After firmware update, the interface does not connect "INTERFACE NOT FOUND"
mikayo
Mexico
C?ID=36838
Hi,
I upgraded the firmware of my interface, the process finished successfully but when try to connect the interface i got a message "INTERFACE NOT FOUND"
At power up the LED is ORANGE/YELLOW then became GREEN.
I am using a STARTECH USB-Serial Interface with FTDI chip, Lenovo YOGA 3 I5 WIN10, VCDS 16.8.2
Any idea ?
Regards.
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Personally i'm interested in this problem. Please explain to me: "STARTECH USB-Serial Interface", where it was purchased, whether it is original Ross-Tech? :thanks:
stevecrk
Budapest, Hungary
C?ID=59799
As far as I know, none of the USB / Serial converters are officially supported, although the FTDI based ones used to work in most cases.
What comes to my mind regarding this, it's just a tip, but it worths checking:
In the device manager, under ports, please choose the emulated serial port, and check the latency setting on the Advanced tab.
By default, it is set to 16 ms. If this is the case with your USB / Serial converter, please set it to 1 ms.
Sometimes, this settings will change back to default 16 ms on it's own.
Boki Ar
C?ID=57300
Does this mean Mikayo uses the "old" COM RS232 unit (just like me) ;), with the "transition" to USB via "STARTECH USB-Serial Interface"?
stevecrk
Budapest, Hungary
C?ID=59799
If I got this right, yes.
Boki Ar
C?ID=57300
In this case it would be best to try an older computer, can be desk-top with "native" COM port. :cool:
stevecrk
Budapest, Hungary
C?ID=59799
If he still has such a computer, then it would be the best to try. This way, he could rule out any problem with the converter.
Boki Ar
C?ID=57300
I agree. Today i compare old & new version of interface and software. ;)
RS 232:
Wednesday,05,October,2016,14:48:34:24395
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: WVWZZZ3CZ9P026386   License Plate: BG7XXVX
Mileage: 221290km-137503mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 2E 42 44 46 52 53 55 56 62
          72 77
VIN: WVWZZZ3CZ9P026386   Mileage: 221290km-137503miles
10-Park/Steer Assist -- Status: Cannot be reached 1100
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 EM    HW: 03L 907 309
   Component: R4 2,0L EDC G000SG  3502
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000172
   Shop #: WSC 00152 264 88968
   VCID: F4ED9CCB97E4E49EEA-80A0
006470 - Control Module 1 for Coolant Fan
               P1946 - 000 - Defective - Intermittent
                    Mileage: 220619 km
                    Date: 2016.09.11
                    Time: 11:28:14
                    RPM: 897 /min
                    Speed: 3.0 km/h
                    Temperature: 53.1°C
                    Temperature: 79.2°C
                    Temperature: 26.1°C
                    Lambda: 60.0 %
                    Lambda: 0.0 %
006481 - Radiator Fan 2 (V177)
               P1951 - 000 - Movement Restricted / Jammed - Intermittent
                    Mileage: 220898 km
                    Date: 2016.09.24
                    Time: 15:07:40
                    RPM: 1564 /min
                    Speed: 34.0 km/h
                    Temperature: 39.6°C
                    Temperature: 93.6°C
                    Temperature: 23.4°C
                    Lambda: 15.0 %
                    Lambda: 0.0 %
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000785931518
   Coding: 0002328
   Shop #: WSC 00028 028 00001
   VCID: AB5F47B70A5AFB667B-80FE
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 DC    HW: 3C0 907 044 DC
   Component: ClimatronicPQ46 132 0811
   Revision: 00132023    Serial number: 00000000000000
   VCID: E5CBF18F2C3E0D166D-80B0
            000 -  -  - Intermittent
                    Reset counter: 85
                    Mileage: 220008 km
                    Date: 2016.07.03
                    Time: 14:03:37
01810 - Actuating Motor for Temperature Flap; Right (V159)
                    Fault Frequency: 195
                    Reset counter: 85
                    Mileage: 220011 km
                    Date: 2016.07.04
                    Time: 08:40:38
   Part No SW: 3C8 937 049 F    HW: 3C8 937 049 F
   Revision: 00H54000    Serial number: 00000005766092
   Coding: E7828F0700041A00470A00000F000000000F5D435C000120000000000000
   VCID: B46D5CCBD764A49E2A-80E0
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 180608 003  0205
   Coding: 00046997
   Shop #: WSC 00028
   Component: RLS     200808 046  0204
   Coding: 00208933
   Shop #: WSC 00028
Address 10: Park/Steer Assist
   Part No SW: 5N0 959 655     HW: 5N0 959 655
   Component: J234__013 VW10 HI   1815
   Revision: 19013000    Serial number: 0039BPFSBXGM
   Coding: 0012595
   VCID: FAF1B2F3B58092EEB0-80AE
   Subsystem 1 - Serial number: 6333FTS640211608
   Subsystem 2 - Serial number: 6343FTS600951728
   Subsystem 3 - Serial number: 6353ETS679OFUVNH
   Subsystem 4 - Serial number: 6363ETS6UJ2DUVNH
   Part No SW: 3C0 953 549 AE    HW: 3C0 953 549 AE
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C5953507AT
   Coding: 0000111
   VCID: EFE793A7FEC2C74617-80BA
   Part No SW: 3C0 920 871 E    HW: 3C0 920 871 E
   Component: KOMBIINSTRUMENT VD1 2416
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0005105
   Shop #: WSC 12345 123 999999
   VCID: A649B68311B8C60EA4-80F2
03075 - Parallel Parking Assistance Control Module (J791)
                    Reset counter: 46
                    Mileage: 220008 km
                    Date: 2016.07.03
                    Time: 13:53:58
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 H    HW: 3C0 907 951
   Component: J533__Gateway   H13 0142
   Revision:   H13       Serial number: 2600P087140ADF
   Coding: F9A37F060006121002
                    Reset counter: 50
                    Mileage: 181204 km
                    Date: 2015.04.08
                    Time: 11:50:14
                    Reset counter: 223
                    Mileage: 189901 km
                    Date: 2015.07.29
                    Time: 11:27:55
   Part No SW: 0BS 907 554 A    HW: 0BS 907 554 A
   Component: Haldex 4Motion      4013
   Coding: 0000005
   VCID: C48D0C0B87C4141E9A-8090
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   VCID: B9736DFFF00659F6F9-80EC
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Part No SW: 5N0 035 342 A    HW: 5N0 035 342 A
   Component: SG EXT.PLAYER H13 0062
   Revision: A1001003    Serial number: 7667170282
   VCID: A54BB18FACBECD16AD-80F0
   Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1517
   Revision: 71009005    Serial number: 00000276388711
   Coding: 0004343
   VCID: F1E395DFE8F6D1B601-80A4
                    Fault Status: 00101100
                    Reset counter: 64
                    Mileage: 220055 km
                    Date: 2016.07.17
                    Time: 08:00:38
00109 - Left Mirror Turn Signal Lamp (L131)
                    Reset counter: 85
                    Mileage: 220008 km
                    Date: 2016.07.03
                    Time: 14:17:35
   Part No SW: 5N1 909 144 G    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.083 0401
   Revision: 1AH02234    Serial number: 00081270221402
   Coding: 0000258
   VCID: B66966C3C118B68E14-80E2
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 042 0472
   Coding: 00910A0001860E763004941570084FCE707C01
   Component: LIN BACKUP HORN H08 9001
   Component: Neigungssensor  004 0611
   Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1517
   Revision: 71009005    Serial number: 00000525788711
   Coding: 0004342
   VCID: F2E19AD3EDF0EAAEF8-80A6
                    Fault Frequency: 19
                    Reset counter: 69
                    Mileage: 220091 km
                    Date: 2016.07.20
                    Time: 18:01:34
00106 - Signal Central Locking SAVE/LOCK Passenger Side
                    Fault Frequency: 79
                    Reset counter: 84
                    Mileage: 219174 km
                    Date: 2016.05.22
                    Time: 15:26:41
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000106840
   Coding: 0000057
   VCID: A855B8BB1BACD07E96-80FC
   Component: AFS-Steuergeraet    0133
   Coding: 2343937
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  012 0029
   Revision: 00000000    Serial number: VWZ1Z2H5362929
   Coding: 0100040004
   VCID: E5CBF18FEC3E0D166D-80B0
                    Reset counter: 223
                    Mileage: 189901 km
                    Date: 2015.07.29
                    Time: 11:31:00
00856 - Radio Antenna
                    Fault Status: 00101011
                    Fault Frequency: 44
                    Reset counter: 49
                    Mileage: 211244 km
                    Date: 2016.03.05
                    Time: 16:56:24
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0308
   Revision: 41004101    Serial number: 00000000548327
   Coding: 0000208
   VCID: F0E590DBE3FCD8BE0E-80A4
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0308
   Revision: 41004101    Serial number: 00000000540337
   Coding: 0000208
Address 77: Telephone
End-------------------------(Elapsed Time: 02:09)--------------------------
Wi-Fi:
Wednesday,05,October,2016,15:00:23:21130
VCDS Version: 16.8.2.3  HEX-NET CB: 0.4323.4
Data version: 20160926 DS261.0
VIN: WVWZZZ3CZ9P026386   License Plate: BGDELL
          72 77
   Coding: 0000172
   VCID: F4A4933197E925E220-80A0
                    Mileage: 220619 km
                    Date: 2016.09.11
                    Time: 11:28:14
                    RPM: 897 /min
                    Speed: 3.0 km/h
                    Temperature: 53.1°C
                    Temperature: 79.2°C
                    Temperature: 26.1°C
                    Lambda: 60.0 %
                    Lambda: 0.0 %
                    Mileage: 220898 km
                    Date: 2016.09.24
                    Time: 15:07:40
                    RPM: 1564 /min
                    Speed: 34.0 km/h
                    Temperature: 39.6°C
                    Temperature: 93.6°C
                    Temperature: 23.4°C
                    Lambda: 15.0 %
                    Lambda: 0.0 %
   Coding: 0002328
   VCID: AB16484D0A573A1AB1-80FE
   VCID: E582FE752C33CC6AA7-80B0
                    Reset counter: 85
                    Mileage: 220008 km
                    Date: 2016.07.03
                    Time: 14:03:37
                    Reset counter: 85
                    Mileage: 220011 km
                    Date: 2016.07.04
                    Time: 08:40:38
   VCID: B4245331D76965E2E0-80E0
   Coding: 00046997
   Shop #: WSC 00028
   Coding: 00208933
   Shop #: WSC 00028
   Coding: 0012595
   VCID: FAB8BD09B58D53927A-80AE
   Coding: 0000111
   VCID: EFAE9C5DFECF063ADD-80BA
   Coding: 0005105
   VCID: A600B97911B507726E-80F2
                    Reset counter: 46
                    Mileage: 220008 km
                    Date: 2016.07.03
                    Time: 13:53:58
                    Reset counter: 50
                    Mileage: 181204 km
                    Date: 2015.04.08
                    Time: 11:50:14
                    Reset counter: 223
                    Mileage: 189901 km
                    Date: 2015.07.29
                    Time: 11:27:55
   Coding: 0000005
   VCID: C4C403F187C9D56250-8090
   VCID: B93A6205F00B988A33-80EC
   VCID: A502BE75ACB30C6A67-80F0
   Coding: 0004343
   VCID: F1AA9A25E8FB10CACB-80A4
                    Reset counter: 64
                    Mileage: 220055 km
                    Date: 2016.07.17
                    Time: 08:00:38
                    Reset counter: 85
                    Mileage: 220008 km
                    Date: 2016.07.03
                    Time: 14:17:35
   Coding: 0000258
   VCID: B6206939C11577F2DE-80E2
   Coding: 0004342
   VCID: F2A89529EDFD2BD232-80A6
                    Fault Frequency: 19
                    Reset counter: 69
                    Mileage: 220091 km
                    Date: 2016.07.20
                    Time: 18:01:34
                    Fault Frequency: 79
                    Reset counter: 84
                    Mileage: 219174 km
                    Date: 2016.05.22
                    Time: 15:26:41
   Coding: 0000057
   VCID: A81CB7411BA111025C-80FC
   Coding: 2343937
   Coding: 00000035
   Coding: 00000035
   Coding: 0100040004
   VCID: E582FE75EC33CC6AA7-80B0
                    Reset counter: 223
                    Mileage: 189901 km
                    Date: 2015.07.29
                    Time: 11:31:00
                    Fault Frequency: 44
                    Reset counter: 49
                    Mileage: 211244 km
                    Date: 2016.03.05
                    Time: 16:56:24
   Coding: 0000208
   VCID: F0AC9F21E3F119C2C4-80A4
   Coding: 0000208
End----------(Elapsed Time: 01:43, VBatt start/end: 12.2V/12.2V)-----------
mikayo
Mexico
C?ID=36838
Hi,
Yes i am using the "VCDS" with an old RS232 port, because i bought the interface several years ago ...
Regards.
mikayo
Mexico
C?ID=36838
This will be very difficult, i do not have a Desk-Top / Lap-Top with "native" COM PORT :cry:
mikayo
Mexico
C?ID=36838
I will try tomorrow ...
Boki Ar
C?ID=57300
Well, progress of technology brought to RS232 is omitted. No more production. This is what i talked with Uwe in Frankfurt. :cool:
mikayo
Mexico
C?ID=36838
After firmware update, the interface does not connect "INTERFACE NOT FOUND" *SOLVED*
Yep, he's using a HEX-COM+CAN from early in 2006.
Good. That means MCU in the interface is running and has valid firmware.
Please do have a look at the latency timer setting, like this.
Dear,
You are alright, i changed the latency time form 16ms to 1 ms and the interface connects to the VCDS.
Thanks a lot.
Regards/Saludos.
