Trying to adapt steering end stops in 44 module, but security access balloon doesn't give the code... so need help with this code. 40168 doesn't match. Thanks.
Tuesday,11,October,2016,12:13:33:03864
VCDS Version: 16.8.2.3 (x64)
Data version: 20160926 DS261.0
VIN: WAUZZZ4G0EN143580 License Plate: AUDI A6ALL
Mileage: 40532km-25185mi Repair Order:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 20 28 34 36 3B 42 44 46
52 53 55 56 5F 62 6C 6D 72 88 89 AC
VIN: WAUZZZ4G0EN143580 Mileage: 40532km-25185miles
17-Instruments -- Status: Cannot be reached 0100
56-Radio -- Status: Cannot be reached 0100
88-Multicont. Seat Driver -- Status: Malfunction 0010
89-Multicont. Seat Pass. -- Status: Malfunction 0010
Address 01: Engine (J623-CKVC) Labels: 059-907-401-V2.clb
Part No SW: 4G0 907 401 R HW: 4G0 907 401 E
Component: 3.0TDI EDC17 H14 0001
Revision: 58H14---
Coding: 32254012042609030000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TDI0114G0907401R 001001
ROD: EV_ECM30TDI0114G0907401R.rod
VCID: 3261657A652079D272-8066
U1113 00 [039] - -
Mileage: 40532 km
Date: 2016.10.04
Time: 00:19:19
Engine speed: 0.00 /min
Coolant temperature: 11 °C
Intake air temperature: 11 °C
Voltage terminal 30: 11.500 V
Cruise Control System (CCS): switch position-Bit 0: 129
Cruise Control System (CCS): status-Bit 0: 44
Cruise control switch-off: irreversible-Bit 0: 255
Cruise control switch-off: reversible-Bit 0: 255
Cruise Control System: specified speed: 0.00 km/h
Engine control module reset status-Bit 0: 0
Engine control module reset status-Bit 8: 0
Cruise control switch-off: irreversible w. brake intervention-Bit 0: 0
U1113 00 [039] - -
Mileage: 40532 km
Date: 2016.10.04
Time: 00:19:19
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 4G9 927 156 F HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H02 0003
Revision: --H02---
ASAM Dataset: EV_TCMDL501021 001015
ROD: EV_TCMDL501021_001_AU48.rod
VCID: 38755752835C93824C-806C
Address 03: ABS Brakes (J104) Labels: 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
Component: ESP PREMIUM H09 0450
Coding: 27A6DF05E465FBA0DB00
ASAM Dataset: EV_ESPPremiAU57X 004039
VCID: 3A714D5ABD508192BA-806E
0697 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 80
Mileage: 40532 km
Date: 2016.09.30
Time: 06:36:09
VzRef: 00
Bit Info 1: 80
Bit Info 2: 42
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 02
F-Type: 0B
Uz: B7
0788 - Control Module Incorrectly Coded
U1014 00 [137] - -
Reset counter: 80
Mileage: 40532 km
Date: 2016.09.30
Time: 06:37:58
VzRef: 00
Bit Info 1: 00
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 01
F-Type: AE
Uz: 9E
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 EP HW: 4H0 907 064 EP
Component: BCM2 2.0 H36 0521
Coding: 05A92F06000000000000
VCID: 7BFF885EFAEA789AE1-802E
Part No SW: 4G8 959 760 C HW: 4G8 959 760 C
Component: MEM-BFS H04 0157
Revision: AA000000 Serial number: 00000092965374
Coding: C018320085006201000001010101112030303333283333
VCID: 3A714D5AB5508192BA-806E
Address 08: Auto HVAC (J255) Labels: 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 AN HW: 4G0 820 043 AN
Component: KLIMA 4 ZONEN H14 0093
Serial number: 27031400040078
Coding: 3602007E21
ASAM Dataset: EV_AirCondiComfoUDS 004003
ROD: EV_AirCondiComfoUDS_004.rod
VCID: 6BDFB81E828AE81A71-803E
0267 - Sensor for Refrigerant Pressure and Temperature
B10C2 21 [009] - Signal Amplitude Too Low
Reset counter: 80
Mileage: 40532 km
Date: 2016.09.30
Time: 06:32:27
Compressor current: actual value: 0 mA
Outside air temperature: 8.5 °C
Temperature after evaporator: 11.84 °C
Engine speed: 0 /min
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0130
Revision: 20012002 Serial number: 00000001859600
Coding: 2600201040749FE00981008080001D0CCF9C47082E090201000008606101
VCID: 6ED9B10AB9981D3256-803A
Component: WWS57X 140313 H37 0080
Serial number: 140317114447
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 22425555
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 S HW: 4G0 941 531 S
Component: E1 - LDS H07 0044
Serial number: 26 03 2014 00000172
Serial number: EFE84E17000000000001
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0083
Revision: 11001001 Serial number: 61061409100831
Coding: A8C30C
ASAM Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000.rod
VCID: 71E3AA76A0A602CA4B-8024
1113107 - Front Parking Aid Sensor(s)
B10FC 13 [008] - Open Circuit
Reset counter: 80
Mileage: 40532 km
Date: 2016.09.30
Time: 06:42:24
13679386 - Databus
Reset counter: 80
Mileage: 40532 km
Date: 2016.09.30
Time: 06:30:11
13679387 - Databus
Reset counter: 80
Mileage: 40532 km
Date: 2016.09.30
Time: 06:30:11
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00HATCK
Coding: 30323436313330303333554A304C34473053
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3669596A894865F25E-8062
Serial number: 3575HRB404V2EBL08143
Serial number: 3585HRB404V2EBL09HP%
Serial number: 3515JRB400G50UJ8Q1S-
Serial number: 3525JRB401C50UUEAA7N
Serial number: 3554VRB400650UJCN9S7
Serial number: 3564VRB400Q50UUORP44
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20140327000483
Coding: 000035
VCID: 30656F72632C4BC204-8064
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G9 920 950 L HW: 4G9 920 950 L
Component: TDieRdw Nv H58 0622
Revision: 29131237 Serial number: 658210314596013
Coding: 13A622081B410008040600
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 39735256B8568A8AB3-806C
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Component: J533--Gateway H13 0050
Revision: -------- Serial number: 00000001321548
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001019
VCID: 72E1A57AA5A039D2B2-8026
Serial number: 2667922803
Voltage stabilizer:
0267 - Optical data bus
U1049 00 [009] - Open circuit
Reset counter: 80
Mileage: 40532 km
Date: 2016.09.30
Time: 06:38:08
Voltage terminal 30: 12.0 V
Voltage terminal 15: 12.0 V
Control Module temperature: 22 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02018264747464545425363E00
VCID: 7CFD8B42FFE47FA2E8-8028
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 M HW: 4G0 919 158 M
Component: KLIMA FOND H08 0093
Serial number: 28031400040274
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Coding: 008000
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E59710A71185D3216-807A
0648 - Function Restriction due to Implausible Message(s)
U1112 00 [009] - -
Reset counter: 80
Mileage: 40532 km
Date: 2016.09.30
Time: 06:29:52
Component: MEM-FS H04 0157
Revision: AA000000 Serial number: 00000092965521
Coding: C0183B0085016201000001010101112030303333203333
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H03 0056
Revision: -------- Serial number: EJ1BPA8206NXJ%
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_005_AU57.rod
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F16005E00620202080002
VCID: 479724AEF6A2EC7A35-8012
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H40 0010
Revision: 00001000 Serial number: 0020405757
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009_AU57.rod
6628353 - Internal Control Module Memory Check Sum Error
B2000 49 [137] - Internal electronic failure
Mileage: 40529 km
Date: 2016.08.17
Time: 13:36:46
valid
5258753 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
Fault Frequency: 47
Reset counter: 80
Mileage: 40532 km
Date: 2016.09.30
Time: 06:41:31
valid
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0330929267
Coding: 01000E2820B930818320090400010F470000000000000000000000000000
03544 - Left Brake Light Lamp 2
Fault Status: 11101100
Reset counter: 80
Mileage: 40532 km
Date: 2016.09.30
Time: 06:33:53
Reset counter: 80
Mileage: 40532 km
Date: 2016.09.30
Time: 06:42:24
Address 52: Door Elect, Pass. (J387) Labels: None
Component: TSG BF H03 0507
VCID: 468929AAF1A8F572CE-8012
Component: EPB-4 H03 0015
Revision: -------- Serial number: 00000001013200
ROD: EV_ParkiBrake_AU57.rod
VCID: 2D5B76067C1E262A2F-8078
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 140329-0002-027
Coding: 11226F101002A300
ROD: EV_HeadlRegulBasic.rod
Address 56: Radio
Address 62: Door, Rear Left (J388) Labels: None
Component: TSG HL H03 0507
Coding: 010F14004000620202080002
VCID: 49932296E0B61A0A23-801C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H08--- Serial number: 525 PA8J42GCWC
Coding: 1080005
VCID: 2649892A91E81572EE-8072
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
Component: HDSG-Modul H03 0143
Revision: 14003001 Serial number: 079400343
Coding: 097205C010
ROD: EV_HDSGAu571.rod
VCID: 356B5E66944E6EEA57-8060
0114 - Load Space Cover
B12EF 54 [137] - Missing Calibration / Basic Setting
Reset counter: 80
Mileage: 40532 km
Date: 2016.09.30
Time: 06:30:24
11.76 V
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0507
Address 88: Multicont. Seat Driver (J873) Labels: None
Part No SW: 4G8 881 073 HW: 4G8 881 073
Component: P2G H02 0032
Serial number: 0E2K2L2
Coding: 6620F0
ASAM Dataset: EV_P2GDriveSideFrnt 001006
ROD: EV_P2GDriveSideFrnt.rod
VCID: 6ED9B10AB1981D3256-803A
Valve Block 1 In Driver Side Front Seat:
0004 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 120
Mileage: 1048574 km
0121 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 120
Mileage: 40532 km
Date: 2016.09.29
Time: 17:47:23
Address 89: Multicont. Seat Pass. (J872) Labels: None
Serial number: 0E2K2XN
Coding: 2620F0
ASAM Dataset: EV_P2GPasseSideFrnt 001006
ROD: EV_P2GPasseSideFrnt.rod
Valve Block 1 In Passenger Side Front Seat:
U1400 00 [008] - -
Reset counter: 120
Mileage: 1048574 km
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H09 0010
Revision: 00000000 Serial number: 140560285
ROD: EV_RDCMA00100.rod
VCID: 2B5F781E420A281A31-807E
End-------------------------(Elapsed Time: 05:18)--------------------------
