Monday,03,October,2016,20:12:58:32212
VCDS Version: 16.8.2.3 (x64)
Data version: 20160926 DS261.0
VIN: WV1ZZZ7HZHH025557 License Plate:
Mileage: 2600km-1615mi Repair Order:
Chassis Type: 7H (7E0)
Scan: 01 02 03 04 08 09 10 13 15 17 18 19 20 22 25 55 5F 61 69 6E
0B
VIN: WV1ZZZ7HZHH025557 Mileage: 2600km-1615miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (2D2D2-CXHA) Labels: 04L-907-309-V2.clb
Part No SW: 04L 906 056 KE HW: 04L 907 445
Component: R4 2.0l TDI H02 3772
Revision: 23002001
Coding: 0025401C637601090000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KE 004004
ROD: N/A
VCID: 7AC3B5E1FDA28D92FA-802E
No ASAM data for: "EV_ECM20TDI03004L906056KE" (VN75)
25347 - ROD - Unknown Error Code
- 00 [096]
Readiness: N/A
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0BT 300 011 S HW: 0BH 927 711 G
Component: DSG DQ500-7A H11 5220
Revision: 00H11V01
VCID: 3E4B79F1A10A61B286-806A
Part No SW: 7E0 907 379 Q HW: 7E0 907 379 N
Component: ESC H06 0133
Revision: 00000000 Serial number: 41586000000051
Coding: 557E809825648483AA7A017BA489219678F700
Shop #: WSC 02739 790 50316
ROD: EV_Brake1ESCCONTIVN75XGP2_011_VN35.rod
VCID: 40B70709DBFE1742F4-8014
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 07071613470841
Coding: 01
ROD: EV_LWSKLOVW25X_VW31.rod
VCID: 7ECBB9F1E18AA1B2C6-802A
Address 08: Auto HVAC (J301) Labels: 7E5-907-047.clb
Part No SW: 7E0 907 047 AC HW: 7E0 907 047 AC
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ROD: EV_ClimaticT5.rod
VCID: 6BED80A582F8241A71-803E
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 187160363
Coding: A0A0303A0A6134B293284F706CEB8FD4C2B4728F60CD7960320400220860
Shop #: WSC 02737 534 1120116
VCID: 2A6345A14582FD12CA-807E
Subsystem 1 - Part No: 5K7 955 559 C
Component: RLS 040716 04 42 0106
Coding: 0228DD
Subsystem 2 - Part No SW: 7E0 959 801 M HW: 7E0 959 801 M Labels: 7E0-959-801.CLB
Component: J386__TSG_FT 003 0653
Serial number: KU0KU005071661878808
Coding: 0400A0
Subsystem 3 - Part No SW: 7E0 959 802 M HW: 7E0 959 802 M Labels: 7E0-959-802.CLB
Component: J387__TSG_BT 003 0653
Serial number: KU0KU005071661877330
Coding: 1400A0
Subsystem 4 - Part No: 7E1 951 172
Subsystem 5 - Part No: 1K0 951 605 C
Subsystem 6 - Part No: 7E1 951 172
Subsystem 7 - Part No SW: 7E0 959 442 A HW: 7E0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29160001313240016275
Coding: B4FFFF
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28261613401318
Coding: 11810D
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_VN75.rod
VCID: 71D192CDA0D4CECA4B-8024
Address 13: Auto Dist. Reg (J428) Labels: 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0210
Serial number: 15071604381365
Coding: 00005800FE0779
Shop #: WSC 01383 790 50316
ROD: EV_ACCBEGVW361.rod
VCID: 365B61D1893AA9F25E-8062
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 7E0 959 655 H HW: 7E0 959 655 H
Component: VW10Airbag01R H08 0018
Revision: -------- Serial number: 003V4000U5RE
Coding: 000000000000000000000000000000003152
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3B4D70E5B218749AA1-806E
Serial number: 3495ZRB400K571NGBQ7%
Serial number: 3505ZRB404R3V6TCK16E
Part No SW: 7E0 920 870 S HW: 7E0 920 870 S
Component: KOMBI H03 1104
Coding: 150F010300
VCID: 39416AEDB824468AB3-806C
Address 18: Aux. Heat (J364) Labels: 7E0-963-27X-18.clb
Part No SW: 7E0 963 272 B HW: 7E0 963 272 B
Component: STH-T5GP2 003 0009
Coding: 5C01
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2_VN75.rod
VCID: 2B6D40A54278E41A31-807E
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000052748
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042207
VCID: 68E7FFA99B0E0F021C-803C
Address 20: High Beam Assist. (J844) Labels: 8S0-857-511.clb
Part No SW: 7E0 857 511 F HW: 7E0 857 511 C
Component: FLA H10 0003
Revision: AA001001
Coding: 040400E200000000000000
ASAM Dataset: EV_HighBeamAssisAU316 001004
ROD: EV_HighBeamAssisAU316.rod
VCID: 2D694EBD7C6CEA2A2F-8078
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0AY 907 554 L HW: 0CQ 525 130 A
Component: Haldex4Motion H53 7620
Serial number: HA1-00001.06.16
Coding: 0501
ROD: EV_AllWheelContrHA1VW37X_SK12.rod
VCID: 549F3B593F869BE240-8000
Component: IMMO H03 1104
VCID: 6AE385A18D023D120A-803E
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Coding: 0FCA020001000000
Shop #: WSC 02757 790 50316
ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3A4375E1BD224D92BA-806E
Part No SW: 5C0 035 680 D HW: 5C0 035 680 D
Component: MU-S-N-ER H31 0356
Serial number: VWZAZ2S5192372
Coding: 065700013C00000011110001000808001F0100C4002001004F
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 2273AD8135B2255282-8076
Subsystem 1 - Part No SW: 3G0 919 866 S HW: -----------
Component: ECE1 2016/17 --- 0635
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 330B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Address 69: Trailer (J345) Labels: 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000410790772
Coding: 410D000103000000
VCID: 32535DC16D52B5D272-8066
Address 6E: Ctrl Head Roof (J702) Labels: None
Part No SW: 7E5 919 037 G HW: 7E5 919 037 G
Component: Dachdisplay H15 0185
Revision: 10100011 Serial number: 437816
Coding: 000103
Shop #: WSC 02759 790 00000
VCID: 355966DD9C3CA2EA57-8060
End-------------------------(Elapsed Time: 03:55)--------------------------
