DSG VW Golf GTI MK7 - Grateful for some help
GE90
C?ID=276174
Hi all
Armed with the Ross Tech guide for recalibrating the 6 speed DSG, I started out, but found that the names of the various tests differered on these later Golfs! I don't know whether it is because the car software is newer, or if it is the VCDS software, but is there a more up to date guide please?
Many thanks
GE90
C?ID=276174
I hope this is the scan results required, many thanks
Address 01: Engine (J623-CHHB)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0007
   Revision: --H13---
   Coding: 091D00322464050B2000
   Shop #: WSC 61946 001 1048576
   ASAM Dataset: EV_ECM20TFS0215G0906259 001011
   ROD: EV_ECM20TFS0215G0906259.rod
   VCID: 6BD27906824CFC1A65-803E
   Part No SW: 0D9 300 040 L    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 4025
   Revision: 05652104    Serial number: TFK01309271317
   ROD: EV_TCMDQ250021.rod
   VCID: 20485E2A3B0AEF4280-8074
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 6287300000006F
   Coding: 01FA93A134272973037A0608C1C3A980C92C94C0608395F7F8425078C109
   ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
   VCID: 7CF04A5AF7226BA2FC-8028
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0912
   Revision: 00001K06
   Coding: 00120004200100011005000000101000
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 66C4083299AEC1723A-8032
   Air quality sensor:
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011330000597
   Coding: 03001A46C24122FB0BA44080B10C0728100A000000000000000000000000
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 77FA5576CE0448FA91-8022
   Component: WWS    131010  042 0551
   Serial number:         131014023523
   Component: RLFS  024 0042
   Serial number: Y13M10D25H15M21S45S6
   Coding: 00A8DD
   Serial number: 000000000ZY132542ASZ
   Serial number: 00000000000057809336
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231330000450
   Coding: 0071051011
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 3B728946B2ACAC9AB5-806E
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H04 0150
   Serial number: 16091376510019
   Coding: 001C1300FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
   VCID: 35669F7E94887AEA43-8060
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR015B04
   VCID: 7F0ABD56E63470BAD9-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169677B30101340218
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169676B25101371370
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 910 13
   Serial number: 35767000000354E01E0Q
   Subsystem 4 - Part No SW: -----------    HW: 480 000 910 13
   Serial number: 35867000000AF9D01E05
   Subsystem 5 - Part No SW: -----------    HW: 480 402 810 13
   Serial number: 3516502A51230BB292C4
   Subsystem 6 - Part No SW: -----------    HW: 480 401 810 13
   Serial number: 3526502AF1230BB61265
   Subsystem 7 - Part No SW: -----------    HW: 480 401 810 13
   Serial number: 3556502AF11FBEA0E19+
   Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 22101304401683
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 7BF24946F22C6C9AF5-802E
   Part No SW: 5G6 920 970     HW: 5G6 920 970
   Component: KOMBI         314 2210
   Coding: 27AD09082F80260001882A01000000
   ROD: EV_DashBoardVDDMQBAB_VW37.rod
   VCID: 6DD6771EBC58F22A7B-8038
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0001118457
   Coding: 030100042B085900EF00027E1C0F00010001000000000000000000000000
   ROD: EV_GatewLear.rod
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N
   Component: E221__MFL-DC1  H06 0038
   Serial number: 29130000124500083413
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 1206841503
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 09101303110159
   Coding: 003F0220D001048000001000
   VCID: 3F8AFD56A6B4B0BA99-806A
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Serial number: 00000000000003184129
   Coding: 0D0000
   Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
   Component: EPS_MQB_ZFLS  502 5011
   Coding: 8101
   ASAM Dataset: EV_SteerAssisMQB 009026
   ROD: EV_SteerAssisMQB_VW37.rod
   VCID: 3362A1669AFC64DA6D-8066
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 13101303110904
   Coding: 003F0020DE01048000801000
   VCID: 3E748052A1BEB9B292-806A
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Serial number: 00000000000003169959
   Coding: 050000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029E01000B000200
   VCID: 3D76875EACB8A2AA8B-8068
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
   Component: MU-S-D-ER     040 0421
   Serial number: V5C02510132035
   Coding: 02730000FF00000021111201002800001F0203060100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 1F4A5DD60674D0BAB9-804A
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H51 0022
   Serial number: VWZ8Z9NJ7026U6
5634 - Control Head for Multimedia System; MEDIA Source Selection Button
          B1291 F3 [009] - Unknown Error Elaboration
                    Reset counter: 160
                    Mileage: 24210 km
                    Date: 2016.07.22
                    Time: 11:18:55
                    Voltage terminal 30: 14.0 V
6179 - Display Module 1 for Multimedia System
          B1297 F6 [008] - Cable for Video Signal; Open Circuit
                    Reset counter: 12
                    Mileage: 24782 km
                    Date: 2016.09.20
                    Time: 14:19:34
                    Voltage terminal 30: 12.5 V
   Component: SAS-GEN 2     H06 0011
   Serial number: 130918201802
End-------------------------(Elapsed Time: 04:16)--------------------------
GE90
C?ID=276174
Hi Dana
Thanks very much for your reply. The only problem is downshifts to 2nd not being smooth. No repairs have been completed, or required. VW say no fault, but I had exactly the same issue with an earlier GTI I once owned, and the DSG reset really helped.
Looking forward to a procedure to try.
United States
Please try this:
Prerequisites:
Transmission fluid temperature between 30°C - 100°C confirmed using Advanced Measuring Values:
** IDE00102 Control Module temperature
** IDE00024 Transmission fluid temperature
Selector lever in Park
Engine idle speed, do not press accelerator pedal
Parking brake and foot brake applied during the entire procedure. This can be confirmed using Advanced Measuring Values:
* IDE02713 Brake Light Switch
* IDE02714 Brake test switch
0D9 - DQ250 MQB - Basic Settings Procedure:
[Select]
[02- Auto Trans]
[Basic Settings-04]
Select [Basic settings of transmission]
[Show Measuring Data] and select:
* IDE00021 Engine speed
* IDE00322 Status of basic setting
[Go!]
- During the basic setting procedure, there may be some loud gear shifting noises from the transmission, this is normal.
Basic settings may not complete successfully if:
- The fluid temperature gets too hot.
- Brake is released
- Engine RPM is increased
Once complete, there should be an indication of this in the [Status of Basic Settings] Advanced Measuring Value group and Basic Settings should report Finished Correctly..
[Done, Go Back] and Check for fault codes. If you have several Intermittent fault codes stored please [Save] them before clearing so the text can be pasted here with any feedback you happen to have.
Best Regards,
GE90
C?ID=276174
Thanks very much Dana.
There appears to be some other resets available, not just basic settings.
Calibration of synchro-points
Resetting of all adaption values
Etc
Etc
I have a work colleague who confirmed that he reset these other things with no issues after (in fact, quite an improvement apparently), but I am hesitant. Any issue with me doing these also?
GE90
C?ID=276174
Look forward to your thoughts Dana. Thanks
United States
We do not have documentation for every available basic setting function and our feedback is limited to the steps in the above procedure. I would recommend giving our existing procedure a shot before moving onto any of the additional basic settings this module happens to support.
Basic setting of transmission
Erase counter for start and stop processes
Reset CAN installation info
Reset clutch characteristic curve
Reset driving percentages per selector lever position
Reset gear selector data
Reset logging data for clutch 1
Reset logging data for clutch 2
Resetting of all adaptation values
Start double clutch fast adaptation​
Any number of the additional groups could have undesirable results but I would specifically avoid Resetting of all adaptation values because some control modules require dealer level online SVM configuration after doing so.
GE90
C?ID=276174
Thanks very much. However, I did end up doing the following yesterday, followed by the defined drive. Does this mean I need to go to a dealer....? I hope not! By way of feedback, the gear changes are much smoother, a massive transformation.
Reset clutch characteristic curve (possibly not, cannot recall!)
GE90
C?ID=276174
I've run a check, and no faults present.
United States
I'm glad to hear that went well! If Resetting of all adaptation values did not create a DTC with scary description such as invalid data record and the transmission still performs properly I wouldn't be concerned. If you saved screen shots or added anything to a VCDS log as you went please share it here.
GE90
C?ID=276174
Thanks. Unfortunately I didn't record anything as I went, but happy to plug in and check anything if requested.
Thanks again.
Luc83
Avignon, France
C?ID=292634
Hi GE90,
Even if I don't have the same engine (TDI 184), I have the same menu on MQB car (Skoda Octavia).
Can you tell us later how your solution has improve in long run? How long did you noticed improvement ? Has it last for more than 10.000 km ? less ?
Hoping you are still on this forum for experience sharing...
GE90
C?ID=276174
Hi
Unfortunately any slight improvement that there might have been was very short lived, as in less than 20 miles!
Luc83
Avignon, France
C?ID=292634
Hi
Not very surprised actually.... I don't like the autoadapt that tends to turn to eco mode too often I think. I have also noticed an improvement changing the fuel pump module. Try to make a test on fuel pump (engine/test) and see improvement.
Thanks for reply.
4m0wagen
Pennsylvania
C?ID=63571
I followed the steps to do just the basic settings adaptation reset and I got 4 fault codes.
I cleared them and will report back after tomorrow how the car drives
2017 Alltrack
