MK2 MY15 Škoda Superb 3T 4x4 steering wheel with non working flappy paddles
ladfromoz
AU
C?ID=181995
I've fitted a Flat Bottom Steering wheel with Paddle Shifters to my car Part# 5E0 419 091 BC and I activated TripTronic Shifters in Controller 16 Steering Wheel.
On initial fitting the paddles worked just fine but the Multi-functions buttons did not.
I purchased buttons 5EO 919 719 G WHS from advise received on Briskoda.
Fitted the buttons and all Multi-function worked but the paddles did not...they illuminated but that is all.
Just thinking now, that maybe I could change the pin configuration on the paddles and that may help - though I don't know how to do this or where to find any info on this???
I also checked Advanced Measuring to test the buttons but nothing happened.
Here is my latest Autoscan
Any help will be gratefully appreciated.
VIN: TMBMF93T2F9027151 * License Plate:*
Mileage: 17120km * Repair Order:*
Chassis Type: 3T (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 25 2B 2E 36 37 42 44 46
* * * * * 47 52 55 56 61 62 6D 72 77
VIN: TMBMF93T2F9027151 * Mileage: 17120km-10637miles
Address 01: Engine (J623-CFGB) * * * Labels: 03L-906-018-CFF.clb
* *Part No SW: 03L 906 018 RS * *HW: 03L 906 018 MH
* *Component: R4 2,0L EDC * H28 5357 *
* *Revision: 41H28--- * *Serial number: * * * * * * **
* *Coding: 001D0032042701080000
* *Shop #: WSC 33361 790 00999
* *ASAM Dataset: EV_ECM20TDI01103L906018RS 003003
* *ROD: EV_ECM20TDI01103L906018RQ.rod
* *VCID: 0C17F2CAA72F9822D0-8058
Readiness: 0 0 0 0 0*
Address 02: Auto Trans * * * *Labels: 02E-927-770.clb
* *Part No SW: 02E 300 016 D * *HW: 02E 927 770 AL
* *Component: GSG DSG AG6 * * 531 4013 *
* *Revision: 05653104 * *Serial number: 00001409040719
* *Coding: 0000020
* *Shop #: WSC 33361 790 00078
* *VCID: 152197AE3CE559EA7F-8040
Address 03: ABS Brakes (J104) * * * Labels: 1K0-907-379-60EC1F.clb
* *Part No SW: 1K0 907 379 BS * *HW: 1K0 907 379 BS
* *Component: ESP MK60EC1 * H46 0166 *
* *Revision: 00H46001 * *
* *Coding: 863D601609240001610C06E9901A0092A1095023
* *VCID: 0407DAEA877FD06298-8050
01325 - Control Module for Tire Pressure Monitoring (J502)*
* * * * * * 004 - No Signal/Communication - Intermittent
* * * * * * *Freeze Frame:
* * * * * * * * * * Fault Status: 00100100
* * * * * * * * * * Fault Priority: 2
* * * * * * * * * * Fault Frequency: 1
* * * * * * * * * * Reset counter: 18
* * * * * * * * * * Mileage: 17001 km
* * * * * * * * * * Time Indication: 0
* * * * * * * * * * Date: 2016.10.16
* * * * * * * * * * Time: 00:01:10
* * * * * * * * * * Count: 2
* * * * * * * * * * Count: 14
* * * * * * * * * * Count: 20480
* * * * * * * * * * Count: 16390
* * * * * * * * * * Count: 43008
* * * * * * * * * * Count: 0
* * * * * * * * * * Count: 65280
Address 05: Acc/Start Auth. (J518) * * * Labels: 5K0-959-434.clb
* *Part No SW: 5K0 959 434 E * *HW: 5K0 959 434*
* *Component: VWKESSYPQ35GP 092 1202 *
* *Revision: 00092000 * *Serial number: 0345823220
* *Coding: 030C0C
* *ASAM Dataset: EV_KESSYPQ35G A02717
* *ROD: EV_KESSYPQ35G_VW01.rod
* *VCID: 377D7D268E294BFA4D-8062
Address 08: Auto HVAC (J255) * * * Labels: 5K0-907-044.clb
* *Part No SW: 3T0 907 044 CE * *HW: 3T0 907 044 CE
* *Component: Climatronic * H19 0709 *
* *Revision: 00001009 * *
* *Coding: 0010000003
* *ASAM Dataset: EV_Climatronic A01010
* *ROD: EV_ClimaAutoBasis_SK35.rod
* *VCID: 77FDBD26CEA98BFA8D-8022
Address 09: Cent. Elect. (J519) * * * Labels: 1K0-937-08x-09.clb
* *Part No SW: 1K0 937 087 AN * *HW: 1K0 937 087 AN
* *Component: BCM PQ35 *H+ *112 0771 *
* *Revision: AF112771 * *
* *Coding: 4C190ABCE849F1C0C00800C0310089EC4BF900AE677D85B080814704A041
* *VCID: 7DF1AF0EE495A1AAD7-8028
* *Subsystem 1 - Part No: 3T2 955 119 B *Labels: 1KX-955-119.CLB
* *Component: Wischer 07091 *26 *0700*
* *Coding: 00D7B7
* *Subsystem 2 - Part No: 1K0 955 559 AH *Labels: 1K0-955-559-AG.CLB
* *Component: RLS 061014 05 *54 *0403*
* *Coding: 0630ED
* *Subsystem 3 - Part No: 7N0 951 171 A
* *Component: DWA-Sensor 00 *002 0206*
* *Subsystem 4 - Part No: 1K0 951 605 C
* *Component: LIN BACKUP HO *H05 1501*
Address 10: Park/Steer Assist (J791) * * * Labels: 3T0-919-475-V2.clb
* *Part No SW: 3T0 919 475 D * *HW: 4H0 919 475 E
* *Component: PARKHILFE PLA H06 0005 *
* *Revision: -------- * *Serial number: 56231425901153
* *Coding: 349102
* *ASAM Dataset: EV_EPHVA2CAS46X0000 001003
* *ROD: EV_EPHVA2CAS46X0000.rod
* *VCID: 3E736802A1137AB28E-806A
Address 15: Airbags * * * *Labels: 5N0-959-655.lbl
* *Part No SW: 3T0 959 655 D * *HW: 3T0 959 655 D
* *Component: J234__LDQ VW10 HI * 2518 *
* *Revision: 26020000 * *Serial number: 003LEPJW6R7P *
* *Coding: 0017489
* *VCID: 428B1CF21DEB1E52EA-8016
* *Subsystem 1 - Serial number: 6332MTS647302664*
* *Subsystem 2 - Serial number: 6342MTS609602674*
* *Subsystem 3 - Serial number: 6351HTS66KA36DKJ*
* *Subsystem 4 - Serial number: 6361HTS6PCD66DKJ*
* *Subsystem 5 - Serial number: 63727TS6FM3H2DKJ*
* *Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) * * * Labels: 5K0-953-569.clb
* *Part No SW: 5K0 953 521 DT * *HW: 5K0 953 569 AH
* *Component:*LENKS.MODUL** 016 0140 *
* *Revision: FF010042 * *Serial number: 20140929301985
* *Coding: 1012140000
* *ASAM Dataset: EV_SMLSNGVOLWSXS A01004
* *ROD:*EV_SMLSNGVOLWSXS.rod
* *VCID: 0109D3FE906DC54AB3-8054
* *Multifunction steering wheel control module:*
* *Subsystem 1 - Part No SW: 5E0 919 719 G * *HW: 5E0 919 719 G
* *Component: E221__MFL-PR6 *H05 0130*
* *Coding: 830000
Address 17: Instruments (J285) * * * Labels: 5K0-920-xxx-17.clb
* *Part No SW: 3T2 920 841 M * *HW: 3T2 920 841 M
* *Component: KOMBI * * * * H08 0811 *
* *Serial number: 00000000000000
* *Coding: 111C01
* *ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
* *ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
Address 19: CAN Gateway (J533) * * * Labels: 7N0-907-530-V2.clb
* *Part No SW: 7N0 907 530 AQ * *HW: 7N0 907 530 AL
* *Component: J533 *Gateway H58 1653 *
* *Revision: * H58 * * * Serial number: 071014F1001208
* *Coding: 359303
* *VCID: 7F0D5506EE99B3BAC5-802A
Address 22: AWD * * * *Labels: 0AY-907-554-V1.clb
* *Part No SW: 0BR 907 554 C * *HW: 0BR 907 554 C
* *Component: Haldex 4Motion * * *3018 *
* *Coding: 0000005
* *Shop #: WSC 00000 000 00000
* *VCID: 458107EE0CC5296ACF-8010
Address 25: Immobilizer (J334) * * * Labels: 5K0-920-xxx-25.clb
* *Part No SW: 5K0 953 234 * * HW: 5K0 953 234*
* *Component: IMMO * * * * *H08 0811 *
* *Coding: 000007
* *ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
* *ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
* *VCID: 6ADB94528D1B261202-803E
Address 2B: Steer. Col. Lock (J764) * * * Labels: 5K0-905-861.clb
* *Part No SW: 5K0 905 861 C * *HW: 5K0 905 861 C
* *Component: ELV-PQ35 * * *H21 0240 *
* *Revision: 00000000 * *Serial number: 14000260308003
* *Coding: 4900000000000000
* *ASAM Dataset: EV_ELVMarquMPVW36X A01001
* *ROD: EV_ELVMarquMPVW36X.rod
* *VCID: 306F463A6B479CC20C-8064
Address 2E: Media Player 3 (J650) * * * Labels: 5N0-035-342.lbl
* *Part No SW: 5N0 035 342 G * *HW: 5N0 035 342 G
* *Component: SG EXT.PLAYER H19 0770 *
* *Revision: A1001003 * *Serial number: 7666660927 * *
* *Coding: 010100
* *VCID: 2B5551564A61FF1A39-807E
Address 36: Seat Mem. Drvr (J810) * * * Labels: 3C0-959-760.lbl
* *Part No SW: 3C8 959 760 E * *HW: 3C8 959 760 E
* *Component: Sitzmemory * *H05 3101 *
* *Revision: 00H05000 * *
* *Coding: 00003B
* *Shop #: WSC 12336 024 394758
* *VCID: 377D7D2686294BFA4D-8062
Address 37: Navigation (J0506) * * * Labels: 1T0-035-680.clb
* *Part No SW: 3T0 035 680 S * *HW: 3T0 035 680 S
* *Component: RNS-MID * * * H23 6276 *
* *Revision: AB001001 * *Serial number: SKZ6Z7P7261121
* *Coding: 04060042000000811000
* *VCID: 408F16FAD3E70C42FC-8014
* *Subsystem 1 - Part No: 3T0 051 859 S
* *Component: AUNZ V7 *8035*
Address 42: Door Elect, Driver (J386) * * * Labels: 8X0-959-793.clb
* *Part No SW: 8X0 959 793 H * *HW: 8X0 959 793 H
* *Component: TSG FA * * * *H10 0415 *
* *Revision: -------- * *Serial number: --------------
* *Coding: 011D0220DE01001000
* *VCID: 52AB2CB20D8B8ED25A-8006
Address 44: Steering Assist * * * *Labels: 1Kx-909-14x-44.clb
* *Part No: 1K0 909 144 R
* *Component: EPS_ZFLS Kl. 196 * *3501 *
* *Revision: 00H22000 * *
* *VCID: 39797B1E703D5D8ABB-806C
Address 47: Sound System (R12) * * * Labels: 5K0-035-456.clb
* *Part No: 5C6 035 456 C
* *Component: KonzernAmp10K H08 6831 *
* *Revision: -------- * *Serial number: EAA098C0020586
* *ASAM Dataset: EV_AudioVerst10KanalBNO1 A01003
* *ROD: EV_AudioVerst10KanalBNO1.rod
* *VCID: 285FAE5A5397D402D4-807C
Address 52: Door Elect, Pass. (J387) * * * Labels: 8X0-959-792.clb
* *Part No SW: 8X0 959 792 H * *HW: 8X0 959 792 H
* *Component: TSG BF * * * *H11 0415 *
* *VCID: 51A923BE088DF5CA63-8004
Address 55: Headlight Range (J745) * * * Labels: 5M0-907-357-V3.clb
* *Part No SW: 5M0 907 357 F * *HW: 7L6 907 357 C
* *Component: AFS-ECU * * * H04 0111 *
* *Coding: 01CE00003F000000
* *ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
* *ROD: EV_HeadlRegulVWAFSPt_VW46.rod
* *Left Headlamp Power Output Stage:*
* *Subsystem 1 - Part No SW: 8U0 941 329 * * HW: 8U0 941 329 * Labels: 3D0-941-329.CLB
* *Component: LeiMo links *H01 0005*
* *Coding: 8E0000
* *Right Headlamp Power Output Stage:*
* *Subsystem 2 - Part No SW: 8U0 941 329 * * HW: 8U0 941 329 * Labels: 3D0-941-329.CLB
* *Component: LeiMo rechts *H01 0005*
* *Coding: 8E0000
Address 56: Radio (J0506) * * * Labels: 1T0-035-680.clb
Address 61: Battery Regul. (J840) * * * Labels: 1K0-907-534.clb
* *Part No SW: 7N0 907 534 * * HW: 7N0 907 530 AL
* *Component: Batt.regelung H58 1653 *
* *Serial number: 071014F1001208
* *Coding: 330F785A
* *VCID: 71E9833EA8CDD5CA43-8024
* *Subsystem 1 - Part No SW: 1K0 915 181 H * *HW: 1K0 915 181 A
* *Component: J367-BDM *H07 0180*
* *Serial number: 31268005151491847877
Address 62: Door, Rear Left (J388) * * * Labels: None
* *Part No SW: 8X0 959 795 D * *HW: 8X0 959 795 D
* *Component: TSG HL * * * *H08 0415 *
* *Coding: 010C00200001001000
* *VCID: 50AF26BA0387FCC26C-8004
Address 6D: Trunk Elect. (J605) * * * Labels: 7N0-959-107.clb
* *Part No SW: 7N0 959 107 G * *HW: 7N0 959 107 A
* *Component: HDSG-Modul * *H11 0250 *
* *Revision: 41011001 * *Serial number: 262400423
* *Coding: 082301C002
* *ASAM Dataset: EV_HDSGSk462 301136
* *ROD: EV_HDSGSk462_SK46.rod
* *VCID: 3B756116B2016F9AA9-806E
Address 72: Door, Rear Right (J389) * * * Labels: None
* *Component: TSG HR * * * *H08 0415 *
Address 77: Telephone (J412) * * * Labels: 7P6-035-730.clb
* *Part No SW: 7P6 035 730 N * *HW: 7P6 035 730 N
* *Component: TELEFON * * * H16 4217 *
* *Revision: 1B001001 * *Serial number: 00007666667639
* *Coding: 0211000000010110
* *ASAM Dataset: EV_UHVNA 002720
* *ROD: EV_UHVNA_002.rod
* *VCID: 3D716F0EAC1561AA97-8068
End-------------------------(Elapsed Time: 03:57)--------------------------
ladfromoz
AU
C?ID=181995
Anyone able to provide assistance??
