TBA
joe67
Verified VCDS-Lite User
C?ID=284377
Was gettng fault code:
00516 closed throttle (idle) position switch f60 2700 implausible signal
Ive removed the throttle body on a 1.4 16v ahw, cleaned it and refitted. Used a pole to hold accelerator down, pulled the cable back just to the point were throttle body butterfly was open.
Heres a vid off the vcds process, am now getting basic setting not complete error, the engine refuses to idle and cuts out
Please post an Auto-Scan.
If this is a cable-throttle engine, the cable needs to have a bit of slack in it when the throttle is closed.
joe67
C?ID=284377
its cable throttle
VCDS-Lite Version: Release 1.2
Sunday, 16 October 2016, 16:41:05:3906
Chassis Type: 17 - VW Golf Citi
Scan: 01,09,15,17,25,56
Address 01: Engine       Labels: 036-906-014-AHW.LBL
   Controller: 036 906 014 AN
   Component:  MARELLI 4CV       2893
   Coding: 00031
   Shop #: WSC 00028
   VCID: 5CCB1831DF33
01087 -  Basic Setting Not Performed
            35-00 -   -
Readiness: N/A
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   Controller: 6Q0 909 605 A
   Component: Y2 AIRBAG VW5       0003
   Coding: 22834
   Shop #: WSC 00028
   VCID: 351DAD951C59
00532 -  Supply Voltage B+
            07-10 -  Signal too Low - Intermittent
Address 17: Instruments       Labels: 1J0-920-xx0-17.LBL
   Controller: 1J0 920 901
   Component: A4-KOMBIINSTR. VDO V12
   Coding: 01441
   Shop #: WSC 00001
   VCID: E0B3ACC1735B
   IMMO-IDENTNR: VWZ7Z0X1452133
Address 25: Immobilizer       Labels: None
   Controller: Bit teA dre sst
   Component: e 17 eingeben
   VCID: CEEF627919CF
No Faults Found
  or a communication error ocurred
End   --------------------------------------------------------------------------------------------------
joe67
C?ID=284377
after engines been started
Sunday, 16 October 2016, 16:51:59:3906
   Coding: 00031
   Shop #: WSC 00028
   VCID: 5CCB1831DF33
00282 -  Throttle Position Actuator (V60)
            26-00 -  Output Open
            35-00 -   -
Readiness: N/A
   Coding: 22834
   Shop #: WSC 00028
   VCID: 351DAD951C59
   Coding: 01441
   Shop #: WSC 00001
   VCID: E0B3ACC1735B
   VCID: CEEF627919CF
No Faults Found
edit: cable has slack
the for cleaning the tb is the engine was hunting and cutting out
the original fault code was 00516 closed throttle (idle) position switch f60 2700 implausible signal
I would suggest that whatever is causing this needs to be fixed:
            26-00 -  Output Open
MartinsX
Riga, Latvia
C?ID=268515
Completely agree. Bad wiring, bad throttle motor, bad output driver IC inside ECU in the worst case.
joe67
C?ID=284377
narrowed it down to the throttle body, it shows as throttle open on vcds even with cable disconnected. bridging pins 3 and 7 on the throttle body plug changed it to idle
MartinsX
Riga, Latvia
C?ID=268515
The best way is to replace TB with new one. Or used one, if You want to save some money. Is Your TB clean inside? No soot or something like it not allowing full range movement of throttle?
joe67
C?ID=284377
Already cleaned the Tb mate, hence the TBA. Going to go for a known working used one and see how it goes. Thanks for the help
joe67
C?ID=284377
Thursday, 20 October 2016, 13:20:02:3906
   Coding: 00031
   Shop #: WSC 00028
   VCID: 5CCB1831DF33
            35-00 -   -
Readiness: N/A
   Coding: 22834
   Shop #: WSC 00028
   VCID: 351DAD951C59
   Coding: 01441
   Shop #: WSC 00001
   VCID: E0B3ACC1735B
   VCID: CEEF627919CF
No Faults Found
00282 - Throttle Position Actuator(V60)
26-00 - Output Open
isnt returning now, it will if engine is started
edit: to avoid any mix up, the above means the code only returned after the engine has been started.
It goes straight to error when i first put 098 into basic settings, i then switch to measuring blocks using the tab at the bottom left and it shows the same results, i then switch back to basic settings, sometimes for a split second its shows ADP OK then quickly changes to error.
MartinsX
Riga, Latvia
C?ID=268515
It is another TB showing the same fault code?
joe67
C?ID=284377
You are not supposed to do the ADP with the engine running!:banghead:
I liked your post because it's funny.......
i didnt.... sorry jack, it means the code only returns after the engine has been started
joe67
C?ID=284377
it started off with
00532 supply voltage b+ 07-10 signal to low intermittent
after the throttle body clean
26-00 - Output Open
but it was reading as part throttle with the cable disconnected, and changed to idle once pins 3 and 7 were briged
throttle body from breakers was fitted, it now shows as idle in vcds but still shows error in adaptation idle/error field
and this code if the engine has been started, after codes have been cleared
26-00 - Output Open
joe67
C?ID=284377
had some help, looking for a second opinion. Would you guys agree that the following results from measuring blocks point towards a faulty replacement throttle body?
 005 zone 4 tv cal. xx000000 = 00000100
joe67
C?ID=284377
got there in the end, turned out to be a fault with the wiring/plug at the throttle body
