Hi. How are you? I need help module 55 headlights and Security code to module 36 driver seat. Thank you
16,September,2016,09:36:51:08180
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: WAUR2AFDXDN011093 License Plate: AUDI A8L 09.16.16
Mileage: 75677km-47023mi Repair Order:
Chassis Type: FD (4H0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 28 34 36 3B 3C 42 46
47 48 52 53 55 56 5B 5F 62 6C 6D 6F 72 7F 81 85 88 8A 8B 8D
8E 8F 90 BA
VIN: WAUR2AFDXDN011093 Mileage: 75677km-47023miles
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
7F-Inform. Electr. II -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CEUA) Labels: None
Part No SW: 4H0 906 014 L HW: 4H0 906 014
Component: 4.0l V8TFSI / H61 0004
Revision: NCH61---
Coding: 022A00326546010E1000
Shop #: WSC 64135 001 1048576
ASAM Dataset: EV_ECM40TFS0114H0906014L 001004
ROD: EV_ECM40TFS0114H0906014L.rod
VCID: 2C57661C4714C3222C-8078
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4H1 927 158 EE HW: 0BK 927 156 AG
Component: 0BK 40TFSIUSA H16 1002
Revision: --H16---
Shop #: WSC 53740 001 1048576
ROD: EV_TCMALX51011.rod
VCID: 77FD8970CED2B0FA91-8022
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 E HW: 4H0 907 379 E
Component: ESP PREMIUM H10 0352
Coding: C4E5F30023A7CF00E200
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_AU64.rod
VCID: 34677E7C9F249BE274-8060
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 DD HW: 4H0 907 064 CD
Component: BCM2 2.0 H32 0510
Coding: 0DA72046000000000000
Shop #: WSC 51079 000 1048576
VCID: 6ED3AC14B988F13242-803A
Serial number: 2312000058077004
Part No SW: 4H0 959 760 H HW: 4H0 959 760 H
Component: MEM-BFS H09 0163
Revision: AA000000 Serial number: 00000029372944
Coding: C018B60084006201040001010101112909313229283232
Shop #: WSC 02313 785 00200
VCID: 387F4A4C8B4C7F8258-806C
Address 08: Auto HVAC (J255) Labels: 4H0-820-043.clb
Part No SW: 4H0 820 043 H HW: 4H0 820 043 H
Component: Klima 4 Zonen H20 0121
Coding: 688122FE7C
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_AU64.rod
VCID: 2541933824FEF26AF3-8070
0137 - Motor for Right Side Window Defrost Flap
B10D8 22 [008] - Signal Amplitude Too High
Fault Frequency: 52
Reset counter: 54
Mileage: 75166 km
Date: 2016.09.09
Time: 16:59:24
Voltage terminal 30-Data: 13.5 V
Outside air temperature-Data: 41.00 °C
Interior temperature-Data: 32.70 °C
Defrost flap motor for right side window-Act.value: 13945
Defrost flap motor for right side window-Specified value: 13945
Defrost flap motor for right side window-Stop open: 0
Defrost flap motor for right side window-Stop closed: 0
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial number: 00000001565323
Coding: 02002011163C9FE3CB018004A0003908009CD20886000121800008406000
VCID: 6CD7A61C8F9403226C-8038
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 120614 H35 0080
Serial number: 120725101630
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 20065943
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 D HW: 4H0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 24 04 2012 00000275
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103988000001758590
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 8A984346000000000001
02258 - Door Opener Transmitter
Reset counter: 252
Mileage: 75166 km
Date: 2016.09.09
Time: 16:59:00
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0072
Revision: 11001001 Serial number: 61061224001318
Coding: A80B02
ASAM Dataset: EV_EPHVA18AU57X0000 003008
ROD: EV_EPHVA18AU57X0000.rod
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4H0 907 561 B HW: 4H0 907 561
Component: ACC3 H19 0400
Coding: 7E01010201
ASAM Dataset: EV_AdaptCruisContrAU64X 002021
ROD: EV_AdaptCruisContrAU64X.rod
VCID: 2A5B60044DE0DD12DE-807E
150016 - invalid data record
B2005 00 [009] - -
Reset counter: 254
Mileage: 75259 km
Date: 2016.09.10
Time: 12:36:34
Control Module temperature: 68 °C
Voltage terminal 15: 14.110 V
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 D HW: 4H0 959 655 D
Component: Airbag10.43 H44 0041
Revision: -------- Serial number: 003JS001C61R
Coding: 303143303230303030354A55304C34483053
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 377D49708E5270FA51-8062
Subsystem 1 - Part No SW: 4H0 959 339 A HW: 4H0 959 339 A
Component: BF-Gewichtss. H03 0040
Serial number: 5850000R1272705BKE
Serial number: 3575HRB40511G7FGBPPT
Serial number: 3585HRB405P1HAR438U
Serial number: 3515JRB404V1D2AS5HDR
Serial number: 3525JRB40551D2ASCOSW
Serial number: 3554VRB400O52JMQM904
Serial number: 3564VRB405J1EVLGMGF-
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372MCE001C7
Coding: 0004FC
Subsystem 1 - Part No SW: 4H0 951 528 L HW: 4H0 951 528 L
Component: E221 - MFL H09 0009
Serial number: 22 10 2011 33152270
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4H0 920 980 K HW: 4H0 920 980 K
Component: TBenUSAACC--- H71 0515
Revision: 35081077 Serial number: 658280712592008
Coding: 034F08015F40D705020000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
VCID: 33657D609A2A9CDA6D-8066
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 G HW: 4H0 919 204 G
Component: Analoguhr D4 H05 0224
Serial number: 1120626002039
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4H0 907 468 AC HW: 4H0 907 468 AA
Component: J533--Gateway H11 0035
Revision: -------- Serial number: 00000000652449
Coding: 00ED074800
ASAM Dataset: EV_GatewPkoUDS 001016
ROD: EV_GatewPKOUDS_AU57.rod
VCID: 72EBB864A5B0D5D2A6-8026
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 00000000004970769257
Address 28: HVAC, Rear (E265) Labels: None
Part No SW: 4H0 919 158 E HW: 4H0 919 158 E
Component: Klima Fond H16 0121
Coding: 2600000000
ASAM Dataset: EV_AirCondiHeck 001039
ROD: EV_AirCondiHeck_AU64.rod
VCID: 326B7864653095D266-8066
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4H0 907 553 E HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0099
Coding: 008002
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_AU64.rod
VCID: 2E536C147108B13202-807A
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000033701171
Coding: C018BF8085857201070001010101112131313333203333
VCID: 356143789C5E82EA43-8060
03331 - Motor for Backrest Angle Adjustment
Fault Status: 01100101
Reset counter: 252
Mileage: 75166 km
Date: 2016.09.09
Time: 16:59:23
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 K HW: 4H0 907 637 F
Component: SARA 6D H02 0053
Revision: -------- Serial number: EJ1BPA77006A2Q
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2_AU57.rod
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4H0 907 566 A HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial number: 6PZ 010 287-07
Coding: 0000002
VCID: 2E536C14B908B13202-807A
Subsystem 1 - Part No: 4H0 907 568 A
Component: J770 SWA Slave H02 0040
Subsystem 2 - Serial number: 6PZ 010 287-27
Subsystem 3 - Serial number: 5F03.08.1200H02000AMS14287ÿ
Subsystem 4 - Serial number: S14287ÿ
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H06 0263
Revision: -------- Serial number: 0000129740023
Coding: 011F1F005E0062C202003017
Shop #: WSC 02312 785 00200
VCID: 489F3A8CFBAC0F0228-801C
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0181662308
Coding: 0106023A00FA759FB030C7840203010F0000000000000000000000000000
Shop #: WSC 02311 785 00200
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000096656
Subsystem 3 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J245 007C H06 0005
Serial number: 226600089108
Coding: 020200
Subsystem 4 - Part No SW: 4H0 947 135 BR HW: 4H0 947 135 BR
Component: Dachelektroni H11 0080
Serial number: A2012000000000612632
Coding: 070000
Subsystem 5 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J394 0014 H06 0005
Serial number: 226200088632
Coding: 020200
Subsystem 6 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J392 006A H06 0005
Serial number: 226600089098
Coding: 020200
Subsystem 7 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J867 00E0 H06 0005
Serial number: 226100088493
Coding: 020200
Subsystem 8 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84294237
Part No SW: 4G1 035 223 A HW: 4G1 035 223 A
Component: BOSE-G3C7-ANC H02 0540
Revision: CJ002700 Serial number: 00000000003839
Coding: 030000
VCID: 1C37B6DC1FB433A25C-8048
Address 48: Seat, Rear, DS (J876) Labels: None
Part No SW: 4H0 959 860 A HW: 4H0 959 860 A
Component: MEM-FS-Fond H06 0155
Revision: AA000000 Serial number: 00000031924660
Coding: C01892808500700D0B00392038193A2039203B3B202020
VCID: 326B78646D3095D266-8066
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0261
Revision: -------- Serial number: 0000130203523
Coding: 011F1F005E0062C202003007
VCID: 3C77565CBF7453A2BC-8068
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000453969
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B556500421AC41A25-807E
Address 55: Headlight Range (J431) Labels: 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 C HW: 4H4 907 357 A
Component: ....AFS13.... H01 0020
Serial number: 120824-0004-021
Coding: 11116F331002F900
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
H02 0009
Coding: 1A0000
H02 0010
Coding: 1A0000
796164 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
Reset counter: 253
Mileage: 75166 km
Date: 2016.09.09
Time: 17:02:37
Part No SW: 4H0 035 082 D HW: 4H0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 155H.0C7523553
Coding: 020007010003000001
VCID: 224B88243DD0055296-8076
Address 5B: Seat,Rear,PS (J877) Labels: None
Component: MEM-BFS-Fond H06 0155
Revision: AA000000 Serial number: 00000031924678
Coding: C01896808500700D0F00392038193A2039203B3B3B2020
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4H0 035 746 C HW: 4H0 035 746 C
Component: H-BNT-NA H49 0549
Revision: -------- Serial number: 183H%0C7502659
Coding: 020200000001F9EF7D728B1E00000003140001000000000000
VCID: 285F9A0C5BECEF02C8-807C
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 4H0 919 604 F HW: 4H0 919 604 F
Component: DU8 D4 SV NB H47 0021
Serial number: AUZ8ZDC9300UTQP
Subsystem 3 - Part No SW: 4H1 919 600 H HW: 4H1 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000089683
Subsystem 4 - Part No: 8R0 060 961 D
Component: CD-Database 4353
Fault Frequency: 18
Reset counter: 14
Mileage: 75677 km
Date: 2016.09.16
Time: 09:14:02
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00000010
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0262
Revision: -------- Serial number: 0000130225535
Coding: 010F1F00420062C202003007
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4H0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J26D0F1
Coding: 1080003
VCID: 2643943491F8F972FA-8072
Address 6D: Trunk Elect. (----) Labels: None
Part No SW: 4H0 959 107 R HW: 4H0 959 107 M
Component: HDSG-Modul H11 0039
Revision: 10011001 Serial number: 206200612
Coding: 0210044100
ASAM Dataset: EV_DeckLidContrUnit 001025
ROD: EV_DeckLidContrUnit.rod
VCID: 3D715B58AC6E5AAA8B-8068
Address 6F: Centr. Conv. II (J773) Labels: None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000082761
Coding: 600000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 63C5CD206A4A4C5ADD-8036
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H06 0262
Revision: -------- Serial number: 0000130225534
Address 7F: Inform. Electr. II (J829) Labels: None
Part No SW: 4H0 035 774 D HW: 4H0 035 774 D
Component: H-BN-NA H49 0550
Revision: -------- Serial number: 188GV0C7500133
Coding: 02020000000100400140000400001300000000000000000000
VCID: 2A5B600445E0DD12DE-807E
Subsystem 1 - Part No SW: 4H0 919 607 HW: 4H0 919 607
Component: DU10 RSE H41 0021
Serial number: AUZ8ZDC1200TSA+
Subsystem 2 - Part No SW: 4H4 919 607 HW: 4H4 919 607
Serial number: AUZ8ZDC27007QMZ
Subsystem 3 - Part No SW: 4H0 919 709 C HW: 4H0 919 709 C
Component: E499 BDT 2 H07 0019
Serial number: 90238LGA00010
Subsystem 5 - Part No: 8R0 060 884 AM
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H08 0083
Revision: 0L0D5014 Serial number: SN120702 0630
ROD: EV_GSM2x3Mono.rod
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H25 0038
Coding: E9060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2643943459F8F972FA-8072
Address 88: Multicont. Seat Driver (J873) Labels: None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00007183028302
Coding: 766FF2
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F6D71107602B83A09-807A
Address 8A: Multicont. Seat Rear,DS (J875) Labels: None
Part No SW: 4H0 907 182 G HW: 4H0 907 182 G
Component: IVB H08 0042
Serial number: 00006527131402
Coding: 306F00
ASAM Dataset: EV_IVBDriveSideRear 001003
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4H0 907 541 B HW: 4H0 907 541
Coding: 7E01010201
ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
ROD: EV_AdaptCruisContr2AU57X.rod
VCID: 285F9A0C53ECEF02C8-807C
Address 8D: Multicont. Seat Rear,PS (J874) Labels: None
Serial number: 00007189049302
Coding: 306F00
ASAM Dataset: EV_IVBPasseSideRear 001003
Address 8E: Image Processing (J851) Labels: 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000052208127
Coding: 02A19A000111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 275D99305EF2E07AC1-8072
Component: RGS-VL H13 0080
Coding: 0066F609031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 316977686036AECA1F-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H05 0006
Revision: 00001001 Serial number: 97804000684104
ASAM Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X.rod
VCID: 66C3D434997839723A-8032
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [009] - Mechanical Failure
Reset counter: 253
Mileage: 75166 km
Date: 2016.09.09
Time: 16:59:27
End-------------------------(Elapsed Time: 08:04)--------------------------
