key adaptation trouble
leakinboost
C?ID=216249
hello everyone,
second owner of my mkv Gli so I only have one key. Immobilizer of course works however the remote function do not. So what I've done is purchase a new key fob with uncut key. So what I've done is go to module 46/adaptation/00/save/done go back/adaptation/pgup to 01/ insure 1 key selection is selected/save/ then on the key press 1 or 2 for 1 second (with in 15 sec) and i understand the signals on the instrument cluster are suppose to flash. never get a flash and of course I get no response when trying the remote buttons to unlock the doors. below is my scan
(edited to show full autoscan
Friday,27,June,2014,21:33:01:37672
VCDS Version: 14.6.1.0 (x64)
Data version: 20140601
VIN: 3VWWJ71K77M182445   License Plate: JETTA
Mileage: 152840km-94970mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 62 65 72
VIN: 3VWWJ71K77M182445   Mileage: 152840km-94970miles
65-Tire Pressure -- Status: Not registered 0001
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 H    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWZ7Z0G8105458
   Coding: 0403010A18070160
   Shop #: WSC 00066 000 00000
   VCID: AB1646700A96986214-80FE
Readiness: 0000 0001
   Revision: 00H11001
   Coding: 0021122
   VCID: F3A69E10922680A29C-80A6
   Part No SW: 1K0 820 047 GG    HW: 1K0 820 047 GG
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: EFAE9260FE0EA44278-80BA
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000000632882
   Coding: 17058E234004150007140000001400000028770B5C0000
   VCID: EC94856CCF185F5A5D-80B9
   Component: Wischer 180507 020  0501
   Coding: 00038805
   Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
   Component: SDAR SIRIUS     H06 0080
   Revision: 00000000    Serial number: AUZ4Z7G0088742
   VCID: AE104F643984ED4A33-80FB
                    Reset counter: 144
                    Mileage: 137159 km
                    Time: 17:05:27
02788 - Internal Communications Error
                    Reset counter: 84
                    Mileage: 152478 km
                    Time: 17:02:58
                    Bin. Bits: 00000000
                    Bin. Bits: 00000001
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M01TE22
   Coding: 0013889
   Subsystem 1 - Part No: 1K0 959 339 F
   Component: BF-Gewichtsens. 007 0005
   Subsystem 2 - Serial number: 6332MSME17390A135
   Subsystem 3 - Serial number: 6342MSME175E467AQ
   Subsystem 4 - Serial number: 6351HSME0D1359468
   Subsystem 5 - Serial number: 6361HSME0D15477BG
   Subsystem 6 - Serial number: 63727SME0C6E19709
   Subsystem 7 - Serial number: 63827SME0C6D52144
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0002021
   VCID: 814AC4D8D89AA2329E-80D4
   Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
   Revision: V0003000    Serial number: VWZ7Z0G8105458
   Coding: 0023207
   VCID: B12A541828BAF2B22E-80E4
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 260307F1000118
   Coding: 7D3F03600F001002
   VCID: AF2E52603E8EE44238-80FA
                    Mileage: 152845 km
                    Time: 20:32:06
   Part No SW: 1K5 919 965 A    HW: 1K5 919 965 A
   Component: Kompass         005 0004
   Revision: 00005000    Serial number: 1293324T2MSG04
   Coding: 0000003
   VCID: B93A6C38F0CA3AF296-80EC
   Component: IMMO            VDD 1610
   Shop #: WSC 06909 444 04954
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000159478418
   Coding: 0001205
   VCID: BB367630FAF608E284-80EE
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   VCID: B4245D0CD7A8C79A45-80E1
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Component:    KSG PQ35 RDK 052 0218
   Coding: 1B900F880186281B0904058FB0880F0488DC00
   VCID: 8444CDCCC788B71AB5-80D1
01179 - Incorrect Key Programming
                    Reset counter: 76
                    Mileage: 152845 km
                    Time: 20:39:49
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000065578502
   Coding: 0001204
   VCID: BC34752CFFF80FDA8D-80E9
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: F4A49D0C9728879A85-80A1
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7J2283029
   Coding: 0010400
   VCID: A91ABC78006A8A72E6-80FC
00003 - Control Module
            014 - Defective
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000001444036
   Coding: 0001168
   VCID: BE307F24E9E41DCAA3-80EB
   Component:    RDK              0440
   Coding: 0100101
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000001448833
   Coding: 0001168
   VCID: BFCE0220EEEE14C2A8-80EA
End-------------------------(Elapsed Time: 02:08)--------------------------
Look at measuring blocks 010 and 011 (in 46: Central Conv.). Do you see anything happening there when you press buttons on that remote? I would expect even an unmatched remote should show up there, and if nothing at all happens when you press buttons on the remote, your new remote is either NFG or incompatible with the car. However, I'm not absolutely certain about this, so if I'm wrong, somebody please correct me.
Zenerdiode
Newcastle, England
C?ID=24330
Where did you get your new remote? They may look identical but transmit at different frequencies in different areas or countries. They have slightly different part numbers/colour codes to reflect this.
leakinboost
C?ID=216249
I bought them from a website name ikeyless.com. I'm about to look around that site to see if any frequency are specified.
Spacewalker
Poland
C?ID=159607
what p/n is on the KEY ?
leakinboost
C?ID=216249
HLO 1KO 959 753 H on both new remote
HLO 1J0 159 753 AM on my old key. My old key has never worked. I bought this car used with this one key (remote key and immobilizer) And kinda tired of using a key to open the doors and trunk.
None of the 3 remotes (old and 2 new) show activity on block 10 and 11. 10 shows no remote
Could my module simply be coded incorrectly
Spacewalker
Poland
C?ID=159607
Any Frequnecy on the NEW KEY , close to p/n ?
Zenerdiode
Newcastle, England
C?ID=24330
1K0 959 753 H - 315MHz
1J0 959 753 AM - 315MHz (I don't know where you got 159 from, must have copied it down wrong...)
Your CCM - 1K0 959 433 CT - doesn't have any PR code in the catalogue, so I'm assuming it is 434MHz. If so, the correct key transmitter for your car would be 1K0 959 753 G - 434MHz.
I'm also presuming a 2007 Jetta - because you weren't specific about that either.
It may be worth double checking my work though.
leakinboost
C?ID=216249
You are correct there is no 159. typo on my part.
The car is a 2007 Jetta Gli purchased used with only one 1 Key. the immobilizer has always work however the remote has never. Figured I wasn't going to let a remote keep me from a good buy.
finally see the frequency stamped and both say 315MHz so I have contacted the seller (ikeyless.com) and waiting on a reply.
Spacewalker
Poland
C?ID=159607
CT module , or future DA is for US market
5D2, 5D3, 5D5 - all 315Mhz
leakinboost
C?ID=216249
Zenerdiode
Newcastle, England
C?ID=24330
I think you are going to have to seek help from a dealership; as when I looked at the catalogue the CT module did not have any of the PR-Codes after it; i.e. It did not have PR-5D2, PR-5D3 or PR-5D5 after it, so I presumed it is a 434MHz unit...?
Please check.
Spacewalker
Poland
C?ID=159607
Etka screen below
leakinboost
C?ID=216249
Etka screen below
Ok kinda getting confused, really I appreciate all the help. So all these mean per that 1K0 959 433 CT so I need the remote with the 1K0 959 753 G - 434MHz.
Spacewalker
Poland
C?ID=159607
did you read my post ?
