Battery Adaptation for A3/S3 (8V) Problem
RS200Z
C?ID=251076
I just changed my battery from the factory provided EFB to a Varta AGM one. I was able to change the following 2 Battery adaptations:
channel IDE03256-MAS06105-Battery adaptation-Rated battery capacity, from 69Ah to 70Ah
channel IDE03256-MAS06106-Battery adaptation-Battery technology, from EFB to Binary - AGM
however, I got the "Request out of range" error when trying to change the Battery Manufacturer adaptation.
The factory battery is made by Banner and the old value is BA2. I tried changing it to VA0 but was unsuccessful.
Last but not least, as I didn't get the battery from Audi, it did not come with the BEM Code sticker. As such, there is no 11 digits serial number on the new Varta battery. Is it important to change the Battery Serial Number adaptation?
Yes, it seems that changing the serial number is what tells the system that there's a new battery.
If you don't have a real serial number, just change the last digit on the existing serial number.
RS200Z
C?ID=251076
Thanks for the reply. How about the "Request out of range" problem with changing Battery Manufacturer? Is that a problem that will be fixed in the next VCDS release?
Since you haven't told us what version of VCDS you were using, much less posted an Auto-Scan, we don't have enough info to even begin looking whether this is a problem with VCDS. ;)
RS200Z
C?ID=251076
Sorry about that. Am using the latest 16.8.3 version.
Here's the Auto Scan log.
Saturday,15,October,2016,11:06:59:57576
VCDS Version: 16.8.3.1 (x64)
VIN: WAUZZZ8V4F1132003   License Plate:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F BB BC
VIN: WAUZZZ8V4F1132003   Mileage: 26748km-16620miles
Address 01: Engine (J623-CZCA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 DA    HW: 04E 907 309 AC
   Component: 1.4l R4 TSI   H22 8231
   Revision: R7H22---
   Coding: 02250032232401083000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM14TFS01104E906027DA 001011
   ROD: EV_ECM14TFS01104E906027DA.rod
   VCID: 66C3FBDB9987257226-8032
   CAN Converter 01:
Readiness: 1110 0001
   Part No SW: 0CW 300 047 D    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5220
   Revision: 00043014    Serial number: CU501503176524
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021.rod
   VCID: 3C7779B3B78B4FA2A0-8068
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 60865000002650
   Coding: 13F18AA22423126E0177060041C629C851244880608294F20221503A8208
   Shop #: WSC 43276 002 104857
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: 489F1563F353130234-801C
   Revision: 00021000    Serial number: 0363457336
   Coding: 030C0C
   VCID: 3A7B7FABBDBF7192B2-806E
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000605231
   Coding: 03100004110000011000000000001500
   VCID: 326B578B65CF89D27A-8066
   Serial number: E0890E97000000000001
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011508502270
   Coding: 07051A42C24122F543C04004001807A80800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 000FCD439BE3EB42BC-8054
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 150319  041 0585
   Serial number:         150321133332
   Coding: 0A47F7
   Serial number: 23844961
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 15 01 2015  00001690
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0047
   Revision: --------    Serial number: 39431504401933
   Coding: 0130064011
   Shop #: WSC 18207 123 104857
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003_VW37.rod
   VCID: 428B074BD56F3952EA-8016
13639168 - Databus
                    Reset counter: 186
                    Mileage: 26748 km
                    Date: 2016.10.15
                    Time: 11:01:45
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Serial number: 003MMR0385KO
   Coding: 98CCC000000000005C54000000C800000065
   Subsystem 1 - Part No SW: -----------    HW: 480 002 603 15
   Serial number: 35767000000E1A01831N
   Subsystem 2 - Part No SW: -----------    HW: 480 002 603 15
   Serial number: 3586700000097A01831P
   Subsystem 3 - Part No SW: -----------    HW: 480 402 303 15
   Serial number: 3516502C119EFD2203DL
   Subsystem 4 - Part No SW: -----------    HW: 480 402 003 15
   Serial number: 3526502B919EFD22419R
   Subsystem 5 - Part No SW: -----------    HW: 480 402 711 14
   Serial number: 3556502B1188FC2361EM
   Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 02041504400923
   Coding: A018
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 0A1BEF6BADDFA112E2-805E
   Part No SW: 8V0 920 871     HW: 8V0 920 871
   Component: KOMBI         H02 4292
   Coding: 27AD19182B9000080104E8001000000000000000
   ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
   VCID: 79F9A0A7F839BA8AFB-802C
   Revision: --------    Serial number: 21031510801552
   Coding: 030100043F0857005B0002481C0B00000001010000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72EB978BA54FC9D2BA-8026
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185703001503140403
   Revision: 00000000    Serial number: 15000082359003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 346751939FDB87E268-8060
   Serial number: 250215BBO17692
   Coding: 001C1F205C01040000001002
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 8303
   Shop #: WSC 14577 001 104857
   VCID: 4385024FCA75305AE1-8016
   Serial number: 210315BCK0331A
   Coding: 001C17205E01040000001002
   VCID: 41890847D069224AF3-8014
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 019E000001000000
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   VCID: 75E1AC97D421DEEA9F-8020
Address 5F: Information Electr. (J794)       Labels: 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 045 E    HW: 8V0 035 045 C
   Component: MU-H-N-RW     H44 0357
   Serial number: A307C0F7522178
   Coding: 01730107FF00000021110001000A00002F000306010001005E
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_AU37.rod
   Subsystem 1 - Part No SW: V03 959 800 TG    HW: -----------
   Component: ROW 2016/2017  --- 0058
   Component: DU High  H49 0014
   Serial number: AUZ8Z9FY202UJX
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000007021500030099
   Compact Disc Database:
   Component: Gracenote  --- 4006
Address BB: Door Rear Drv (J388)       Labels: None
   Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0028
   Serial number: 150315BCF06251
   Coding: 000C17204001040000001002
Address BC: Door Rear Pass (J389)       Labels: None
   Component: TSG HBFS      020 0028
   Serial number: 150315BCF08799
End-------------------------(Elapsed Time: 04:24)--------------------------
RS200Z
C?ID=251076
Any insight to the problem I am facing?
I have nothing beyond some speculation at this point. Perhaps there are serial number ranges assigned to the different manufacturers and module does a plausibility check whether the serial number of the battery belongs to that manufacturer?
PS: How is your situation a "problem"? You bought a battery without a BEM sticker. It works, anyway, right?
RS200Z: Hi . I have admaps from the CAN Gatway of numerous "5Q0" vehicles in my database from around the world (Europe, Australia, USA). Whilst the settings for the battery channels related to capacity and construction-type vary, without exception, they all contain the factory settings below:
(3)-Battery adaptation-Battery manufacturer JCB
(4)-Battery adaptation-Battery Serial Number 1111111111
Now, there is much about which I am ignorant when it comes to how the boffins at VW set the values for adaptation channel on MQB model vehicles. But my hypothesis based on the observations above (i.e the fact that whist the settings for battery capacity and construction-type differ, the settings for battery manufacturer and battery serial number don't change) is that it doesn't matter what two settings are applied to the two channels above. I'm more than happy to be corrected in my thinking (always willing to learn), but if anyone has an alternative theory please explain how it complies with my observations above!
So, I suspect that Uwe is correct in his advice (nothing surprising about that - I agree) - leave the manufacturer setting as is and change the last digit of the serial number to 0 to tell the CAN gateway that there has been a battery change.
RS200Z
C?ID=251076
Uwe / DV52, thanks for the advice. Have increased the last digit of the battery serial number so the CAN gateway registers the battery change.
