2012 V6TDI Touareg 8 Speed Auto problem
chainsaw
Australia
C?ID=277463
Bit of background history..........Couple of weeks ago dealership had engine/trans out and resealed timing chain covers. Went fine for 2 weeks then trans fault light came on dash, trans was shifting erratic but getting all gears. Put Vagcom on and reset fault codes (where it appeared in each module) as well as full reset. Took to dealers for service and get this fault looked at. (gave them copy of printout).
They say malfunction of Nuetral Switch ($656 for part and $231 Labour) to Fix.. Having worked over the years on a lot of Japanese Autos I am reluctant to suspect that. Drove it home from dealer and was like in "Limp Home Mode" Started in about 3 gear and would not change. When home put Vagcom on again and reset fault codes. NOW has Rev but no Fwd gears. Have checked adjustment of gear selector and N start switch. SO, here is where I am up to Fault codes cleared... KO... foot on brake....Light on dash and console indicate Park, move to Rev and lights correspond. move to N no light on console and dash reads R, move to Drive and get D1 then changes to -- and fault code logged again.
Have checked connection of electrical plugs, all OK. So now wondering if it is the N Switch or the TCM ?????????
Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
   Part No SW: 0C8 927 750 AG    HW: 0C8 927 750 AG
   Component: AL1000 AISIN  001 2083
   Coding: 001568
   Shop #: WSC 25981 002 1048576
   ROD: EV_TCMAL991031_VW52.rod
   VCID: 71E9A156A0D85ACA5F-8024
12782 - Transmission Range Sensor (F125)
          P0706 00 [175] - Implausible Signal
                    Reset counter: 44
                    Engine speed: 690.0 /min
                    Transmission input speed: 600 /min
                    Engine torque: -12 Nm
                    Transmission fluid temperature: 30 °C
                    Accelerator position: 0.0 %
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Clutch status: Open
                    Electrical Oil Pump failure status: Normalcy
                    Electrical Oil Pump target revolution: 0 /min
                    Electrical Oil Pump actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    Electrical Oil Pump failure status with Electrical Oil Pump without HV: Motor normal stop
                    Electrical Oil Pump target current: 65278 mA
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 BL    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0111
   Revision: 15012002    Serial number: 00000001263214
   Coding: 6900001181345D010005000300005F5F431D460807000241000000000000
   Shop #: WSC 31414 790 00001
   VCID: 73E5AB5ED2C468DAAD-8026
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    111124  31  0020
   Serial number: 90243401120109160333
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10335272
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 F    HW: 7P6 941 431 F
   Component: E1 - LDS  H04 0031
   Serial number: 00000000000803120031
                    Fault Status: 00101101
                    Reset counter: 168
                    Mileage: 167064 km
                    Date: 2016.10.06
                    Time: 13:07:00
Sorry but I cant see how to attach my Vagcom Log file
ivagp
C?ID=95551
when u shift what is the data telling u.
chainsaw
Australia
C?ID=277463
Well this morning was like normal (for a short time) All lights for gearshift corresponded, even N THEN was like something warmed up and back to same fault. Makes me think a faulty connection, so have now purchased a Tone Generator and Probe to test the individual wires.
ivagp
C?ID=95551
first bit of advice, before taking in for service it is highly recommended to do a complete auto scan. secondly go to trans and find the address for gear position and verify gear selected matches the one from the address. you should try this when its acting up. shift manually thru all the gears
chainsaw
Australia
C?ID=277463
Thanks ivagp,, Did have the VCDS on and in 02 transmission....Advanced Measuring Blocks I selected Selector Position and others up to 12 allowed. With KOEO P reads P..........R reads R...N reads N....D reads D1......S reads S1..... THEN when move selector out of S fault is logged...........Here is then what it logs.
Wednesday,12,October,2016,08:18:35:28992
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
VIN: WVGZZZ7PZCD053403 License Plate: ROD097
Mileage: 167065 Repair Order:
Control Module Part Number: 0C8 927 750 AG
Component and/or Version: AL1000 AISIN 001 2083
Software Coding: 001568
Work Shop Code: WSC 25981
Advanced Identification/FAZIT
Identification: AW7-000
Date: 02.03.12
Manufacturer number: 0001
Test stand number: 0188
Flash Status
Programming Attempts(application): 0/0/0
Successful Attempts(data): 0/0/0
Flash Date: 01.01.00
Misc.
Hardware number: 0C8 927 750 AG
Workshop System Name: J217
ASAM Dataset Revision: 002112
VCDS Info:
Address 02: Auto Trans (0C8 927 750 AG)
08:26:12
IDE00089 Driving position P
IDE00090 selected gear undefine(Init: Fail)
IDE00095 Status of selector lever lock not active
IDE00096-ENG100569 Selector lever position-Shift Position ERROR
IDE00098-ENG110956 Transmission position-POS_INFO signal 2 ERROR
IDE06915-ENG98331 Trans. position switch: raw signal-a closed
IDE06915-ENG98436 Trans. position switch: raw signal-B Open
IDE06915-ENG98435 Trans. position switch: raw signal-C Open
IDE06915-ENG98824 Trans. position switch: raw signal-Pa closed
IDE06920-MAS00115 Tiptronic: raw signal-Tiptronic gate OFF
IDE06920-MAS00116 Tiptronic: raw signal-Tiptronic + OFF
IDE06920-MAS00117 Tiptronic: raw signal-Tiptronic - OFF
The body of this old fella has given up crawling around under the vehicle, so have to taken it to my Auto Electrician to tear his hair out. But any advice anyone can give is appreciated, I can then pass it onto him.
chainsaw
Australia
C?ID=277463
I am new to using the VCDS can you explain in more detail how to do this please.
chainsaw
Australia
C?ID=277463
OK here is the update. My Electrician checked out the wiring and said was OK. I Bought the part from VW (about A$650) and he fitted it, so all is working well (so far)..
