ACC (Auto Dist. Reg) Coding Following Trailer Retrofit Help Please
Zenerdiode
Newcastle, England
C?ID=24330
Hello Guys & Gals,
I've just completed (retro)fitting a towbar to my 2009 A4 B8. I opted for a Westfalia one (OEM to Audi) with their dedicated electrics - which of course includes a J345 mudule. All mechanically fitted, electrically fitted without a problem. However, I'm having trouble with the coding of my 13-Auto Dist. Reg module.
Would anyone have a code to try?
All other codes were accepted as you'll see at the bottom of my Autoscan; and summarised here:
01 - Engine - Byte6 Bit3
03 - ABS Brakes - Byte1 Bit7
09 - Cent. Elect. - Byte18 Bit5
10 - Park Assist - Short coding possible. Label File Encrypted..! - OK to code (actually it's changed to Long Coding now)
13 - Adaptive Cruise Control - **No Information**
19 - CAN Gateway - Add Module 69 - Trailer
69 - Trailer - Byte0 Bit0
Many Thanks.
Wednesday,25,June,2014,22:55:00:26758
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WAUZZZ8K69A09XXXX   License Plate:
Mileage: 51810km-32193mi   Repair Order: Trailer re-code
Chassis Type: 8K (8T0)
Scan: 01 03 05 07 08 09 0E 0F 10 13 15 16 17 19 1E 36 37 42 46 47
          52 53 55 56 57 62 69 6C 72 77
VIN: WAUZZZ8K69A09XXXX   Mileage: 51810km/32193miles
Address 01: Engine (-----CDNC)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 A    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H12 0002
   Revision: E1H12---
   Coding: 0104000C180F0260
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM20TFS8K2907115A A01003
   ROD: EV_ECM20TFS8K2907115A.rod
   VCID: 2D5B729C7C79B876001-8078
4327 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 51818 km
                    Date: 2014.06.25
                    Time: 22:44:33
4330 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 51818 km
                    Date: 2014.06.25
                    Time: 22:44:33
Readiness: 1110 0101
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
   Part No SW: 8K0 907 379 AD    HW: 8K0 907 379 AD
   Component: ESP8 quattro  H04 0060
   Coding: 074D00
   VCID: 7BFF8CC4FA8DE6C6CE5-802E
                    Reset counter: 11
                    Mileage: 51818 km
                    Date: 2014.06.25
                    Time: 22:44:33
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x003C
                    Hex Value: 0x0395
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 AE    HW: 8K0 907 064 AE
   Component: BCM2 1.1      H71 0134
   Coding: 071100
   VCID: 73EFA4E4D2DDAE86965-8026
   Component: ELVAUDIB8  H36 0041
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 730     HW: 4E0 035 729 A
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 331GW087527386
   Coding: 0000002
   VCID: EED93590F9FF036EF9B-80BB
   Subsystem 1 - Part No: 8T0 919 609 C
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000122047
   Subsystem 3 - Serial number: 0125.07.080000000100010252ÿ
   Subsystem 4 - Serial number: 010252ÿ
   Part No SW: 8T2 820 043 T    HW: 8T2 820 043 T
   Component: KLIMA 3 ZONEN H06 0140
   Revision: D1000000    Serial number: 0112.07.080038
   Coding: 64040000
   VCID: 438F3424C2FD5E06C65-8016
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000197362
   Coding: 260050914034AF010001000300001D0D4F1D030800010141000000
   Shop #: WSC 00783 210 90835
   VCID: 30656BE8634BD59E2B7-8065
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 150708  H05 0070
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Coding: 024B2D
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Part No SW: 8T2 035 110 C    HW: 8T2 035 110 C
   Component: MP3-Changer     H44 0390
   Revision: 00044003    Serial number: AUZ5ZBH8521457
   VCID: 2B5F7C848A6DB6461E5-807E
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276W7300525
   Coding: 0000001
   VCID: 244D97B8E7B3793EDFF-8071
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 E    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0020
   Revision: 11001001    Serial number: 52830821004243
   Coding: 300003
   VCID: 3B7F4CC4BA0D26C68E5-806E
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561     HW: 8K0 907 561
   Component: ACC2          H07 0080
   Coding: 00C7D6
   VCID: EFE728943EF50A66F2D-80BA
                    Reset counter: 11
                    Temperature: 20.0°C
                    Voltage: 11.65 V
                    Bin. Bits:    01000
                    Hex Value: 0x044B
                    Hex Value: 0x0002
                    Lateral Accel.: 0.00 m/s^2
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 11
                    Mileage: 51818 km
                    Date: 2014.06.25
                    Time: 22:44:32
                    Temperature: 20.0°C
                    Voltage: 11.65 V
                    Bin. Bits:    01000
                    Hex Value: 0x044B
                    Hex Value: 0x0015
                    Reset counter: 11
                    Mileage: 51818 km
                    Date: 2014.06.25
                    Time: 22:44:32
                    Temperature: 20.0°C
                    Voltage: 11.65 V
                    Bin. Bits:    01000
                    Hex Value: 0x044B
                    Hex Value: 0x0013
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD182SKG
   Coding: 30363434363030303030554A3052384B3053
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 3C7D4FD8B70321FE87F-8069
   Serial number: 6334MSME3E12552BG
   Serial number: 6344MSME3F43723AL
   Serial number: 6352QSME7C522E43Q
   Serial number: 6362QSME7F3A3927Y
   Serial number: 63732SME2D024606W
   Crash sensor for front airbag; passenger side:
   Serial number: 63832SME45002800J
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H12 0013
   Revision: --------    Serial number: 90304HG3000BA
   Coding: 00001E
   VCID: 3E7945D0A91F33EEA9B-806B
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 980 E    HW: 8K0 920 980 E
   Component: KOMBIINSTR.   H12 0216
   Revision: 00400000    Serial number: 6Y912F1A7
   Coding: 2F0D09000F002600010400
   VCID: 346D67F89753E9BE4FF-8061
   Part No SW: 8T0 907 468 L    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0092
   Revision: FB402044    Serial number: 4400F087218051
   Coding: 000303
   VCID: 4A911900E5D78F4E053-801F
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
Address 1E: Media Player 2 (R199)       Labels: 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H15 0850
   Revision: 00000000
   VCID: 2B5F7C844A6DB6461E5-807E
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Part No SW: 8K0 959 760     HW: 8K0 959 760
   Component: MEM-FS        H05 0043
   Revision: AA000000    Serial number: 00001001111410
   Coding: 00781B00000000000000
   VCID: F7F710F446A542A62AD-80A2
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
   Component: MNS ECE         H51 1060
   Revision: 00000000    Serial number: 333G%087599178
   Shop #: WSC 00762 210 97024
   VCID: 3B7F4CC47A0D26C68E5-806E
Address 42: Door Elect, Driver (J386)       Labels: User\TEST-42.lbl
   Part No SW: 8K0 959 793 B    HW: 8K0 959 793
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007541200
   Coding: 011C12205E01410001
   VCID: 3F8738D4AE153AE6A2D-806A
   Revision: 00002001    Serial number: 0113463471
   Coding: 011B0E22003905C5003001
   Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS034  H06 0037
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
   Component: DSP Prem      H14 0400
   Revision: 00H14003    Serial number: 34814002277201
   Coding: 020101
   Shop #: WSC 12336 024 394758
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Date: 2064.00.00
                    Time: 00:00:10
                    Voltage: 11.30 V
                    Temperature: 251.0°C
                    Temperature: 253.0°C
                    Bin. Bits: 00000100
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
   Part No SW: 8K0 959 792 B    HW: 8K0 959 792
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007516848
Address 53: Parking Brake (J540)       Labels: 8K0-907-801.clb
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 10000000072910
   VCID: 31636EEC6841DC96249-8064
Address 55: Xenon Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 A    HW: 8H0 907 357
   Coding: 0000019
   Shop #: WSC 06324 000 00000
   VCID: 30656BE8A34BD59E2B7-8065
   Subsystem 1 - Part No: 8K0 941 329
   Component: AFS-Modul links H01 S001
   Subsystem 2 - Part No: 8K0 941 329
   Component: AFS-Modul rechtsH01 S001
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 336H+087584845
   Coding: 0000001
   VCID: 31636EECA841DC96249-8064
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 E    HW: 4E0 919 148
   Component: R78 TVHybridDVB     0470
   Revision: R0H06000    Serial number: 76300801710102
   Coding: 0000103
   VCID: 254B8ABCEC898036C81-8070
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795     HW: 8K0 959 795
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000007490460
   Coding: 010C12204001210001
   VCID: FF07F8D46E957AE662D-80AA
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00008200250331
   Coding: 0100000000000000
   VCID: 36695DF0812FFBAE71B-8063
Address 6C: Back-up Cam.        Labels: 4L0-910-441.lbl
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J87910O
   Coding: 1022006
   VCID: 377750F4462502A66AD-8062
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Part No SW: 8K0 959 794     HW: 8K0 959 795
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000007559497
   VCID: FEF905D0699F73EE69B-80AB
Address 77: Telephone        Labels: 4F1-910-336.lbl
   Part No SW: 4F1 910 336 D    HW: 4F1 862 335
   Component: BTA             H11 1120
   Revision: 00H11000    Serial number: 00000007586811
   Coding: 1010021
   Shop #: WSC 00783 210 84012
Address 01:8K2 907 115 A recoded (Long Coding) from 0104000C180F0260 to 0104000C180F0A60  (06325/000/00000)
Address 03:8K0 907 379 AD recoded (Long Coding) from 074D00 to 07CD00  (06325/000/00000)
Address 09:8K0 907 063 D recoded (Long Coding) from 260050914034AF010001000300001D0D4F1D030800010141000000 to 260050914034AF010001000300001D0D4F1D230800010141000000  (00783/210/90835)
Address 10:8K0 919 475 E recoded (Long Coding) from 300003 to 310003  (06325/000/00000)
Address 6C:8T0 907 441 B recoded (Short coding) from 1022006 to 1032006  (06325/000/00000)
Zenerdiode
Newcastle, England
C?ID=24330
Would it help if I posted some MVB and Adaptation maps for this module?
NEtech
Denmark
C?ID=56995
That is always good.
Try: 00C7CF
Zenerdiode
Newcastle, England
C?ID=24330
It was nearly midnight when I saw your reply, still I had to try it...
...and 00C7CF has worked perfectly!! Thank you very much indeed. I've now got to convince the neighbour I'm not weird (again). :p
Zenerdiode
Newcastle, England
C?ID=24330
Almost forgot my manners. Here's some data:
Auto-Scan following successful coding:
Saturday,09,August,2014,14:53:05:26758
VIN: WAUZZZ8K69AXXXXXX   License Plate:
Mileage: 52720km-32758mi   Repair Order: AfterTrailerInstall
VIN: WAUZZZ8K69AXXXXXX   Mileage: 52720km/32758miles
   Revision: E1H12---
   Coding: 0104000C180F0A60
   Coding: 07CD00
   Coding: 071100
   Coding: 0000002
   Coding: 64040000
   Coding: 260050914034AF010001000300001D0D4F1D230800010141000000
   Shop #: WSC 01130 210 66681
   Coding: 00FD11
   Coding: 024B2D
   Coding: 0000001
   Coding: 310003
   Coding: 00C7CF
   Coding: 00001E
   Coding: 000303
   Revision: 00000000
   Coding: 020101
            014 - Defective
                    Date: 2064.00.00
                    Time: 00:00:10
                    Voltage: 11.30 V
                    Bin. Bits: 00000100
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
   Coding: 0000019
   Coding: 0000001
   Coding: 0000103
   Coding: 1032006
   Coding: 1010021
Adaptation Map:
;SW:8K0-907-561   HW:8K0-907-561 ---  Auto Dist. Reg
;Component:ACC2          H07 0080, Coding:00C7CF
;Saturday,09,August,2014,14:59:59:26758
;VCDS Version: Release 12.12.2  Data version: 20140212
;VCID: EFE728943EF50A66F2D-80BA
Channel,,Field 1,Field 2,Field 3,Field 4,
01,1122,00000100 01100010,N/A,N/A,N/A,
02,65535,11111111 11111111,N/A,N/A,N/A,
03,1,Heater On,N/A,N/A,N/A,
04,1,ON,N/A,N/A,N/A,
05,,ERROR:,Security,access,required,
06,,ERROR:,Security,access,required,
07,0,OFF,N/A,N/A,N/A,
08,,ERROR:,Channel 08,Not,Available,
09,,ERROR:,Channel 09,Not,Available,
10,,ERROR:,Channel 10,Not,Available,
11,,ERROR:,Channel 11,Not,Available,
12,,ERROR:,Channel 12,Not,Available,
13,,ERROR:,Channel 13,Not,Available,
14,,ERROR:,Channel 14,Not,Available,
15,,ERROR:,Channel 15,Not,Available,
16,,ERROR:,Channel 16,Not,Available,
17,,ERROR:,Channel 17,Not,Available,
18,,ERROR:,Channel 18,Not,Available,
19,,ERROR:,Channel 19,Not,Available,
20,,ERROR:,Channel 20,Not,Available,
21,,ERROR:,Channel 21,Not,Available,
22,,ERROR:,Channel 22,Not,Available,
23,,ERROR:,Channel 23,Not,Available,
24,,ERROR:,Channel 24,Not,Available,
25,,ERROR:,Channel 25,Not,Available,
26,,ERROR:,Channel 26,Not,Available,
27,,ERROR:,Channel 27,Not,Available,
28,,ERROR:,Channel 28,Not,Available,
29,,ERROR:,Channel 29,Not,Available,
30,,ERROR:,Channel 30,Not,Available,
31,,ERROR:,Channel 31,Not,Available,
32,,ERROR:,Channel 32,Not,Available,
33,,ERROR:,Channel 33,Not,Available,
34,,ERROR:,Channel 34,Not,Available,
35,,ERROR:,Channel 35,Not,Available,
36,,ERROR:,Channel 36,Not,Available,
37,,ERROR:,Channel 37,Not,Available,
38,,ERROR:,Channel 38,Not,Available,
39,,ERROR:,Channel 39,Not,Available,
40,,ERROR:,Channel 40,Not,Available,
41,,ERROR:,Channel 41,Not,Available,
42,,ERROR:,Channel 42,Not,Available,
43,,ERROR:,Channel 43,Not,Available,
44,,ERROR:,Channel 44,Not,Available,
45,,ERROR:,Channel 45,Not,Available,
46,,ERROR:,Channel 46,Not,Available,
47,,ERROR:,Channel 47,Not,Available,
48,,ERROR:,Channel 48,Not,Available,
49,,ERROR:,Channel 49,Not,Available,
50,,ERROR:,Channel 50,Not,Available,
51,,ERROR:,Channel 51,Not,Available,
52,,ERROR:,Channel 52,Not,Available,
53,,ERROR:,Channel 53,Not,Available,
54,,ERROR:,Channel 54,Not,Available,
55,,ERROR:,Channel 55,Not,Available,
56,,ERROR:,Channel 56,Not,Available,
57,,ERROR:,Channel 57,Not,Available,
58,,ERROR:,Channel 58,Not,Available,
59,,ERROR:,Channel 59,Not,Available,
60,,ERROR:,Channel 60,Not,Available,
61,,ERROR:,Channel 61,Not,Available,
62,,ERROR:,Channel 62,Not,Available,
63,,ERROR:,Channel 63,Not,Available,
64,,ERROR:,Channel 64,Not,Available,
65,,ERROR:,Channel 65,Not,Available,
66,,ERROR:,Channel 66,Not,Available,
67,,ERROR:,Channel 67,Not,Available,
68,,ERROR:,Channel 68,Not,Available,
69,,ERROR:,Channel 69,Not,Available,
70,,ERROR:,Channel 70,Not,Available,
71,,ERROR:,Channel 71,Not,Available,
72,,ERROR:,Channel 72,Not,Available,
73,,ERROR:,Channel 73,Not,Available,
74,,ERROR:,Channel 74,Not,Available,
75,,ERROR:,Channel 75,Not,Available,
76,,ERROR:,Channel 76,Not,Available,
77,,ERROR:,Channel 77,Not,Available,
78,,ERROR:,Channel 78,Not,Available,
79,,ERROR:,Channel 79,Not,Available,
80,,ERROR:,Channel 80,Not,Available,
81,,ERROR:,Channel 81,Not,Available,
82,,ERROR:,Channel 82,Not,Available,
83,,ERROR:,Channel 83,Not,Available,
84,,ERROR:,Channel 84,Not,Available,
85,,ERROR:,Channel 85,Not,Available,
86,,ERROR:,Channel 86,Not,Available,
87,,ERROR:,Channel 87,Not,Available,
88,,ERROR:,Channel 88,Not,Available,
89,,ERROR:,Channel 89,Not,Available,
90,,ERROR:,Channel 90,Not,Available,
91,,ERROR:,Channel 91,Not,Available,
92,,ERROR:,Channel 92,Not,Available,
93,,ERROR:,Channel 93,Not,Available,
94,,ERROR:,Channel 94,Not,Available,
95,,ERROR:,Channel 95,Not,Available,
96,,ERROR:,Channel 96,Not,Available,
97,,ERROR:,Channel 97,Not,Available,
98,,ERROR:,Channel 98,Not,Available,
99,,ERROR:,Security,access,required,
100,,ERROR:,Channel 100,Not,Available,
101,,ERROR:,Channel 101,Not,Available,
102,,ERROR:,Channel 102,Not,Available,
103,,ERROR:,Channel 103,Not,Available,
104,,ERROR:,Channel 104,Not,Available,
105,,ERROR:,Channel 105,Not,Available,
106,,ERROR:,Channel 106,Not,Available,
107,,ERROR:,Channel 107,Not,Available,
108,,ERROR:,Channel 108,Not,Available,
109,,ERROR:,Channel 109,Not,Available,
110,,ERROR:,Channel 110,Not,Available,
111,,ERROR:,Channel 111,Not,Available,
112,,ERROR:,Channel 112,Not,Available,
113,,ERROR:,Channel 113,Not,Available,
114,,ERROR:,Channel 114,Not,Available,
115,,ERROR:,Channel 115,Not,Available,
116,,ERROR:,Channel 116,Not,Available,
117,,ERROR:,Channel 117,Not,Available,
118,,ERROR:,Channel 118,Not,Available,
119,,ERROR:,Channel 119,Not,Available,
120,,ERROR:,Channel 120,Not,Available,
121,,ERROR:,Channel 121,Not,Available,
122,,ERROR:,Channel 122,Not,Available,
123,,ERROR:,Channel 123,Not,Available,
124,,ERROR:,Channel 124,Not,Available,
125,,ERROR:,Channel 125,Not,Available,
126,,ERROR:,Channel 126,Not,Available,
127,,ERROR:,Channel 127,Not,Available,
128,,ERROR:,Channel 128,Not,Available,
129,,ERROR:,Channel 129,Not,Available,
130,,ERROR:,Channel 130,Not,Available,
131,,ERROR:,Channel 131,Not,Available,
132,,ERROR:,Channel 132,Not,Available,
133,,ERROR:,Channel 133,Not,Available,
134,,ERROR:,Channel 134,Not,Available,
135,,ERROR:,Channel 135,Not,Available,
136,,ERROR:,Channel 136,Not,Available,
137,,ERROR:,Channel 137,Not,Available,
138,,ERROR:,Channel 138,Not,Available,
139,,ERROR:,Channel 139,Not,Available,
140,,ERROR:,Channel 140,Not,Available,
141,,ERROR:,Channel 141,Not,Available,
142,,ERROR:,Channel 142,Not,Available,
143,,ERROR:,Channel 143,Not,Available,
144,,ERROR:,Channel 144,Not,Available,
145,,ERROR:,Channel 145,Not,Available,
146,,ERROR:,Channel 146,Not,Available,
147,,ERROR:,Channel 147,Not,Available,
148,,ERROR:,Channel 148,Not,Available,
149,,ERROR:,Channel 149,Not,Available,
150,,ERROR:,Channel 150,Not,Available,
151,,ERROR:,Channel 151,Not,Available,
152,,ERROR:,Channel 152,Not,Available,
153,,ERROR:,Channel 153,Not,Available,
154,,ERROR:,Channel 154,Not,Available,
155,,ERROR:,Channel 155,Not,Available,
156,,ERROR:,Channel 156,Not,Available,
157,,ERROR:,Channel 157,Not,Available,
158,,ERROR:,Channel 158,Not,Available,
159,,ERROR:,Channel 159,Not,Available,
160,,ERROR:,Channel 160,Not,Available,
161,,ERROR:,Channel 161,Not,Available,
162,,ERROR:,Channel 162,Not,Available,
163,,ERROR:,Channel 163,Not,Available,
164,,ERROR:,Channel 164,Not,Available,
165,,ERROR:,Channel 165,Not,Available,
166,,ERROR:,Channel 166,Not,Available,
167,,ERROR:,Channel 167,Not,Available,
168,,ERROR:,Channel 168,Not,Available,
169,,ERROR:,Channel 169,Not,Available,
170,,ERROR:,Channel 170,Not,Available,
171,,ERROR:,Channel 171,Not,Available,
172,,ERROR:,Channel 172,Not,Available,
173,,ERROR:,Channel 173,Not,Available,
174,,ERROR:,Channel 174,Not,Available,
175,,ERROR:,Channel 175,Not,Available,
176,,ERROR:,Channel 176,Not,Available,
177,,ERROR:,Channel 177,Not,Available,
178,,ERROR:,Channel 178,Not,Available,
179,,ERROR:,Channel 179,Not,Available,
180,,ERROR:,Channel 180,Not,Available,
181,,ERROR:,Channel 181,Not,Available,
182,,ERROR:,Channel 182,Not,Available,
183,,ERROR:,Channel 183,Not,Available,
184,,ERROR:,Channel 184,Not,Available,
185,,ERROR:,Channel 185,Not,Available,
186,,ERROR:,Channel 186,Not,Available,
187,,ERROR:,Channel 187,Not,Available,
188,,ERROR:,Channel 188,Not,Available,
189,,ERROR:,Channel 189,Not,Available,
190,,ERROR:,Channel 190,Not,Available,
191,,ERROR:,Channel 191,Not,Available,
192,,ERROR:,Channel 192,Not,Available,
193,,ERROR:,Channel 193,Not,Available,
194,,ERROR:,Channel 194,Not,Available,
195,,ERROR:,Channel 195,Not,Available,
196,,ERROR:,Channel 196,Not,Available,
197,,ERROR:,Channel 197,Not,Available,
198,,ERROR:,Channel 198,Not,Available,
199,,ERROR:,Channel 199,Not,Available,
200,,ERROR:,Channel 200,Not,Available,
201,,ERROR:,Channel 201,Not,Available,
202,,ERROR:,Channel 202,Not,Available,
203,,ERROR:,Channel 203,Not,Available,
204,,ERROR:,Channel 204,Not,Available,
205,,ERROR:,Channel 205,Not,Available,
206,,ERROR:,Channel 206,Not,Available,
207,,ERROR:,Channel 207,Not,Available,
208,,ERROR:,Channel 208,Not,Available,
209,,ERROR:,Channel 209,Not,Available,
210,,ERROR:,Channel 210,Not,Available,
211,,ERROR:,Channel 211,Not,Available,
212,,ERROR:,Channel 212,Not,Available,
213,,ERROR:,Channel 213,Not,Available,
214,,ERROR:,Channel 214,Not,Available,
215,,ERROR:,Channel 215,Not,Available,
216,,ERROR:,Channel 216,Not,Available,
217,,ERROR:,Channel 217,Not,Available,
218,,ERROR:,Channel 218,Not,Available,
219,,ERROR:,Channel 219,Not,Available,
220,,ERROR:,Channel 220,Not,Available,
221,,ERROR:,Channel 221,Not,Available,
222,,ERROR:,Channel 222,Not,Available,
223,,ERROR:,Channel 223,Not,Available,
224,,ERROR:,Channel 224,Not,Available,
225,,ERROR:,Channel 225,Not,Available,
226,,ERROR:,Channel 226,Not,Available,
227,,ERROR:,Channel 227,Not,Available,
228,,ERROR:,Channel 228,Not,Available,
229,,ERROR:,Channel 229,Not,Available,
230,,ERROR:,Channel 230,Not,Available,
231,,ERROR:,Channel 231,Not,Available,
232,,ERROR:,Channel 232,Not,Available,
233,,ERROR:,Channel 233,Not,Available,
234,,ERROR:,Channel 234,Not,Available,
235,,ERROR:,Channel 235,Not,Available,
236,,ERROR:,Channel 236,Not,Available,
237,,ERROR:,Channel 237,Not,Available,
238,,ERROR:,Channel 238,Not,Available,
239,,ERROR:,Channel 239,Not,Available,
240,,ERROR:,Channel 240,Not,Available,
241,,ERROR:,Channel 241,Not,Available,
242,,ERROR:,Channel 242,Not,Available,
243,,ERROR:,Channel 243,Not,Available,
244,,ERROR:,Channel 244,Not,Available,
245,,ERROR:,Channel 245,Not,Available,
246,,ERROR:,Channel 246,Not,Available,
247,,ERROR:,Channel 247,Not,Available,
248,,ERROR:,Channel 248,Not,Available,
249,,ERROR:,Channel 249,Not,Available,
250,,ERROR:,Channel 250,Not,Available,
251,,ERROR:,Channel 251,Not,Available,
252,,ERROR:,Channel 252,Not,Available,
253,,ERROR:,Channel 253,Not,Available,
254,,ERROR:,Channel 254,Not,Available,
255,,ERROR:,Channel 255,Not,Available,
...and finally a Measuring Block map:
;Saturday,09,August,2014,14:55:42:26758
Group,Field 1,Data type,Field 2,Data type,Field 3,Data type,Field 4,Data type,
1,65535,Error Code,65535,Error Code,65535,Error Code,N/A,,
2,-0.104°,Angle,0.288°,Angle,-0.366°,Angle,N/A,,
3,323.85 m,Distance,0.0 km/h,Speed,0.00 m,Distance,0.00 %, ,
4,323.85 m,Distance,0.0 km/h,Speed,0.00 m,Distance,0.00 %, ,
5,-0.00 m,Distance,-0.0 km/h,Speed,-0.00 m,Distance,0.00 m/s^2,Lateral Accel.,
6,323.85 m,Distance,-0.0 km/h,Speed,-0.00 m,Distance,0.00 m/s^2,Lateral Accel.,
7,13.60 V,Voltage,OFF, ,0.00 %, ,53.0°C,Temperature,
9,2,Error Code,4,Error Code,0,Error Code,N/A,,
10,00000000 00100010,Bin. Bits,00000000 01000001,Bin. Bits,00000000 00001110,Bin. Bits,00000000,Bin. Bits,
11,0.861°,Angle,-0.00,(no units),00000100 01100010,Bin. Bits,10010111 11111111,Bin. Bits,
12,10000001,Bin. Bits,00000000,Bin. Bits,N/A,,N/A,,
13,0,Error Code,10456,Error Code,8610,Error Code,203,Error Code,
14,65535,Error Code,65535,Error Code,65535,Error Code,65535,Error Code,
15,1092 h,ON Time,113 h,ON Time,4 h,ON Time,3285,Error Code,
125,Engine 1, ,ABS 1, , , ,Instruments 1, ,
126,Steer. ang. 1, ,St. Wheel 1, , , ,Gateway 1, ,
127,Act. Steer 1, ,N/A,,N/A,,N/A,,
225,0.0,(no units),0.0,(no units), , ,0.0,(no units),
226,2.0,(no units),0.0,(no units), , ,0.0,(no units),
227,255.0,(no units),N/A,,N/A,,N/A,,
Thank You Niels,
Christopher
