Hello everyone.
It seems the well known tweaks to set the VIM and to enable the Hidden/Green menu in the Audi A6 C7 don´t work on the facelifted versions (>=2015). I've seen in the web that Vag Can can activate the green/hidden menu (and that the button combination has changed, too), and that it can set the VIM - apparently through a billed separated package.
Also, some modules codifications are missing, like 09-Cent. Elect., 5F, etc.
Any news on these topics?
Here's a log:
Cheers!
Here's a log:
Monday,26,September,2016,18:17:18:30049
VCDS Version: 16.8.1.1 (x64)
Data version: 20160902 DS256
VIN: WAUBGC4G8FN060095 License Plate:
Mileage: 1105km-686mi Repair Order:
Chassis Type: 4G (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 36 3B 42 44 46 52 53 55
5F 62 6C 72 82 84 85 8B 8E 8F 90
VIN: WAUBGC4G8FN060095 Mileage: 1105km-686miles
Address 01: Engine (J623-CREC) Labels: None
Part No SW: 4G2 907 551 HW: 4H2 907 551 A
Component: 3.0l V6 TFSI H10 0003
Revision: --H10---
Coding: 0A2500320566010B3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G2907551 002003
ROD: EV_ECM30TFS0214G2907551.rod
VCID: 68D831639306BA0200-803C
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 4G0 927 166 D HW: 0B5 927 156 K
Component: 0B5 30TFSIRdW H03 0009
Revision: --H03---
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021_AU48.rod
VCID: 2E54877B716224320A-807A
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 44A68F492265F1929B00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_AU57.rod
VCID: 3F8ACA3FA608DDBA91-806A
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 FT HW: 4H0 907 064 ET
Component: BCM2 2.0 H36 0560
Coding: 05A86F0E000000000000
VCID: 000809C393766242A8-8054
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4G0 820 043 CA HW: 4G0 820 043 CA
Component: KLIMA 2 ZONEN H14 0112
Serial number: 16011500110027
Coding: 660131083D0000
ASAM Dataset: EV_AirCondiBasisUDS 003009
ROD: EV_AirCondiBasisUDS.rod
VCID: 60C829437B36C242C8-8034
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00000986317001
Coding: 0105001540349FE2C101408480001800CF9CC3082E08020180000494E10115020040003C030000
VCID: 71EE5C07A8DC7BCA57-8024
Component: WWS57X 141216 H37 0080
Serial number: 150109110047
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23660604
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BH HW: 4G0 941 531 BH
Component: E1 - LDS H07 0044
Serial number: 22 01 2015 00001478
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA110936000011148343
Coding: 020300
Subsystem 5 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: C6480D87000000000001
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Component: ACC3 H21 0053
Coding: 7C04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002014
ROD: EV_AdaptCruisContrAU57X.rod
VCID: 295E7467488C430ADF-807C
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Revision: -------- Serial number: 003P1002XMMM
Coding: 30333130313730323837554A304C34473053
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3B72BE2FB210C19ABD-806E
Serial number: 3575HRB405R33HNI9GK5
Serial number: 3585HRB405T2UKGOAO4T
Serial number: 3515JRB405T33PKS8HMK
Serial number: 3525JRB404T3468498L0
Serial number: 3554VRB404T34JH4MHD7
Serial number: 3564VRB404T34JH4HHD3
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Revision: -------- Serial number: 90372OAN0004M
Coding: 00003C
VCID: 377AA21F8638E5FA59-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Serial number: 06 01 2015 D0005596
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 933 E HW: 4G8 920 933 E
Component: TBenRdwAccNv H07 0043
Revision: 03001036 Serial number: 658020115596032
Coding: 038E09000F410008150000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 326C930B655A00D26E-8066
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G8 907 468 HW: 4G8 907 468
Revision: -------- Serial number: 00000001704601
Coding: C0CD073018
ROD: EV_GatewPkoUDS_AU57.rod
VCID: 75E66817D4B457EA8B-8020
Serial number: 7495395403
Voltage stabilizer:
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
VCID: 7CF07D33FF9E06A2F4-8028
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000132595058
VCID: 77FA621FC6B825FA99-8022
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA8208W5BH
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_AU57.rod
VCID: 3664AF1B89321CF242-8062
Address 42: Door Elect, Driver (J386) Labels: None
Component: TSG FA H04 0507
Coding: 011F16015E00628002080003
VCID: 4586D8D7CCD4876ADB-8010
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0029366538
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_AU57.rod
VCID: 3362960F9A4009DA65-8066
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Component: BCM2 2.0 H36 BCM2 2.0 H36 05600560
Revision: 00002001 Serial number: 0359124578
Coding: 011F0E2080B90085C33008040E030E470000000000000000000000000000
Shop #: WSC 37019 002 1048576
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor
Component: LIN BACKUP HO
Subsystem 3 - Part No: 4G8 959 591 A
Component: J245 PS40.402
Coding: 901F02
Subsystem 4 - Part No: 3AA 962 243 D
Component: GEB.F.Heckoef
No Faults Found
Address 52: Door Elect, Pass. (J387) Labels: None
Component: TSG BF H03 0507
Coding: 011F16015E00628002080002
VCID: 4684DFDBF1D28C72D2-8012
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001337546
ROD: EV_ParkiBrake_AU57.rod
VCID: 2D5680777C645F2A33-8078
Address 55: Headlight Range (J745) Labels: 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 D HW: 7P6 907 357 B
Component: MxB-ECU 001 0081
Coding: 04FA02102A680200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
ROD: EV_HeadlRegulAUDIMXBAU64X_AU57.rod
Coding: E01E00
Coding: E01E00
Part No SW: 4G1 035 046 A HW: 4G1 035 046
Component: MU-H-LN-RW 041 0073
Serial number: A592A0F7508058
Coding: 017501030000000013220002001A00102F0006E4F1700100DE
VCID: 1F4A6ABF06C8BDBAB1-804A
Subsystem 1 - Part No SW: V03 959 801 FP HW: -----------
Component: ROW 2016/2017 --- 0058
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0006
Serial number: AUZ8Z9EY800CF4
Multimedia Operating Unit:
Serial number: 90349OAM0011B
Compact Disc Database:
Component: Gracenote --- 4006
Address 62: Door, Rear Left (J388) Labels: None
Component: TSG HL H03 0507
Coding: 010F14004000628002080002
VCID: 499ED4E7E0CC630A3F-801C
Address 6C: Back-up Cam. (J772) Labels: 5Q0-907-441.clb
Part No SW: 4S0 907 441 B HW: 5Q0 907 441 A
Component: D4-PA RVC Mid H07 0050
Coding: 027501010201000300
ASAM Dataset: EV_CamSysRearPANAAU914 002002
ROD: EV_CamSysRearPANAAU914.rod
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0507
Address 82: Heads Up Display (J898) Labels: 4G0-919-604.clb
Part No SW: 4G0 919 604 M HW: 4G0 919 604 M
Component: HeadUpDisplay H07 0304
Coding: D20000
ASAM Dataset: EV_HUDContiC7 001025
ROD: EV_HUDContiC7.rod
VCID: 3566A817943417EA4B-8060
Address 84: Night Vision (J853) Labels: None
Part No SW: 4G0 907 547 A HW: 4G0 907 547
Component: NV-ECU-Gen3 H08 0107
Serial number: 622352400201447
Coding: 302100
ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
ROD: EV_NightVisioGen3AE4AU64X.rod
VCID: 2C508D73477E562224-8078
Camera For Night Vision System:
Subsystem 1 - Part No SW: 4G0 980 552 HW: 4G0 980 552
Component: NV-CAM-Gen3 H03 0006
Serial number: 623466500F1500900156
Address 85: On Board Cam. (J852) Labels: None
Component: DPC-SG H27 0081
Coding: 6A040000
ROD: EV_OnBoardCamerDPC.rod
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Coding: 7C04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
ROD: EV_AdaptCruisContr2AU57X.rod
VCID: 275A725F5E98757AC9-8072
Address 8E: Image Processing (J851) Labels: 4H0-907-107-V2.clb
Component: BV-SG H33 0090
Serial number: 005000622412147
Coding: 0480A8180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H13 0080
Coding: 00660600031F0376000308014248D2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 316E9C07605C3BCA17-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 05:49)--------------------------
Cheers!
