2017 Audi Q7 (4M) Adaptive Air Suspension Question?
NEtech
Denmark
C?ID=56995
Short procedure for VCDS, if only this DTC active:
C1044 Ride Height Not Learned
Tested by @AINils
ASAM: EV_ChassContrContiAU736
The following steps are carried out with this test program:
-Teach in the basic zero position of the height sensors
Test requirements:
-Start with Ignition ON > OFF 10 sec. > ON
-Vehicle standing on flat level surface
-Wheels must face straight ahead
-Select "Comfort" in Drive Select in MMI
-No persons or extra items in the vehicle
-Battery charger attached
-Doors and Rear lid closed.
[Basic Settings - 04]
  1. IDE03751-MAS00675-Activate level control system
  2. IDE09292-MAS00675-Start up prelim. stage for calibrt. cust. service
  3. IDE03802-MAS00675-Set reference level
  4. IDE03763-MAS00675-Deactivating level control system
- Measure the height difference between the center of the wheel and the lower edge of the wheelhouse on all four wheels.
For example measure diameter of rim in XX mm, divide XX mm with 2, add result with measured distance from rim upper edge to lower edge of the wheelhouse.
- Write down the values and enter them in the next program step.
[Adaptation - 10]
  1. IDE02001-Body height left front wheel house edge
  2. IDE02002-Body height right front wheel house edge
  3. IDE02003-Body height left rear wheel house edge
  4. IDE02004-Body height right rear wheel house edge
  1. IDE09283-MAS00675-Switch to normal level control function
  2. IDE03751-MAS00675-Activate level control system
Please wait until the compressor can no longer be heard.
Ignition OFF 1 min.
   #62
toto99
C?ID=326534
Hello Folks,
Today i wanted to lower the Air Suspension on an A8 D5/4N 2019.
Step 1 "Turn the level control on", works.
Step 2 "Approach reference level" is interrupted with the Error "Abort due to malfunction".
What could be the Reason?
Thanks...
   #64
toto99
C?ID=326534
There are no Errors in Error Memory.
If I approach the reference Level in the basic Settings, I get the message "Abort due to malfunction".
After the Error, I close the "Approach reference level" channel and complete the basic setting with "Switch to normal level control function".
End.
   #65
Westbury, UK
End.
Still need the VCDS Auto-Scan to see how this particular A8 is equipped and configured.
toto99
C?ID=326534
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 11 x64
VCDS Version: PCI 23.3.1.0  HEX-V2 CB: 0.4634.4
Datenstand: 20230627 DS346.2
www.vcdspro.de
Fahrzeug-Ident.-Nr.: WAUZZZF81KN011686   KFZ-Kennzeichen:
Fahrzeugtyp: F8-AU65 (4N2)
Scan: 01 02 03 06 09 13 15 16 17 19 1B 29 36 39 3C 42 44 46 47 52
          5F 61 6D 74 81 82 A5 AC BA BB BC C4 CA CB CC CD CF D6 D7 DB
          DC DE
Fahrzeug-Ident.-Nr.: WAUZZZF81KN011686   Kilometerstand: 204218km
01-Motorelektronik -- Status: Fehler 0010
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
06-Sitzverst. Beifah. -- Status: i.O. 0000
09-Zentralelektrik -- Status: Fehler 0010
13-Distanzregelung -- Status: Fehler 0010
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: Fehler 0010
1B-Aktive Lenkung -- Status: i.O. 0000
29-Lichtsteuerung li. -- Status: i.O. 0000
36-Sitzverst. Fahr. -- Status: i.O. 0000
39-Lichtsteuerung re. -- Status: i.O. 0000
3C-Spurwechsel -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
46-Komfortsystem -- Status: Fehler 0010
47-Soundsystem -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: Fehler 0010
5F-Informationselek. I -- Status: Fehler 0010
61-Batterieregelung -- Status: i.O. 0000
6D-Heckklappe -- Status: i.O. 0000
74-Fahrwerkssteuer. -- Status: i.O. 0000
81-Wählhebel -- Status: i.O. 0000
82-Head-Up-Display (HUD) -- Status: i.O. 0000
A5-Front-/Vorfeldkamera -- Status: Fehler 0010
AC-Reduktionsmitteldosier. -- Status: i.O. 0000
BA-Aggregatelagerung -- Status: i.O. 0000
BB-Türelektronik hinten links -- Status: i.O. 0000
BC-Türelektronik hinten rechts -- Status: i.O. 0000
C4-Spannungswandler Elektroantrieb -- Status: i.O. 0000
CA-Schiebedachelektronik -- Status: i.O. 0000
CB-Hinterachslenkung -- Status: i.O. 0000
CC-Startergenerator -- Status: i.O. 0000
CD-Laser Distanzregelung -- Status: Fehler 0010
CF-Spurwechselassistent 2 -- Status: i.O. 0000
D6-Lichtsteuerung links 2 -- Status: i.O. 0000
D7-Lichtsteuerung rechts 2 -- Status: i.O. 0000
DB-Kurvenradar 1 vorne -- Status: i.O. 0000
DC-Kurvenradar 2 vorne -- Status: i.O. 0000
DE-Ladegerät 1 für Mobilger. -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-DDVC)       Labeldatei: Keine
   Teilenummer SW: 4N0 907 401 K    HW: 059 907 309 L
   Bauteil: 3.0l V6 TDI   H26 0001
   Revision: CAH26---    CVN: 6E71653356070F8A755A2113755A211300000000D6C3ECFE
   Codierung: 0A2A4012056E050334286000000400000000000000000000
   Betriebsnr.: WSC 19570 004 1048576
   ASAM Datensatz: EV_ECM30TDI0114N0907401K 001001
   ROD: EV_ECM30TDI0114N0907401K.rod
   VCID: 323CEDDB74ACE43AC9F-8066
   VINID: 9D196AAAA58805B78004118818EA0BF48F
3 Fehlercodes gefunden:
31965 - Differenzdruckgeber für Niederdruck-Abgasrückführung
          P197D 00 [096] - unplausibles Signal
          Sporadisch - unbestätigt - geprüft seit letzter Löschung
4814 - Versorgungsspannung 1 für Steuergerät
          U3501 00 [032] - zu klein
             Umgebungsbedingungen:
                    Fehlerstatus: 00000001
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Kilometerstand: 203998 km
                    Datum: 2023.08.22
                    Zeit: 13:27:19
                    Motordrehzahl: 0.00 /min
                    Normierter Lastwert: 0.0 %
                    Fahrzeuggeschwindigkeit: 0 km/h
                    Kühlmitteltemperatur: 30 °C
                    Ansauglufttemperatur: 33 °C
                    Umgebungsluftdruck: 960 mbar
                    Spannung Klemme 30: 10.900 V
                    Verlernzähler nach OBD: 37
                    Status des Motors: COENG_READY
                    Status des Motors-Test_Program_Co Eng st COMPU VERB UBYTE: 1
31519 - Geber 1 für NOx Bank 1
          P2201 00 [096] - unplausibles Signal
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Kilometerstand: 203316 km
                    Datum: 2023.06.27
                    Zeit: 12:04:32
                    Motordrehzahl: 971.50 /min
                    Normierter Lastwert: 17.6 %
                    Fahrzeuggeschwindigkeit: 23 km/h
                    Kühlmitteltemperatur: 70 °C
                    Ansauglufttemperatur: 24 °C
                    Umgebungsluftdruck: 1010 mbar
                    Spannung Klemme 30: 14.160 V
                    Verlernzähler nach OBD: 30
                    NOx Sensor 1: NOx Konzentration: 151 ppm
                    Com r Lam Lin Rec Ds: 0.0360
                    NOx Sensor 1: Versorgungsspannung: 13920 mV
                    Sollwert der Heiztemperatur des NOx-Sensors 1-Bits 0-7: 1
                    Com st N Ox Vld Ds-Bits 0-7: 1
                    Abgastemperatursensor 1: 130.9 °C
Adresse 02: Getriebe (J217)       Labeldatei:* Keine
   Teilenummer SW: 4N0 927 158 BS    HW: 0D5 927 156 P
   Bauteil: 0D5 30TDIRdW  H05 0001
   Revision: --H05---    CVN: D554867600009238
   Codierung: 100000
   Betriebsnr.: WSC 02391 785 00200
   ASAM Datensatz: EV_TCMALX52011 002015
   ROD: EV_TCMALX52011_AU65.rod
   VCID: 074A6C0FAFAEB1924E1-8052
   ATF-Pumpe:
   Subsystem 1 - Teilenummer SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Bauteil: V552 ATFP  H01 0705
   Seriennummer: 1812060123
Kein(e) Fehlercode(s) gefunden.
Adresse 03: Bremsenelektronik (J104)       Labeldatei: Umleit. fehlgeschl.!
   Teilenummer SW: 4N0 907 379 AG    HW: 4N0 907 379 P
   Bauteil: ESP9 Premium  H06 0853
   Datenstand-Nummer: 4N0909504AD 0002 CVN: D9581B23
   Codierung: 1CAA329D31A30B9711A44C991883D1E2F5B9C9384C8CD08832188B47AF9D93
   ASAM Datensatz: EV_ESP9BOSCHCMP 004011
   ROD: EV_ESP9BOSCHCMP_AU58.rod
   VCID: 7DA60EE7FD72EB4264D-8028
Adresse 06: Sitzverst. Beifah. (J521)       Labeldatei:* Keine
   Teilenummer SW: 4M4 959 760 D    HW: 4M4 959 760 D
   Bauteil: MEM-BFS       009 0044
   Seriennummer: 00000357999160 Datenstand-Nummer: 4N0909866C  0014
   Codierung: 0018B2400005BEA148438181A101A10081A100070700878700000000000000
   ASAM Datensatz: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   VCID: 3D26CEE7BDF22B4224D-8068
   Ventilblock 1 im Vordersitz Beifahrerseite:
   Subsystem 1 - Teilenummer SW: 4N0 907 182     HW: 4N0 907 182
   Bauteil: N477 VB1 BFSv  H04 0011
   Seriennummer: SJ8001021218402580DD
   Codierung: BF2F00
   Ventilblock 2 im Vordersitz Beifahrerseite:
   Subsystem 2 - Teilenummer SW: 4N0 907 182 D    HW: 4N0 907 182 D
   Bauteil: N478 VB2 BFSv  H04 0010
   Seriennummer: SJ80012611181147025A
Adresse 09: Zentralelektrik (J519)       Labeldatei:* 4N0-907-063-V2.clb
   Teilenummer SW: 4N0 907 063 DE    HW: 4N0 907 063 AE
   Bauteil: BCM1 MLBevo   H10 0652
   Datenstand-Nummer: 4N0909514J  0029
   Codierung: 07500143C13900CD070E57A81CEF9C68131BB7111406009381000A00020196800845010200100000000003030045081B18020030C403F107000000000000000000
   ASAM Datensatz: EV_BCM1BOSCHAU651 014010
   ROD: EV_BCM1BOSCHAU651_014.rod
   VCID: 74B02BC3CE38AA0A1B3-8020
   Steuergerät für Wischermotor:
   Subsystem 1 - Teilenummer SW: 4N1 955 119     HW: 4N1 955 119
   Bauteil: WWS651 181016  052 0915
   Seriennummer: 904753F0401828901514
   Codierung: 7DC727
   Sensor für Regen- und Lichterkennung:
   Subsystem 2 - Teilenummer SW: 81A 955 555 A    HW: 81A 955 555
   Bauteil: G397_RLFSS  H06 0002
   Seriennummer: 22223287X81A955555A0
   Codierung: 02005E
   Lichtschalter:
   Subsystem 3 - Teilenummer SW: 4N1 941 501 C    HW: 4N1 941 501 C
   Bauteil: E1 - LTM  H09 0086
   Seriennummer: 21S12.12.1800691504
   Steuergerät für Garagentoröffnung:
   Subsystem 4 - Teilenummer SW: 4N0 907 410 B    HW: 4M0 907 410 A
   Bauteil: USHL5  H10 0100
   Seriennummer: 0000009600368Z00AK02
   Codierung: 210000
   Automatisch abblendbarer Innenspiegel:
   Subsystem 5 - Teilenummer SW: 8W0 857 511     HW: 8W0 857 511
   Bauteil: Y7_Innenspieg  H09 0002
   Seriennummer: GX1CE105101823611809
   Codierung: 010000
   Innenlichtmodul:
   Subsystem 6 - Teilenummer SW: 4N0 947 135 CF    HW: 4N0 947 135 CF
   Bauteil: Dachelektroni  H42 0063
   Seriennummer: 00000869900000000000
   Codierung: 200000
   Steuergerät für elektrisch verstellbare Lenksäule:
   Subsystem 7 - Teilenummer SW: 80A 907 705     HW: 80A 907 705
   Bauteil: J866-EVLS-SG  H03 0100
   Seriennummer: WA135300000058702938
   Lüfter 1 für Sitzlehne vorn links:
   Subsystem 8 - Teilenummer SW: 4N0 963 575     HW: 4N0 963 575
   Bauteil: V512 LLR1SLvL  H01 0012
   Seriennummer: Q98AI340A5285
   Lüfter 1 für Sitzkissen vorn links:
   Subsystem 9 - Teilenummer SW: 4N0 963 575     HW: 4N0 963 575
   Bauteil: V514 LLR1SKvL  H01 0012
   Seriennummer: Q98AI33753909
   Lüfter 1 für Sitzlehne vorn rechts:
   Subsystem 10 - Teilenummer SW: 4N0 963 575     HW: 4N0 963 575
   Bauteil: V516 LLR1SLvR  H01 0012
   Seriennummer: Q98AI33985471
   Lüfter 1 für Sitzkissen vorn rechts:
   Subsystem 11 - Teilenummer SW: 4N0 963 575     HW: 4N0 963 575
   Bauteil: V518 LLR1SKvR  H01 0012
   Seriennummer: Q98AI33753911
   Frontscheibenwaschpumpe:
   Subsystem 12 - Teilenummer SW: 4N0 907 605 B    HW: 4N0 907 605
   Bauteil: J1100/SWP  H21 0015
   Seriennummer: 00000000001833801807
   Codierung: 020000
   Innenlichtmodul 2:
   Subsystem 13 - Teilenummer SW: 4N0 947 111 F    HW: 4N0 947 111 F
   Bauteil: Dachelektroni  H42 0060
   Seriennummer: 00000308130000000000
4 Fehlercodes gefunden:
67736 - Datenbus empfangener Fehlerwert
          U1123 00 [008] - -
          [Camera sensor blocked]
          Sporadisch - bestätigt - geprüft seit letzter Löschung
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 2
                    Verlernzähler: 143
                    Kilometerstand: 204056 km
                    Datum: 2023.08.23
                    Zeit: 05:58:47
                    average_Voltage_terminals: 14.10 V
                    Temperaturfühler für Aussentemperatur-Widerstandswert: 0.00 kOhm
                    Temperaturfühler für Aussentemperatur-Außentemperatur auf CAN: 20.00 °C
                    interior_temperature: 24.50 °C
                    Fahrzeuggeschwindigkeit: 58.29 km/h
                    Klemmensteuerung-Status Klemme 75: ein
                    Klemmensteuerung-Status Klemme 15 Signal: ein
                    Klemmensteuerung-Klemme 15 über CAN: ein
                    Klemmensteuerung-Klemme 75: Qualifizierung: aus
405507 - Funktionseinschränkung durch Energiemanagement
          B10CD 00 [008] - -
          [Function limitation due to energy management system]
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 3
                    Verlernzähler: 140
                    Kilometerstand: 203358 km
                    Datum: 2023.06.30
                    Zeit: 09:41:45
                    average_Voltage_terminals: 11.40 V
                    Temperaturfühler für Aussentemperatur-Außentemperatur auf CAN: 16.50 °C
                    interior_temperature: 20.50 °C
                    Fahrzeuggeschwindigkeit: 0.00 km/h
                    Klemmensteuerung-Status Klemme 75: aus
                    Klemmensteuerung-Status Klemme 15 Signal: aus
                    Klemmensteuerung-Klemme 15 über CAN: aus
65826 - Datenbus Komfort
          U0011 00 [008] - keine Kommunikation
          [Comfort data bus: No communication]
                    Fehlerpriorität: 6
                    Verlernzähler: 142
                    Kilometerstand: 186126 km
                    Datum: 2022.12.22
                    Zeit: 10:04:46
                    average_Voltage_terminals: 12.20 V
                    Temperaturfühler für Aussentemperatur-Außentemperatur auf CAN: 11.00 °C
                    interior_temperature: 19.50 °C
65828 - Datenbus fehlende Botschaft
          U1121 00 [008] - -
          [Comfort system central control module: no signal/communication]
                    Fehlerpriorität: 4
                    Fehlerhäufigkeit: 65
                    Verlernzähler: 142
                    Datum: 2022.12.22
                    Zeit: 10:04:38
Adresse 13: Distanzregelung (J428)       Labeldatei:* Keine
   Teilenummer SW: 4N0 907 561 F    HW: 4N0 907 561
   Bauteil: LRR4          H04 0332
   Datenstand-Nummer: 4N0909863L  0001
   Codierung: 5465FF5478082C00010360E0000000BE4A1246484481009E00
   ASAM Datensatz: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 3430EBC38EB8EA0ADB3-8060
2 Fehlercodes gefunden:
2344 - Datenbus empfangener Fehlerwert
          U1123 00 [008] - -
          [FAULT_CAMERA_DIRT_OBJ]
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 2
                    Verlernzähler: 143
                    Datum: 2023.08.23
                    Zeit: 05:58:36
                    Steuergerätetemperatur: 33 °C
                    Spannung Klemme 15: 14.1 V
                    Fahrzeuggeschwindigkeit: 21.29 m/s
                    Längsbeschleunigung: -0.36 m/s²
                    Adaptive Abstandsdistanzregelung: Status: ACC_StandBy
                    Steering_angle-Data: 6.400 °
                    Yaw_rate-Data: 0.724 rad/s
                    adjustment_calculation: On
                    Dejustagewinkel horizontal: -0.025 °
                    Dejustagewinkel horizontal - schneller Algorithmus: -0.040 °
                    Staupilot: Status: aus
                    Außentemperatur: 19.50 °C
                    Sensorblindheit: Radar: keine Blindheit erkannt
2343 - Datenbus empfangener Fehlerwert
          U1123 00 [008] - -
          [FAULT_CAMERA_DIRT_PEDEST]
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 2
                    Verlernzähler: 143
                    Datum: 2023.08.23
                    Zeit: 05:58:36
Adresse 15: Airbag (J234)       Labeldatei:| 80A-959-655.clb
   Teilenummer SW: 4N0 959 655 R    HW: 4N0 959 655 R
   Bauteil: AirbagVW31    H10 2710
   Seriennummer: 003Z0M00C0A$ Datenstand-Nummer: 4N0909602AC 0002
   Codierung: AAFCF0C00CC00000985400FFF00D410000C5
   ASAM Datensatz: EV_AirbaVW31SMEAU65x 001032
   VCID: 4BC2903FF34695F2AA9-801E
   Gurtstraffer links:
   Subsystem 1 - Teilenummer SW: 4N0 980 945 A    HW: 4N0 980 945 A
   Bauteil: BeltPretRevFL  H10 0115
   Seriennummer: 00AI2018339622000000
   Codierung: 0A0301
   Gurtstraffer rechts:
   Subsystem 2 - Teilenummer SW: 4N0 980 946 A    HW: 4N0 980 946 A
   Bauteil: BeltPretRevFR  H10 0115
   Seriennummer: 00AI2018339322400000
   Codierung: 0A0301
   Crashsensor für Seitenairbag Fahrerseite:
   Subsystem 3 - Teilenummer SW: -----------    HW: 480 001 012 18
   Bauteil: SideSensor_Df  001 0887
   Seriennummer: 357000000008D198763R
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag Beifahrerseite:
   Subsystem 4 - Teilenummer SW: -----------    HW: 480 001 012 18
   Bauteil: SideSensor_Pf  001 0887
   Seriennummer: 358000000008C198763R
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag hinten Fahrerseite:
   Subsystem 5 - Teilenummer SW: -----------    HW: 480 031 312 18
   Bauteil: SideSensor_Dr  002 0149
   Seriennummer: 351001C18F6C2540BC6I
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag hinten Beifahrerseite:
   Subsystem 6 - Teilenummer SW: -----------    HW: 480 031 312 18
   Bauteil: SideSensor_Pr  002 0149
   Seriennummer: 352001C18F6469308C7G
   Codierung: 2D2D2D
   Crashsensor für Frontairbag Fahrerseite:
   Subsystem 7 - Teilenummer SW: -----------    HW: 480 031 312 18
   Bauteil: FrontSensor_D  002 0149
   Seriennummer: 355001C1864891A158FG
   Codierung: 2D2D2D
   Crashsensor für Frontairbag Beifahrerseite:
   Subsystem 8 - Teilenummer SW: -----------    HW: 480 031 312 18
   Bauteil: FrontSensor_P  002 0149
   Seriennummer: 356001C186485A003AFB
   Codierung: 2D2D2D
   Crashsensor für Fußgängerschutz Fahrerseite:
   Subsystem 9 - Teilenummer SW: -----------    HW: 480 031 107 18
   Bauteil: PedP_Sensor_D  002 0149
   Seriennummer: 228001C14F3DC5F05B0N
   Codierung: 2D2D2D
   Crashsensor für Fußgängerschutz Beifahrerseite:
   Subsystem 10 - Teilenummer SW: -----------    HW: 480 031 107 18
   Bauteil: PedP_Sensor_P  002 0149
   Seriennummer: 229001C14F360DE07B0E
   Codierung: 2D2D2D
   Crashsensor für Fußgängerschutz Mitte:
   Subsystem 11 - Teilenummer SW: -----------    HW: 480 030 712 18
   Bauteil: PedP_Sensor_C  002 0149
   Seriennummer: 230001C186419D305E40
   Codierung: 2D2D2D
   Crashsensor für Fußgängerschutz Fahrerseite 2:
   Subsystem 12 - Teilenummer SW: -----------    HW: 480 000 512 18
   Bauteil: PedPSensor_D2  001 0887
   Seriennummer: I0M000000006A164A6B8
   Codierung: 2D2D2D
   Crashsensor für Fußgängerschutz Beifahrerseite 2:
   Subsystem 13 - Teilenummer SW: -----------    HW: 480 000 512 18
   Bauteil: PedPSensor_P2  001 0887
   Seriennummer: I0N000000007B164A6BB
   Codierung: 2D2D2D
   Zentraler Crashsensor X/Y:
   Subsystem 14 - Teilenummer SW: -----------    HW: 480 020 612 18
   Bauteil: CentrSensorXY  000 0148
   Seriennummer: I0O0001BB2953C4277F2
Adresse 16: Lenkradelektronik (J527)       Labeldatei: 4M0-907-129.clb
   Teilenummer SW: 4N0 907 129 BQ    HW: 4N0 907 129 BQ
   Bauteil: Lenks.Modul   H03 0005
   ASAM Datensatz: EV_SMLSKLOAU736 007012
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 015E7217818A8FA2005-8054
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:* Keine-SRI2
   Teilenummer SW: 4N0 920 790 D    HW: 4N0 920 790 D
   Bauteil: FBenRDWACC--- H11 0153
   Datenstand-Nummer: 4N0909525F  0023
   Codierung: 858400E07C88000800B3E1609080480008000000
   ASAM Datensatz: EV_DashBoardAU65X 001017
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: 313EE2D771AADF22B05-8064
Adresse 19: Diagnoseinterface (J533)       Labeldatei:* Keine
   Teilenummer SW: 4N2 907 468 AL    HW: 4N2 907 468 AB
   Bauteil: Gateway       H14 0044
   Revision: AB000002    Seriennummer: 028AB840018C01 Datenstand-Nummer: 4N0909515E  0038
   Codierung: 060100050004064073960000005B0132DC98004818000000097D078E10000000
   GVL: F1517C080844000002FC88000100C800110E0070000000000000000000000000
   ASAM Datensatz: EV_CGateCONTIAU491 003170
   ROD: EV_CGateCONTIAU491_003_AU58.rod
   VCID: 0352781F9B969DB2129-8056
   Steuergerät für Multifunktionslenkrad:
   Subsystem 1 - Teilenummer SW: 4N0 951 523 J    HW: 4N0 951 523 J
   Bauteil: E221__MFL  H06 0003
   Seriennummer: 00000000000000000000
   Steuergerät für Batterieüberwachung:
   Subsystem 2 - Teilenummer SW: 4N0 915 181 A    HW: 4N0 915 181 A
   Bauteil: J367-BDMConti  H03 1050
   Seriennummer: 7588540300181126026C
   Wechselrichter für Netzsteckdose:
   Subsystem 3 - Teilenummer SW: 4N0 907 155     HW: 4N0 907 155
   Bauteil: U13  DCAC  H14 0017
   Seriennummer: 00000000000002014724
1 Fehler gefunden:
8519683 - Energiemanagement aktiv
          U140B 00 [008] - -
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 3
                    Verlernzähler: 140
                    Datum: 2023.06.30
                    Zeit: 09:41:36
                    EM_vehicle_state: 20 08
                    Ruhestromabschaltstufe: Abschaltstufe 1
                    Anforderung Einschaltverbot Standheizung-Standheizung: Erlaubt
                    Anforderung Einschaltverbot Standheizung-Erlaubte Laufzeit Standheizung: 0 min
Adresse 1B: Aktive Lenkung (J792)       Labeldatei: Keine
   Teilenummer SW: 4N0 907 144 C    HW: 8W0 907 144 C
   Bauteil: SCU_MLBevo    H03 0802
   Seriennummer: 30303030303030 Datenstand-Nummer: 4N0909848H  0001
   ASAM Datensatz: EV_SCUZFLSAU65X 003019
   ROD: EV_SCUZFLSAU65X.rod
   VCID: 2E04F9AB6094C0DAAD7-807A
Adresse 29: Lichtsteuerung li. (J1018)       Labeldatei: 8S0-907-397.clb
   Teilenummer SW: 80A 907 397 D    HW: 80A 907 397 D
   Bauteil: LCM_MLBevo    H07 0022
   Datenstand-Nummer: 4N0909519C  0017
   Betriebsnr.: WSC 00000 000 00000
   ASAM Datensatz: EV_LCMLeftCONTIAU426 001009
   ROD: EV_LCMLeftCONTIAU426_VW53.rod
   VCID: 3038E7D37AA0D62ABFB-8064
Adresse 36: Sitzverst. Fahr. (J136)       Labeldatei:* Keine
   Bauteil: MEM-FS        009 0044
   Seriennummer: 00000357999631 Datenstand-Nummer: 4N0909856B  0012
   Codierung: 00189A400005BEA1480301012101210081A100070700878700000000004000
   ASAM Datensatz: EV_SCMDriveSideCONTIAU736 006009
   Ventilblock 1 im Vordersitz Fahrerseite:
   Bauteil: N475 VB1 FSv  H04 0011
   Seriennummer: SJ8001021218402580DC
   Codierung: BF2F00
   Ventilblock 2 im Vordersitz Fahrerseite:
   Bauteil: N476 VB2 FSv  H04 0010
   Seriennummer: SJ800126111811470258
Adresse 39: Lichtsteuerung re. (J1023)       Labeldatei: 8S0-907-397.clb
   Datenstand-Nummer: 4N0909520C  0017
   ASAM Datensatz: EV_LCMRightCONTIAU426 001009
Adresse 3C: Spurwechsel (J769)       Labeldatei:* Keine
   Teilenummer SW: 4N0 907 566 F    HW: 4N0 907 566 A
   Bauteil: MRR_HR H12 0266
   Datenstand-Nummer: 4N0909535E  0021
   Codierung: 0FFC00
   ASAM Datensatz: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651.rod
   VCID: 392EDAF7A9DA1762085-806C
Adresse 42: Türelektr. Fahrer (J386)       Labeldatei:* Keine
   Teilenummer SW: 4M1 959 793 D    HW: 4M1 959 793 D
   Bauteil: TSG FS001 0188
   Seriennummer: YE007RKS01415 Datenstand-Nummer: 4N0909872B  0042
   Codierung: 001DDA00520004C2A009B036
   ASAM Datensatz: EV_DCU2DriveSideMAXHKLO 001010
   ROD: EV_DCU2DriveSideMAXHKLO_AU58.rod
   VCID: 40D8B713CA0046AA4FB-8014
Adresse 44: Lenkhilfe (J500)       Labeldatei:* Keine
   Teilenummer SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Bauteil: EPS_MLBEVO2BS H21 0504
   Datenstand-Nummer: 4N0909852L  0010
   Codierung: E1000101010000
   ASAM Datensatz: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
Adresse 46: Komfortsystem (J393)       Labeldatei:* Keine
   Teilenummer SW: 4N0 907 064 CG    HW: 4N0 907 064 G
   Bauteil: BCM2 MLBevo H14 0163
   Datenstand-Nummer: 4N0909501E  0050
   Codierung: 013400000FB000606309A0046C00090E0B004000804F06502F0400200504823F001F0100010011
   ASAM Datensatz: EV_BCM2CONTIAU651 009009
   ROD: EV_BCM2CONTIAU651_009.rod
   VCID: 76B411CBD844B81A257-8022
   ID - Geber:
   Codierung: 000000
   Sensor für Diebstahlwarnanlage:
   Subsystem 2 - Teilenummer SW: 5Q0 951 177     HW: 5Q0 951 172
   Bauteil: Sensor, DWA  005 0316
   Seriennummer: 000000000ZY210550RN2
   Alarmhorn:
   Subsystem 3 - Teilenummer SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Bauteil: Sirene, DWA  005 0314
   Seriennummer: 00000000000045999149
   Steuergerät für Heckklappenöffnung:
   Subsystem 4 - Teilenummer SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Bauteil: GEB.F.Heckoef  H17 0906
   Seriennummer: 11338346
   Steuergerät Heckspoilerverstellung:
65669 - Steuergerät für Heckklappenöffnung
          U1152 00 [008] - keine Kommunikation
          [Control module for tailgate spoiler opening: no communication]
                    Fehlerpriorität: 5
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 140
                    Kilometerstand: 203993 km
                    Datum: 2023.08.14
                    Zeit: 10:57:09
                    Versorgungsspannungen-Versorgungsspannung Klemme 30: 12.193 V
                    Versorgungsspannungen-Versorgungsspannung Klemme 30 - 2: 12.235 V
                    Versorgungsspannungen-Versorgungsspannung Klemme 30 - 3: 12.158 V
                    general_additional_freeze_frame-production_mode: nicht aktiv
                    general_additional_freeze_frame-Stall_current_cutoff_level: Abschaltstufe 0
                    general_additional_freeze_frame-Stall_Current_Measuring_Mode: nicht aktiv
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 04 18
                    general_additional_freeze_frame-Transport_Mode: nicht aktiv
                    can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
131120 - Funkschlüssel 1
          B1479 18 [008] - Stromstärke zu groß
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 137
                    Kilometerstand: 193503 km
                    Datum: 2023.03.05
                    Zeit: 00:03:42
                    Versorgungsspannungen-Versorgungsspannung Klemme 30: 12.945 V
                    Versorgungsspannungen-Versorgungsspannung Klemme 30 - 2: 12.958 V
                    Versorgungsspannungen-Versorgungsspannung Klemme 30 - 3: 12.882 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 A0 98 06 60
                    general_additional_freeze_frame-Vehicle speed: 172.47 km/h
                    key_error_freeze_frame: 01001000 11111111 11111111 11111111
Adresse 47: Soundsystem (J525)       Labeldatei:* Keine
   Teilenummer SW: 4N0 035 223 C    HW: 4N0 035 223
   Bauteil: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Seriennummer: AUZ8ZAJ7D005UC% Datenstand-Nummer: 4N4909510B  0011
   Codierung: 0156010200AAAAAFAA0000010000
   Betriebsnr.: WSC 22342 182 00000
   ASAM Datensatz: EV_AMPMst16C1Gen2pALPI 001011
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 24101B833E587A8A4B3-8070
Adresse 52: Türelektr. Beifahr. (J387)       Labeldatei:* Keine
   Teilenummer SW: 4M1 959 792 D    HW: 4M1 959 792 D
   Bauteil: TSG BFS001 0188
   Seriennummer: YE007RKS16206 Datenstand-Nummer: 4N0909873B  0042
   Codierung: 001DDA005E0004C2A009B034
   ASAM Datensatz: EV_DCU2PasseSideMAXHKLO 001010
   ROD: EV_DCU2PasseSideMAXHKLO_AU58.rod
   VCID: 3FDAB4EFB7FE3952361-806A
1 Fehler gefunden:
196681 - automatisch abblendbarer Außenspiegel
          B1317 01 [008] - Elektrischer Fehler
                    Fehlerpriorität: 5
                    Verlernzähler: 138
                    Datum: 2022.12.22
                    Zeit: 12:28:00
Adresse 5F: Informationselek. I (J794)       Labeldatei:| 4G1-035-MIB-HGH2.clb
   Teilenummer SW: 4K0 035 063 D    HW: 4K0 035 063 A
   Bauteil: MU-H-LND-EU   046 2711
   Datenstand-Nummer: 4N0909545D  0033
   Codierung: 0156010100000000C3111102C00800302F0001E403F008008E
   ASAM Datensatz: EV_MUHigGen2pALPI 001001
   Datenträger:
   Subsystem 1 - Teilenummer: V03 959 807 SJ
   Bauteil: MIB2P_EU_Q421  0580
   Anzeigeeinheit 1 für Multimediasystem:
   Subsystem 2 - Teilenummer SW: 4N0 919 605 G    HW: 4N0 919 605 C
   Bauteil: DU AU651 Top  H43 0147
   Seriennummer: INX00123081800040152
   Compact Disc Datenbank:
   Subsystem 3 - Teilenummer: V03 959 800 EG
   Bauteil: Gracenote2  1009
   Lautstärkeregler 1:
   Subsystem 4 - Teilenummer SW: 4N1 919 616 B    HW: 4N1 919 616
   Bauteil: LSR-D5/C8  H33 0110
   Seriennummer: 00004418000241048046
   Anzeigeeinheit 5 für Multimediasystem:
   Subsystem 5 - Teilenummer SW: 4N0 919 603 C    HW: 4N0 919 603
   Bauteil: DU AU651 Bot  H41 0147
   Seriennummer: INX00129091800050174
   Media Player 1:
   Subsystem 6 - Teilenummer SW: 4N0 035 123     HW: 4N0 035 123
   Bauteil: DISC PLAYER  H06 0006
   Seriennummer: AUZ8ZCJKJ00KYTD
   Medienbuchse:
   Subsystem 7 - Teilenummer SW: 4N0 035 736 A    HW: 4N0 035 736
   Bauteil: MediaConnectH  014 0133
   Seriennummer: 051800761558007
1 Fehler gefunden:
6724 - Rückfahrkamera
          B1102 F0 [008] - LVDS-Leitung kein Signal
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 137
                    Kilometerstand: 203608 km
                    Datum: 2023.06.30
                    Zeit: 17:18:01
                    Spannung Klemme 30: 14.2 V
Adresse 61: Batterieregelung (J1120)       Labeldatei: DRV\4N0-915-105.clb
   Teilenummer SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Bauteil: BMS_48V_LiIon H06 0108
   ASAM Datensatz: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 290E0AB7597AA7E2785-807C
Adresse 6D: Heckklappe (J605)       Labeldatei:| DRV\5Q0-959-107.clb
   Teilenummer SW: 8W5 959 107 D    HW: 8W5 959 107
   Bauteil: HDSG-Modul    H13 0170
   Revision: --------    Seriennummer: A2-C744-8791-0 Datenstand-Nummer: 4N0909541B  0005
   Codierung: 1430
   ASAM Datensatz: EV_DeckLidCONTIAU736 001016
   VCID: 47CAAC0FEF2E71928E1-8012
Adresse 74: Fahrwerkssteuer. (J775)       Labeldatei:* Keine
   Teilenummer SW: 4N0 907 777 AC    HW: 4N0 907 777 C
   Bauteil: Fahrwerk-SG   H52 2121
   Seriennummer: 0207180355  Datenstand-Nummer: 4N0909576T  0002
   Codierung: 745C483BF840
   ASAM Datensatz: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002.rod
   VCID: 7BA200FFE366E5725A9-802E
   Kompressor für Luftfederung:
   Subsystem 1 - Teilenummer SW: 4M0 907 778     HW: 4M0 907 778
   Bauteil: V66LFKompOLV  H06 0013
   Seriennummer: 00000000004130466549
   Codierung: 303030
Adresse 81: Wählhebel (J587)       Labeldatei: 4MX-713-041-81.clb
   Teilenummer SW: 4N1 713 041 D    HW: 4N1 713 041 C
   Bauteil: GSM-LL        H10 0077
   Revision: 0L0D5012    Seriennummer: 18110749894719
   ASAM Datensatz: EV_GSMWaehlZFAU736 001017
   ROD: EV_GSMWaehlZFAU736_VW53.rod
   VCID: 270A0C8F4F6E91926E1-8072
Adresse 82: Head-Up-Display (HUD) (J898)       Labeldatei:* Keine
   Teilenummer SW: 4N1 919 617 A    HW: 4N1 919 617 A
   Bauteil: HeadupDisplay H14 1815
   Codierung: 4700E0
   ASAM Datensatz: EV_HeadUpDisplAU65X 001010
   ROD: EV_HeadUpDisplAU65X.rod
   VCID: 3536D6C785C2F302ECD-8060
Adresse A5: Front-/Vorfeldkamera (J1121)       Labeldatei:* DRV\4N0-907-107-V2.clb
   Teilenummer SW: 4KE 907 107 AC    HW: 4N0 907 107 H
   Bauteil: zFAS Var C    H09 0291
   Datenstand-Nummer: 4N0909466M  0049
   Codierung: 040184000000000000FFD60000F0D50C1B1F560000000000000000000096D401009BA8000000000000000080000000000000000000000000F980400000000000000078D0008000B000800080000000000080400000E0
   ASAM Datensatz: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 005877138A8086AA0FB-8054
2117665 - Interne Störung
          B200F F9 [008] - Unbekannte Fehlerbeschreibung
          [Internal PCB Temperature Sensor not readable]
                    Fehlerpriorität: 4
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 134
                    Datum: 2023.06.30
                    Zeit: 08:05:48
                    Platform_zFAS_Error_Handler_Master-ErrorHandlerMaster: 01 00 48 11 DA 10 00 00 00 00 00 00 00 00 00 00
                    Platform_zFAS_Error_Handler_SSH-ErrorHandlerSSH: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                    Platform_zFAS_Internal_Power_Supplies-Aurix 1V3: 1354 mV
                    Platform_zFAS_Internal_Power_Supplies-Aurix 3V3: 3295 mV
                    Platform_zFAS_Internal_Power_Supplies-AVDD HDMI PLL: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-AVDD PLL: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-KL30_LOCAL_VM: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-KL30_MAIN_VM: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-MIB_ADC_IN: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-MIB_SW_LOGO_FRONT: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-MIB_SW_LOGO_REAR: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-PEX VDD: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-Power Good MAX20024: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good SYS_1V1: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good SYS_1V2: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good VDD_CAM_PG: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good VDD_CORE: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good VDD_CPU: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good VDD_DDR_FPGA: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good VDD_GPU: not OK
                    Platform_zFAS_Internal_Power_Supplies-Power Good VTT_DDR3_PG: not OK
                    Platform_zFAS_Internal_Power_Supplies-Qualifier AURIX_1V3: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier AURIX_3V3: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier AVDD_HDMI_PLL: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier AVDD_PLL: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier KL30_LOCAL_VM: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier KL30_MAIN_VM: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier MIB_ADC_IN: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier MIB_SW_LOGO_FRONT: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier MIB_SW_LOGO_REAR: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier PEX_VDD: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SPKR_DIAG: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SUP_LIN_FRNT: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SUP_LIN_REAR: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SUPPLY_LIN_FRNT_P: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SUPPLY_LIN_REAR_P: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SYS_1V1: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SYS_1V2: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SYS_2V5: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SYS_5V: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier SYS_9V: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV1: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV1_VCC: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV2: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV2_VCC: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV3: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV3_VCC: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV4: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier TV4_VCC: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier US_SPEAKER_FRONT: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier US_SPEAKER_REAR: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VBAT_MAIN: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VCC_CAM: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_1V1: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_1V2: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_1V8: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_3V3: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_CORE: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_CPU: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_DDR: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_DDR_FPGA: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_DDR_HS: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_GPU: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDD_RTC: not_available
                    Platform_zFAS_Internal_Power_Supplies-Qualifier VDDIO_SYS: not_available
                    Platform_zFAS_Internal_Power_Supplies-SPKR_DIAG: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-SUP_LIN_FRNT: 12013 mV
                    Platform_zFAS_Internal_Power_Supplies-SUP_LIN_REAR: 11925 mV
                    Platform_zFAS_Internal_Power_Supplies-SUPPLY_LIN_FRNT_P: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-SUPPLY_LIN_REAR_P: 70 mV
                    Platform_zFAS_Internal_Power_Supplies-Sys 1V2: 1206 mV
                    Platform_zFAS_Internal_Power_Supplies-Sys 2V5: 2490 mV
                    Platform_zFAS_Internal_Power_Supplies-Sys 5V: 5065 mV
                    Platform_zFAS_Internal_Power_Supplies-SYS_1V1: 1101 mV
                    Platform_zFAS_Internal_Power_Supplies-SYS_9V: 11997 mV
                    Platform_zFAS_Internal_Power_Supplies-TV1_ISENSE: 347 mV
                    Platform_zFAS_Internal_Power_Supplies-TV1_VCC: 8321 mV
                    Platform_zFAS_Internal_Power_Supplies-TV2: 351 mV
                    Platform_zFAS_Internal_Power_Supplies-TV2_VCC: 8335 mV
                    Platform_zFAS_Internal_Power_Supplies-TV3: 346 mV
                    Platform_zFAS_Internal_Power_Supplies-TV3_VCC: 8401 mV
                    Platform_zFAS_Internal_Power_Supplies-TV4: 343 mV
                    Platform_zFAS_Internal_Power_Supplies-TV4_VCC: 8343 mV
                    Platform_zFAS_Internal_Power_Supplies-US_SPEAKER_FRONT: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-US_SPEAKER_REAR: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-VBAT_MAIN: 11977 mV
                    Platform_zFAS_Internal_Power_Supplies-VCC_CAM: 8825 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD 1V1: 1101 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD 1V2: 1203 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD 1V8: 1798 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD 3V3: 3292 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD Core: 1044 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD CPU: 908 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD GPU: 897 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD_DDR: 1354 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD_DDR_FPGA: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-VDD_DDR_HS: 1049 mV
                    Platform_zFAS_Internal_Power_Supplies-VDDIO_SYS: 0 mV
                    Platform_zFAS_Internal_Power_Supplies-VDDRTC: 1002 mV
221284 - Frontkamera für Fahrerassistenzsysteme
          C12B3 FD [008] - temporäre Sichteinschränkung
          [temp view limitations]
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 2
                    Verlernzähler: 143
                    Datum: 2023.08.23
                    Zeit: 05:58:36
                    EyeQ-Temperaturen-CPU: -40 °C
                    EyeQ-Temperaturen-VPM: 32 °C
                    Fahrzeuggeschwindigkeit: 76.01 km/h
                    Frontkamera: Blindheitserkennung-Status: nicht aktiv
                    Frontkamera: Blindheitserkennung-Blindheit durch Wahrnehmungsmodul Lichtassistenz erkannt: ja
                    Frontkamera: Blindheitserkennung-Blindheit durch Wahrnehmungsmodul Verkehrszeichenerk. erkannt: ja
                    Frontkamera: Blindheitserkennung-Blindheit durch Wahrnehmungsmodul Fußgängererkennung erkannt: ja
                    Frontkamera: Blindheitserkennung-Blindheit durch Wahrnehmungsmodul Fahrspurerkennung erkannt: ja
                    Frontkamera: Blindheitserkennung-Blindheit durch Wahrnehmungsmodul Objekterkennung erkannt: ja
                    Frontkamera: Blindheitserkennung-Blindheit durch Wahrnehmungsmodul Abstandsregelung erkannt: ja
                    Frontkamera: Blindheitserkennung-Blindheit durch Wahrnehmungsmodul Straßenprofilschätz. erkannt: ja
                    Frontkamera: Blindheitserkennung-Blindheit durch Wahrnehmungsmodul Freiraumerkennung erkannt: ja
                    Frontkamera: Blindheitserkennung-Anforderung Scheibenheizung für Frontsensorik wegen Blindheit: ja
                    Frontkamera: Blindheitserkennung-Eigenblendung erkannt: nein
                    Frontkamera: Blindheitserkennung-freie Sicht einmal erkannt: ja
65537 - Kreuzungsassistent
          C12D8 F0 [008] - Statusrückmeldung für HMI unplausibel
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 28
                    Verlernzähler: 143
                    Kilometerstand: 186107 km
                    Datum: 2022.12.22
                    Zeit: 09:35:52
                    Profile Master Status Kreuzungsassistent-Soll Status: ein
                    Profile Master Status Kreuzungsassistent-Ist Status: Initialisierung
Adresse AC: Reduktionsmitteldosier. (J880)       Labeldatei: 4M0-907-355.clb
   Teilenummer SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Bauteil: SCR-Stg-G3H05 0006
   Datenstand-Nummer: 4N0909571F  0002
   ASAM Datensatz: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736_VW53.rod
Adresse BA: Aggregatelagerung (J931)       Labeldatei: Keine
   Teilenummer SW: 4M0 907 145 E    HW: 4M0 907 145 B
   Bauteil: AEMevo        H10 0132
   Datenstand-Nummer: 4N0909578H  0003
   ASAM Datensatz: EV_AEMZFAU736 006014
   ROD: EV_AEMZFAU736_006.rod
Adresse BB: Türelektronik hinten links (J388)       Labeldatei:* Keine
   Teilenummer SW: 4M1 959 795 D    HW: 4M1 959 795 D
   Bauteil: TSG HFS003 0188
   Seriennummer: YE007RKR03135 Datenstand-Nummer: 4N0909897B  0042
   Codierung: 000DDA00000004C2A008B024
   ASAM Datensatz: EV_DCU2RearDriveMAXHKLO 001010
   VCID: 42DCBD1BC40C54BA59F-8016
Adresse BC: Türelektronik hinten rechts (J389)       Labeldatei:* Keine
   Bauteil: TSG HBFS003 0188
   Seriennummer: YE007RKR03171 Datenstand-Nummer: 4N0909896B  0042
   ASAM Datensatz: EV_DCU2RearPasseMAXHKLO 001010
Adresse C4: Spannungswandler Elektroantrieb (A7)       Labeldatei: Keine
   Teilenummer SW: 4K0 959 663     HW: 4K0 959 663
   Bauteil: DCDC_GEN_2 H20 0307
   Seriennummer: DC18504000947 Datenstand-Nummer: 4N0909475B  0016
   ASAM Datensatz: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
   VCID: 75B616C7C542B3022CD-8020
Adresse CA: Schiebedachelektronik (J245)       Labeldatei:| 4M0-907-594.clb
   Teilenummer SW: 4M0 907 594 BJ    HW: 4M0 907 594
   Bauteil: SAD_STG_1     014 0007
   Datenstand-Nummer: 4N0909469C  0013
   Codierung: 668040065102
   ASAM Datensatz: EV_SunRoofCONTIAU736 008010
   ROD: EV_SunRoofCONTIAU736_008.rod
   VCID: 7F5AF4EFF77EF952761-802A
Adresse CB: Hinterachslenkung (J1019)       Labeldatei:* Keine
   Teilenummer SW: 4N0 909 145 K    HW: 4N0 909 145 C
   Bauteil: HAL_MLBevoH03 0398
   Revision: --------    Seriennummer: CCC_098_B_9056_ Datenstand-Nummer: 4N0909904K  0001
   Codierung: 42244200
   ASAM Datensatz: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010_VW53.rod
Adresse CC: Startergenerator (C29)       Labeldatei:* Keine
   Teilenummer SW: 4N0 903 028 Q    HW: 4N0 903 028 Q
   Bauteil: BSG-HP1-65    H18 0527
   Seriennummer: 31082100030066
   Codierung: 28000000000000
   Betriebsnr.: WSC 28304 004 1048576
   ASAM Datensatz: EV_Start48VAU651 002007
   ROD: EV_Start48VAU651_002.rod
Adresse CD: Laser Distanzregelung (J1122)       Labeldatei: 4N0-907-660.clb
   Teilenummer SW: 4N0 907 660 E    HW: 4N0 907 660
   Bauteil: LASER_SCANNER H36 0306
   Datenstand-Nummer: 4N0909639T  0002
   ASAM Datensatz: EV_LaserScannAU651 015021
   ROD: EV_LaserScannAU651_015.rod
   VCID: 3332E8DF8BB6ED32C29-8066
1 Fehler gefunden:
11546627 - Laser für Distanzregelung
          C12EB F1 [009] - Funktionsstörung
          [Heater_Resistance_too_high_error]
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 1
                    Kilometerstand: 185518 km
                    Datum: 2022.12.07
                    Zeit: 17:37:57
                    Steuergerätetemperatur-Host: externe Temperatur: 18 °C
                    Steuergerätetemperatur-Zynq: interne Temperatur: 32 °C
                    Steuergerätetemperatur-Host: interne Temperatur: 17 °C
                    Steuergerätetemperatur-Zynq: externe Temperatur: 16 °C
                    Spannung Klemme 15: 14.380 V
                    heating_resistor: 116.76 Ohm
                    Heizung-mittlere Leistung: 0.000 W
                    Heizung-Spannung: 0.000 V
                    Heizung-PWM-Wert: 0 %
                    Heizung-Stromaufnahme (Mittelwert): 0.000 A
                    Heizungs- und Reinigungsmanagement-Sicht: 0 %
                    Heizungs- und Reinigungsmanagement-Verschmutzungsgrad: 10 %
                    Heizungs- und Reinigungsmanagement-Heizungsstatus: 02
                    Heizungs- und Reinigungsmanagement-Reinigungsstatus: 02
                    Außentemperatur: 15 °C
Adresse CF: Spurwechselassistent 2 (J770)       Labeldatei:* Keine
   Bauteil: MRR_HL H12 0266
   Datenstand-Nummer: 4N0909468E  0021
   Codierung: 0FFC00
   ASAM Datensatz: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651.rod
Adresse D6: Lichtsteuerung links 2 (A31)       Labeldatei: 7PP-941-592.clb
   Teilenummer SW: 7PP 941 592 BA    HW: 7PP 941 592 B
   Bauteil: LED1L         H09 4002
   Datenstand-Nummer: 4N0909471C  0013
   ASAM Datensatz: EV_LEDModLeftMELCOAU736 001004
   ROD: EV_LEDModLeftMELCOAU736_VW51.rod
   VCID: 18683F73F2102E6AD7B-804C
Adresse D7: Lichtsteuerung rechts 2 (A27)       Labeldatei: 7PP-941-592.clb
   Bauteil: LED1R         H09 4002
   Datenstand-Nummer: 4N0909472C  0013
   ASAM Datensatz: EV_LEDModRightMELCOAU736 001004
Adresse DB: Kurvenradar 1 vorne (J1089)       Labeldatei:* Keine
   Teilenummer SW: 4N0 907 669 F    HW: 4N0 907 669 A
   Bauteil: MRR_VR H12 0266
   Datenstand-Nummer: 4N0909482D  0015
   Codierung: 003000
   ASAM Datensatz: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651.rod
Adresse DC: Kurvenradar 2 vorne (J1088)       Labeldatei:* Keine
   Bauteil: MRR_VL H12 0266
   Datenstand-Nummer: 4N0909483D  0015
   Codierung: 003000
   ASAM Datensatz: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651.rod
Adresse DE: Ladegerät 1 für Mobilger. (J1146)       Labeldatei:* DRV\4N0-035-502.clb
   Teilenummer SW: 4N0 035 502 A    HW: 4N0 035 502 A
   Bauteil: WLC Front     H10 0061
   Codierung: 800000
   ASAM Datensatz: EV_Charg1MobilDevicAU651 004001
   VCID: 221C1D9B244C74BA39F-8076
Ende--(Dauer: 02:58, Batt.-Spannung Start/Ende: 12.0V/11.9V. VIgn 11.9V)---
  • Disagree
Reactions: TTT
   #67
Westbury, UK
To explain the red X from TTT - very few of us speak or understand German, so we always ask that the English version of VCDS is used when posting here.
The English version can be downloaded from the Ross-Tech website and will happily install alongside your German version.
