Audi Recall
Stevedevil
C?ID=268674
Hi Gang..
My A3 Convertible, 2011 1.6 TDI is one of the engines that have been recalled..
My question is, can I use VagCom before the modification and software remap to take readings of the engine performance on a set length of road etc, to then see once the recall has been completed if the Car has the same response and fuel consumption etc etc..
If I can, then could someone please walk me through the best steps to use whilst plugged into the care etc
Cheers
Steve
MartinsX
Riga, Latvia
C?ID=268515
You can do logs, of course. But the question is what is reason of recall and what exactly dealers are going to do with Your engine? If this is a bad EGR module, typical for those engines, no any changes will be made to engine performance. If You could provide full autoscan from Your car, it could be easier to imagine what's wrong with Your engine now.
Stevedevil
C?ID=268674
Hi Mate
Audi have mentioned a modification ( They call it an Air Stabiliser ) that goes in front of the Mass Air Flow Sensor
They state this makes the sensor read more accurately, then they reprogram ( Take out the Cheat Program ) to make the NOx gasses less
My Issue ( Degree in Engineering ) is reduce the Air intake, so injectors and ECU reduce Diesel into injector, so sorry less power obtained, also then the Torque Curve for the engine is different, so power ratio's change.. so Engine will be different !!!
Cheers Steve
I would log mass air flow and injection quantities. Performance is determined by these.
Stevedevil
C?ID=268674
Im very new to Ross Tech, I assume you select these items to be read as you drive the car, does the software keep this log info ??
