55:13
Component: IMMO H20 0420
VCID: 6ADD7AA68D802D121E-803E
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2120
Coding: 0131764
VCID: 316FADCAA8D69ECA1F-8064
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 3461A4DE57C4ABE274-8060
000 - - - MIL ON
Fault Status: 11100000
Mileage: 217211 km
Date: 2016.10.25
Time: 00:56:37
Battery Volts: 11.8 V
DD
Temperature: 23.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Component: Tuer-SG 009 2152
Coding: 0131764
Address 56: Radio
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H41 1623
Coding: 030B185A
VCID: 71EF6DCAA856DECA5F-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900906664
00458 - Control Module for Battery Monitoring (J367)
Reset counter: 106
Mileage: 217211 km
Date: 2016.10.25
Time: 00:56:12
02252 - Generator
Fault Status: 00100011
Reset counter: 106
Mileage: 217211 km
Date: 2016.10.25
Time: 00:09:14
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0131216
Shop #: WSC 01357 011 1012552
VCID: 356799DA5CBEB2EA43-8060
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0131216
VCID: 36659ED641B8B9F24A-8062
End-------------------------(Elapsed Time: 02:22)--------------------------
Tuesday,25,October,2016,16:13:56:65476
Mileage: 217211KM Repair Order:
Address 01: Engine (03L 906 023 MN)
16:13:28
IDE00427-ENG101722 Particle filter: difference pressure-DIP_PF 1027.18 hPa
IDE00428-ENG100917 Particle filter: offset for differential press.-DIP_PF_AD[0] 0.00 hPa
IDE00430-ENG102682 Particle filter: field regeneration request status-STATE_RGN_PF 10
IDE00432-ENG103847 Particle filter: time since last regeneration-T_WOUT_RGN 90952.80 s
IDE00433-ENG103279 Particle filter: oil ash volume-MASS_ASH_PF 59.0127840 g
IDE00434-ENG102050 Particle filter: soot mass calculated-MASS_SOOT_SIM_PF 53.98 g
IDE00435-ENG101197 Particle filter: soot mass measured-MASS_SOOT_PHY_PF 31.39 g
IDE00436-ENG102397 Particle filter: kilometers since last regeneration-DIST_RGN 396.3 km
