This vehicles original problem was drive belt tensioner gave out causing the serpentine belt to shread and get caught up into the engine timing belt. The engine timing belt jumped and car will crank but no start. With 123k miles, overdue for a timing belt replacement. After replacing the timing belt, vehicle still cranks over but will not start. An autoscan and a log of the engine while trying to start is posted below. Yes, the correct timing belt tool from metalnerd and at tdc everything lined up. please advise, thank you very much
VCDS Version: 16.8.1.1 (x64)
Data version: 20160902 DS256
VIN: 3VWPL7AJ8AM647442 License Plate:
Gateway Installation List: 1K0 907 530 AD
Chassis Type: AJ (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 65 72 77
VIN: 3VWPL7AJ8AM647442 Mileage: 198620km-123416miles
Part No SW: 03L 906 019 CM HW: 03L 906 022 TS
Component: R4 2,0L EDC G000AG 9971
Revision: 12H02--- Serial number:
Coding: 0050078
Shop #: WSC 05089 444 84564
VCID: 78D110290BDD0B8290-802C
000833 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signalp
Mileage: 198623 km
Date: 2011.02.25
Time: 00:13:01
RPM: 138 /min
Voltage: 9.73 V
Temperature: 30.6°C
Idle Stabilization: 0.0°KW
RPM: 68 /min
(no units): 33.0
Part No SW: 02E 300 052 T HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2114
Revision: 51112 Serial number: 00000911111046
Shop #: WSC 02069 000 90108
VCID: 256F095DECEF466AFB-8070
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B600C49260001880F06E8921B0042310000
Shop #: WSC 00066 000 00000
VCID: 7AD50A21F5D11992E6-802E
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00185
ROD: EV_ClimaBasis_VW36.rod
VCID: 75CF191DD4CF76EA8B-8020
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 G HW: 5K0 937 085 G
Component: BCM PQ35 B++ 111 0128
Revision: BI111001
Coding: 2D380E1A902F3EC480080001400000C401000086535D8560648020000000
VCID: 3753D3158643C4FA59-8062
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 16120 21 0512
Coding: 009795
01598 - Drive Battery Voltage
Fault Status: 00101011
Reset counter: 250
Mileage: 170007 km
Date: 2010.07.04
Time: 22:42:53
Voltage: 13.30 V
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 019 0706
Serial number: 003C4D07MXHP
Coding: 00003044
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3957D52DB857D28AAF-806C
Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--0004YMH900
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME6B28534AZZZ%
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME5B75524CZZZ2
Serial number: 3511HSME76660F1EZZZ-
Serial number: 3521HSME7A570F1EZZZ+
Serial number: 35527SME4231581EZZZE
Serial number: 35627SME2621581EZZZG
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001532
VCID: 76CD1E1101C97DF282-8022
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Part No SW: 5K0 920 970 Q HW: 5K0 920 970 Q
Component: KOMBI H03 0305
Coding: 270F00
Shop #: WSC 00066 000 00148
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 3C59CC39B765E7A2B4-8068
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0111
Revision: H07 01 Serial number: 281009F1000977
Coding: ED807F07001602002002
VCID: 69F7456D4077A20A1F-803C
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223T6HW104
Coding: 0000002
VCID: 7EDD063129F935B2DA-802A
Component: IMMO H03 0305
VCID: 6AF53A618D71A91216-803E
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0000165045
Coding: 0004B5
Shop #: WSC 01383 790 50316
ROD: EV_DCU42BroseDriveSide.rod
VCID: 277303555EE3547AC9-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004574941
Coding: 000490
B11EC 54 [008] - Missing Calibration / Basic Setting
Reset counter: 250
Mileage: 198623 km
Date: 2016.10.04
Time: 00:29:20
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 70 2901
Revision: 00H15000
VCID: 2F43EB75BE130C3A01-807A
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 12.7 V
PD
Temperature: 33.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0000164770
Coding: 0004B4
ROD: EV_DCU52BrosePasseSide.rod
VCID: 2871006953FD5B02C0-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000004556915
Coding: 000490
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----20S Serial number: VWZ4Z7J3050641
Coding: 0500040004
VCID: 61E75D4D7847EA4AC7-8034
Reset counter: 210
Mileage: 198623 km
Date: 2011.02.25
Time: 00:29:19
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Component: RDK 111 0821
Coding: 018705
Address 77: Telephone (J738) Labels: 1K8-035-730.clb
Part No SW: 1K8 035 730 C HW: 1K8 035 730 C
Component: Telefon H08 6600
Revision: 00008000 Serial number: 20389520277571
Coding: 412100
VCID: 2977056D40F7620ADF-807C
Reset counter: 250
Mileage: 198623 km
Date: 2011.02.25
Time: 17:30:16
End-------------------------(Elapsed Time: 01:59)--------------------------
