Adaptation of diff pressure sensor particulate filter using VCDS
Skaterboy
C?ID=245507
Hi Guy
New member and need a little help with the above topic
Procedure
Stage 1 - Engine basis settings - 04
The Adaptation off diff pressure sensor particulate filter - press GO to activate the basic setting
Stage 2 - Then select Resetting of learned values of diff pressure sensor particulate filter - press GO to active basis settings
Then Stop
However the stage two on my VCDS shows the following in the drop down mode
Reset learned values . quantity meter. unit and press. control .valve ----- IS this the correct precedure for stage 2 ???????
Thanks Mark
It's not really possible to provide a meaningful reply without knowing what ECU you have. So please post an Auto-Scan.
Skaterboy
C?ID=245507
Hi Uwe
Hope this helps
Monday,17,October,2016,13:42:01:44477
VCDS Version: 16.8.3.1 (x64)
VIN: TMBBT21Z7A2113202   License Plate: FV10WZP
Mileage: 139470km-86662mi   Repair Order: 1
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBBT21Z7A2113202   Mileage: 139470km-86662miles
Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 AG    HW: 03L 906 023 AG
   Component: 1,6l R4 CR td H23 5697
   Revision: --------    Serial number:
   Coding: 00114016032500080000
   Shop #: WSC 73430 031 00999
   ASAM Dataset: EV_ECM16TDI02103L906023AG 001003
   ROD: EV_ECM16TDI02103L906023A_001.rod
   VCID: 6BD581E882284D1A79-803E
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0104
   Revision: 00H35001
   Coding: 0017665
   Shop #: WSC 73430 790 00999
   VCID: 7BF5B1A83A48DD9AE9-802E
   Part No SW: 3T0 907 044 AR    HW: 3T0 907 044 AR
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 020BCC4C95A2AC52AA-8056
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0575
   Revision: 00103 AG
   Coding: 4C180AB8B05BB1C04008008001000124430000AE626D81605C0440000000
   VCID: 326B5C8C6D82DCD27A-8066
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 26031  22  0601
   Coding: 00D7B7
   Component: RLS 300310 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
Address 10: Park/Steer Assist (J446)       Labels: 1Z0-919-475-V1.clb
   Part No SW: 1Z0 919 475 B    HW: 1Z0 919 475
   Component: PARKHILFE 4K  H06 0006
   Revision: --------    Serial number: 66641008104152
   Coding: 100001
   VCID: 408F0644D32E7E42FC-8014
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2KVCK5
   Coding: 0020788
   VCID: 3D717FB064DC13AA97-8068
   Subsystem 1 - Serial number: 6332MSME50330C576
   Subsystem 2 - Serial number: 6342MSME51611900
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000034
   VCID: 0305C94842B8A55AA1-8056
   Part No SW: 1Z0 920 903 G    HW: 1Z0 920 903 G
   Component: KOMBI         H06 0305
   Coding: 410F00
   VCID: 39796BA0B8F42F8ABB-806C
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K1032707CE
   Coding: E9A07F06000202001303
   VCID: 69D9FBE040D45F0A0B-803C
                    Fault Status: 00101011
                    Reset counter: 183
                    Mileage: 138939 km
   Component: IMMO          H06 0305
   VCID: 6ADB84EC8DD2541202-803E
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2114
   Coding: 0000758
   VCID: 76E3A09C016A80F296-8022
00100 - Drivers Interior Locking Button (E308)
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
   VCID: 31695380A884E7CA03-8064
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0000758
   VCID: 489F1E643B1E460234-801C
   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
   Component: BOLERO        010 0053
   Revision: 0A001001    Serial number: SKZ1Z3K8443731
   Coding: 0D0004000001
   VCID: 356167909CECCBEA5F-8060
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012551
   VCID: 326B5C8CAD82DCD27A-8066
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 336559885298D5DA71-8066
End-------------------------(Elapsed Time: 02:14)--------------------------
OK, where did you get the procedure you referenced above?
It looks to me like all you would need on this engine is:
Adaptation of diff. pressure sensor particulate filter
I don't see why
Reset learned values quant. meter. unit and press. contr. valve
... would be needed here.
Skaterboy
C?ID=245507
Exhaust Gas Differential Pressure Sensor (G450) Adaptation
The Exhaust Gas Differential Pressure Sensor (G450) Adaptation is performed based on the EDC Protocol which is shown in the upper left corner of the Open Controller screen
CAN Protocol (G450) procedure
Instructions should be populated in a pop-up balloon when connected to the controller in question with VCDS.
Key ON, Engine OFF
[Coding-2] or [Login-II] button
Enter the code shown in the VCDS pop-up balloon
[Do It!]
Switch Ignition OFF for 30 seconds
After the key is cycled back on the adaptation should be completed. If it is not completed, proceed with the next steps:
These steps must be repeated 5 times.
Ignition ON
Wait 5 seconds
Ignition OFF
Wait 40 seconds
Repeat 4 more times
Note: If a code is NOT shown in the VCDS pop-up balloon registered customers can Join our Forum -or- send the complete Auto-Scan via email with the recent repair history including the part number of the original/removed sensor and the new replacement sensor.
UDS Protocol (G450) procedure
Key ON, Engine OFF
[Basic Settings]
Select Adaptation of diff. pressure sensor particulate filter
[Go!] to activate the Basic Setting.
After the result of Finished Correctly appears click [Stop]
Select Resetting of learned values of difference pressure sensor
[Done, Go Back]
Special Notes
Exhaust Pressure Control Valve (J883) feedback from a 2009 NAR market Jetta is located Here
G212/N18, G69/J338 and G336/V157 feedback from RoW market CBAB and CBBB engines in the Passat is located In this thread
FMA (Fuel Mean Value Adaptation / Kraftstoffmengen-Mittelwertadaptation) discussion is located In this thread
Kejo
Denmark
C?ID=505887
Key ON, Engine OFF
[Do It!]
Ignition ON
Wait 5 seconds
Ignition OFF
Wait 40 seconds
Repeat 4 more times
Key ON, Engine OFF
[Basic Settings]
[Done, Go Back]
Special Notes
Hi,
I got fault code P2002. I think to change Differential Pressure Sensor. It is a VW touran tdi 2.0 from 2020. working with uds protocol. Can I adapt Differential Pressure Sensor with the method you wrote above ?
Hope this helps.
Wednesday,15,June,2022,10:45:20:53620
VCDS Version: 22.3.1.4  HEX-V2 CB: 0.4615.4
VIN: WVGZZZ1TZLW053153
Chassis Type: 1T-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 20 42 44 52 55 5F 6D 75 BB
          BC
VIN: WVGZZZ1TZLW053153   Mileage: 173976km-108103miles
Address 01: Engine (J623-DFGC)       Labels: None
   Part No SW: 04L 906 027 M    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H26 7437
   Revision: B4H26---    CVN: EC5434BE37C5C2A218229D33
   Coding: 0125001203641D083000
   ASAM Dataset: EV_ECM20TDI01104L906027M 004002
   ROD: EV_ECM20TDI01104L906027F.rod
   VCID: 35372E4595CC61E32C9-8060
   VINID: 9E65EAAAA064A9C9C01430450C52F1215E
20170 - Particulate Trap Bank 1
          P2002 00 [104] - Efficiency Below Threshold
                    Fault Frequency: 40
                    Mileage: 167140 km
                    Date: 2022.05.22
                    Time: 01:08:06
                    Engine RPM: 1280.50 /min
                    Vehicle speed: 65 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 75 °C
                    Voltage terminal 30: 14.360 V
                    Exhaust mass flow of low-pressure EGR: calculated: 2.380
                    Differential pressure ratio: low-pressure EGR: 66.9 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 49.9 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 51.0 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 99.90 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 100.00 %
                    Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 49.8 hPa
15733 - SCR NOx Catalyst Bank 1
          P20EE 00 [104] - Efficiency too Low
                    Mileage: 169274 km
                    Date: 2022.05.31
                    Time: 15:22:48
                    Engine RPM: 1736.50 /min
                    Normed load value: 58.0 %
                    Vehicle speed: 112 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 94 °C
                    Voltage terminal 30: 13.020 V
                    Unlearning counter according OBD: 34
                    Reducing agent quality sensor: urea concentration: 34.5 %
                    Measured NOx conversion range 1: 0.468
                    Calculated efficiency of NOx conversion: 0.997
                    Efficiency threshold of NOx conversion range 1: 0.492
                    Mean temperature of SCR catalyst: 348.9 °C
                    NOx sensor after SCR cat conv: offset correction factor: 0 ppm
                    Reducing agent quality sensor: raw temperature value: 18.9 °C
Readiness: 0 2 0 0 0
   Part No SW: 0GC 300 044 F    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2405
   Revision: 00H06V11    CVN: BA56A815
   ROD: EV_TCMDQ381061.rod
   VCID: 2B03083D438827134AD-807E
   No subsystems:
   Part No SW: 5Q0 614 517 DP    HW: 5Q0 614 517 BS
   Component: ESC           H82 0113
   Revision: 00000000    Serial number: 61540000000353
   Coding: 0CEA6AA0A0250B6F4778060560C629305605D0E2600694753862F078D2024A0B0000040212121212B235351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 025D85999482065BD9B-8056
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0548654366
   Coding: 132C0C0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D75E85C52CF163BC9-8010
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 14598833
   Part No SW: 5G1 907 044 AP    HW: 5G1 907 044 AP
   Component: Climatronic   H04 2401
   Revision: 00001K10
   Coding: 08020104203114011005100C0010142A
   ASAM Dataset: EV_ACClimaBHBVW37X 006151
   VCID: 76B5E949C84A2AFBE53-8022
   Air quality sensor:
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Reset counter: 4
                    Mileage: 166563 km
                    Date: 2022.05.20
                    Time: 20:57:37
                    Voltage terminal 30: 12.9 V
                    Outside temperature: 14.5 °C
                    System run time-Engine running time: 24 s
                    System run time-Terminal 15 on: 24 s
   Part No SW: 5Q0 937 086 CE    HW: 5Q0 937 086 BQ
   Component: BCM PQ37BOSCH 038 0303
   Revision: --------    Serial number: J53F1506200133
   ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
   ROD: EV_BCMBOSCH_020_VW37.rod
   VCID: 7F5B0C6DE7706BB3B65-802A
   Subsystem 1 - Part No SW: 5TB 955 119 A    HW: 5TB 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    200316  043  0608
   Serial number:         200324135704
   Subsystem 2 - Part No SW: 81D 955 555 A    HW: 81D 955 555
   Component: G397_RLFSS  H06  0004
   Serial number: 30311382X81D955555A0
   Coding: 0000DE
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 R    HW: 5Q1 953 569 B
   Component: Lenks.Modul  H23  0170
   Serial number: 0100220420200C105421
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058320162
   Coding: 0471051811
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 50F97FD10A6E24CB1FF-8004
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H05 0196
   Coding: 3200678259FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
   Component: AirbagVW21    008 0403
   Serial number: 003FNR6BTDLJ
   Coding: 98CCC0C00C0000005C5450CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 1373B0DDFBF89FD362D-8046
   Left seat belt tensioner:
   Component: BeltPretRevFL  106 1040
   Serial number: 5TB857705F0164U00131
   Coding: 80000D
   Right seat belt tensioner:
   Component: BeltPretRevFR  106 1040
   Serial number: 5TB857706F0167U00018
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 001 806 20
   Serial number: 357000000001E17D684Q
   Subsystem 4 - Part No SW: -----------    HW: 480 001 806 20
   Serial number: 3580000000090C45094G
   Subsystem 5 - Part No SW: -----------    HW: 480 410 306 20
   Component: SideSensor_Dr  003 0189
   Serial number: 351001A150CCC9323F5D
   Subsystem 6 - Part No SW: -----------    HW: 480 410 306 20
   Component: SideSensor_Pr  003 0189
   Serial number: 352001A159B98934ECFZ
   Subsystem 7 - Part No SW: -----------    HW: 480 401 606 20
   Serial number: 355000126630194356EU
   Subsystem 8 - Part No SW: -----------    HW: 480 400 906 20
   Component: PedP_Sensor_C  004 6149
   Serial number: 23000012663054141094
   Subsystem 9 - Part No SW: -----------    HW: 480 002 805 20
   Serial number: I0M000000007F895E74N
   Subsystem 10 - Part No SW: -----------    HW: 480 002 805 20
   Serial number: I0N00000000BA695E74L
   Part No SW: 5TA 920 751 D    HW: 5TA 920 751 D
   Component: KOMBI         301 7430
   Coding: 07A401082F80000801886B011401000800000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009014
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: 46D55989F82AFA7BB53-8012
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 25062010523134
   Coding: 030100045F087300FB10025C180F00010001070000000000000000000000
   GVL: 01443C0008000500400C90008000C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B9DF51AA2E04CB3FF-8024
   Generator:
   Component: 4-00-05-00-04
   Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  H06 0025
   Serial number: 0902010065800359FF2B
   Coding: 2F0000
   Component: J367-BDMHella  H11 9070
   Serial number: 4240834705
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Fault Frequency: 34
                    Reset counter: 15
                    Mileage: 165502 km
                    Date: 2022.05.17
                    Time: 01:58:28
                    Terminal 30 power supply: 12.0 V
                    Terminal 15: OFF
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 3G0 857 511 AE    HW: 3G0 857 511 AE
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 0404000300000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 6B83C83D8308E7130AD-803E
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007TC70277C
   Coding: 003B9320D000048000001000
   VCID: 49CF52B5E9341503581-801C
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 074004 00
   Coding: 0100001000400110
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007TC910073
   Coding: 003B9120DC00048000001000
   VCID: 48C957B1F23EEC0B47F-801C
   Coding: 07CA020009000000
   VCID: 75B7EE45D54C21E3EC9-8020
   Part No SW: 3Q0 035 846 B    HW: 3Q0 035 846 B
   Component: MU-S-N-ER     H42 0478
   Serial number: VWZAZ2X0872737
   Coding: 02730801FF0000005111000100080A001F0500C401200100CE
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 30391F516AAE44CB7FF-8064
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  361 8214
   Serial number: VWZ6ZHX1703677
   Subsystem 2 - Part No SW: 5NA 919 866 T    HW: -----------
   Component: ECE2 2020  --- 1310
   Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0271
   Revision: --------    Serial number: A2-C737-6291-8
   Coding: 0308
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0827
   Revision: --------
   Coding: 02730801EA42180D3F1CBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   VCID: 3D273665ADFCB9A3E49-8068
   Part No SW: 5Q0 959 595 K    HW: 8W1 959 595 D
   Component: TSG HFS004 0330
   Serial number: YE007TCC1104C
   Coding: 002091200000048000001000
   VCID: 4BC368BDE34807136AD-801E
   Component: TSG HBFS004 0330
   Serial number: YE007TC313462
End----------(Elapsed Time: 02:00, VBatt start/end: 13.4V/13.4V)-----------
                Address 01: Engine       Labels: None
Control Module Part Number: 04L 906 027 M    HW: 04L 907 309 P
  Component and/or Version: R4 2.0l TDI   H26 7437
           Software Coding: 0125001203641D083000
            Work Shop Code: WSC 01357 011 00200
              ASAM Dataset: EV_ECM20TDI01104L906027M 004002 (VW37)
                    Fault Frequency: 40
                    Mileage: 167140 km
                    Date: 2022.05.22
                    Time: 01:08:06
                    Mileage: 169274 km
                    Date: 2022.05.31
                    Time: 15:22:48
                    Fault Frequency: 40
                    Mileage: 167140 km
                    Date: 2022.05.22
                    Time: 01:08:06
                    Mileage: 169274 km
                    Date: 2022.05.31
                    Time: 15:22:48
I don't think this engine has a traditional differential pressure sensor for the DPF. It only uses such a sensor for the low-pressure EGR.
Kejo
Denmark
C?ID=505887
Key ON, Engine OFF
[Do It!]
Ignition ON
Wait 5 seconds
Ignition OFF
Wait 40 seconds
Repeat 4 more times
Key ON, Engine OFF
[Basic Settings]
[Done, Go Back]
Special Notes
Hi,
i have just change the differential pressure sensor.But I can not find the adaptation of differential pressure sensor in the list under basic settings. May be does my car not need it ? It is a 2020 model Touran tdi with UDS protocol.
Again, I don't think this engine has a differential pressure sensor for the DPF. It has a differential pressure sensor for the low-pressure EGR, and if you changed a differential pressure sensor, then I would suppose that's the one you changed. There is a Basic Setting for that one:
IDE05936 -- Low-pressure EGR differential pressure sensor adaptation
But I doubt this will fix your DPF fault.
Kejo
Denmark
C?ID=505887
Hi Uwe,
thank you for your suggetion.
The Part number which I have replaced is 04L906051 M. I baught a genuine part in VW same as fitted on my car with two pipe connection. Google says it is differential pressure sensore for DPF. I have driven over 100 km after replaced it (without adaptation). The engine light has not on yet. What is your suggetion ?
Westbury, UK
Who do you believe - Google or the firmware actually in your car?
I know which one I would believe...
Wait, I thought Google was omniscient, and VAG has been known to mis-label things in their firmware. So if it was my car, I would do some digging into the repair manuals and applicable SSPs to find out how this stuff actually works. :)
Kejo
Denmark
C?ID=505887
Hi ,
I made a adaptation for EGR low pressure differencial pressure sensor.But car gets still same fault code(p2002) and gets still engine light on. Should I also make a resetting of learned values of EGR low pressure difference pressure sensor. But I can not find it in list on VCDS. Ther is only ''resetting of learned values of pressure sensor'' on the list. Can you help me ?
