vw caddy fault
LUKEGAUGHAN
C?ID=256620
anybody got any ides on this fault code my van is going into limp mode because of it and losing all power switching the key on and off write fast all the power comes back but after about 10mins it go's again :mad: :mad: :mad: :mad:
 37-Navigation -- Status: Not registered 0011
 Address 01: Engine (J623-CAYE) Labels: 03L-906-023-CAY.clb
 Part No SW: 03L 906 023 PB HW: 03L 907 425 C
 Component: 1,6l R4 CR td H43 0868
 Revision: --H43--- Serial number: 00000000000000
 Coding: 00114030032501080000
 Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023PB 003003
 ROD: N/A
 VCID: 75E6479AD4279BEA97-8020
 No ASAM data for: "EV_ECM16TDI02103L906023PB" (VW36 *)
 7462 - ROD - Unknown Error Code
 - 00 [172]
 Mileage: 111952 km
 Date: 2016.10.09
 Time: 19:51:38
golfi_vend
Tartu, Estonia
C?ID=195131
Hello
Welcome to the forum. No need for 2 separate threads.
Please read following thread and post full auto-scan as auto-scan is requirement when seeking help in this forum.
How to post autoscan
MartinsX
Riga, Latvia
C?ID=268515
No full autoscan, we can't see vehicle data. If it is EGR module failing, I suggest to check at dealers before starting repair work by Yourself, some 1,6 CR TDI got recall for it. Maybe it is possible to get EGR module replaced free of charge.
P.S. Uwe, how do You decode faults if there is no ROD file? Are there some possibilities to do this in general or You just have some preparations for ROD file for this exact engine, only they are not finished and released yet?
I didn't exactly decode it. But I did look in scans from other 1.6 TDIs that do have ROD files and found that exact (native) fault in a couple of them. It seems to be not at all uncommon.
